path: root/include/linux/zorro.h
2013-11-26zorro/UAPI: Disintegrate include/linux/zorro*.hGeert Uytterhoeven
The Zorro definitions and device IDs are used by bootstraps, hence they should be exported through UAPI. Unfortunately zorro.h was never marked for export when headers_install was introduced, so it was forgotten during the big UAPI disintegration. In addition, the removal of zorro_ids.h had been sneaked into commit 7e7a43c32a8970ea2bfc3d1af353dcb1a9237769 ("PCI: don't export device IDs to userspace") before, so it was also forgotten. Split off and export the Zorro definitions used by bootstraps. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro: Do not allocate zorro_autocon[] staticallyGeert Uytterhoeven
Currently the array of Zorro devices is allocated statically, wasting up to 4.5 KiB when running an Amiga or multi-platform kernel on a machine with no or a handful of Zorro expansion cards. Convert it to conditional dynamic memory allocation to fix this. amiga_parse_bootinfo() still needs to store some information about the detected Zorro devices, at a time even the bootmem allocator is not yet available. This is now handled using a much smaller array (typically less than 0.5 KiB), which is __initdata and thus freed later. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-17m68k: amiga - Zorro host bridge platform device conversionGeert Uytterhoeven
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2006-06-23[PATCH] m68k: Remove some unused definitions in zorro.hRoman Zippel
These definitions have long been superseded by asm-offsets.h Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] amiga: fix driver_register() return handling, remove zorro_module_init()Bjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. zorro_module_init() used the device count to automatically unregister and unload drivers that found no devices. That might have worked at one time, but has been broken for some time because zorro_register_driver() returned either a negative error or a positive count (never zero). So it could only unregister on failure, when it's not needed anyway. This functionality could be resurrected in individual drivers by counting devices in their .probe() methods. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
