path: root/include/linux
2008-06-05V4L/DVB (7166): [v4l] Add new user class controls and deprecate othersDavid Woodhouse
These were removed in commit 26d507fcfef7f7d0cd2eec874a87169cc121c835: > -#define V4L2_CID_HCENTER (V4L2_CID_BASE+22) > -#define V4L2_CID_VCENTER (V4L2_CID_BASE+23) > -#define V4L2_CID_LASTP1 (V4L2_CID_BASE+24) /* > last CID + 1 */ > + > +/* Deprecated, use V4L2_CID_PAN_RESET and V4L2_CID_TILT_RESET */ > +#define V4L2_CID_HCENTER_DEPRECATED (V4L2_CID_BASE+22) > +#define V4L2_CID_VCENTER_DEPRECATED (V4L2_CID_BASE+23) But there was no warning in Documentation/feature-removal-schedule.txt and I'm receiving reports that it's breaking userspace apps (the gstreamer-v4l2 plugin breaks in Fedora rawhide). You can't just pull things from the published userspace API like that. Please can we revert the addition of _DEPRECATED to these ioctl definitions. Perhaps we can add a runtime warning if they actually get used? Or a compile-time warning if we can manage that? Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) l2tp: Fix possible oops if transmitting or receiving when tunnel goes down tcp: Fix for race due to temporary drop of the socket lock in skb_splice_bits. tcp: Increment OUTRSTS in tcp_send_active_reset() raw: Raw socket leak. lt2p: Fix possible WARN_ON from socket code when UDP socket is closed USB ID for Philips CPWUA054/00 Wireless USB Adapter 11g ssb: Fix context assertion in ssb_pcicore_dev_irqvecs_enable libertas: fix command size for CMD_802_11_SUBSCRIBE_EVENT ipw2200: expire and use oldest BSS on adhoc create airo warning fix b43legacy: Fix controller restart crash sctp: Fix ECN markings for IPv6 sctp: Flush the queue only once during fast retransmit. sctp: Start T3-RTX timer when fast retransmitting lowest TSN sctp: Correctly implement Fast Recovery cwnd manipulations. sctp: Move sctp_v4_dst_saddr out of loop sctp: retran_path update bug fix tcp: fix skb vs fack_count out-of-sync condition sunhme: Cleanup use of deprecated calls to save_and_cli and restore_flags. xfrm: xfrm_algo: correct usage of RIPEMD-160 ...
2008-06-04Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata-sff: Fix oops reported in kerneloops.org for pnp devices with no ctl libata: kill unused constants sata_mv: PHY_MODE4 cleanups [libata] ata_piix: more acer short cable quirks [libata] ACPI: Properly handle bay devices in dock stations
2008-06-04libata-sff: Fix oops reported in kerneloops.org for pnp devices with no ctlAlan Cox
- Make ata_sff_altstatus private so nobody uses it by mistake - Drop the 400nS delay from it Add ata_sff_irq_status - encapsulates the IRQ check logic This function keeps the existing behaviour for altstatus using devices. I actually suspect the logic was wrong before the changes but -rc isn't the time to play with that ata_sff_sync - ensure writes hit the device Really we want an io* operation for 'is posted' eg ioisposted(ioaddr) so that we can fix the nasty delay this causes on most systems. - ata_sff_pause - 400nS delay Ensure the command hit the device and delay 400nS - ata_sff_dma_pause Ensure the I/O hit the device and enforce an HDMA1:0 transition delay. Requires altstatus register exists, BUG if not so we don't risk corruption in MWDMA modes. (UDMA the checksum will save your backside in theory) The only other complication then is devices with their own handlers. rb532 can use dma_pause but scc needs to access its own altstatus register for internal errata workarounds so directly call the drivers own altstatus function. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-04libata: kill unused constantsTejun Heo
Kill a few unused constants. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-03route: Remove unused ifa_anycast fieldThomas Graf
The field was supposed to allow the creation of an anycast route by assigning an anycast address to an address prefix. It was never implemented so this field is unused and serves no purpose. Remove it. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03route: Mark unused routing attributes as suchThomas Graf
