Check a few input params to make sure there is
no potential for a heap overflow in the driver.
(Back ported from Nexus N9 project)
Bug 1757475 (nvidia)
Bug 1832830 (nvidia)
Bug 28193342 (google)
Change-Id: I979fa38c5f453cfad7070f0340ec04adde5bac13
Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com>
Reviewed-on: http://git-master/r/1271369
GVS: Gerrit_Virtual_Submit
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Several places in the camera stack can hit integer overflows or cause
bad allocations if userspace passes in a bogus sizeofvalue parameter.
Protect against this by using appropriately-sized integer types, adding
range checks, replacing array-allocation calls with kcalloc(), and
checking for allocations returning ZERO_SIZE_PTR.
For one specific ioctl (PCLLK_IOCTL_UPDATE) sizeofvalue = 0 is fine,
since when that happens the subdrivers won't actually touch the returned
allocation. In fact the existing userspace camera driver makes calls
like these and expects them to succeed! Handle this special case by
adding a __camera_get_params variant that optionally treats zero-sized
inputs as valid.
(back ported from Nexus N9 project)
Bug 1832830
Change-Id: Ie3250d8a4b814de5820fa0190b4cbd1af3ca4b3f
Reported-by: Jianqiang Zhao <zhaojianqiang1@gmail.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Reviewed-on: http://git-master/r/1271367
We need to validate power on/off function size passed
in from user mode in order to avoid integer overflow
or out of memory failures.
Bug 1745100
Change-Id: Idddd848f7dc1e864559ad219f9204325128484e5
Signed-off-by: Frank Chen <frankc@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1114354
(cherry picked from commit 8b3afcc132882f3102083f9a24de7f55476ca59b)
Reviewed-on: http://git-master/r/1150944
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Bug 200044433
Change-Id: I792062649c247229270678a44d10323d2744b569
Signed-off-by: Kassey Li <kasseyl@nvidia.com>
Reviewed-on: http://git-master/r/721561
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Bug 1598204
Change-Id: I453d18ce570e57c0feab8dc3b24cc2c957b95301
Signed-off-by: Ming Wong <miwong@nvidia.com>
Reviewed-on: http://git-master/r/672147
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Bug 1600299
Change-Id: I63f4d597bcc8b960407a7291fde6aa2ddb5bec25
Reviewed-on: http://git-master/r/674099
Change-Id: I1c00d571e294ccf1c4d795bb90e71defd3395293
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/591333
(cherry picked from commit b87d110ddc52048944862fb8bf019922333b1dd5)
Reviewed-on: http://git-master/r/665999
Tested-by: Winnie Hsu <whsu@nvidia.com>
Bug 1552628
Bug 1576621
Change-Id: Icc881724f0e4e5c0346aa44ffeb80dc8d498919c
Reviewed-on: http://git-master/r/598929
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
add support for dual ar0330
Bug 1552628
Change-Id: I6ccd6ea0886f17710de3e241c408788cc608dce9
Reviewed-on: http://git-master/r/558147
add regulator vana for dw9718
Bug 1259310
Change-Id: I654669b1f02af9b7afbf51e8077a4f8324ead403
Signed-off-by: Shreshtha Sahu <ssahu@nvidia.com>
Signed-off-by: Mihir Thakkar <mthakkar@nvidia.com>
Reviewed-on: http://git-master/r/555460
Tested-by: Tushar Khinvasara <tkhinvasara@nvidia.com>
Sony IMX135 camera sensor can be found on Ardbeg/Laguna. This patch
introduced sensor driver for imx135 using soc_camera interface.
Bug 1380143
Change-Id: Ifa0becf1ec2d9931ebf9ea3a4e9ea3e1013a9e36
Reviewed-on: http://git-master/r/337469
(cherry picked from commit 94a04c2c9b614519aab6f718d60bcf1d8032aa8f)
Reviewed-on: http://git-master/r/498935
Since the user space code may works in either 32 or 64 bit mode,
attentions should be taken while passing pointers from user space to
the kernel. In this case, the p_value of struct nvc_param and
power_on/power_off of struct virtual_device received from the user
space should be handled properly.
