Signed-off-by: Jim Garlick <garlick@llnl.gov>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Some of the flags are OS/arch dependent we add a 9p
protocol value which maps to asm-generic/fcntl.h values in Linux
Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
unlinkat - Remove a directory entry
size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4]
size[4] Runlinkat tag[2]
older Tremove have the below request format
size[4] Tremove tag[2] fid[4]
The remove message is used to remove a directory entry either file or directory
The remove opreation is actually a directory opertation and should ideally have
dirfid, if not we cannot represent the fid on server with anything other than
name. We will have to derive the directory name from fid in the Tremove request.
NOTE: The operation doesn't clunk the unlink fid.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
renameat - change name of file or directory
size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s]
size[4] Rrenameat tag[2]
older Trename have the below request format
size[4] Trename tag[2] fid[4] newdirfid[4] name[s]
The rename message is used to change the name of a file, possibly moving it
to a new directory. The rename opreation is actually a directory opertation
and should ideally have olddirfid, if not we cannot represent the fid on server
with anything other than name. We will have to derive the old directory name
from fid in the Trename request.
Switch to generic kernel hexdump library and cleanup macros to
be more consistent with the way we do normal debug prints.
There are two small cleanups in this patch:
- p9_errstr2errno was declared twice - remove one declaration.
- A uint8_t type was mixed in, change it to u8 to match
with the rest of the type names and remove dependency.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Typo fixes and minor cleanups for v9fs
Signed-off-by: Rob Landley <rob@landley.net>
Reviewed-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com>
Now that we use write_inode to flush server
cache related to fid, we don't need tsyncfs either fort dotl or dotu
protocols. For dotu this helps to do a more efficient server flush.
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
If a transport prefers payload to be sent separate from the PDU
(P9_TRANS_PREF_PAYLOAD_SEP), there is no need to allocate msize
PDU buffers(struct p9_fcall).
This patch allocates only upto 4k buffers for this kind of transports
and there won't be any change to the legacy transports.
Hence, this patch on top of zero copy changes allows user to
specify higher msizes through the mount option
without hogging the kernel heap.
This patch prepares p9_fcall structure for zero copy. Added
fields send the payload buffer information to the transport layer.
In addition it adds a 'private' field for the transport layer to
store mapped/pinned page information so that it can be freed/unpinned
during req_done.
This patch also creates trans_common.[ch] to house helper functions.
It adds the following helper functions.
p9_release_req_pages - Release pages after the transaction.
p9_nr_pages - Return number of pages needed to accomodate the payload.
payload_gup - Translates user buffer into kernel pages.
Synopsis
size[4] TReadlink tag[2] fid[4]
size[4] RReadlink tag[2] target[s]
Description
Readlink is used to return the contents of the symoblic link
referred by fid. Contents of symboic link is returned as a
response.
target[s] - Contents of the symbolic link referred by fid.
Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Synopsis
size[4] TGetlock tag[2] fid[4] getlock[n]
size[4] RGetlock tag[2] getlock[n]
Description
TGetlock is used to test for the existence of byte range posix locks on a file
identified by given fid. The reply contains getlock structure. If the lock could
be placed it returns F_UNLCK in type field of getlock structure. Otherwise it
returns the details of the conflicting locks in the getlock structure
getlock structure:
type[1] - Type of lock: F_RDLCK, F_WRLCK
start[8] - Starting offset for lock
length[8] - Number of bytes to check for the lock
If length is 0, check for lock in all bytes starting at the location
'start' through to the end of file
pid[4] - PID of the process that wants to take lock/owns the task
in case of reply
client[4] - Client id of the system that owns the process which
has the conflicting lock
Synopsis
size[4] TLock tag[2] fid[4] flock[n]
size[4] RLock tag[2] status[1]
Description
Tlock is used to acquire/release byte range posix locks on a file
identified by given fid. The reply contains status of the lock request
flock structure:
type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK
flags[4] - Flags could be either of
P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a
conflicting lock exists, wait for that lock to be released.
