This is an initial driver release for the Omnivision 5642 CMOS sensor.
Signed-off-by: Bastian Hecht <hechtb@gmail.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Now we have a camera working over the marvell cam controller core. It
works like the cafe driver and has all the same limitations, contiguous DMA
only being one of them. But it's a start.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This soc_camera driver is for Omnivision's OV9740 sensor. This initial
submission provides support for YUV422 output at 1280x720 (720p), which is
the sensor's native resolution. 640x480 (VGA) is also supported, with
cropping and scaling performed by the sensor's ISP.
This driver is heavily based off of the existing OV9640 driver.
Signed-off-by: Andrew Chew <achew@nvidia.com>
Add ID for NOON010PC30 camera chip and reserve ID range for
Siliconfile sensors.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com>
Add a driver for the video capture port on VIA integrated chipsets. This
version has a remaining OLPCism or two and expects to be talking to an
ov7670; those can be improved as the need arises.
This work was supported by the One Laptop Per Child project.
Thanks to Laurent Pinchart for a number of useful comments.
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Chip identification register contains the value 0x74.
This patch provides a V4L2 SoC Camera driver for OV6650 camera sensor, found
on OMAP1 SoC based Amstrad Delta videophone.
Since I have no experience with camera sensors, and the sensor documentation I
was able to find was not very comprehensive, I left most settings at their
default (reset) values, except for:
- those required for proper mediabus parameters and picture geometry and
format setup,
- those used by controls.
Resulting picture quality may be far from perfect, but better than nothing.
In order to be able to get / set the sensor frame rate from userspace, I
decided to provide two not yet SoC camera supported operations, g_parm and
s_parm. These can be used after applying patch 4/6 from this series,
"SoC Camera: add support for g_parm / s_parm operations".
Created and tested against linux-2.6.36-rc5 on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
AK8814 only differs from AK8813 by included Macrovision Copy Protection
function. This patch adds a driver for AK8813 and AK8814 I2C PAL/NTSC TV
encoders.
Add CHIP ID of the NEC MPEG2 encoders uPD61151 and uPD61152.
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
This list should stay sorted to make it easy to find new ID ranges when
adding new chip families.
[mchehab@redhat.com: fixed bad whitespacing]
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
When the saa7111 driver was merged into saa7115 several bugs were introduced,
in particular with the saa7111a support as is used in the mxb.c driver.
This patch fixes the saa7111a support. This was tested with the mxb driver.
This patch provides required chip identification definitions
within v4l2. Included only definitions for TVP7002.
Signed-off-by: Santiago Nunez-Corrales <santiago.nunez@ridgerun.com>
Initial support for the SAA7706H Car Radio DSP.
It is a I2C device and currently the mute control is supported.
When the device is unmuted it is brought out of reset and initiated using
the proposed intialisation sequence.
When muted the DSP is brought into reset state.
[akpm@linux-foundation.org: include delay.h]
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
Cc: Douglas Schilling Landgraf <dougsland@gmail.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
create mode 100644 drivers/media/video/mt9t112.c
create mode 100644 include/media/mt9t112.h
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
This patch adds support for TEF6862 Car Radio Enhanced Selectivity Tuner.
It's implemented as a subdev, supporting checking signal strength
and setting and getting frequency.
Signed-off-by: Richard Röjfors <richard.rojfors@mocean-labs.com>
sensor from Sharp
This adds an soc-camera / v4l2-subdev driver for the RJ54N1CB0C CMOS camera
sensor from Sharp. The sensor is very picky about initialisation and
configuration sequences. The driver limits artificially maximum window size by
800x600, although the sensor supports 1600x1200. Sizes above 800x600 don't seem
to work correctly, besides, examples from the system integrator use sizes above
640x480 only for still photography. Unfortunately, I had to use "magic"
register-value pairs for undocumented and "reserved" registers. This version of
the driver also omits some functionality, like cropping, which hasn't been
sufficiently tested yet and will be added later.
create mode 100644 drivers/media/video/rj54n1cb0c.c
cx25840 modules
Add identifiers for CX2388[578] chips, CX2310[012] chips, integrated
A/V decoders cores, integrated IR controller core, and the CX23417
MPEG encoder. The cx23885 module and cx25840 module will use these
identifiers in upcoming changes.