The solution is to create a set of 32 bit version of structures
nvc_param and virtual_device along with some dedicated 32 bit mode
ioctl commands, then in the ioctl functions, the 32 bit user mode
access will be handled separately.
bug 1518359
Change-Id: I4cbbeeaef446ab962aaa1f92251ce1fd9d5723aa
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/437390
(cherry picked from commit 3fdbc210fc9f33d0f89af079a89bdb1f41e73ecb)
Reviewed-on: http://git-master/r/482230
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
- display notice, for auto detect showing the begin of auto-detect.
- add read-in-write feature, camera_dev_wr_table can read device
while parsing scripts.
- return error state in table write.
- camera_app_remove will not throw out warnings when shutdown.
- code optimization, add camera_get_params to replace duplicated code.
bug 1472043
Change-Id: I9ee683bade00ea738a1c8edc282c40ad30d57c7f
Reviewed-on: http://git-master/r/394834
Reviewed-by: Gary Fitzer <gfitzer@nvidia.com>
Reviewed-by: David Wang (SW-TEGRA) <davidw@nvidia.com>
device tree platfom data support.
interface to read device tree from user space.
bug 1455100
Change-Id: I25b6b7b03bc25195c25d7014f91ca761caeb635f
Reviewed-on: http://git-master/r/381103
Read imx135 EEPROM and return it
as factory data.
Tested with an imx135 camera module
with EEPROM burnt with factory data.
Bug 1163086
Change-Id: I2f8eeb36d4bb1bad505b8505d074391bff87b4aa
Signed-off-by: Hu He <hhe@nvidia.com>
Reviewed-on: http://git-master/r/367987
Tested-by: Sachin Nikam <snikam@nvidia.com>
Update OV5693 driver to support multiple
OV5693 in the same system.
Bug 1465726
Change-Id: Ic23ddbaf80068142e8354f313b76c17a9b2a3b7f
Reviewed-on: http://git-master/r/379242
Reviewed-by: Philip Breczinski <pbreczinski@nvidia.com>
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Mitch Luban <mluban@nvidia.com>
Switch focuser position writes to a synchronize mechanism
with isp frame triggers to improve auto focusing algorithms.
Bug 1441127.
Change-Id: I323e997aed6412b5b4719a16727d1d14c9d29adc
Signed-off-by: Gary Fitzer <gfitzer@nvidia.com>
Reviewed-on: http://git-master/r/374485
Appropriate GPLv2 license is updated.
Bug 1458628
Change-Id: If6c8377b02a36bbbba5f2107e4c10103c74791e5
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/369253
(cherry picked from commit c0d9741fb5da323c9d5fd190cd2a253abfb2e748)
Reviewed-on: http://git-master/r/369800
Tested-by: Mitch Luban <mluban@nvidia.com>
Added new ioctl and function for setting minimum
frame rate for soc1040. This allows change between
fixed and variable framerate.
Bug 1435570
Change-Id: I133874aa68f6ea374fdef8d13cee709ef7aaec20
Signed-off-by: David Wang <davidw@nvidia.com>
Reviewed-on: http://git-master/r/366408
a new edp framework has been impemented, so the old edp supports
need to be removed.
support for new framework will be implemeted next.
bug 1431977
Change-Id: I78957a3b2979919b9222e0c2b26426b2c2431bb6
Reviewed-on: http://git-master/r/358837
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
* Make structures 8 byte aligned.
* Remove pointers
* user _IOC_NR for ioctl
Bug 1408557
Change-Id: I7b4d53f0d7316dd5abe2b9546fe34c8ba45295f2
Signed-off-by: Rakesh Sharma <rasharma@nvidia.com>
Reviewed-on: http://git-master/r/350665
(cherry picked from commit f93bd46c9c7630da77dfd30d93ee836464f03582)
Reviewed-on: http://git-master/r/358025
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Fix compilation errors for 64-bit kernel
Bug 1423785
Change-Id: If9591732327775b310ef4bed333859bda9f9b140
Reviewed-on: http://git-master/r/345863
(cherry picked from commit 50103d95ad194f619b4b7dd3b4838e4b0e30e412)
Reviewed-on: http://git-master/r/358013
In case of 64 bit kernel and 32 bit odm code
int will create problem.
