Add a kvm_ prefix to avoid polluting kernel's name space.
Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
To share with other archs, this patch moves device assignment
logic to common parts.
Allow guest pagetables to go out of sync. Instead of emulating write
accesses to guest pagetables, or unshadowing them, we un-write-protect
the page table and allow the guest to modify it at will. We rely on
invlpg executions to synchronize individual ptes, and will synchronize
the entire pagetable on tlb flushes.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Based on a patch by: Kay, Allen M <allen.m.kay@intel.com>
This patch enables PCI device assignment based on VT-d support.
When a device is assigned to the guest, the guest memory is pinned and
the mapping is updated in the VT-d IOMMU.
[Amit: Expose KVM_CAP_IOMMU so we can check if an IOMMU is present
and also control enable/disable from userspace]
Signed-off-by: Kay, Allen M <allen.m.kay@intel.com>
Signed-off-by: Weidong Han <weidong.han@intel.com>
Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com>
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
Acked-by: Mark Gross <mgross@linux.intel.com>
This patch extends the VT-d driver to support KVM
[Ben: fixed memory pinning]
[avi: move dma_remapping.h as well]
Offline or uninitialized vcpu's can be executed if requested to perform
userspace work.
Follow Avi's suggestion to handle halted vcpu's in the main loop,
simplifying kvm_emulate_halt(). Introduce a new vcpu->requests bit to
indicate events that promote state from halted to running.
Also standardize vcpu wake sites.
Signed-off-by: Marcelo Tosatti <mtosatti <at> redhat.com>
Based on a patch from: Amit Shah <amit.shah@qumranet.com>
This patch adds support for handling PCI devices that are assigned to
the guest.
The device to be assigned to the guest is registered in the host kernel
and interrupt delivery is handled. If a device is already assigned, or
the device driver for it is still loaded on the host, the device
assignment is failed by conveying a -EBUSY reply to the userspace.
Devices that share their interrupt line are not supported at the moment.
By itself, this patch will not make devices work within the guest.
The VT-d extension is required to enable the device to perform DMA.
Another alternative is PVDMA.
This patch adds a trace point for the instruction emulation on embedded powerpc
utilizing the KVM_TRACE interface.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
This patch adds trace points to track powerpc TLB activities using the
KVM_TRACE infrastructure.
Signed-off-by: Jerone Young <jyoung5@us.ibm.com>
The current kvmtrace code uses get_cycles() while the interpretation would be
easier using using nanoseconds. ktime_get() should give at least the same
accuracy as get_cycles on all architectures (even better on 32bit archs) but
at a better unit (e.g. comparable between hosts with different frequencies.
[avi: avoid ktime_t in public header]
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
This patch fixes kvmtrace use on big endian systems. When using bit fields the
compiler will lay data out in the wrong order expected when laid down into a
file.
This fixes it by using one variable instead of using bit fields.
Move KVM trace definitions from x86 specific kvm headers to common kvm
headers to create a cross-architecture numbering scheme for trace
events. This means the kvmtrace_format userspace tool won't need to know
which architecture produced the log file being processed.
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (55 commits)
HID: build drivers for all quirky devices by default
HID: add missing blacklist entry for Apple ATV ircontrol
HID: add support for Bright ABNT2 brazilian device
HID: Don't let Avermedia Radio FM800 be handled by usb hid drivers
HID: fix numlock led on Dell device 0x413c/0x2105
HID: remove warn() macro from usb hid drivers
HID: remove info() macro from usb HID drivers
HID: add appletv IR receiver quirk
HID: fix a lockup regression when using force feedback on a PID device
HID: hiddev.h: Fix example code.
HID: hiddev.h: Fix mixed space and tabs in example code.
HID: convert to dev_* prints
HID: remove hid-ff
HID: move zeroplus FF processing
HID: move thrustmaster FF processing
HID: move pantherlord FF processing
HID: fix incorrent length condition in hidraw_write()
HID: fix tty<->hid deadlock
HID: ignore iBuddy devices
HID: report descriptor fix for remaining MacBook JIS keyboards
Commit 8006479c9b75fb6594a7b746af3d7f1fbb68f18f introduced a spinlock in
input_dev->event_lock, which is locked when handling input events.
However, the hid-pidff driver sleeps when handling events as it waits for
reports being sent to the device before changing the report contents
again.
This causes a system lockup when trying to use force feedback with a PID
device, a regression introduced in 2.6.24 and 2.6.23.15.
