path: root/include/media
2008-06-05V4L/DVB (7911): Remove v4l2_video_std_fps prototype declarationGuennadi Liakhovetski
The v4l2_video_std_fps function has been removed by Adrian Bunk in 2004 but then its prototype re-appeared in include/media/v4l2-dev.h. Remove it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-20Fix a deadlock in the bttv driverArjan van de Ven
vidiocgmbuf() does this: mutex_lock(&fh->cap.vb_lock); retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize, V4L2_MEMORY_MMAP); and videobuf_mmap_setup() then just does mutex_lock(&q->vb_lock); ret = __videobuf_mmap_setup(q, bcount, bsize, memory); mutex_unlock(&q->vb_lock); which is an obvious double-take deadlock. This patch fixes this by having vidiocgmbuf() just call the __videobuf_mmap_setup function instead. Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Reported-by: Koos Vriezen <koos.vriezen@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-11i2c: Convert some more new-style drivers to use module aliasingJean Delvare
Update 3 more new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. These video drivers aren't used yet so converting them is trivial. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (28 commits) V4L-DVB(7789a): cx18: fix symbol conflict with ivtv driver V4L/DVB (7789): tuner: remove static dependencies on analog tuner sub-modules V4L/DVB (7785): [2.6 patch] make mt9{m001,v022}_controls[] static V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chip V4L/DVB (7783): drivers/media/dvb/frontends/s5h1420.c: printk fix V4L/DVB (7782): pvrusb2: Driver is no longer experimental V4L/DVB (7781): pvrusb2-dvb: include dvb support by default and update Kconfig help text V4L/DVB (7780): pvrusb2: always enable support for OnAir Creator / HDTV USB2 V4L/DVB (7779): pvrusb2-dvb: quiet down noise in kernel log for feed debug Rename common tuner Kconfig names to use the same Fix V4L/DVB core help messages V4L/DVB (7769): Move other terrestrial tuners to common/tuners V4L/DVB (7768): reorganize some DVB-S Kconfig items V4L/DVB(7767): Move tuners to common/tuners V4L/DVB (7766): saa7134: add another PCI ID for Beholder M6 V4L/DVB (7765): Add support for Beholder BeholdTV H6 V4L/DVB (7763): ivtv: add tuner support for the AverMedia M116 V4L/DVB (7762): ivtv: fix tuner detection for PAL-N/Nc V4L/DVB (7761): ivtv: increase the DMA timeout from 100 to 300 ms V4L/DVB (7759): ivtv: increase version number to 1.2.1 ...
2008-04-29V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chipHans Verkuil
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from Conexant for their support. I am in particular thankful to Hauppauge since without their help this driver would not exist. It should also be noted that Steve did the work to get the DVB part up and running. Thank you! Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: G. Andrew Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-24V4L/DVB (7677): saa7134: Add/fix Beholder entriesDmitry Belimov
Beholder TV/FM tuners: Changes: Add support Beholder Columbus PCMCIA card. Add key map for remote control of Beholder Columbus PCMCIA card. Fix gpiomask for all Beholder tuners. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7665): videodev: Add default vidioc handlerDouglas Schilling Landgraf
Added default vidioc handler for other private ioctls Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7566): videobuf-dvb: allow its usage with videobuf-vmallocMauro Carvalho Chehab
videobuf-dvb were still using a function that were videobuf-dma-sg dependent. This patch creates a generic handler for this function. This way, videobuf-dvb can now work with all videobuf implementations. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7554): videobuf-dma-sg: Remove unused flagMauro Carvalho Chehab
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7506): Powercolor Real Angel 330 (remote control support)Dâniel Fraga
The attached patch adds complete remote control support for Powercolor Real Angel 330. Signed-off-by: Daniel Fraga <fragabr@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7501): soc-camera: use a spinlock for videobuffer queueGuennadi Liakhovetski
All drivers should provide a spinlock to be used in videobuf operations. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Reviewed-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7500): soc-camera: extract function pointers from host object into ↵Guennadi Liakhovetski
operations Function pointers and the driver owner are not expected to change throughout soc-camera host's life. Extract them into an operations struct. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7493): videobuf: Avoid deadlock with QBUF and bring up to spec for ↵Brandon Philips