Also removes an unused policy entry for an attribute which is only used in kernel->user direction. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03route: Mark unused route cache flags as such.Thomas Graf
Also removes an obsolete check for the unused flag RTCF_MASQ. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03serial_core: uart_set_ldisc infrastructureAlan Cox
The tty layer provides a callback that is used when the line discipline is changed. Some hardware uses this to configure hardware specific features such as IrDA mode on serial ports. Unfortunately the serial layer does not provide this feature or pass it down to drivers. Blackfin used to hack around this by rewriting the tty ops, but those are now properly shared and const so the hack fails. Instead provide the proper operations. This change plus a follow up from the Blackfin guys is needed to avoid blackfin losing features in this release. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-02mmc_spi: mmc_spi.h should include linux/interrupts.hAnton Vorontsov
Since mmc_spi.h uses irqreturn_t type, it should include appropriate header, otherwise build will break if users didn't include it (some of them do not use interrupts). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: notify on empty virtio: force callback on empty. virtio_blk: fix endianess annotations virtio_config: fix len calculation of config elements virtio_net: another race with virtio_net and enable_cb virtio: An entropy device, as suggested by hpa. virtio_blk: allow read-only disks lguest: fix ugly <NULL> in /proc/interrupts virtio: set device index in common code. virtio: virtio_pci should not set bus_id. virtio: bus_id for devices should contain 'virtio' Fix crash in virtio_blk during modprobe ; rmmod ; modprobe lguest: use ioremap_cache, not ioremap
2008-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: rename SW_RADIO to SW_RFKILL_ALL Input: gtco - fix double kfree in error handling path Input: pxa27x_keypad - miscellaneous fixes Input: atkbd - mark keyboard as disabled when suspending/unloading Input: apanel - remove duplicate include Input: wm9713 - support five wire panels Input: wm97xx-core - fix race on PHY init Input: wm97xx-core - fix driver name Input: wm97xx-core - report a phys for WM97xx touchscreens Input: i8042 - make sure Dritek quirk is invoked at resume Input: i8042 - add Dritek quirk for Acer TravelMate 660
2008-05-30Input: rename SW_RADIO to SW_RFKILL_ALLHenrique de Moraes Holschuh
The SW_RADIO code for EV_SW events has a name that is not descriptive enough of its intended function, and could induce someone to think KEY_RADIO is its EV_KEY counterpart, which is false. Rename it to SW_RFKILL_ALL, and document what this event is for. Keep the old name around, to avoid userspace ABI breaks. The SW_RFKILL_ALL event is meant to be used by rfkill master switches. It is not bound to a particular radio switch type, and usually applies to all types. It is semantically tied to master rfkill switches that enable or disable every radio in a system. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-30virtio: force callback on empty.Rusty Russell
virtio allows drivers to suppress callbacks (ie. interrupts) for efficiency (no locking, it's just an optimization). There's a similar mechanism for the host to suppress notifications coming from the guest: in that case, we ignore the suppression if the ring is completely full. It turns out that life is simpler if the host similarly ignores callback suppression when the ring is completely empty: the network driver wants to free up old packets in a timely manner, and otherwise has to use a timer to poll. We have to remove the code which ignores interrupts when the driver has disabled them (again, it had no locking and hence was unreliable anyway). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio_blk: fix endianess annotationsChristian Borntraeger