P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is
trying to reclaim a lock after a server restrart (due to crash)
length[8] - Number of bytes to lock
If length is 0, lock all bytes starting at the location 'start'
client_id[4] - Unique client id
status[1] - Status of the lock request, can be
P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or
P9_LOCK_GRACE(3)
P9_LOCK_SUCCESS - Request was successful
P9_LOCK_BLOCKED - A conflicting lock is held by another process
P9_LOCK_ERROR - Error while processing the lock request
P9_LOCK_GRACE - Server is in grace period, it can't accept new lock
requests in this period (except locks with
P9_LOCK_FLAGS_RECLAIM flag set)
SYNOPSIS
size[4] Tfsync tag[2] fid[4]
size[4] Rfsync tag[2]
DESCRIPTION
The Tfsync transaction transfers ("flushes") all modified in-core data of
file identified by fid to the disk device (or other permanent storage
device) where that file resides.
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com>
TXATTRCREATE: Prepare a fid for setting xattr value on a file system object.
size[4] TXATTRCREATE tag[2] fid[4] name[s] attr_size[8] flags[4]
size[4] RXATTRCREATE tag[2]
txattrcreate gets a fid pointing to xattr. This fid can later be
used to set the xattr value.
flag value is derived from set Linux setxattr. The manpage says
"The flags parameter can be used to refine the semantics of the operation.
XATTR_CREATE specifies a pure create, which fails if the named attribute
exists already. XATTR_REPLACE specifies a pure replace operation, which
fails if the named attribute does not already exist. By default (no flags),
the extended attribute will be created if need be, or will simply replace
the value if the attribute exists."
The actual setxattr operation happens when the fid is clunked. At that point
the written byte count and the attr_size specified in TXATTRCREATE should be
same otherwise an error will be returned.
TXATTRWALK: Descend a ATTR namespace
size[4] TXATTRWALK tag[2] fid[4] newfid[4] name[s]
size[4] RXATTRWALK tag[2] size[8]
txattrwalk gets a fid pointing to xattr. This fid can later be
used to read the xattr value. If name is NULL the fid returned
can be used to get the list of extended attribute associated to
the file system object.
Implement 9p2000.L version of open(LOPEN) interface in 9p client.
For LOPEN, no need to convert the flags to and from 9p mode to VFS mode.
Synopsis:
size[4] Tlopen tag[2] fid[4] mode[4]
size[4] Rlopen tag[2] qid[13] iounit[4]
[Fix mode bit format - jvrao@linux.vnet.ibm.com]
Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
SYNOPSIS
size[4] Tlcreate tag[2] fid[4] name[s] flags[4] mode[4] gid[4]
size[4] Rlcreate tag[2] qid[13] iounit[4]
DESCRIPTION
The Tlreate request asks the file server to create a new regular file with the
name supplied, in the directory (dir) represented by fid.
The mode argument specifies the permissions to use. New file is created with
the uid if the fid and with supplied gid.
The flags argument represent Linux access mode flags with which the caller
is requesting to open the file with. Protocol allows all the Linux access
modes but it is upto the server to allow/disallow any of these acess modes.
If the server doesn't support any of the access mode, it is expected to
return error.
Implement TMKDIR as part of 2000.L Work
Synopsis
size[4] Tmkdir tag[2] fid[4] name[s] mode[4] gid[4]
size[4] Rmkdir tag[2] qid[13]
Description
mkdir asks the file server to create a directory with given name,
mode and gid. The qid for the new directory is returned with
the mkdir reply message.
Note: 72 is selected as the opcode for TMKDIR from the reserved list.
Synopsis
size[4] Tmknod tag[2] fid[4] name[s] mode[4] major[4] minor[4] gid[4]
size[4] Rmknod tag[2] qid[13]
Description
mknod asks the file server to create a device node with given major and
minor number, mode and gid. The qid for the new device node is returned
with the mknod reply message.
[sripathik@in.ibm.com: Fix error handling code]
Create a symbolic link
SYNOPSIS
size[4] Tsymlink tag[2] fid[4] name[s] symtgt[s] gid[4]
size[4] Rsymlink tag[2] qid[13]
DESCRIPTION
Create a symbolic link named 'name' pointing to 'symtgt'.
gid represents the effective group id of the caller.
The permissions of a symbolic link are irrelevant hence it is omitted
from the protocol.
Reviewed-by: Sripathi Kodi <sripathik@in.ibm.com>
This patch adds a helper function to get the dentry from inode and
uses it in creating a Hardlink
SYNOPSIS
size[4] Tlink tag[2] dfid[4] oldfid[4] newpath[s]
size[4] Rlink tag[2]
DESCRIPTION
Create a link 'newpath' in directory pointed by dfid linking to oldfid path.
