path: root/include/linux/wireless.h
2010-10-13wext: fix alignment problem in serializing 'struct iw_point'Gerrit Renker
wext: fix alignment problem in serializing 'struct iw_point' This fixes a typo in the definition of the serialized length of struct iw_point: a) wireless.h is exported to userspace, the typo causes IW_EV_POINT_PK_LEN to be 12 on 64-bit, and 8 on 32-bit systems (causing misalignment); b) in compat-64 mode iwe_stream_add_point() memcpys overlap (see below). The second case in in compat-64 mode looks like (variable names are as in include/net/iw_handler.h:iwe_stream_add_point()): point_len = IW_EV_COMPAT_POINT_LEN = 8 lcp_len = IW_EV_COMPAT_LCP_LEN = 4 2nd memcpy: IW_EV_POINT_PK_LEN - IW_EV_LCP_PK_LEN = 12 - 4 = 8 IW_EV_LCP_PK_LEN <--------------> *---> 'extra' data area +-------+-------+-------+-------+---------------+------- ...-+ | len | cmd |length | flags | (empty) -> extra ... | +-------+-------+-------+-------+---------------+------- ...-+ 2 2 2 2 4 lcp_len <--------------> <-!! OVERLAP !!> <--1st memcpy--><------- 2nd memcpy -----------> <---- 3rd memcpy ------- ... > <--------- point_len ----------> This case could cause overrun whenever iw_point.length < 4. The other two cases are - * 32-bit systems: IW_EV_POINT_PK_LEN - IW_EV_LCP_PK_LEN = 8 - 4 = 4, the second memcpy copies exactly the 4 required bytes; * 64-bit systems: IW_EV_POINT_PK_LEN - IW_EV_LCP_PK_LEN = 12 - 4 = 8, the second memcpy copies a superfluous (but non overlapping) 4 bytes. The patch changes IW_EV_POINT_PK_LEN to be 8, so that in all 3 cases always only the requested iw_point.{length,flags} (both __u16) are copied, avoiding overrrun (compat-64) and superfluous copy (64-bit). In addition, the userspace header is sanitized (in agreement with version 30 of the wireless tools). Many thanks to Johannes Berg for help and review with this patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-23wireless.h: Use SIOCIWFIRST not SIOCSIWCOMMIT for range checkJoe Perches
These two #defines use the same value, but SIOCIWFIRST makes more sense in this use. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-23include/linux/wireless.h: Add IW_HANDLER macro to initialize array entryJoe Perches
Copied the idea from orinoco Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-15net/compat/wext: send different messages to compat tasksJohannes Berg
Wireless extensions have the unfortunate problem that events are multicast netlink messages, and are not independent of pointer size. Thus, currently 32-bit tasks on 64-bit platforms cannot properly receive events and fail with all kinds of strange problems, for instance wpa_supplicant never notices disassociations, due to the way the 64-bit event looks (to a 32-bit process), the fact that the address is all zeroes is lost, it thinks instead it is 00:00:00:00:01:00. The same problem existed with the ioctls, until David Miller fixed those some time ago in an heroic effort. A different problem caused by this is that we cannot send the ASSOCREQIE/ASSOCRESPIE events because sending them causes a 32-bit wpa_supplicant on a 64-bit system to overwrite its internal information, which is worse than it not getting the information at all -- so we currently resort to sending a custom string event that it then parses. This, however, has a severe size limitation we are frequently hitting with modern access points; this limitation would can be lifted after this patch by sending the correct binary, not custom, event. A similar problem apparently happens for some other netlink users on x86_64 with 32-bit tasks due to the alignment for 64-bit quantities. In order to fix these problems, I have implemented a way to send compat messages to tasks. When sending an event, we send the non-compat event data together with a compat event data in skb_shinfo(main_skb)->frag_list. Then, when the event is read from the socket, the netlink code makes sure to pass out only the skb that is compatible with the task. This approach was suggested by David Miller, my original approach required always sending two skbs but that had various small problems. To determine whether compat is needed or not, I have used the MSG_CMSG_COMPAT flag, and adjusted the call path for recv and recvfrom to include it, even if those calls do not have a cmsg parameter. I have not solved one small part of the problem, and I don't think it is necessary to: if a 32-bit application uses read() rather than any form of recvmsg() it will still get the wrong (64-bit) event. However, neither do applications actually do this, nor would it be a regression. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-29mac80211: 802.11w - Configuration of MFP disabled/optional/requiredJouni Malinen
Add new WEXT IW_AUTH_* parameter for setting MFP disabled/optional/required. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - WEXT configuration for IGTKJouni Malinen
Added new SIOCSIWENCODEEXT algorithm for configuring BIP (AES-CMAC) keys (IGTK). Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - WEXT parameter for setting mgmt cipherJouni Malinen
Add a new IW_AUTH parameter for setting cipher suite for multicast/broadcast management frames. This is for full-mac drivers that take care of RSN IE generation for (re)association request frames. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Dispatch and handle compat ioctls entirely in net/wireless/wext.cDavid S. Miller
Next we can kill the hacks in fs/compat_ioctl.c and also dispatch compat ioctls down into the driver and 80211 protocol helper layers in order to handle iw_point objects embedded in stream replies which need to be translated. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03WEXT: Add support for passing PMK and capability flags to WEXTMasakazu Mokuno
This defines the flags for setting the PMK to the driver and the capability flag for this so that the user space program can figure out whether the target driver wants to do 4-way hand shake by itself and pass the PMK which is needed before 4-way handshake to the driver. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-01Make linux/wireless.h be able to compileKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06WEXT: add mesh interface typeJohannes Berg
