PREEMPT_NONE
commit 8603e1b30027f943cc9c1eef2b291d42c3347af1 upstream.
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
commit e09c2c295468476a239d13324ce9042ec4de05eb upstream.
create_singlethread_workqueue() is a compat interface for single
threaded workqueue which maps to ordered workqueue w/ rescuer in the
current implementation. create_singlethread_workqueue() currently
implemented by invoking alloc_workqueue() w/ appropriate parameters.
8719dceae2f9 ("workqueue: reject adjusting max_active or applying
attrs to ordered workqueues") introduced __WQ_ORDERED to protect
ordered workqueues against dynamic attribute changes which can break
ordering guarantees but forgot to apply it to
create_singlethread_workqueue(). This in itself is okay as nobody
currently uses dynamic attribute change on workqueues created with
However, 4c16bd327c ("workqueue: implement NUMA affinity for unbound
workqueues") broke singlethreaded guarantee for ordered workqueues
through allocating a separate pool_workqueue on each NUMA node by
default. A later change 8a2b75384444 ("workqueue: fix ordered
workqueues in NUMA setups") fixed it by allocating only one global
pool_workqueue if __WQ_ORDERED is set.
Combined, the __WQ_ORDERED omission in create_singlethread_workqueue()
became critical breaking its single threadedness and ordering
guarantee.
Let's make create_singlethread_workqueue() wrap
alloc_ordered_workqueue() instead so that it inherits __WQ_ORDERED and
can implicitly track future ordered_workqueue changes.
v2: I missed that __WQ_ORDERED now protects against pwq splitting
across NUMA nodes and incorrectly described the patch as a
nice-to-have fix to protect against future dynamic attribute
usages. Oleg pointed out that this is actually a critical
breakage due to 8a2b75384444 ("workqueue: fix ordered workqueues
in NUMA setups").
Reported-by: Mike Anderson <mike.anderson@us.ibm.com>
Cc: Oleg Nesterov <onestero@redhat.com>
Cc: Gustavo Luiz Duarte <gduarte@redhat.com>
Cc: Tomas Henzl <thenzl@redhat.com>
Fixes: 4c16bd327c ("workqueue: implement NUMA affinity for unbound workqueues")
Tommi noticed a 'funny' lock class name: "%s#5" from a lock acquired in
process_one_work().
Maybe #fmt plus #args could be used as the lock_name to give some more
information for some fmt string like the above.
__builtin_constant_p() check is removed (as there seems no good way to
check all the variables in args list). However, by removing the check,
it only adds two additional "s for those constants.
Some lockdep name examples printed out after the change:
lockdep name wq->name
"events_long" events_long
"%s"("khelper") khelper
"xfs-data/%s"mp->m_fsname xfs-data/dm-3
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made
WQ_NON_REENTRANT no-op but the following patches didn't remove the
flag or update the documentation. Let's mark the flag deprecated and
update the documentation accordingly.
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
This patch adds system wide workqueues aligned towards power saving. This is
done by allocating them with WQ_UNBOUND flag if 'wq_power_efficient' is set to
'true'.
tj: updated comments a bit.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Workqueues can be performance or power-oriented. Currently, most workqueues are
bound to the CPU they were created on. This gives good performance (due to cache
effects) at the cost of potentially waking up otherwise idle cores (Idle from
scheduler's perspective. Which may or may not be physically idle) just to
process some work. To save power, we can allow the work to be rescheduled on a
core that is already awake.
Workqueues created with the WQ_UNBOUND flag will allow some power savings.
However, we don't change the default behaviour of the system. To enable
power-saving behaviour, a new config option CONFIG_WQ_POWER_EFFICIENT needs to
be turned on. This option can also be overridden by the
workqueue.power_efficient boot parameter.
tj: Updated config description and comments. Renamed
CONFIG_WQ_POWER_EFFICIENT to CONFIG_WQ_POWER_EFFICIENT_DEFAULT.
Reviewed-by: Amit Kucheria <amit.kucheria@linaro.org>
One of the problems that arise when converting dedicated custom
threadpool to workqueue is that the shared worker pool used by workqueue
anonimizes each worker making it more difficult to identify what the
worker was doing on which target from the output of sysrq-t or debug
dump from oops, BUG() and friends.
