path: root/include/media/videobuf-core.h
2008-05-20Fix a deadlock in the bttv driverArjan van de Ven
vidiocgmbuf() does this: mutex_lock(&fh->cap.vb_lock); retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize, V4L2_MEMORY_MMAP); and videobuf_mmap_setup() then just does mutex_lock(&q->vb_lock); ret = __videobuf_mmap_setup(q, bcount, bsize, memory); mutex_unlock(&q->vb_lock); which is an obvious double-take deadlock. This patch fixes this by having vidiocgmbuf() just call the __videobuf_mmap_setup function instead. Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Reported-by: Koos Vriezen <koos.vriezen@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24V4L/DVB (7566): videobuf-dvb: allow its usage with videobuf-vmallocMauro Carvalho Chehab
videobuf-dvb were still using a function that were videobuf-dma-sg dependent. This patch creates a generic handler for this function. This way, videobuf-dvb can now work with all videobuf implementations. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7493): videobuf: Avoid deadlock with QBUF and bring up to spec for ↵Brandon Philips
empty queue Add a waitqueue to wait on when there are no buffers in the buffer queue. DQBUF waits on this queue without holding vb_lock to allow a QBUF to happen. Once a buffer has been queued we recheck that the queue is still streaming and wait on the new buffer's waitqueue while holding the vb_lock. The driver should come along in a timely manner and put the buffer into its next state finishing the DQBUF. By implementing this waitqueue it also brings the videobuf DQBUF up to spec and it now blocks on O_NONBLOCK even when no buffers have been queued via QBUF: "By default VIDIOC_DQBUF blocks when no buffer is in the outgoing queue." - V4L2 spec Signed-off-by: Brandon Philips <bphilips@suse.de> CC: Trent Piepho <xyzzy@speakeasy.org> CC: Carl Karsten <carl@personnelware.com> CC: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7376): Improve compile-time type-checking in videobufGuennadi Liakhovetski
Make the dev member of the struct videobuf_queue of type "struct device *" to avoid future problems. Also change the prototype of the videobuf_queue_core_init() function. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7121): Renames videobuf lock to vb_lockMauro Carvalho Chehab
This helps to identify where vb_lock is being used, and find missusages of the locks. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6997): Replace a very dirty hack on videobuf for a clean wait_eventMauro Carvalho Chehab
In order to videobuf_iolock to work, mmap_mapper should be called first. Otherwise, an OOPS is generated. On some cases, .mmap file handler used to took some time to be called. On those situations, mmap_mmapper() were called after iolock. This patch properly waits for mmap_mapper to be called, otherwise generating an error. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6603): V4L: videobuf: convert streaming and reading to bitfieldsBrandon Philips
Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6600): V4L: videobuf: don't chew up namespace STATE_.*, convert to ↵Brandon Philips
VIDEOBUF_ s/STATE_NEEDS_INIT/VIDEOBUF_NEEDS_INIT/g s/STATE_PREPARED/VIDEOBUF_PREPARED/g s/STATE_QUEUED/VIDEOBUF_QUEUED/g s/STATE_ACTIVE/VIDEOBUF_ACTIVE/g s/STATE_DONE/VIDEOBUF_DONE/g s/STATE_ERROR/VIDEOBUF_ERROR/g s/STATE_IDLE/VIDEOBUF_IDLE/g Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-12-11V4L/DVB (6601): V4L: videobuf-core locking fixes and commentsBrandon Philips
- Add comments to functions that require that caller hold q->lock - Add __videobuf_mmap_free that doesn't hold q->lock for use within videobuf - Add locking to videobuf_mmap_free - Fix linux/drivers/media/common/saa7146_video.c which was holding lock around videobuf_read_stop - Add locking to functions that operate on a queue - Add videobuf_stop to take care of stopping in both the read and stream case TODO: bttv still has an unsafe call to videobuf_queue_is_busy Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-13v4l: copy_to_user() is not a good method nameAl Viro
Breaks on any target that has copy_to_user() defined as a non-trivial macro. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10V4L/DVB (6292): videobuf_core init always require callback implementationMauro Carvalho Chehab
In the past, videobuf_queue_init were used to initialize PCI DMA videobuffers. This patch renames it, to avoid confusion with the previous kernel API, doing: s/videobuf_queue_init/void videobuf_queue_core_init/ Also, the operations is now part of the function parameter. The function will also add a test if this is defined, otherwise producing BUG. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6290): remove videobuf_set_pci_opsMauro Carvalho Chehab
Before the videobuf redesign, a procedure for re-using videobuf without PCI scatter/gather where provided by changing the pci-dependent operations by other operations. With the newer approach, those methods are obsolete and can safelly be removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6266): videobuf cleanup: mmap check is common to all videobuf. Make ↵Mauro Carvalho Chehab
it at core Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
2007-10-09V4L/DVB (6251): Replace video-buf to a more generic approachMauro Carvalho Chehab
video-buf currently does two different tasks: - Manages video buffers with a common code that allows implementing all the V4L2 different modes of buffering; - Controls memory allocations While the first task is generic, the second were written to support PCI DMA Scatter/Gather needs. The original approach can't even work for those video capture hardware that don't support scatter/gather. I did one approach to make it more generic. While the approach worked fine for vivi driver, it were not generic enough to handle USB needs. This patch creates two different modules, one containing the generic video buffer handling (videobuf-core) and another with PCI DMA S/G. After this patch, it would be simpler to write an USB video-buf and a non-SG DMA module. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
