path: root/include/linux/virtio_blk.h
2009-10-22virtio_blk: Revert serial number supportRusty Russell
This reverts "Add serial number support for virtio_blk, V4a". Turns out that virtio_pci, lguest and s/390 all have an 8 bit limit on virtio config space, so noone could ever use this. This is coming back later in a cleaner form. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: john cooper <john.cooper@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio_blk: add support for cache flushChristoph Hellwig
Recent qemu has added a VIRTIO_BLK_F_FLUSH flag to advertise that the virtual disk has a volatile write cache that needs to be flushed. In case we see this feature implement tell the Linux block layer about the fact and use the new VIRTIO_BLK_T_FLUSH to flush the cache when required. This allows for an correct and simple implementation of write barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-07-30lguest and virtio: cleanup struct definitions to Linux style.Rusty Russell
I've been doing this for years, and akpm picked me up on it about 12 months ago. lguest partly serves as example code, so let's do it Right. Also, remove two unused fields in struct vblk_info in the example launcher. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-06-09Add serial number support for virtio_blk, V4ajohn cooper
This patch extracts the opaque data from pci i/o region 0 via the added VIRTIO_BLK_F_IDENTIFY field. By convention this data takes the form of that returned by an ATA IDENTIFY DEVICE command, however the driver (except for structure size) makes no interpretation of the data. The structure data is copied wholesale to userspace via a HDIO_GET_IDENTITY ioctl command (eg: hdparm -i <dev>). Signed-off-by: john cooper <john.cooper@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-18virtio_blk: SG_IO passthru supportHannes Reinecke
Add support for SG_IO passthru to virtio_blk. We add the scsi command block after the normal outhdr, and the scsi inhdr with full status information aswell as the sense buffer before the regular inhdr. [hch: forward ported, added the VIRTIO_BLK_F_SCSI flags, some comments and tested the whole beast] [axboe: updated to use ->resid and not dual-path the byte count] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ checkpatch.pl tweak) Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-31headers_check fix: linux/virtio_blk.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/virtio_blk.h:21: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-07-25virtio_blk: check for hardsector size from hostChristian Borntraeger
Currently virtio_blk assumes a 512 byte hard sector size. This can cause trouble / performance issues if the backing has a different block size (like a file on an ext3 file system formatted with 4k block size or a dasd). Lets add a feature flag that tells the guest to use a different hard sector size than 512 byte. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: clarify that ABI is usable by any implementationsRusty Russell
We want others to implement and use virtio, so it makes sense to BSD license the non-__KERNEL__ parts of the headers to make this crystal clear. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com>
2008-05-30virtio_blk: fix endianess annotationsChristian Borntraeger
Since commit 72e61eb40b55dd57031ec5971e810649f82b0259 (virtio: change config to guest endian) config space is no longer fixed endian. Lets change the virtio_blk_config variables. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio_blk: allow read-only disksChristian Borntraeger
Hello Rusty, sometimes it is useful to share a disk (e.g. usr). To avoid file system corruption, the disk should be mounted read-only in that case. This patch adds a new feature flag, that allows the host to specify, if the disk should be considered read-only. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02virtio: add virtio disk geometry featureRyan Harper
Rather than faking up some geometry, allow the backend to push the disk geometry via virtio pci config option. Keep the old geo code around for compatibility. Signed-off-by: Ryan Harper <ryanh@us.ibm.com> Reviewed-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (modified to single struct)
2008-05-02virtio: de-structify virtio_block status byteRusty Russell
Ron Minnich points out that a struct containing a char is not always sizeof(char); simplest to remove the structure to avoid confusion. Cc: "ron minnich" <rminnich@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: remove unused id field from struct virtio_blk_outhdrRusty Russell
This field has been unused since an older version of virtio. Remove it now before we freeze the ABI. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au.
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Block driver using virtio.Rusty Russell
The block driver uses scatter-gather lists with sg[0] being the request information (struct virtio_blk_outhdr) with the type, sector and inbuf id. The next N sg entries are the bio itself, then the last sg is the status byte. Whether the N entries are in or out depends on whether it's a read or a write. We accept the normal (SCSI) ioctls: they get handed through to the other side which can then handle it or reply that it's unsupported. It's not clear that this actually works in general, since I don't know if blk_pc_request() requests have an accurate rq_data_dir(). Although we try to reply -ENOTTY on unsupported commands, ioctl(fd, CDROMEJECT) returns success to userspace. This needs a separate patch. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <jens.axboe@oracle.com>