This patch implements set_worker_desc() which can be called from any
workqueue work function to set its description. When the worker task is
dumped for whatever reason - sysrq-t, WARN, BUG, oops, lockdep assertion
and so on - the description will be printed out together with the
workqueue name and the worker function pointer.
The printing side is implemented by print_worker_info() which is called
from functions in task dump paths - sched_show_task() and
dump_stack_print_info(). print_worker_info() can be safely called on
any task in any state as long as the task struct itself is accessible.
It uses probe_*() functions to access worker fields. It may print
garbage if something went very wrong, but it wouldn't cause (another)
oops.
The description is currently limited to 24bytes including the
terminating \0. worker->desc_valid and workder->desc[] are added and
the 64 bytes marker which was already incorrect before adding the new
fields is moved to the correct position.
Here's an example dump with writeback updated to set the bdi name as
worker desc.
Hardware name: Bochs
Modules linked in:
Pid: 7, comm: kworker/u9:0 Not tainted 3.9.0-rc1-work+ #1
Workqueue: writeback bdi_writeback_workfn (flush-8:0)
ffffffff820a3ab0 ffff88000f6e9cb8 ffffffff81c61845 ffff88000f6e9cf8
ffffffff8108f50f 0000000000000000 0000000000000000 ffff88000cde16b0
ffff88000cde1aa8 ffff88001ee19240 ffff88000f6e9fd8 ffff88000f6e9d08
Call Trace:
[<ffffffff81c61845>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81200150>] bdi_writeback_workfn+0x2a0/0x3b0
Acked-by: Jan Kara <jack@suse.cz>
param to disable NUMA affinity
Unbound workqueues are now NUMA aware. Let's add some control knobs
and update sysfs interface accordingly.
* Add kernel param workqueue.numa_disable which disables NUMA affinity
globally.
* Replace sysfs file "pool_id" with "pool_ids" which contain
node:pool_id pairs. This change is userland-visible but "pool_id"
hasn't seen a release yet, so this is okay.
* Add a new sysf files "numa" which can toggle NUMA affinity on
individual workqueues. This is implemented as attrs->no_numa whichn
is special in that it isn't part of a pool's attributes. It only
affects how apply_workqueue_attrs() picks which pools to use.
After "pool_ids" change, first_pwq() doesn't have any user left.
Removed.
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
There's no reason to make these trivial wrappers full (exported)
functions. Inline the followings.
queue_work()
queue_delayed_work()
mod_delayed_work()
schedule_work_on()
schedule_work()
schedule_delayed_work_on()
schedule_delayed_work()
keventd_up()
Implement a function which queries whether it currently is running off
a workqueue rescuer. This will be used to convert writeback to
workqueue.
There are cases where workqueue users want to expose control knobs to
userland. e.g. Unbound workqueues with custom attributes are
scheduled to be used for writeback workers and depending on
configuration it can be useful to allow admins to tinker with the
priority or allowed CPUs.
This patch implements workqueue_sysfs_register(), which makes the
workqueue visible under /sys/bus/workqueue/devices/WQ_NAME. There
currently are two attributes common to both per-cpu and unbound pools
and extra attributes for unbound pools including nice level and
cpumask.
If alloc_workqueue*() is called with WQ_SYSFS,
workqueue_sysfs_register() is called automatically as part of
workqueue creation. This is the preferred method unless the workqueue
user wants to apply workqueue_attrs before making the workqueue
visible to userland.
v2: Disallow exposing ordered workqueues as ordered workqueues can't
be tuned in any way.
Adjusting max_active of or applying new workqueue_attrs to an ordered
workqueue breaks its ordering guarantee. The former is obvious. The
latter is because applying attrs creates a new pwq (pool_workqueue)
and there is no ordering constraint between the old and new pwqs.
Make apply_workqueue_attrs() and workqueue_set_max_active() trigger
WARN_ON() if those operations are requested on an ordered workqueue
and fail / ignore respectively.
We're gonna add another internal WQ flag. Let's make the distinction
clear. Prefix WQ_DRAINING with __ and move it to bit 16.
Implement apply_workqueue_attrs() which applies workqueue_attrs to the
specified unbound workqueue by creating a new pwq (pool_workqueue)
linked to worker_pool with the specified attributes.