empty queue Add a waitqueue to wait on when there are no buffers in the buffer queue. DQBUF waits on this queue without holding vb_lock to allow a QBUF to happen. Once a buffer has been queued we recheck that the queue is still streaming and wait on the new buffer's waitqueue while holding the vb_lock. The driver should come along in a timely manner and put the buffer into its next state finishing the DQBUF. By implementing this waitqueue it also brings the videobuf DQBUF up to spec and it now blocks on O_NONBLOCK even when no buffers have been queued via QBUF: "By default VIDIOC_DQBUF blocks when no buffer is in the outgoing queue." - V4L2 spec Signed-off-by: Brandon Philips <bphilips@suse.de> CC: Trent Piepho <xyzzy@speakeasy.org> CC: Carl Karsten <carl@personnelware.com> CC: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7406): soc-camera: improve separation between soc_camera_ops and ↵Guennadi Liakhovetski
soc_camera_device In case of muliple cameras, handled by the same driver, they can support Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7381): tuner: rename TUNER_PHILIPS_ATSC to TUNER_PHILIPS_FCV1236DMichael Krufky
TUNER_PHILIPS_ATSC is an ambiguous name for a tuner. Rename it to TUNER_PHILIPS_FCV1236D to be more descriptive. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7376): Improve compile-time type-checking in videobufGuennadi Liakhovetski
Make the dev member of the struct videobuf_queue of type "struct device *" to avoid future problems. Also change the prototype of the videobuf_queue_core_init() function. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7372): cx88: Add IR support for Pixelview MPEG 8000GTMauro Carvalho Chehab
2008-04-24V4L/DVB (7352): tuner-simple: enable digital tuning support for Philips ↵Michael Krufky
FMD1216ME Enable digital tuning support within tuner-simple. This will allow for a single tuner module to manage the hardware, without having dvb-pll loaded. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7351): tuner-simple: add init and sleep methodsMichael Krufky
taken from dvb-pll Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7347): tuner-simple: add basic support for digital tuning of hybrid ↵Michael Krufky
devices Add entry points used for digital tuning via the dvb_frontend. Share state data between multiple instances of the driver for hybrid tuners. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7336): soc-camera: streamline hardware parameter negotiationGuennadi Liakhovetski
Improve hardware parameter negotiation between the camera host driver and camera drivers. Parameters like horizontal and vertical synchronisation, pixel clock polarity shall be set depending on capabilities of the parties. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7276): soc-camera: deactivate cameras when not usedGuennadi Liakhovetski
Only attach cameras to the host interface for probing, then detach until open. This allows platforms with several cameras on an interface, physically supporting only one camera, to handle multiple cameras and activate them selectively after initial probing. The first attach during probe is needed to activate the host interface to be able to physically communicate with cameras. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7237): Convert videobuf-dma-sg to generic DMA APIGuennadi Liakhovetski
videobuf-dma-sg does not need to depend on PCI. Switch it to using generic DMA API, convert all affected drivers, relax Kconfig restriction, improve compile-time type checking, fix some Coding Style violations while at it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7170): soc_camera V4L2 driver for directly-connected SoC-based camerasGuennadi Liakhovetski
This driver provides an interface between platform-specific camera busses and camera devices. It should be used if the camera is connected not over a "proper" bus like PCI or USB, but over a special bus, like, for example, the Quick Capture interface on PXA270 SoCs. Later it should also be used for i.MX31 SoCs from Freescale. It can handle multiple cameras and / or multiple busses, which can be used, e.g., in stereo-vision applications. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7169): Add chip IDs for Micron mt9m001 and mt9v022 CMOS camerasGuennadi Liakhovetski
Add V4L2_IDENT chip IDs for mt9m001 and mt9v022 cameras, will be used by future patches, primarily to implement the g_chip_ident ioctl. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7192): Adds support for Genius TVGo A11MCEAdrian Pardini
Signed-off-by: Adrian Pardini <pardo.bsso@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7150): [v4l] convert videbuf_vmalloc_memory to videobuf_vmalloc_memoryBrandon Philips
Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7121): Renames videobuf lock to vb_lockMauro Carvalho Chehab
This helps to identify where vb_lock is being used, and find missusages of the locks. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7133): Fix Kconfig dependenciesMauro Carvalho Chehab