Bug 1408558
Change-Id: I1a7e7e60838a9680d1bf6ff23f218b112b18022b
Reviewed-on: http://git-master/r/345742
(cherry picked from commit 8dcb181367b4d6d0648551563e127519f9844072)
Reviewed-on: http://git-master/r/358010
bug 1415077
Change-Id: I98ea518ea8de07b2cd78066522c039dadee379bd
Reviewed-on: http://git-master/r/354372
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Ensures ad5823 is powered on when position is written
by temporarily powering on sensor when a position wr
ioctl is received. Mimics ad5816 driver.
Bug 1439565
Change-Id: I168e187f2b72281c956bdc51f5e590dee01e0c68
Signed-off-by: Phil Breczinski <pbreczinski@nvidia.com>
Reviewed-on: http://git-master/r/355231
Revised system edp software framework has been put in place. This
patch removes old system edp client code from imx091, imx132, and
imx179 drivers.
Bug 1431977
Change-Id: I7eb2179fb69802f85e5098aea304635ff2183e64
Signed-off-by: Timo Alho <talho@nvidia.com>
Reviewed-on: http://git-master/r/350412
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Revert "drivers: media: tegra: edp support"
This reverts commit b9145b25074db3ca964b8f28eaedb36b45a0b1b4.
patch removes the old system EDP client code from imx135 and ar0261
camera sensor drivers.
Bug 1431977
Change-Id: I2276878ec69c8ab67f03e8ef2d857ebd4790252e
Reviewed-on: http://git-master/r/350411
This reverts commit bdd27016ab662a70e85245631a3a89b74f1fe664.
patch removes the old system EDP client code from ov5693 and mt9m114
camera sensors.
Bug 1431977
Change-Id: Iedb6807cadfc7d57b3724c398a345cce14867212
Reviewed-on: http://git-master/r/350410
patch removes old system edp client code from as364x, lm3565,
max77387, and max77665 flash drivers.
Bug 1431977
Change-Id: I7bbe058ce5ffd1e6e44a0cef9f5d09879c46d379
Reviewed-on: http://git-master/r/350406
Reviewed-by: Charlie Huang <chahuang@nvidia.com>
Bug 1415077
Change-Id: I34f8969a726e9c069fbf239352c952a8e68fb2ff
Reviewed-on: http://git-master/r/347764
This change is for modifying the copyright/license header from
BSD2.0 to GPLv2 for few board files.
Change-Id: I1b4f624cdceb75654f81177d17ddcc8e0c4508b8
Signed-off-by: Tejas Sonchhatra <tmanoj@nvidia.com>
Reviewed-on: http://git-master/r/345756
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Add EV compensation and manual white balance modes
for SOC1040 YUV sensor
Bug 1403900
Change-Id: I6172eac2103ada434b123e814ec8114d7a7f8146
Reviewed-on: http://git-master/r/343944
to make them compatible with the Linux kernel licensing.
bug 1406088
Change-Id: I33a3f3995d1fe256e662236b0e33b59a4fa024be
Reviewed-on: http://git-master/r/332586
Switch the register writes for coarse time, coarse time
short, and frame length to 16bit register writes. This fixes
missing byte in coarse time and frame length writes during
set modoe.
Bug 1399950
Change-Id: Ied14fc12c480f0c0ff640779848ae6f7bf993a40
Reviewed-on: http://git-master/r/327942
Add EEPROM read/write support for OV5693.
