path: root/include/media/v4l2-int-device.h
2011-10-31include: replace linux/module.h with "struct module" wherever possiblePaul Gortmaker
The <linux/module.h> pretty much brings in the kitchen sink along with it, so it should be avoided wherever reasonably possible in terms of being included from other commonly used <linux/something.h> files, as it results in a measureable increase on compile times. The worst culprit was probably device.h since it is used everywhere. This file also had an implicit dependency/usage of mutex.h which was masked by module.h, and is also fixed here at the same time. There are over a dozen other headers that simply declare the struct instead of pulling in the whole file, so follow their lead and simply make it a few more. Most of the implicit dependencies on module.h being present by these headers pulling it in have been now weeded out, so we can finally make this change with hopefully minimal breakage. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9816): v4l2-int-if: add three new ioctls for std handling and routingVaibhav Hiremath
These changes are needed for the new TVP514x driver. Signed-off-by: Brijesh Jadav <brijesh.j@ti.com> Signed-off-by: Hardik Shah <hardik.shah@ti.com> Signed-off-by: Manjunath Hadli <mrh@ti.com> Signed-off-by: R Sivaraj <sivaraj@ti.com> Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Karicheri Muralidharan <m-karicheri2@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9323): v4l2-int-if: Add enum_framesizes and enum_frameintervals ioctls.Sakari Ailus
Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9322): v4l2-int-if: Export more interfaces to modulesSakari Ailus
Export v4l2_int_device_try_attach_all. This allows initiating the initialisation of int if device after the drivers have been registered. Also allow drivers to call ioctls if v4l2-int-if was compiled as module. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9321): v4l2-int-if: Define new power state changesSakari Ailus
Use enum v4l2_power instead of int as second argument to vidioc_int_s_power. The new functionality is that standby state is also recognised. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9319): v4l2-int-if: Add cropcap, g_crop and s_crop commands.Sameer Venkatraman
Signed-off-by: Sameer Venkatraman <sameerv@ti.com> Signed-off-by: Mohit Jalori <mjalori@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9318): v4l2-int-if: Add command to get slave private data.Sakari Ailus
vidioc_int_g_priv is used to get master's slave-related private data structure. The structure can contain for example master's configuration specific to slave. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-01-25V4L/DVB (6580): Set slave's master before master's attach call.Sakari Ailus
V4L: Int if: Set slave's master before attach, remove master argument The master also now gets its own pointer from slave's structure. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6219): V4L: Int if: Remove [gs]_ext_clkSakari Ailus
Remove support for g_ext_clk and s_ext_clk. The same functionality is now handled by g_ifparm. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6217): V4L: Int if: Add BT.656 interface supportSakari Ailus
This patch adds BT.656 interface settings for [gs]_ifparm. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6216): V4L: Int if: add vidioc_int_g_ifparm, other updatesSakari Ailus
vidioc_int_g_ifparm can be used to obtain hardware-specific information about the interface used by the slave. Rearrange v4l2-int-device.h as well. Also remove useless & characters. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5883): V4L: Fix a compile warning on non-32-bit machines.Sakari Ailus
Fix a compile warning on non-32-bit machines in v4l2-int-device.h. Add internal ioctl interface fallback function for ioctls with one argument. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5862): V4L: Add internal ioctl-like interface.Sakari Ailus
This patch adds an internal ioctl-like interface which can be used in situations where a single Video4Linux device is implemented by multiple device drivers. One master device controls one or more slave devices. The slaves provide Video4Linux ioctl-like interface for the use of the master. Only a handful of ioctls are implemented at the moment. More can (and should) be added as more functionality is required. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
