Update the code to handle some of the differences between
RFC 3041 and RFC 4941, which obsoletes it. Also a couple
of janitorial fixes.
- Allow router advertisements to increase the lifetime of
temporary addresses. This was not allowed by RFC 3041,
but is specified by RFC 4941. It is useful when RA
lifetimes are lower than TEMP_{VALID,PREFERRED}_LIFETIME:
in this case, the previous code would delete or deprecate
addresses prematurely.
- Change the default of MAX_RETRY to 3 per RFC 4941.
- Add a comment to clarify that the preferred and valid
lifetimes in inet6_ifaddr are relative to the timestamp.
- Shorten lines to 80 characters in a couple of places.
Change-Id: I4da097664d4b1de7c1cebf410895319601c7f1cc
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: JP Abgrall <jpa@google.com>
These header files are never installed to user consumption, so any
__KERNEL__ cpp checks are superfluous.
Projects should also not copy these files into their userland utility
sources and try to use them there. If they insist on doing so, the
onus is on them to sanitize the headers as needed.
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
These macros have been defined for several years since v2.6.12-rc2(tracing by git),
but never be used. So remove them.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Another exported symbol only used in one file
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
Clean up a missing exit path in the ipv6 module init routines. In
addrconf_init we call ipv6_addr_label_init which calls register_pernet_subsys
for the ipv6_addr_label_ops structure. But if module loading fails, or if the
ipv6 module is removed, there is no corresponding unregister_pernet_subsys call,
which leaves a now-bogus address on the pernet_list, leading to oopses in
subsequent registrations. This patch cleans up both the failed load path and
the unload path. Tested by myself with good results.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
include/net/addrconf.h | 1 +
net/ipv6/addrconf.c | 11 ++++++++---
net/ipv6/addrlabel.c | 5 +++++
3 files changed, 14 insertions(+), 3 deletions(-)
- Use rcu_dereference_rtnl() in __in6_dev_get
- kerneldoc for __in6_dev_get() and in6_dev_get()
- Use inline functions instead of macros
Update rcu_dereference() primitives to use new lockdep-based
checking. The rcu_dereference() in __in6_dev_get() may be
protected either by rcu_read_lock() or RTNL, per Eric Dumazet.
The rcu_dereference() in __sk_free() is protected by the fact
that it is never reached if an update could change it. Check
for this by using rcu_dereference_check() to verify that the
struct sock's ->sk_wmem_alloc counter is zero.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-5-git-send-email-paulmck@linux.vnet.ibm.com>
This patch fixes commit e36b9d16c6a6d0f59803b3ef04ff3c22c3844c10. The approach
there is to call dev_close()/dev_open() whenever the device type is changed in
order to remap the device IP multicast addresses to HW multicast addresses.
This approach suffers from 2 drawbacks:
*. It assumes tha the device is UP when calling dev_close(), or otherwise
dev_close() has no affect. It is worth to mention that initscripts (Redhat)
and sysconfig (Suse) doesn't act the same in this matter.
*. dev_close() has other side affects, like deleting entries from the routing
table, which might be unnecessary.
The fix here is to directly remap the IP multicast addresses to HW multicast
addresses for a bonding device that changes its type, and nothing else.
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Moni Shoua <monis@voltaire.com>
The ipv6 version of bind_conflict code calls ipv6_rcv_saddr_equal()
which at times wrongly identified intersections between addresses.
It particularly broke down under a few instances and caused erroneous
bind conflicts.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
ipv6_dev_get_saddr()
ipv6_dev_get_saddr() blindly de-references dst_dev to get the network
namespace, but some callers might pass NULL. Change callers to pass a
namespace pointer instead.
Signed-off-by: Brian Haley <brian.haley@hp.com>
This pacth makes IPv6 address labels per network namespace.
It keeps the global label tables, ip6addrlbl_table, but
adds a 'net' member to each ip6addrlbl_entry.
This new member is taken into account when matching labels.
Changelog
* v1: Initial version
* v2:
* Minize the penalty when network namespaces are not configured:
* the 'net' member is added only if CONFIG_NET_NS is
defined. This saves space when network namespaces are not
configured.
* 'net' value is retrieved with the inlined function
ip6addrlbl_net() that always return &init_net when
CONFIG_NET_NS is not defined.
* 'net' member in ip6addrlbl_entry renamed to the less generic
'lbl_net' name (helps code search).
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
- Allow longer lifetimes (>= 0x7fffffff/HZ) on 64bit archs
by using unsigned long.
- Shadow this arithmetic overflow workaround by introducing
helper functions: addrconf_timeout_fixup() and
addrconf_finite_timeout().
- Define link-local all-node / all-router multicast addresses.
- Remove ipv6_addr_all_nodes() and ipv6_addr_all_routers().