Signed-off-by: Andy Walls <awalls@radix.net>
OV9640 sensor
This is an initial driver for Analog Devices ADV7180 Video Decoder.
So far it only supports query standard.
[akpm@linux-foundation.org: remove unneeded cast]
Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Adds driver for mt9v011 based on its datasheet, available at:
http://download.micron.com/pdf/datasheets/imaging/MT9V011.pdf
The driver was tested with a webcam that will be added on a next patch.
Add ADV7343 I2C based video encoder driver. This follows the
v4l2-subdev framework. This driver has been tested on TI DM646x EVM. It
has been tested for Composite and Component outputs.
Updates as per review by Mauro Chehab, added support for more standards
supported by the encoder. Also adding the missed out signed-offs.Tested
only NTSC and PAL standards.
[hverkuil@xs4all.nl: s_routing API changed, updated driver to use new API]
Signed-off-by: Manjunath Hadli <mrh@ti.com>
Signed-off-by: Brijesh Jadav <brijesh.j@ti.com>
Signed-off-by: Chaithrika U S <chaithrika@ti.com>
This patch adds driver for TI THS7303 video amplifier. This driver is
implemented as a v4l2 sub device. Tested on TI DM646x EVM.
This version has updates based on review comments by Mauro Chehab.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Using VIDIOC_DBG_S/G_REGISTER is the standard way of reading/writing register
for advanced debugging under v4l2. In addition, using this means that the
cafe_ccic driver doesn't need to have knowledge about the used sensor: the
debug ioctl can be passed on to the sensor if it isn't for the host.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Make the g_chip_ident call work for the au0828/au8522. Discovered when testing
with the v4l2_compliance tool
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
[mchehab@redhat.com: fix merge conflict, due to a path change for analog demod]
to v4l2_subdev
Added a new chip identifer to v4l2-chip-ident for the integrated A/V broadcast
decoder core internal to the CX23418. Completed separation and encapsulation
of the A/V decoder core interface as a v4l2_subdevice. The cx18 driver now
compiles and links again.
[mchehab@redhat.com: fix merge conflict with removal of v4l2_ctrl_query_fill_std()]
Modified mxb to load the i2c modules through v4l2_subdev. So no more probing.
Modified tea6415c and tea6420 to use the standard routing ops to do the
routing, rather than using private commands. Dropped the private commands
from tda9840 (they were never used except during initialization of the
module).
Added saa7146 support for VIDIOC_DBG_G_CHIP_IDENT.
Converted saa5246a and saa5249 to v4l2_subdev.
instead of ID.
Since the i2c driver ID will be removed in the near future we have to
modify the v4l2 debugging API to use the driver name instead of driver ID.
Note that this API is not used in applications other than v4l2-dbg.cpp
as it is for debugging and testing only.
Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged
with a warning that it is deprecated and will be removed in 2.6.30.
Micron
This camera is rather similar to MT9M001, but also has a couple of
enhanced features, like pixel binning.
create mode 100644 drivers/media/video/mt9t031.c
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
This patch adds tw9910 driver that use soc_camera framework.
It was tested on SH Migo-r board and mplayer.
create mode 100644 drivers/media/video/tw9910.c
create mode 100644 include/media/tw9910.h
The chip is largely compatible with MT9M111 and is going to be supported by the
same driver.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This patch adds ov772x driver that use soc_camera framework.
It was tested on SH Migo-r board.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cleaned up the saa6752hs i2c driver.
Add AC-3 support.
Add VIDIOC_CHIP_IDENT support.
Converted the last users of audiochip.h to the v4l2-chip-ident.h header
and remove the now unused audiochip.h header.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