A new pwq is linked at the head of wq->pwqs instead of tail and
__queue_work() verifies that the first unbound pwq has positive refcnt
before choosing it for the actual queueing. This is to cover the case
where creation of a new pwq races with queueing. As base ref on a pwq
won't be dropped without making another pwq the first one,
__queue_work() is guaranteed to make progress and not add work item to
a dead pwq.
init_and_link_pwq() is updated to return the last first pwq the new
pwq replaced, which is put by apply_workqueue_attrs().
Note that apply_workqueue_attrs() is almost identical to unbound pwq
part of alloc_and_link_pwqs(). The only difference is that there is
no previous first pwq. apply_workqueue_attrs() is implemented to
handle such cases and replaces unbound pwq handling in
WQ_RESCUER is superflous. WQ_MEM_RECLAIM indicates that the user
wants a rescuer and testing wq->rescuer for NULL can answer whether a
given workqueue has a rescuer or not. Drop WQ_RESCUER and test
wq->rescuer directly.
This will help simplifying __alloc_workqueue_key() failure path by
allowing it to use destroy_workqueue() on a partially constructed
workqueue, which in turn will help implementing dynamic management of
pool_workqueues.
While at it, clear wq->rescuer after freeing it in
destroy_workqueue(). This is a precaution as scheduled changes will
make destruction more complex.
This patch doesn't introduce any functional changes.
Introduce struct workqueue_attrs which carries worker attributes -
currently the nice level and allowed cpumask along with helper
routines alloc_workqueue_attrs() and free_workqueue_attrs().
Each worker_pool now carries ->attrs describing the attributes of its
workers. All functions dealing with cpumask and nice level of workers
are updated to follow worker_pool->attrs instead of determining them
from other characteristics of the worker_pool, and init_workqueues()
is updated to set worker_pool->attrs appropriately for all standard
pools.
Note that create_worker() is updated to always perform set_user_nice()
and use set_cpus_allowed_ptr() combined with manual assertion of
PF_THREAD_BOUND instead of kthread_bind(). This simplifies handling
random attributes without affecting the outcome.
This patch doesn't introduce any behavior changes.
v2: Missing cpumask_var_t definition caused build failure on some
archs. linux/cpumask.h included.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Workqueue is mixing unsigned int and int for @cpu variables. There's
no point in using unsigned int for cpus - many of cpu related APIs
take int anyway. Consistently use int for @cpu variables so that we
can use negative values to mark special ones.
This patch doesn't introduce any visible behavior changes.
When a work item is off-queue, its work->data contains WORK_STRUCT_*
and WORK_OFFQ_* flags. As WORK_OFFQ_* flags are used only while a
work item is off-queue, it can occupy bits of work->data which aren't
used while off-queue. WORK_OFFQ_* currently only use bits used by
on-queue CWQ pointer. As color bits aren't used while off-queue,
there's no reason to not use them.
Lower WORK_OFFQ_FLAG_BASE from WORK_STRUCT_FLAG_BITS to
WORK_STRUCT_COLOR_SHIFT thus giving 4 more bits to off-queue flag
space which is also used to record worker_pool ID while off-queue.
This doesn't introduce any visible behavior difference.
tj: Rewrote the description.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
workqueue has moved away from global_cwqs to worker_pools and with the
scheduled custom worker pools, wforkqueues will be associated with
pools which don't have anything to do with CPUs. The workqueue code
went through significant amount of changes recently and mass renaming
isn't likely to hurt much additionally. Let's replace 'cpu' with
'pool' so that it reflects the current design.
* s/struct cpu_workqueue_struct/struct pool_workqueue/
* s/cpu_wq/pool_wq/
* s/cwq/pwq/
This patch is purely cosmetic.
To avoid executing the same work item from multiple CPUs concurrently,
a work_struct records the last pool it was on in its ->data so that,
on the next queueing, the pool can be queried to determine whether the
work item is still executing or not.
A delayed_work goes through timer before actually being queued on the
target workqueue and the timer needs to know the target workqueue and
CPU. This is currently achieved by modifying delayed_work->work.data
such that it points to the cwq which points to the target workqueue
and the last CPU the work item was on. __queue_delayed_work()
extracts the last CPU from delayed_work->work.data and then combines
it with the target workqueue to create new work.data.
The only thing this rather ugly hack achieves is encoding the target
workqueue into delayed_work->work.data without using a separate field,
which could be a trade off one can make; unfortunately, this entangles
work->data management between regular workqueue and delayed_work code
by setting cwq pointer before the work item is actually queued and
becomes a hindrance for further improvements of work->data handling.
