path: root/include/media/videobuf-dvb.h
2011-05-25[media] Add missing include guard to header fileHans Petter Selasky
Signed-off-by: Hans Petter Selasky <hselasky@c2i.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13103): create a standard method for dvb adapter drivers to ↵Michael Krufky
override frontend ioctls Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-21V4L/DVB (9335): videobuf: split unregister bus creating self-contained ↵Darron Broad
frontend de-allocator This creates a self contained frontend de-allocator for the instances where an adapter has not been registered yet frontend de-allocation may be required. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9276): videobuf-dvb: two functions are now staticMauro Carvalho Chehab
This patch marks those two functions as static: static int videobuf_dvb_register_adapter(struct videobuf_dvb_frontends *fe, static int videobuf_dvb_register_frontend(struct dvb_adapter *adapter, Since MFE patches changed their calls by videobuf_dvb_register_bus. To avoid having to declare the prototypes, the patch moves videobuf_dvb_register_bus() to be after the declaration of the above functions used there. Cc: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9271): videobuf: data storage optimisation (2)Darron Broad
To optimise data storage even further one other redundant var has been removed. This also removes a redundant assignment. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9265): videobuf: data storage optimisationDarron Broad
To optimise data storage redundant vars are removed. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9227): MFE: Add multi-frontend mutual exclusionDarron Broad
This add frontend R/W mutual exclusion. Prior to this point in time it was possible to open both frontends simultaneously which an MFE card cannot support. In order to stop this, a delayed open is performed which has the following function: - Return EBUSY after a configurable amount of time if a frontend is unavailable due to the other being in use. - Only allow opening of a frontend if the kernel thread of the other has stopped. This solution was chosen to allow switching between frontends to work as seamlessly as possible. When both frontends are actually opened simultaneously then one will only open, but if quick switching is performed between one of many then the new open will succeed in a clean fashion rather than interrupting a kernel thread. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9225): MFE: Add configurable gate controlDarron Broad
This adds a configurable (one per card) gate control option for multi-frontend. Prior to this point gate control was assumed to be on the primary frontend, this is a fault when the gate to the analogue section is on the secondary which is the default for both the HVR-3000 and HVR-4000 in MFE. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9222): S2API: Add Multiple-frontend on a single adapter support.Steven Toth
A detailed description from the original patches 2 years ago: "The WinTV-HVR3000 has a single transport bus which is shared between a DVB-T and DVB-S modulator. These patches build on the bus acquisition cx88 work from a few weeks ago to add support for this. So to applications the HVR3000 looks like this: /dev/dvb/adapter0/fe0 (cx24123 DVB-S demod) /dev/dvb/adapter0/fe1 (cx22702 DVB-T demod) Additional boards continue as before, eg: /dev/dvb/adapter1/fe0 (lgdt3302 ATSC demod) The basic change is removing the single instance of the videobuf_dvb in cx8802_dev and saa7134_dev(?) and replacing it with a list and some supporting functions. *NOTE* This branch was taken before v4l-dvb was closed for 2.6.19 so two or three current cx88 patches appear to be reversed by this tree, this will be cleaned up in the near future. The patches missing change the mutex handing to core->lock, fix an enumeration problem." It should be recognised that a number of people have been maintaining this patchset. Significant levels of Kudos to everyone one involved, including but not limited to: Darron Broad Fabio M. Di Nitto Carlo Scarfoglio Hans Werner Without the work of these people, and countless others, my two year old patches would of died on the Mercurial linuxtv.org vine a long time ago. TODO: Revise these patches a little further so that the need for demux1 and dvr0 is optional, not mandatory on the HVR3000. HISTORY (darron): This is the last update to MFE prepared by Hans which is based upon the `scratchpad' diff created by Carlo. All MFE work prior to that point must be attributed to Fabio who ported and maintained Steve's original patch up to that time. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6257): Rename video-buf-dvb to videobuf-dvb to be consistent with ↵Mauro Carvalho Chehab
the other patches Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