Since commit 72e61eb40b55dd57031ec5971e810649f82b0259 (virtio: change config to guest endian) config space is no longer fixed endian. Lets change the virtio_blk_config variables. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio_config: fix len calculation of config elementsChristian Borntraeger
Rusty, This patch is a prereq for the virtio_blk blocksize patch, please apply it first. Adding an u32 value to the virtio_blk_config unconvered a small bug the config space defintions: v is a pointer, to we have to use sizeof(*v) instead of sizeof(v). Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio: An entropy device, as suggested by hpa.Rusty Russell
Note that by itself, having a "hardware" random generator does very little: you should probably run "rngd" in your guest to feed this into the kernel entropy pool. Included: virtio_rng: dont use vmalloced addresses for virtio If virtio_rng is build as a module, random_data is an address in vmalloc space. As virtio expects guest real addresses, this can cause any kind of funny behaviour, so lets allocate random_data dynamically with kmalloc. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio_blk: allow read-only disksChristian Borntraeger
Hello Rusty, sometimes it is useful to share a disk (e.g. usr). To avoid file system corruption, the disk should be mounted read-only in that case. This patch adds a new feature flag, that allows the host to specify, if the disk should be considered read-only. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6tip-timers-nohz-2008-05-30_12.28_FriLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: driver-core: prepare for 2.6.27 api change by adding dev_set_name
2008-05-29driver-core: prepare for 2.6.27 api change by adding dev_set_nameStephen Rothwell
Create the dev_set_name function now so that various subsystems can start changing over to it before other changes in 2.6.27 will make it compulsory. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: re-tune NUMA topologies sched: stop wake_affine from causing serious imbalance sched: fix sched_clock_cpu() revert ("sched: fair-group: SMP-nice for group scheduling") sched: cleanup show_schedstat(): fix memleak sched: unite unlikely pairs in rt_policy() and schedule_debug() revert ("sched: fair: weight calculations")
2008-05-29Merge commit 'linus/master' into sched-fixes-for-linusIngo Molnar
2008-05-29sched: re-tune NUMA topologiesIngo Molnar
improve the sysbench ramp-up phase and its peak throughput on a 16way NUMA box, by turning on WAKE_AFFINE: tip/sched tip/sched+wake-affine ------------------------------------------------- 1: 700 830 +15.65% 2: 1465 1391 -5.28% 4: 3017 3105 +2.81% 8: 5100 6021 +15.30% 16: 10725 10745 +0.19% 32: 10135 10150 +0.16% 64: 9338 9240 -1.06% 128: 8599 8252 -4.21% 256: 8475 8144 -4.07% ------------------------------------------------- SUM: 57558 57882 +0.56% this change also improves lat_ctx from 6.69 usecs to 1.11 usec: $ ./lat_ctx -s 0 2 "size=0k ovr=1.19 2 1.11 $ ./lat_ctx -s 0 2 "size=0k ovr=1.22 2 6.69 in sysbench it's an overall win with some weakness at the lots-of-clients side. That happens because we now under-balance this workload a bit. To counter that effect, turn on NEWIDLE: wake-idle wake-idle+newidle ------------------------------------------------- 1: 830 834 +0.43% 2: 1391 1401 +0.65% 4: 3105 3091 -0.43% 8: 6021 6046 +0.42% 16: 10745 10736 -0.08% 32: 10150 10206 +0.55% 64: 9240 9533 +3.08% 128: 8252 8355 +1.24% 256: 8144 8384 +2.87% ------------------------------------------------- SUM: 57882 58591 +1.21% as a bonus this not only improves the many-clients case but also improves the (more important) rampup phase. sysbench is a workload that quickly breaks down if the scheduler over-balances, so since it showed an improvement under NEWIDLE this change is definitely good.