This introduces a new WEXT type IW_MODE_MESH for mesh networks, used for scan results. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28introduce WEXT scan capabilitiesDan Williams
Introduce scan capabilities to WEXT so that userspace can do intelligent things with scan behavior such as handling hidden SSIDs more gracefully. If the driver reports a specific scan capability, the driver must respect the options specified in the iw_scan_req structure when handling the SIOCSIWSCAN call, unless it's mode or state does not allow it to do so, in which case it must return an error. This version switches to Dave Kilroy's suggestion of claiming unused padding space for the scan_capa field. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[PATCH] Update my email address from jkmaline@cc.hut.fi to j@w1.fiJouni Malinen
After 13 years of use, it looks like my email address is finally going to disappear. While this is likely to drop the amount of incoming spam greatly ;-), it may also affect more appropriate messages, so let's update my email address in various places. In addition, Host AP mailing list is subscribers-only and linux-wireless can also be used for discussing issues related to this driver which is now shown in MAINTAINERS. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-03-27[PATCH] WE-22 : prevent information leak on 64 bitJean Tourrilhes
Johannes Berg discovered that kernel space was leaking to userspace on 64 bit platform. He made a first patch to fix that. This is an improved version of his patch. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-14[PATCH] wireless: fix IW_IS_{GET,SET} comment in wireless.hIngo van Lil
I just noticed the comments about even/odd ioctl command numbers in Linux's wireless.h file are mixed up. Signed-off-by: Ingo van Lil <inguin@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] wext: extend MLME supportChristian Lamparter
This patch adds two new defines for the SIOCSIWMLME to cover all kinds MLMEs (well, except REASSOC) through a ioctl. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-25[PATCH] WE-21 support (core API)John W. Linville
This is version 21 of the Wireless Extensions. Changelog : o finishes migrating the ESSID API (remove the +1) o netdev->get_wireless_stats is no more o long/short retry This is a redacted version of a patch originally submitted by Jean Tourrilhes. I removed most of the additions, in order to minimize future support requirements for nl80211 (or other WE successor). CC: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-23[PATCH] WE-20 for kernel 2.6.16Jean Tourrilhes
This is version 20 of the Wireless Extensions. This is the completion of the RtNetlink work I started early 2004, it enables the full Wireless Extension API over RtNetlink. Few comments on the patch : o totally driver transparent, no change in drivers needed. o iwevent were already RtNetlink based since they were created (around 2.5.7). This adds all the regular SET and GET requests over RtNetlink, using the exact same mechanism and data format as iwevents. o This is a Kconfig option, as currently most people have no need for it. Surprisingly, patch is actually small and well encapsulated. o Tested on SMP, attention as been paid to make it 64 bits clean. o Code do probably too many checks and could be further optimised, but better safe than sorry. o RtNetlink based version of the Wireless Tools available on my web page for people inclined to try out this stuff. I would also like to thank Alexey Kuznetsov for his helpful suggestions to make this patch better. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-09-07[wireless] build fixes after merging WE-19Jeff Garzik
2005-09-06[PATCH] WE-19 for kernel 2.6.13Jean Tourrilhes
Hi Jeff, This is version 19 of the Wireless Extensions. It was supposed to be the fallback of the WPA API changes, but people seem quite happy about it (especially Jouni), so the patch is rather small. The patch has been fully tested with 2.6.13 and various wireless drivers, and is in its final version. Would you mind pushing that into Linus's kernel so that the driver and the apps can take advantage ot it ? It includes : o iwstat improvement (explicit dBm). This is the result of long discussions with Dan Williams, the authors of NetworkManager. Thanks to him for all the fruitful feedback. o remove pointer from event stream. I was not totally sure if this pointer was 32-64 bits clean, so I'd rather remove it and be at peace with it. o remove linux header from wireless.h. This has long been requested by people writting user space apps, now it's done, and it was not even painful. o final deprecation of spy_offset. You did not like it, it's now gone for good. o Start deprecating dev->get_wireless_stats -> debloat netdev o Add "check" version of event macros for ieee802.11 stack. Jiri Benc doesn't like the current macros, we aim to please ;-) All those changes, except the last one, have been bit-roting on my web pages for a while... Patches for most kernel drivers will follow. Patches for the Orinoco and the HostAP drivers have been sent to their respective maintainers. Have fun... Jean Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12 [PATCH] Wireless Extensions 18 (aka WPA)
This is version 18 of the Wireless Extensions. The main change is that it adds all the necessary APIs for WPA and WPA2 support. This work was entirely done by Jouni Malinen, so let's thank him for both his hard work and deep expertise on the subject ;-) This APIs obviously doesn't do much by itself and works in concert with driver support (Jouni already sent you the HostAP changes) and userspace (Jouni is updating wpa_supplicant). This is also orthogonal with the ongoing work on in-kernel IEEE support (but potentially useful). The patch is attached, tested with 2.6.11. Normally, I would ask you to push that directly in the kernel (99% of the patch has been on my web page for ages and it does not affect non-WPA stuff), but Jouni convinced me that it should bake a few weeks in wireless-2.6 first, so that other driver maintainers can get up to speed with it. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