[sripathik@in.ibm.com : p9_client_link should not free req structure
if p9_client_rpc has returned an error.]
SYNOPSIS
size[4] Tsetattr tag[2] attr[n]
size[4] Rsetattr tag[2]
DESCRIPTION
The setattr command changes some of the file status information.
attr resembles the iattr structure used in Linux kernel. It
specifies which status parameter is to be changed and to what
value. It is laid out as follows:
valid[4]
specifies which status information is to be changed. Possible
values are:
ATTR_MODE (1 << 0)
ATTR_UID (1 << 1)
ATTR_GID (1 << 2)
ATTR_SIZE (1 << 3)
ATTR_ATIME (1 << 4)
ATTR_MTIME (1 << 5)
ATTR_ATIME_SET (1 << 7)
ATTR_MTIME_SET (1 << 8)
The last two bits represent whether the time information
is being sent by the client's user space. In the absense
of these bits the server always uses server's time.
mode[4]
File permission bits
uid[4]
Owner id of file
gid[4]
Group id of the file
size[8]
File size
atime_sec[8]
Time of last file access, seconds
atime_nsec[8]
Time of last file access, nanoseconds
mtime_sec[8]
Time of last file modification, seconds
mtime_nsec[8]
Time of last file modification, nanoseconds
Explanation of the patches:
*) The kernel just copies relevent contents of iattr structure to
p9_iattr_dotl structure and passes it down to the client. The
only check it has is calling inode_change_ok()
*) The p9_iattr_dotl structure does not have ctime and ia_file
parameters because I don't think these are needed in our case.
The client user space can request updating just ctime by calling
chown(fd, -1, -1). This is handled on server side without a need
for putting ctime on the wire.
*) The server currently supports changing mode, time, ownership and
size of the file.
*) 9P RFC says "Either all the changes in wstat request happen, or
none of them does: if the request succeeds, all changes were made;
if it fails, none were."
I have not done anything to implement this specifically because I
don't see a reason.
Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com>
SYNOPSIS
size[4] Tgetattr tag[2] fid[4] request_mask[8]
size[4] Rgetattr tag[2] lstat[n]
DESCRIPTION
The getattr transaction inquires about the file identified by fid.
request_mask is a bit mask that specifies which fields of the
stat structure is the client interested in.
The reply will contain a machine-independent directory entry,
st_result_mask[8]
Bit mask that indicates which fields in the stat structure
have been populated by the server
qid.type[1]
the type of the file (directory, etc.), represented as a bit
vector corresponding to the high 8 bits of the file's mode
word.
qid.vers[4]
version number for given path
qid.path[8]
the file server's unique identification for the file
st_mode[4]
Permission and flags
st_uid[4]
User id of owner
st_gid[4]
Group ID of owner
st_nlink[8]
Number of hard links
st_rdev[8]
Device ID (if special file)
st_size[8]
Size, in bytes
st_blksize[8]
Block size for file system IO
st_blocks[8]
Number of file system blocks allocated
st_atime_sec[8]
Time of last access, seconds
st_atime_nsec[8]
Time of last access, nanoseconds
st_mtime_sec[8]
Time of last modification, seconds
st_mtime_nsec[8]
Time of last modification, nanoseconds
st_ctime_sec[8]
Time of last status change, seconds
st_ctime_nsec[8]
Time of last status change, nanoseconds
st_btime_sec[8]
Time of creation (birth) of file, seconds
st_btime_nsec[8]
Time of creation (birth) of file, nanoseconds
st_gen[8]
Inode generation
st_data_version[8]
Data version number
request_mask and result_mask bit masks contain the following bits
#define P9_STATS_MODE 0x00000001ULL
#define P9_STATS_NLINK 0x00000002ULL
#define P9_STATS_UID 0x00000004ULL
#define P9_STATS_GID 0x00000008ULL
#define P9_STATS_RDEV 0x00000010ULL
#define P9_STATS_ATIME 0x00000020ULL
#define P9_STATS_MTIME 0x00000040ULL
#define P9_STATS_CTIME 0x00000080ULL
#define P9_STATS_INO 0x00000100ULL
#define P9_STATS_SIZE 0x00000200ULL
#define P9_STATS_BLOCKS 0x00000400ULL
#define P9_STATS_BTIME 0x00000800ULL
#define P9_STATS_GEN 0x00001000ULL
#define P9_STATS_DATA_VERSION 0x00002000ULL
#define P9_STATS_BASIC 0x000007ffULL
#define P9_STATS_ALL 0x00003fffULL
This patch implements the client side of getattr implementation for
9P2000.L. It introduces a new structure p9_stat_dotl for getting
Linux stat information along with QID. The data layout is similar to
stat structure in Linux user space with the following major
differences:
inode (st_ino) is not part of data. Instead qid is.