This can be easily made sane by adding a target workqueue field to
delayed_work. While delayed_work is used widely in the kernel and
this does make it a bit larger (<5%), I think this is the right
trade-off especially given the prospect of much saner handling of
work->data which currently involves quite tricky memory barrier
dancing, and don't expect to see any measureable effect.
Add delayed_work->wq and drop the delayed_work->work.data overloading.
Now that workqueue has moved away from gcwqs, workqueue no longer has
the need to have a CPU identifier indicating "no cpu associated" - we
now use WORK_OFFQ_POOL_NONE instead - and most uses of WORK_CPU_NONE
are gone.
The only left usage is as the end marker for for_each_*wq*()
iterators, where the name WORK_CPU_NONE is confusing w/o actual
WORK_CPU_NONE usages. Similarly, WORK_CPU_LAST which equals
WORK_CPU_NONE no longer makes sense.
Replace both WORK_CPU_NONE and LAST with WORK_CPU_END. This patch
doesn't introduce any functional difference.
tj: s/WORK_CPU_LAST/WORK_CPU_END/ and rewrote the description.
Currently, when a work item is off-queue, work->data records the CPU
it was last on, which is used to locate the last executing instance
for non-reentrance, flushing, etc.
We're in the process of removing global_cwq and making worker_pool the
top level abstraction. This patch makes work->data point to the pool
it was last associated with instead of CPU.
After the previous WORK_OFFQ_POOL_CPU and worker_poo->id additions,
the conversion is fairly straight-forward. WORK_OFFQ constants and
functions are modified to record and read back pool ID instead.
worker_pool_by_id() is added to allow looking up pool from ID.
get_work_pool() replaces get_work_gcwq(), which is reimplemented using
get_work_pool(). get_work_pool_id() replaces work_cpu().
This patch shouldn't introduce any observable behavior changes.
Currently, when a work item is off queue, high bits of its data
encodes the last CPU it was on. This is scheduled to be changed to
pool ID, which will make it impossible to use WORK_CPU_NONE to
indicate no association.
This patch limits the number of bits which are used for off-queue cpu
number to 31 (so that the max fits in an int) and uses the highest
possible value - WORK_OFFQ_CPU_NONE - to indicate no association.
This function no longer has any external users. Unexport it. It will
be removed later on.
Now that cancel_delayed_work() can be safely called from IRQ handlers,
there's no reason to use __cancel_delayed_work(). Use
cancel_delayed_work() instead of __cancel_delayed_work() and mark the
latter deprecated.
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Roland Dreier <roland@kernel.org>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
cancel_delayed_work() can't be called from IRQ handlers due to its use
of del_timer_sync() and can't cancel work items which are already
transferred from timer to worklist.
Also, unlike other flush and cancel functions, a canceled delayed_work
would still point to the last associated cpu_workqueue. If the
workqueue is destroyed afterwards and the work item is re-used on a
different workqueue, the queueing code can oops trying to dereference
already freed cpu_workqueue.
This patch reimplements cancel_delayed_work() using
try_to_grab_pending() and set_work_cpu_and_clear_pending(). This
allows the function to be called from IRQ handlers and makes its
behavior consistent with other flush / cancel functions.
Up to now, for delayed_works, try_to_grab_pending() couldn't be used
from IRQ handlers because IRQs may happen while
delayed_work_timer_fn() is in progress leading to indefinite -EAGAIN.
This patch makes delayed_work use the new TIMER_IRQSAFE flag for
delayed_work->timer. This makes try_to_grab_pending() and thus
mod_delayed_work_on() safe to call from IRQ handlers.
Reimplement delayed_work initializers using new timer initializers
which take timer flags. This reduces code duplications and will ease
further initializer changes. This patch also adds a missing
initializer - INIT_DEFERRABLE_WORK_ONSTACK().
Initalizers for deferrable delayed_work are confused.
* __DEFERRED_WORK_INITIALIZER()
* DECLARE_DEFERRED_WORK()
* INIT_DELAYED_WORK_DEFERRABLE()
Rename them to
* __DEFERRABLE_WORK_INITIALIZER()
* DECLARE_DEFERRABLE_WORK()
* INIT_DEFERRABLE_WORK()
This patch doesn't cause any functional changes.
Consistently use the last tab position for '\' line continuation in
complex macro definitions. This is to help the following patches.