As pointed by Adrian Bunk, with I2C=m and VIDEO_DEV=y, videodev brokes. This patch moves the functions that videodev needs from v4l2-common. It also fixes some Kconfig changes. After this patch, I2C=m / VIDEO_DEV=y will make v4l2 core statically linked into kernel. v4l2-common will be m, and all V4L drivers will also be m. This approach is very conservative, since it is possible to have V4L drivers that don't need I2C or v4l2-common. The better is to map what drivers really need v4l2-common, making them to select v4l2-common, and allowing the others to be 'y', 'm' and 'n'. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-03include/media/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-27i2c: Constify client address dataMark M. Hoffman
This patch allows much of the I2C client address data to move from initdata into text. Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-25V4L/DVB (7058): IR corrections for the Pinnacle 800iSteven Toth
IR corrections for the Pinnacle 800i Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7042): xc5000: Tuner analog supportSteven Toth
From Zhang: This an updated patch that adds analog support for the xc5000 tuner driver. it was tested on a Pinnacle PCTV HD 800i card (patches to follow). Patch commited as-is, cleanup to follow ... Steve. Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7002): cx25840: Add basic CX23885 AVCore supportSteven Toth
The cx23885/7/8 PCIe bridge has an internal AVCore modelled on the cx2584x family. Many of the registers positions are identical but some moved. The register values are also different because the different bridges run at different clock rates. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6997): Replace a very dirty hack on videobuf for a clean wait_eventMauro Carvalho Chehab
In order to videobuf_iolock to work, mmap_mapper should be called first. Otherwise, an OOPS is generated. On some cases, .mmap file handler used to took some time to be called. On those situations, mmap_mmapper() were called after iolock. This patch properly waits for mmap_mapper to be called, otherwise generating an error. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6973): Add Beholder TV 401/405/407/409/505/507/609/M6 supportAndrey J. Melnikoff (TEMHOTA)
This patch updates cardlist for Beholder TV tuners: old models (with GPIO ir) 401, 403, 405, 407, 409, 505, 507 and add support for 607, 609, M6 cards with new i2c-ir. Signed-off-by: Igor Kuznetsov <igk72@yandex.ru> Signed-off-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6921): include/media/v4l2-i2c-drv.h must #include <media/v4l2-common.h>Michael Krufky
Fix the following compiler error: v4l2-i2c-drv.h:72: error: implicit declaration of function 'v4l2_i2c_attach' Also, prevent multiple inclusions of v4l2-i2c-drv.h Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6869): cs5345: new i2c driverHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6861): cx2341x: command argument should be u32 instead of intHans Verkuil
2008-01-25V4L/DVB (6785): tda8290: remove dependency on struct tunerMichael Krufky
- remove dependency of tda8290 module on struct tuner - move tuner_foo printk macros from tuner-driver.h into tuner-core.c - clean up #includes of tuner-i2c.h / tuner-driver.h Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6766): ivtv: remove i2c legacy support from drivers that no longer ↵Hans Verkuil
need it Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6603): V4L: videobuf: convert streaming and reading to bitfieldsBrandon Philips
2008-01-25V4L/DVB (6600): V4L: videobuf: don't chew up namespace STATE_.*, convert to ↵Brandon Philips
VIDEOBUF_ s/STATE_NEEDS_INIT/VIDEOBUF_NEEDS_INIT/g s/STATE_PREPARED/VIDEOBUF_PREPARED/g s/STATE_QUEUED/VIDEOBUF_QUEUED/g s/STATE_ACTIVE/VIDEOBUF_ACTIVE/g s/STATE_DONE/VIDEOBUF_DONE/g s/STATE_ERROR/VIDEOBUF_ERROR/g s/STATE_IDLE/VIDEOBUF_IDLE/g Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6580): Set slave's master before master's attach call.Sakari Ailus
V4L: Int if: Set slave's master before attach, remove master argument The master also now gets its own pointer from slave's structure. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6574): common/ir-functions.c: make a function staticAdrian Bunk
ir_rc5_decode() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6496): saa7146_vv.h: remove wrong include <linux/videodev.h>Marco Schluessler
remove wrong include <linux/videodev.h> Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6486): m52790: add new Mitsubishi A/V switch i2c driverHans Verkuil
This driver is used by the ASUS Falcon2 cx23416-based cards. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6469): tuner: remove TUNER_PHILIPS_TDA8295Michael Krufky
TUNER_PHILIPS_TDA8290 will autodetect a TDA8290 or a TDA8295, so we don't need this separate entry anymore. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