device (st_dev) is not part of data because this doesn't make sense
on the client.
All time variables are 64 bit wide on the wire. The kernel seems to use
32 bit variables for these variables. However, some of the architectures
have used 64 bit variables and glibc exposes 64 bit variables to user
space on some architectures. Hence to be on the safer side we have made
these 64 bit in the protocol. Refer to the comments in
include/asm-generic/stat.h
There are some additional fields: st_btime_sec, st_btime_nsec, st_gen,
st_data_version apart from the bitmask, st_result_mask. The bit mask
is filled by the server to indicate which stat fields have been
populated by the server. Currently there is no clean way for the
server to obtain these additional fields, so it sends back just the
basic fields.
This patch implements the kernel part of readdir() implementation for 9p2000.L
Change from V3: Instead of inode, server now sends qids for each dirent
SYNOPSIS
size[4] Treaddir tag[2] fid[4] offset[8] count[4]
size[4] Rreaddir tag[2] count[4] data[count]
DESCRIPTION
The readdir request asks the server to read the directory specified by 'fid'
at an offset specified by 'offset' and return as many dirent structures as
possible that fit into count bytes. Each dirent structure is laid out as
follows.
qid.type[1]
word.
qid.vers[4]
qid.path[8]
offset[8]
offset into the next dirent.
type[1]
type of this directory entry.
name[256]
name of this directory entry.
This patch adds v9fs_dir_readdir_dotl() as the readdir() call for 9p2000.L.
This function sends P9_TREADDIR command to the server. In response the server
sends a buffer filled with dirent structures. This is different from the
existing v9fs_dir_readdir() call which receives stat structures from the server.
This results in significant speedup of readdir() on large directories.
For example, doing 'ls >/dev/null' on a directory with 10000 files on my
laptop takes 1.088 seconds with the existing code, but only takes 0.339 seconds
with the new readdir.
I made a V2 of this patch on top of my patches for VFS switches.
All the changes were due to change in some offsets.
rename - change name of file or directory
size[4] Rrename tag[2]
to a new directory. The 9P wstat message can only rename a file within the
same directory.
I made a V2 of this patch on top of my patches for VFS switches. The
change was adding v9fs_statfs pointer to v9fs_super_ops_dotl
instead of v9fs_super_ops.
statfs - get file system statistics
size[4] Tstatfs tag[2] fid[4]
size[4] Rstatfs tag[2] type[4] bsize[4] blocks[8] bfree[8] bavail[8]
files[8] ffree[8] fsid[8] namelen[4]
The statfs message is used to request file system information returned
by the statfs(2) system call, which is used by df(1) to report file
system and disk space usage.
This patch adds a persistent, read-only caching facility for
9p clients using the FS-Cache caching backend.
When the fscache facility is enabled, each inode is associated
with a corresponding vcookie which is an index into the FS-Cache
indexing tree. The FS-Cache indexing tree is indexed at 3 levels:
- session object associated with each mount.
- inode/vcookie
- actual data (pages)
A cache tag is chosen randomly for each session. These tags can
be read off /sys/fs/9p/caches and can be passed as a mount-time
parameter to re-attach to the specified caching session.
Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu>
Fixes build problem with 9p when building with debug disabled.
Also contains some fixes for warnings which pop up when
CONFIG_NET_9P_DEBUG is disabled.
The new debug support lacks some of the information that the previous fcprint
code provided -- this patch focuses on better presentation of debug data along
with more helpful debug along error paths.
Remove depricated conv functions which have been replaced with new
protocol routines.
This patch also reworks the one instance of the file-system code which
directly calls conversion routines (to accomplish unpacking dirreads).