Bug 1390863
Change-Id: I01198c27f56bef953b33598f7866a26123c910de
Reviewed-on: http://git-master/r/326313
Reconstruct the driver for Tegra V4L2 camera driver:
- remove old driver file tegra_v4l2_camera.c
- create driver file vi.c for VI/CSI (T20/T30/T114/T148)
- create driver file vi2.c for VI2/CSI2 (T124)
Bug 1377330
Change-Id: If030cf98e700b9201caa60328be822bc10610e74
Reviewed-on: http://git-master/r/289329
Reviewed-by: Allen Martin <amartin@nvidia.com>
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
Adding the following features to ov7695 YUV sensor
- EV Compensation(-2, -1, 0, +1, +2)
- White Balance Modes (Auto, Cloudy, Daylight,
Fluoresent, Incandescent)
Bug 1327952
Change-Id: Ib0d326daa31aad8bd77e884501a302666c1af0d5
Reviewed-on: http://git-master/r/302538
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Added edp support on ar0261 and imx135
bug 1358215
Change-Id: I9930865d438be7e672435fc792d5c0f1daf70ea0
Reviewed-on: http://git-master/r/301404
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
on ov5693 and mt9m114 (SOC1040)
bug 1391722
bug 1391719
Change-Id: Ic0830ea803cf8a50e8ef94d3c0c1393d0a29da10
Reviewed-on: http://git-master/r/302932
.priv field is used by Tegra V4L2 SoC camera driver, so introduce
a new field named .dev_priv.
Bug 1377330
Change-Id: Id714dca05d7640175b3dc25f7ce582d76abbcaf4
Reviewed-on: http://git-master/r/289328
Update the ov5693 driver to reflect changes made during
tegranote development on serperate branch.
Fixing the following issues:
- Sluggish preview
- Pink preview in video mode
Bug 1373309
Bug 1367317
Change-Id: Ic0de85a6b783678cebfc328e38cf84c30e6bf316
Reviewed-on: http://git-master/r/298692
This is to bring the ad5823 focuser driver to
the same state of TegraNote ad5823 driver.
This should solve the focuser timeout issue.
Bug 1371717
Change-Id: I33ea762f489f38e92a024bb3c49596c96a88606b
Reviewed-on: http://git-master/r/282828
Tested-by: David Wang (SW-TEGRA) <davidw@nvidia.com>
adding HDR support code for front camera
sensor ar0261.
Bug 1330898
Change-Id: I455d8d9fc8b529ea0bd35ce4538932fd48b6882a
Reviewed-on: http://git-master/r/299108
Update ov5693's fuse ID read ioctl handling to match
the standard.
Bug 1369367
Change-Id: I600bd459ca4c8315b4f2bfe243a3e36e5ffc8aa7
(cherry picked from commit 84654e65576d0c9d735d889959786c8883678689)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Bug 1313737
Bug 1350300
Change-Id: I95bae7eb04bf73b998b4333a1707967b3417ddb2
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: http://git-master/r/275073
Reviewed-by: Adam Jiang <chaoj@nvidia.com>
change some dev_err to dev_notice to avoid LNX error filter alarm.
synchronize cam_device_layout with odm imager as well as update
debugfs prints.
change the regulator names of imx132 and ov5693 to avoid name conflict
with other sensors.
bug 1339839
Change-Id: I134b8b10d5df965bffa8ac0333a0c3775cf882a5
Reviewed-on: http://git-master/r/259810
(cherry picked from commit 89f7b0768a509fc70e78457c6352ef13f874988f)
Reviewed-on: http://git-master/r/272739
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Add SOC1040 (mt9m114) YUV sensor driver
Bug 1327952
Change-Id: I91fc5ac9cbb7b537bdb6f31684d99725689a61a3
Reviewed-on: http://git-master/r/274669
Reviewed-by: Jean Huang <jeanh@nvidia.com>
Reviewed-by: Hu He <hhe@nvidia.com>
commit a19dec6ea94c036af68c31930c1c92681f55af41 upstream.
This patch fixes following error:
include/media/v4l2-ctrls.h:193:15: error: field ‘_lock’ has incomplete type
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_lock’:
include/media/v4l2-ctrls.h:570:2: error: implicit declaration of
function ‘mutex_lock’ [-Werror=implicit-function-declaration]
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_unlock’:
include/media/v4l2-ctrls.h:579:2: error: implicit declaration of
function ‘mutex_unlock’ [-Werror=implicit-function-declaration]
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Adds support for reading fuse ids for IMX132 sensor.
Bug 1307361
Change-Id: I7b750a91d3ead5fac383e85df013b78d7fe4c6a2
Reviewed-on: http://git-master/r/254573
(cherry picked from commit 77b2dc05d8d051659140343531d9ce34e01efeea)
Reviewed-on: http://git-master/r/272670