Fix it by extracting the raw report data from struct hid_report
immediately when hid_submit_report() is called, therefore allowing
drivers to change the contents of struct hid_report immediately without
affecting the already-queued transfer.
In hid-pidff, re-add the removed usbhid_wait_io() to
pidff_erase_effect() instead, to prevent a full report queue from causing
the submission to fail, thus not freeing up device memory.
pidff_erase_effect() is not called while dev->event_lock is held.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Fix hiddev.h example code.
To get the correct usage code, you need to set report_type and
report_id.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
hid-ff.c now calls only pidff (generic driver), the special ones are now
in separate drivers. Invoke pidff on all non-special directly.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Move the force feedback processing into a separate module.
[jkosina@suse.cz: fix Kconfig texts a little bit]
Merge the logitech force feedback processing directly into logitech
driver from the usbhid core.
Move the handling of the leds resetting from the core to
the dell and logitech drivers.
Move connecting from usbhid to the hid layer and fix also hidp in
that manner.
This removes all the ignore/force hidinput/hiddev connecting quirks.
Remove support for both dynamic and static report descriptor
quirks. There is no longer rdesc code which it would support,
so it's useless.
Remove the file since these is no user now.
Move them from the core code to a separate driver.
Add compat option to hid code to allow loading of all modules on
systems which don't allow autoloading because of old userspace.
Move ignore quirks from usbhid-quirks into hid-core code. Also don't output
warning when ENODEV is error code in usbhid and try ordinal input in hidp
when that error is returned.
Move them from the core and input code to a separate driver.
This mapping are currently used on 2 placces and will be needed by more
quirk drivers, so move them to hid.h to allow them to use it.
Next step for complete hid bus, this patch includes:
- call parser either from probe or from hid-core if there is no probe.
- add ll_driver structure and centralize some stuff there (open, close...)
- split and merge usb_hid_configure and hid_probe into several functions
to allow hooks/fixes between them
Make a bus from hid core. This is the first step for converting all the
quirks and separate almost-drivers into real drivers attached to this bus.
It's implemented to change behaviour in very tiny manner, so that no driver
needs to be changed this time.
Also add generic drivers for both usb and bt into usbhid or hidp
respectively which will bind all non-blacklisted device. Those blacklisted
will be either grabbed by special drivers or by nobody if they are broken at
the very rude base.
Generate aliases for hid device modules to support autoloading.
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux: (59 commits)
svcrdma: Fix IRD/ORD polarity
svcrdma: Update svc_rdma_send_error to use DMA LKEY
svcrdma: Modify the RPC reply path to use FRMR when available
svcrdma: Modify the RPC recv path to use FRMR when available
svcrdma: Add support to svc_rdma_send to handle chained WR
svcrdma: Modify post recv path to use local dma key
svcrdma: Add a service to register a Fast Reg MR with the device
svcrdma: Query device for Fast Reg support during connection setup
svcrdma: Add FRMR get/put services
NLM: Remove unused argument from svc_addsock() function
NLM: Remove "proto" argument from lockd_up()
NLM: Always start both UDP and TCP listeners
lockd: Remove unused fields in the nlm_reboot structure
lockd: Add helper to sanity check incoming NOTIFY requests
lockd: change nlmclnt_grant() to take a "struct sockaddr *"
lockd: Adjust nlmsvc_lookup_host() to accomodate AF_INET6 addresses
lockd: Adjust nlmclnt_lookup_host() signature to accomodate non-AF_INET
lockd: Support non-AF_INET addresses in nlm_lookup_host()
NLM: Convert nlm_lookup_host() to use a single argument
svcrdma: Add Fast Reg MR Data Types
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (26 commits)
mfd: Fix warning in WM8350
mfd: Add placeholders for WM8350 client devices
da903x: add regulator support for DA9030/DA9034
mfd: Add WM8350 subdevice registration helper
regulator: Add WM8350 regulator support
mfd: Add WM8350 interrupt support
mfd: Add initialisation callback for WM8350
mfd: Add GPIO pin configuration support for WM8350
mfd: Add I2C control support for WM8350
mfd: Core support for the WM8350 AudioPlus PMIC
mfd: Add WM8350 watchdog register definitions
mfd: Add WM8350 RTC register definitions
mfd: Add WM8350 comparator register definitions
mfd: Add WM8350 PMU register definitions
mfd: Add WM8350 PMIC register definitions
mfd: Add WM8350 GPIO register definitions
mfd: Add WM8350 audio register definitions
regulator: Export regulator name via sysfs
regulator: Add WM8400 regulator support
mfd: Core support for the WM8400 AudioPlus HiFi CODEC and PMU
This reverts commit c9e587abfdec2c2aaa55fab83bcb4972e2f84f9b, and the
subsequent commits that fixed it up:
- afa9b649 "fbcon: prevent cursor disappearance after switching to 512
character font"
- d850a2fa "vt/fbcon: fix background color on line feed"
- 7fe3915a "vt/fbcon: update scrl_erase_char after 256/512-glyph font
switch"
by request of Alan Cox. Quoth Alan:
"Unfortunately it's wrong and its been causing breakages because
various apps like ncurses expect our previous (and correct)
behaviour."
