path: root/include/linux/w1-gpio.h
2009-06-18w1-gpio: add external pull-up enable callbackDaniel Mack
On embedded devices, sleep mode conditions can be tricky to handle, Especially when processors tend to pull-down the w1 bus during sleep. Bus slaves (such as the ds2760) may interpret this as a reason for power-down conditions and entirely switch off the device. This patch adds a callback function pointer to let users switch on and off the external pull-up resistor. This lets the outside world know whether the processor is currently actively driving the bus or not. When this callback is not provided, the code behaviour won't change. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Ville Syrjala <syrjala@sci.fi> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06w1-gpio: add GPIO w1 bus master driverVille Syrjala
Add a GPIO 1-wire bus master driver. The driver used the GPIO API to control the wire and the GPIO pin can be specified using platform data similar to i2c-gpio. The driver was tested with AT91SAM9260 + DS2401. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