2008-05-29revert ("sched: fair-group: SMP-nice for group scheduling")Ingo Molnar
Yanmin Zhang reported: Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1. It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito. With bisect, I located the following patch: | 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit | commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair-group: SMP-nice for group scheduling Revert it so that we get v2.6.25 behavior. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-28block: make blktrace use per-cpu buffers for message notesJens Axboe
Currently it uses a single static char array, but that risks being corrupted when multiple users issue message notes at the same time. Make the buffers dynamically allocated when the trace is setup and make them per-cpu instead. The default max message size of 1k is also very large, the interface is mainly for small text notes. So shrink it to 128 bytes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in MESSAGE notes for blktracesAlan D. Brunelle
Allows messages to be inserted into blktrace streams. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-27Input: wm9713 - support five wire panelsMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-26posix timers: discard SI_TIMER signals on execOleg Nesterov
Based on Roland's patch. This approach was suggested by Austin Clements from the very beginning, and then by Linus. As Austin pointed out, the execing task can be killed by SI_TIMER signal because exec flushes the signal handlers, but doesn't discard the pending signals generated by posix timers. Perhaps not a bug, but people find this surprising. See http://bugzilla.kernel.org/show_bug.cgi?id=10460 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Align i2c_device_id tuner: Do not alter i2c_client.name
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) vlan: Use bitmask of feature flags instead of seperate feature bits fmvj18x_cs: add NextCom NC5310 rev B support xirc2ps_cs: re-initialize the multicast address in do_reset 3C509: rx_bytes should not be increased when alloc_skb failed NETFRONT: Use __skb_queue_purge() VIRTIO: Use __skb_queue_purge() phylib: do EXPORT_SYMBOL on get_phy_id netlink: Fix nla_parse_nested_compat() to call nla_parse() directly WAN: protect HDLC proto list while insmod/rmmod drivers/net/fs_enet: remove null pointer dereference S2io: Version update for napi and MSI-X patches S2io: Added napi support when MSIX is enabled. S2io: Move all the transmit completions to a single msi-x (alarm) vector drivers/net/ehea - remove unnecessary memset after kzalloc au1000_eth: remove useless check Blackfin EMAC Driver: Removed duplicated include <linux/ethtool.h> cpmac bugfixes and enhancements e1000e: use resource_size_t, not unsigned long, for phys addrs net/usb: add support for Apple USB Ethernet Adapter uli526x: add support for netpoll ...
2008-05-26i2c: Align i2c_device_idJiri Slaby
Align i2c_device_id.driver_data to 8 bytes to not fail on crossbuilds. (Added in d2653e92732bd3911feff6bee5e23dbf959381db.) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-24for_each_online_pgdat(): kerneldoc fixFernando Luis Vazquez Cao
for_each_pgdat() was renamed to for_each_online_pgdat() and kerneldoc comments should be updated accordingly. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: build fixesDavid Brownell
This fixes various gpio-related build errors (mostly potential) reported in part by Russell King and Uwe Kleine-König. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24SM501: reverse FPEN/VBIASEN flags behaviourBen Dooks
To keep backwards compatibility, reverse the meanings of these flags so that when they are not set, the driver uses the original behvaiour. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: restart recovery cleanly after device failure.NeilBrown
When we get any IO error during a recovery (rebuilding a spare), we abort the recovery and restart it. For RAID6 (and multi-drive RAID1) it may not be best to restart at the beginning: when multiple failures can be tolerated, the recovery may be able to continue and re-doing all that has already been done doesn't make sense. We already have the infrastructure to record where a recovery is up to and restart from there, but it is not being used properly. This is because: - We sometimes abort with MD_RECOVERY_ERR rather than just MD_RECOVERY_INTR, which causes the recovery not be be checkpointed. - We remove spares and then re-added them which loses important state information. The distinction between MD_RECOVERY_ERR and MD_RECOVERY_INTR really isn't needed. If there is an error, the relevant drive will be marked as Faulty, and that is enough to ensure correct handling of the error. So we first remove MD_RECOVERY_ERR, changing some of the uses of it to MD_RECOVERY_INTR. Then we cause the attempt to remove a non-faulty device from an array to fail (unless recovery is impossible as the array is too degraded). Then when remove_and_add_spares attempts to remove the devices on which recovery can continue, it will fail, they will remain in place, and recovery will continue on them as desired. Issue: If we are halfway through rebuilding a spare and another drive fails, and a new spare is immediately available, do we want to: 1/ complete the current rebuild, then go back and rebuild the new spare or 2/ restart the rebuild from the start and rebuild both devices in parallel. Both options can be argued for. The code currently takes option 2 as a/ this requires least code change b/ this results in a minimally-degraded array in minimal time. Cc: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: allow parallel resync of md-devices.Bernd Schubert