This patch is cosmetic.
system_nrt[_freezable]_wq are now spurious. Mark them deprecated and
convert all users to system[_freezable]_wq.
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant, so there's no reason to use system_nrt[_freezable]_wq.
Please use system[_freezable]_wq instead.
This patch doesn't make any functional difference.
Acked-By: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: David Airlie <airlied@linux.ie>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
Now that all workqueues are non-reentrant, system[_freezable]_wq() are
equivalent to system_nrt[_freezable]_wq(). Replace the latter with
wrappers around system[_freezable]_wq(). The wrapping goes through
inline functions so that __deprecated can be added easily.
Now that all workqueues are non-reentrant, flush[_delayed]_work_sync()
are equivalent to flush[_delayed]_work(). Drop the separate
implementation and make them thin wrappers around
* start_flush_work() no longer takes @wait_executing as the only left
user - flush_work() - always sets it to %true.
* __cancel_work_timer() uses flush_work() instead of wait_on_work().
delayed_work encodes the workqueue to use and the last CPU in
delayed_work->work.data while it's on timer. The target CPU is
implicitly recorded as the CPU the timer is queued on and
delayed_work_timer_fn() queues delayed_work->work to the CPU it is
running on.
Unfortunately, this leaves flush_delayed_work[_sync]() no way to find
out which CPU the delayed_work was queued for when they try to
re-queue after killing the timer. Currently, it chooses the local CPU
flush is running on. This can unexpectedly move a delayed_work queued
on a specific CPU to another CPU and lead to subtle errors.
There isn't much point in trying to save several bytes in struct
delayed_work, which is already close to a hundred bytes on 64bit with
all debug options turned off. This patch adds delayed_work->cpu to
remember the CPU it's queued for.
Note that if the timer is migrated during CPU down, the work item
could be queued to the downed global_cwq after this change. As a
detached global_cwq behaves like an unbound one, this doesn't change
much for the delayed_work.
Workqueue was lacking a mechanism to modify the timeout of an already
pending delayed_work. delayed_work users have been working around
this using several methods - using an explicit timer + work item,
messing directly with delayed_work->timer, and canceling before
re-queueing, all of which are error-prone and/or ugly.
This patch implements mod_delayed_work[_on]() which behaves similarly
to mod_timer() - if the delayed_work is idle, it's queued with the
given delay; otherwise, its timeout is modified to the new value.
Zero @delay guarantees immediate execution.
v2: Updated to reflect try_to_grab_pending() changes. Now safe to be
called from bh context.
There can be two reasons try_to_grab_pending() can fail with -EAGAIN.
One is when someone else is queueing or deqeueing the work item. With
the previous patches, it is guaranteed that PENDING and queued state
will soon agree making it safe to busy-retry in this case.
The other is if multiple __cancel_work_timer() invocations are racing
one another. __cancel_work_timer() grabs PENDING and then waits for
running instances of the target work item on all CPUs while holding
PENDING and !queued. try_to_grab_pending() invoked from another task
will keep returning -EAGAIN while the current owner is waiting.
Not distinguishing the two cases is okay because __cancel_work_timer()
is the only user of try_to_grab_pending() and it invokes
wait_on_work() whenever grabbing fails. For the first case, busy
looping should be fine but wait_on_work() doesn't cause any critical
problem. For the latter case, the new contender usually waits for the
same condition as the current owner, so no unnecessarily extended
busy-looping happens. Combined, these make __cancel_work_timer()
technically correct even without irq protection while grabbing PENDING
or distinguishing the two different cases.
While the current code is technically correct, not distinguishing the
two cases makes it difficult to use try_to_grab_pending() for other
purposes than canceling because it's impossible to tell whether it's
safe to busy-retry grabbing.
This patch adds a mechanism to mark a work item being canceled.
try_to_grab_pending() now disables irq on success and returns -EAGAIN
to indicate that grabbing failed but PENDING and queued states are
gonna agree soon and it's safe to busy-loop. It returns -ENOENT if
the work item is being canceled and it may stay PENDING && !queued for
arbitrary amount of time.
