path: root/include/linux/virtio_net.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-04-15virtio-net: send gratuitous packets when neededJason Wang
As hypervior does not have the knowledge of guest network configuration, it's better to ask guest to send gratuitous packets when needed. This patch implements VIRTIO_NET_F_GUEST_ANNOUNCE feature: hypervisor would notice the guest when it thinks it's time for guest to announce the link presnece. Guest tests VIRTIO_NET_S_ANNOUNCE bit during config change interrupt and woule send gratuitous packets through netif_notify_peers() and ack the notification through ctrl vq. We need to make sure the atomicy of read and ack in guest otherwise we may ack more times than being notified. This is done through handling the whole config change interrupt in an non-reentrant workqueue. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-11virtio_net: introduce VIRTIO_NET_HDR_F_DATA_VALIDJason Wang
There's no need for the guest to validate the checksum if it have been validated by host nics. So this patch introduces a new flag - VIRTIO_NET_HDR_F_DATA_VALID which is used to bypass the checksum examing in guest. The backend (tap/macvtap) may set this flag when met skbs with CHECKSUM_UNNECESSARY to save cpu utilization. No feature negotiation is needed as old driver just ignore this flag. Iperf shows 12%-30% performance improvement for UDP traffic. For TCP, when gro is on no difference as it produces skb with partial checksum. But when gro is disabled, 20% or even higher improvement could be measured by netperf. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-30virtio: add full three-clause BSD text to headers.Rusty Russell
It's unclear to me if it's important, but it's obviously causing my technical colleages some headaches and I'd hate such imprecision to slow virtio adoption. I've emailed this to all non-trivial contributors for approval, too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: john cooper <john.cooper@redhat.com> Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-07-30lguest and virtio: cleanup struct definitions to Linux style.Rusty Russell
I've been doing this for years, and akpm picked me up on it about 12 months ago. lguest partly serves as example code, so let's do it Right. Also, remove two unused fields in struct vblk_info in the example launcher. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-07-17virtio_net: Sync header with qemuAlex Williamson
Qemu added support for a few extra RX modes that Linux doesn't currently make use of. Sync the headers to maintain consistency. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-05-01virtio: add missing include to virtio_net.hGrant Likely
virtio_net.h uses the macro ETH_ALEN which is defined in linux/if_ether.h. Discovered when hacking on virtio-over-pci patches. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add support for VLAN filtering in the hypervisorAlex Williamson
VLAN filtering allows the hypervisor to drop packets from VLANs that we're not a part of, further reducing the number of extraneous packets recieved. This makes use of the VLAN virtqueue command class. The CTRL_VLAN feature bit tells us whether the backend supports VLAN filtering. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a MAC filter tableAlex Williamson
Make use of the MAC control virtqueue class to support a MAC filter table. The filter table is managed by the hypervisor. We consider the table to be available if the CTRL_RX feature bit is set. We leave it to the hypervisor to manage the table and enable promiscuous or all-multi mode as necessary depending on the resources available to it. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a set_rx_mode interfaceAlex Williamson
Make use of the RX_MODE control virtqueue class to enable the set_rx_mode netdev interface. This allows us to selectively enable/disable promiscuous and allmulti mode so we don't see packets we don't want. For now, we automatically enable these as needed if additional unicast or multicast addresses are requested. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a virtqueue for outbound control commandsAlex Williamson
This will be used for RX mode, MAC filter table, VLAN filtering, etc... The control transaction consists of one or more "out" sg entries and one or more "in" sg entries. The first out entry contains a header defining the class and command. Additional out entries may provide data for the command. The last in entry provides a status response back from the command. Virtqueues typically run asynchronous, running a callback function when there's data in the channel. We can't readily make use of this in the command paths where we need to use this. Instead, we kick the virtqueue and spin. The kick causes an I/O write, triggering an immediate trap into the hypervisor. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-01-31headers_check fix: linux/virtio_net.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/virtio_net.h:28: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-21virtio_net: add link status handlingMark McLoughlin
Allow the host to inform us that the link is down by adding a VIRTIO_NET_F_STATUS which indicates that device status is available in virtio_net config. This is currently useful for simulating link down conditions (e.g. using proposed qemu 'set_link' monitor command) but would also be needed if we were to support device assignment via virtio. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added future masking) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16virtio_net: VIRTIO_NET_F_MSG_RXBUF (imprive rcv buffer allocation)Mark McLoughlin
If segmentation offload is enabled by the host, we currently allocate maximum sized packet buffers and pass them to the host. This uses up 20 ring entries, allowing us to supply only 20 packet buffers to the host with a 256 entry ring. This is a huge overhead when receiving small packets, and is most keenly felt when receiving MTU sized packets from off-host. The VIRTIO_NET_F_MRG_RXBUF feature flag is set by hosts which support using receive buffers which are smaller than the maximum packet size. In order to transfer large packets to the guest, the host merges together multiple receive buffers to form a larger logical buffer. The number of merged buffers is returned to the guest via a field in the virtio_net_hdr. Make use of this support by supplying single page receive buffers to the host. On receive, we extract the virtio_net_hdr, copy 128 bytes of the payload to the skb's linear data buffer and adjust the fragment offset to point to the remaining data. This ensures proper alignment and allows us to not use any paged data for small packets. If the payload occupies multiple pages, we simply append those pages as fragments and free the associated skbs. This scheme allows us to be efficient in our use of ring entries while still supporting large packets. Benchmarking using netperf from an external machine to a guest over a 10Gb/s network shows a 100% improvement from ~1Gb/s to ~2Gb/s. With a local host->guest benchmark with GSO disabled on the host side, throughput was seen to increase from 700Mb/s to 1.7Gb/s. Based on a patch from Herbert Xu. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use netdev_priv) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25virtio: clarify that ABI is usable by any implementationsRusty Russell
We want others to implement and use virtio, so it makes sense to BSD license the non-__KERNEL__ parts of the headers to make this crystal clear. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com>
2008-06-10virtio: Fix typo in virtio_net_hdr commentsMark McLoughlin
Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-02virtio: finer-grained features for virtio_netRusty Russell
So, we previously had a 'VIRTIO_NET_F_GSO' bit which meant that 'the host can handle csum offload, and any TSO (v4&v6 incl ECN) or UFO packets you might want to send. I thought this was good enough for Linux, but it actually isn't, since we don't do UFO in software. So, add separate feature bits for what the host can handle. Add equivalent ones for the guest to say what it can handle, because LRO is coming too (thanks Herbert!). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: Tweak virtio_net definesRusty Russell
1) Turn GSO on virtio net into an all-or-nothing (keep checksumming separate). Having multiple bits is a pain: if you can't support something you should handle it in software, which is still a performance win. 2) Make VIRTIO_NET_HDR_GSO_ECN a flag in the header, so it can apply to IPv6 or v4. 3) Rename VIRTIO_NET_F_NO_CSUM to VIRTIO_NET_F_CSUM (ie. means we do checksumming). 4) Add csum and gso params to virtio_net to allow more testing. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: Net header needs hdr_lenRusty Russell
It's far easier to deal with packets if we don't have to parse the packet to figure out the header length to know how much to pull into the skb data. Add the field to the virtio_net_hdr struct (and fix the spaces that somehow crept in there). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Net driver using virtioRusty Russell
The network driver uses two virtqueues: one for input packets and one for output packets. This has nice locking properties (ie. we don't do any for recv vs send). TODO: 1) Big packets. 2) Multi-client devices (maybe separate driver?). 3) Resolve freeing of old xmit skbs (Christian Borntraeger) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: netdev@vger.kernel.org