In some configurations, a raid6 resync can be limited by CPU speed (Calculating P and Q and moving data) rather than by device speed. In these cases there is nothing to be gained byt serialising resync of arrays that share a device, and doing the resync in parallel can provide benefit. So add a sysfs tunable to flag an array as being allowed to resync in parallel with other arrays that use (a different part of) the same device. Signed-off-by: Bernd Schubert <bs@q-leap.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: kill file_path wrapperChristoph Hellwig
Kill the trivial and rather pointless file_path wrapper around d_path. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: proper extern for mdp_majorAdrian Bunk
This patch adds a proper extern for mdp_major in include/linux/raid/md.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: fix atomic_t overflow in vmAlan Cox
The atomic_t type is 32bit but a 64bit system can have more than 2^32 pages of virtual address space available. Without this we overflow on ludicrously large mappings Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24types.h: don't expose struct ustat to userspacemaximilian attems
<linux/types.h> can't be used together with <sys/ustat.h> because they both define struct ustat: $ cat test.c #include <sys/ustat.h> #include <linux/types.h> $ gcc -c test.c In file included from test.c:2: /usr/include/linux/types.h:165: error: redefinition of 'struct ustat' has been reported a while ago to debian, but seems to have been lost in cat fighting: http://bugs.debian.org/429064 Signed-off-by: maximilian attems <max@stro.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: support for InstaShield IS-400 four port RS-232 PCI cardIgnacio García Pérez
Add support for the InstaShield IS-400 four port RS-232 PCI card. Signed-off-by: Ignacio García Pérez <iggarpe@t2i.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24i5k_amb: support Intel 5400 chipsetDarrick J. Wong
Minor rework to support the Intel 5400 chipset. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23vlan: Use bitmask of feature flags instead of seperate feature bitsPatrick McHardy
Herbert Xu points out that the use of seperate feature bits for features to be propagated to VLAN devices is going to get messy real soon. Replace the VLAN feature bits by a bitmask of feature flags to be propagated and restore the old GSO_SHIFT/MASK values. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: The world is not perfect patch. tcp: Make prior_ssthresh a u32 xfrm_user: Remove zero length key checks. net/ipv4/arp.c: Use common hex_asc helpers cassini: Only use chip checksum for ipv4 packets. tcp: TCP connection times out if ICMP frag needed is delayed netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__ af_key: Fix selector family initialization. libertas: Fix ethtool statistics mac80211: fix NULL pointer dereference in ieee80211_compatible_rates mac80211: don't claim iwspy support orinoco_cs: add ID for SpeedStream wireless adapters hostap_cs: add ID for Conceptronic CON11CPro rtl8187: resource leak in error case ath5k: Fix loop variable initializations
2008-05-21tcp: Make prior_ssthresh a u32Ilpo Järvinen
If previous window was above representable values of u16, strange things will happen if undo with the truncated value is called for. Alternatively, this could be fixed by some max trickery but that would limit undoing high-speed undos. Adds 16-bit hole but there isn't anything to fill it with. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__Patrick McHardy
Greg Steuck <greg@nest.cx> points out that some of the netfilter headers can't be used in userspace without including linux/types.h first. The headers include their own linux/types.h include statements, these are stripped by make headers-install because they are inside #ifdef __KERNEL__ however. Move them out to fix this. Reported and Tested by Greg Steuck. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: CDC WDM driver USB: ehci-orion: the Orion EHCI root hub does have a Transaction Translator USB: serial: ch341: New VID/PID for CH341 USB-serial USB: build fix USB: pxa27x_udc - Fix Oops USB: OPTION: fix name of Onda MSA501HS HSDPA modem USB: add TELIT HDSPA UC864-E modem to option driver usb-serial: Use ftdi_sio driver for RATOC REX-USB60F
2008-05-20[VLAN]: Propagate selected feature bits to VLAN devicesPatrick McHardy
Propagate feature bits from the NETDEV_FEAT_CHANGE notifier. For now only TSO is propagated for devices that announce their ability to support TSO in combination with VLAN accel by setting the NETIF_F_VLAN_TSO flag. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