__cancel_work_timer() is modified to mark the work canceling with
WORK_OFFQ_CANCELING after grabbing PENDING, thus making
try_to_grab_pending() fail with -ENOENT instead of -EAGAIN. Also, it
invokes wait_on_work() iff grabbing failed with -ENOENT. This isn't
necessary for correctness but makes it consistent with other future
users of try_to_grab_pending().
v2: try_to_grab_pending() was testing preempt_count() to ensure that
the caller has disabled preemption. This triggers spuriously if
!CONFIG_PREEMPT_COUNT. Use preemptible() instead. Reported by
Fengguang Wu.
v3: Updated so that try_to_grab_pending() disables irq on success
rather than requiring preemption disabled by the caller. This
makes busy-looping easier and will allow try_to_grap_pending() to
be used from bh/irq contexts.
Cc: Fengguang Wu <fengguang.wu@intel.com>
Low WORK_STRUCT_FLAG_BITS bits of work_struct->data contain
WORK_STRUCT_FLAG_* and flush color. If the work item is queued, the
rest point to the cpu_workqueue with WORK_STRUCT_CWQ set; otherwise,
WORK_STRUCT_CWQ is clear and the bits contain the last CPU number -
either a real CPU number or one of WORK_CPU_*.
Scheduled addition of mod_delayed_work[_on]() requires an additional
flag, which is used only while a work item is off queue. There are
more than enough bits to represent off-queue CPU number on both 32 and
64bits. This patch introduces WORK_OFFQ_FLAG_* which occupy the lower
part of the @work->data high bits while off queue. This patch doesn't
define any actual OFFQ flag yet.
Off-queue CPU number is now shifted by WORK_OFFQ_CPU_SHIFT, which adds
the number of bits used by OFFQ flags to WORK_STRUCT_FLAG_SHIFT, to
make room for OFFQ flags.
To avoid shift width warning with large WORK_OFFQ_FLAG_BITS, ulong
cast is added to WORK_STRUCT_NO_CPU and, just in case, BUILD_BUG_ON()
to check that there are enough bits to accomodate off-queue CPU number
is added.
delayed_work->timer.function is currently initialized during
queue_delayed_work_on(). Export delayed_work_timer_fn() and set
delayed_work timer function during delayed_work initialization
together with other fields.
This ensures the timer function is always valid on an initialized
delayed_work. This is to help mod_delayed_work() implementation.
To detect delayed_work users which diddle with the internal timer,
trigger WARN if timer function doesn't match on queue.
All queueing functions return 1 on success, 0 if the work item was
already pending. Update them to return bool instead. This signifies
better that they don't return 0 / -errno.
This is cleanup and doesn't cause any functional difference.
While at it, fix comment opening for schedule_work_on().
Currently, queue/schedule[_delayed]_work_on() are located below the
counterpart without the _on postifx even though the latter is usually
implemented using the former. Swap them.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@kernel.org>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
alloc_workqueue() currently expects the passed in @name pointer to remain
accessible. This is inconvenient and a bit silly given that the whole wq
is being dynamically allocated. This patch updates alloc_workqueue() and
friends to take printf format string instead of opaque string and matching
varargs at the end. The name is allocated together with the wq and
formatted.
alloc_ordered_workqueue() is converted to a macro to unify varargs
handling with alloc_workqueue(), and, while at it, add comment to
alloc_workqueue().
None of the current in-kernel users pass in string with '%' as constant
name and this change shouldn't cause any problem.
[akpm@linux-foundation.org: use __printf]
Suggested-by: Christoph Hellwig <hch@infradead.org>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
There are users which want to drain workqueues without destroying it.
Separate out drain functionality from destroy_workqueue() into
drain_workqueue() and make it accessible to workqueue users.
To guarantee forward-progress, only chain queueing is allowed while
drain is in progress. If a new work item which isn't chained from the
running or pending work items is queued while draining is in progress,
WARN_ON_ONCE() is triggered.
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
cancel_rearming_delayed_work() and cancel_rearming_delayed_workqueue()
can be removed now.
Signed-off-by: WANG Cong <amwang@redhat.com>
wq:fixes-2.6.38 does s/WQ_FREEZEABLE/WQ_FREEZABLE and wq:for-2.6.39
adds new usage of the flag. The combination of the two creates a
build failure after merge. Fix it by renaming all freezeables to
freezables.
There are two spellings in use for 'freeze' + 'able' - 'freezable' and
'freezeable'. The former is the more prominent one. The latter is
mostly used by workqueue and in a few other odd places. Unify the
spelling to 'freezable'.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Cc: Alex Dubov <oakad@yahoo.com>