Alexander sent out a similar patch.
Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Tested-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexander V. Lukyanov <lav@netis.ru>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
qlge: Fix page size ifdef test.
net: Rationalise email address: Network Specific Parts
dsa: fix compile bug on s390
netns: mib6 section fixlet
enic: Fix Kconfig headline description
de2104x: wrong MAC address fix
s390: claw compile fixlet
net: export genphy_restart_aneg
cxgb3: extend copyrights to 2008
cxgb3: update driver version
net/phy: add missing kernel-doc
pktgen: fix skb leak in case of failure
mISDN/dsp_cmx.c: fix size checks
misdn: use nonseekable_open()
net: fix driver build errors due to missing net/ip6_checksum.h include
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (66 commits)
ata: Add documentation for hard disk shock protection interface (v3)
ide: Implement disk shock protection support (v4)
ide-cd: fix printk format warning
piix: add Hercules EC-900 mini-notebook to ich_laptop short cable list
ide-atapi: assign taskfile flags per device type
ide-cd: move cdrom_info.dma to ide_drive_t.dma
ide: add ide_drive_t.dma flag
ide-cd: add a debug_mask module parameter
ide-cd: convert driver to new ide debugging macro (v3)
ide: move SFF DMA code to ide-dma-sff.c
ide: cleanup ide-dma.c
ide: cleanup ide_build_dmatable()
ide: remove needless includes from ide-dma.c
ide: switch to DMA-mapping API part #2
ide: make ide_dma_timeout() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n
ide: make ide_dma_lost_irq() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n
ide: __ide_dma_end() -> ide_dma_end()
pmac: remove needless pmac_ide_destroy_dmatable() wrapper
pmac: remove superfluous pmif == NULL checks
ide: Two fixes regarding memory allocation
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (313 commits)
V4L/DVB (9186): Added support for Prof 7300 DVB-S/S2 cards
V4L/DVB (9185): S2API: Ensure we have a reasonable ROLLOFF default
V4L/DVB (9184): cx24116: Change the default SNR units back to percentage by default.
V4L/DVB (9183): S2API: Return error of the caller provides 0 commands.
V4L/DVB (9182): S2API: Added support for DTV_HIERARCHY
V4L/DVB (9181): S2API: Add support fot DTV_GUARD_INTERVAL and DTV_TRANSMISSION_MODE
V4L/DVB (9180): S2API: Added support for DTV_CODE_RATE_HP/LP
V4L/DVB (9179): S2API: frontend.h cleanup
V4L/DVB (9178): cx24116: Add module parameter to return SNR as ESNO.
V4L/DVB (9177): S2API: Change _8PSK / _16APSK to PSK_8 and APSK_16
V4L/DVB (9176): Add support for DvbWorld USB cards with STV0288 demodulator.
V4L/DVB (9175): Remove NULL pointer in stb6000 driver.
V4L/DVB (9174): Allow custom inittab for ST STV0288 demodulator.
V4L/DVB (9173): S2API: Remove the hardcoded command limit during validation
V4L/DVB (9172): S2API: Bugfix related to DVB-S / DVB-S2 tuning for the legacy API.
V4L/DVB (9171): S2API: Stop an OOPS if illegal commands are dumped in S2API.
V4L/DVB (9170): cx24116: Sanity checking to data input via S2API to the cx24116 demod.
V4L/DVB (9169): uvcvideo: Support two new Bison Electronics webcams.
V4L/DVB (9168): Add support for MSI TV@nywhere Plus remote
V4L/DVB: v4l2-dev: remove duplicated #include