Now that the new protocol functions are in place, this patch switches
the client code to using the new support code.
One of the current debug options allows users to get a verbose dump of fcalls.
This isn't really necessary as correctly parsed protocol frames can be printed
as part of the code in the client functions. The consolidated printfcalls
structure would require new entries to be added for every extension. This
patch removes the debug print methods and their use.
This adds a new protocol processing support code based on Anthony Liguori's
9p library code. This code performs protocol marshalling/unmarshalling using
printf like strings to represent protocol elements. It is my intent to use
them to replace the current functions in conv.c as well as the
p9_create_* functions.
This should make the client implementation much more clear, and also make it
much easier to add new protocol extensions by limiting the number of places
in which changes need to be made.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
9p trans modules aren't refcounted nor were they unregistered
properly. Fix it.
* Add 9p_trans_module->owner and reference the module on each trans
instance creation and put it on destruction.
* Protect v9fs_trans_list with a spinlock. This isn't strictly
necessary as the list is manipulated only during module loading /
unloading but it's a good idea to make the API safe.
* Unregister trans modules when the corresponding module is being
unloaded.
* While at it, kill unnecessary EXPORT_SYMBOL on p9_trans_fd_init().
There was some cleanup issues during early mount which would trigger
a kernel bug for certain types of failure. This patch reorganizes the
cleanup to get rid of the bad behavior.
This also merges the 9pnet and 9pnet_fd modules for the purpose of
configuration and initialization. Keeping the fd transport separate
from the core 9pnet code seemed like a good idea at the time, but in
practice has caused more harm and confusion than good.
The kernel-doc comments of much of the 9p system have been in disarray since
reorganization. This patch fixes those problems, adds additional documentation
and a template book which collects the 9p information.
GDM gets unhappy if /var/gdm doesn't have the sticky bit set. This patch adds
support for the sticky bit in much the same way setuid/setgid is supported.
With this patch, I can launch X from a v9fs rootfs (although I quickly run out
of fds in the server once gnome starts up).
Signed-off-by: Anthony Liguori <aliguori@us.ibm.com>
Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
The task_struct->pid member is going to be deprecated, so start
using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in
the kernel.
The first thing to start with is the pid, printed to dmesg - in
this case we may safely use task_pid_nr(). Besides, printks produce
more (much more) than a half of all the explicit pid usage.
[akpm@linux-foundation.org: git-drm went and changed lots of stuff]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Airlie <airlied@linux.ie>
A sysctl method was added to enable and disable debugging levels. After
further review, it was decided that there are better approaches to doing this
and the sysctl methodology isn't really desirable. This patch removes the
sysctl code from 9p.
The 9P2000 protocol requires the authentication and permission checks to be
done in the file server. For that reason every user that accesses the file
server tree has to authenticate and attach to the server separately.
Multiple users can share the same connection to the server.
Currently v9fs does a single attach and executes all I/O operations as a
single user. This makes using v9fs in multiuser environment unsafe as it
depends on the client doing the permission checking.
This patch improves the 9P2000 support by allowing every user to attach
separately. The patch defines three modes of access (new mount option
'access'):
- attach-per-user (access=user) (default mode for 9P2000.u)
If a user tries to access a file served by v9fs for the first time, v9fs
sends an attach command to the server (Tattach) specifying the user. If
the attach succeeds, the user can access the v9fs tree.
As there is no uname->uid (string->integer) mapping yet, this mode works
only with the 9P2000.u dialect.
- allow only one user to access the tree (access=<uid>)
Only the user with uid can access the v9fs tree. Other users that attempt
to access it will get EPERM error.
- do all operations as a single user (access=any) (default for 9P2000)
V9fs does a single attach and all operations are done as a single user.
If this mode is selected, the v9fs behavior is identical with the current
one.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
found via make randconfig build testing:
net/built-in.o: In function `init_p9':
mod.c:(.init.text+0x3b39): undefined reference to `p9_sysctl_register'
net/built-in.o: In function `exit_p9':
mod.c:(.exit.text+0x36b): undefined reference to `p9_sysctl_unregister'
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p.
It moves the transport, packet marshalling and connection layers to net/9p
leaving only the VFS related files in fs/9p. This work is being done in
preparation for in-kernel 9p servers as well as alternate 9p clients (other
than VFS).