- net/ipv6/addrconf.c:
ipv6_get_ifaddr(), ipv6_dev_get_saddr()
- net/ipv6/mcast.c:
ipv6_sock_mc_join(), ipv6_sock_mc_drop(),
inet6_mc_check(),
ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(),
ipv6_chk_mcast_addr()
- net/ipv6/route.c:
rt6_lookup(), icmp6_dst_alloc()
- net/ipv6/ip6_output.c:
ip6_nd_hdr()
- net/ipv6/ndisc.c:
ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(),
ndisc_get_neigh(), __ndisc_send()
The function is only used in net/ipv6/addrconf.c.
ipv6_addr_equal(), ipv6_addr_v4mapped(),
ipv6_addr_is_ll_all_{nodes,routers}(),
ipv6_masked_addr_cmp()
Both are identical, let's create ipv6_chk_prefix() and use it
in both places.
This patches removes unused declaration of addrconf_forwarding_on() method
in include/net/addrconf.h.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
Make use of the network namespace information to have this protocol to
handle several network namespace.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Last part of hop-limit determination is always:
hoplimit = dst_metric(dst, RTAX_HOPLIMIT);
if (hoplimit < 0)
hoplimit = ipv6_get_hoplimit(dst->dev).
Let's consolidate it as ip6_dst_hoplimit(dst).
addrconf
This patch propagates the network namespace pointer to the address
configuration routines which need it, which means adding a new
parameter to these functions, and make them use it instead of using
the initial network namespace.
Since most users of ipv6_get_saddr() pass non-NULL as
dst argument, use ipv6_dev_get_saddr() directly.
This short patch modifies the IPv4 networking to enable use of the
240.0.0.0/4 (aka "class-E") address space as propsed in the internet
draft draft-fuller-240space-00.txt.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Looks if the address is belonging to the network namespace, otherwise
discard the address for the check.
The inet6_addr_lst is browsed taking into account the network
namespace specified as parameter. If an address does not belong
to the specified namespace, it is ignored.
When a new address is added, we must check if the new address does not
already exists. This patch makes this check to be aware of a network
namespace, so the check will look if the address already exists for
the specified network namespace. While the addresses are browsed, the
addresses which do not belong to the namespace are discarded.
This patch includes support for the Intra-Site Automatic Tunnel
Addressing Protocol (ISATAP) per RFC4214. It uses the SIT
module, and is configured using extensions to the "iproute2"
utility. The diffs are specific to the Linux 2.6.24-rc2 kernel
distribution.
This version includes the diff for ./include/linux/if.h which was
missing in the v2.4 submission and is needed to make the
patch compile. The patch has been installed, compiled and
tested in a clean 2.6.24-rc2 kernel build area.
Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com>
Policy table is implemented as an RCU linear list since we do not expect
large list nor frequent updates.
This patch makes MIPv6 loadable module named "mip6".
Here is a modprobe.conf(5) example to load it automatically
when user application uses XFRM state for MIPv6:
alias xfrm-type-10-43 mip6
alias xfrm-type-10-60 mip6
Some MIPv6 feature is not included by this modular, however,
it should not be affected to other features like either IPsec
or IPv6 with and without the patch.
We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt
separately for future work.
Loadable features:
* MH receiving check (to send ICMP error back)
* RO header parsing and building (i.e. RH2 and HAO in DSTOPTS)
* XFRM policy/state database handling for RO
These are NOT covered as loadable:
* Home Address flags and its rule on source address selection
* XFRM sub policy (depends on its own kernel option)
* XFRM functions to receive RO as IPv6 extension header
* MH sending/receiving through raw socket if user application
opens it (since raw socket allows to do so)
* RH2 sending as ancillary data
* RH2 operation with setsockopt(2)
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Nominally an autoconfigured IPv6 address is added to an interface in the
Tentative state (as per RFC 2462). Addresses in this state remain in this
state while the Duplicate Address Detection process operates on them to
determine their uniqueness on the network. During this period, these
tentative addresses may not be used for communication, increasing the time
before a node may be able to communicate on a network. Using Optimistic
Duplicate Address Detection, autoconfigured addresses may be used
immediately for communication on the network, as long as certain rules are
followed to avoid conflicts with other nodes during the Duplicate Address
Detection process.
IFA_F_HOMEADDRESS is introduced for Mobile IPv6 Home Addresses on
Mobile Node.
The IFA_F_HOMEADDRESS flag should be set for Mobile IPv6 Home
Addresses for 2 purposes. 1) We need to check this on receipt of
Type 2 Routing Header (RFC3775 Secion 6.4), 2) We prefer Home
Address(es) in source address selection (RFC3484 Section 5 Rule 4).
Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
Add inbound interface of routing header type 2 for Mobile IPv6.
Based on MIPL2 kernel patch.
This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi>
Of this type, mostly:
CHECK net/ipv6/netfilter.c
net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static?
net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static?
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Else the in6_addr layout is not known for struct
prefix_info.
This patch includes net/ipv6.h from addrconf.h since it needs
ipv6_addr_set.
infrastructure for it.
Let it rip!
