path: root/include/media/wm8775.h
2011-03-21[media] Add proper audio support for Nova-S Plus with wm8775 ADCLawrence Rust
This patch adds audio DMA capture and ALSA mixer elements for the line input jack of the Hauppauge Nova-S-plus DVB-S PCI card. The Nova-S-plus has a WM8775 ADC that is currently not detected. This patch enables this chip and exports volume, balance mute and ALC elements for ALSA mixer controls. [mchehab@redhat.com: Changed the patch to only talk with wm8775 if board info says so. Also, added platform_data support, to avoid changing the behaviour for other boards, and fixed CodingStyle] [awalls@md.metrocast.net: Changed patch to make the WM8775_GID defintion bridge driver private and let the bridge driver set the value of v4l2_subdev.grp_id.] -- To unsubscribe from this list: send the line "unsubscribe linux-media" in the body of a message to majordomo@vger.kernel.org More majordomo info at http://vger.kernel.org/majordomo-info.html Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net>
2011-01-03[media] wm8775: Revert changeset fcb9757333 to avoid a regressionMauro Carvalho Chehab
It seems that cx88 and ivtv use wm8775 on some different modes. The patch that added support for a board with wm8775 broke ivtv boards with this device. As we're too close to release 2.6.37, let's just revert it. Reported-by: Andy Walls <awalls@md.metrocast.net> Reported-by: Eric Sharkey <eric@lisaneric.org> Reported-by: Auric <auric@aanet.com.au> Reported by: David Gesswein <djg@pdp8online.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-23[media] Nova-S-Plus audio line inputlawrence rust
This patch adds audio DMA capture and ALSA mixer elements for the line input jack of the Hauppauge Nova-S-plus DVB-S PCI card. The Nova-S-plus has a WM8775 ADC that is currently not detected. This patch enables this chip and exports volume, balance mute and ALC elements for ALSA mixer controls. [mchehab@redhat.com: Fix CodingStyle issues] Signed-off-by: Lawrence Rust <lawrence@softsystem.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2006-03-24V4L/DVB (3599): Implement new routing commands for wm8775 and cs53l32a.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
