path: root/include/net/ax25.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-02-12[AX25] ax25_ds_timer: use mod_timer instead of add_timerJarek Poplawski
This patch changes current use of: init_timer(), add_timer() and del_timer() to setup_timer() with mod_timer(), which should be safer anyway. Reported-by: Jann Traschewski <jann@gmx.de> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[AX25] ax25_timer: use mod_timer instead of add_timerJarek Poplawski
According to one of Jann's OOPS reports it looks like BUG_ON(timer_pending(timer)) triggers during add_timer() in ax25_start_t1timer(). This patch changes current use of: init_timer(), add_timer() and del_timer() to setup_timer() with mod_timer(), which should be safer anyway. Reported-by: Jann Traschewski <jann@gmx.de> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[NET] include/net/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 1Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-17[AX.25]: Fix unchecked ax25_linkfail_register usesRalf Baechle
ax25_linkfail_register uses kmalloc and the callers were ignoring the error value. Rewrite to let the caller deal with the allocation. This allows the use of static allocation of kmalloc use entirely. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-17[AX.25]: Fix unchecked ax25_protocol_register uses.Ralf Baechle
Replace ax25_protocol_register by ax25_register_pid which assumes the caller has done the memory allocation. This allows replacing the kmalloc allocations entirely by static allocations. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-17[AX.25]: Mark all kmalloc users __must_checkRalf Baechle
The recent fix 0506d4068bad834aab1141b5dc5e748eb175c6b3 made obvious that error values were not being propagated through the AX.25 stack. To help with that this patch marks all kmalloc users in the AX.25, NETROM and ROSE stacks as __must_check. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[HAMRADIO]: Fix baycom_epp.c compile failure.Ralf Baechle
Fix foobar in 15b1c0e822f578306332d4f4c449250db5c5dceb and e8cc49bb0fdb9e18a99e6780073d1400ba2b0d1f patch series. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[AX.25]: Fix default address and broadcast address initialization.Ralf Baechle
Only the callsign but not the SSID part of an AX.25 address is ASCII based but Linux by initializes the SSID which should be just a 4-bit number from ASCII anyway. Fix that and convert the code to use a shared constant for both default addresses. While at it, use the same style for null_ax25_address also. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[AX.25]: Constify ax25 utility functionsRalf Baechle
2006-07-03[AX.25]: Reference counting for AX.25 routes.Ralf Baechle DL5RB
In the past routes could be freed even though the were possibly in use ... Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-05-03[AX.25]: Eleminate HZ from AX.25 kernel interfacesRalf Baechle
Convert all AX.25 sysctl time values from jiffies to ms as units. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-19[AX.25]: Fix potencial memory hole.Ralf Baechle DL5RB
If the AX.25 dialect chosen by the sysadmin is set to DAMA master / 3 (or DAMA slave / 2, if CONFIG_AX25_DAMA_SLAVE=n) ax25_kick() will fall through the switch statement without calling ax25_send_iframe() or any other function that would eventually free skbn thus leaking the packet. Fix by restricting the sysctl inferface to allow only actually supported AX.25 dialects. The system administration mistake needed for this to happen is rather unlikely, so this is an uncritical hole. Coverity #651. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-22[AX.25]: Fix signed char bugRalf Baechle
On architectures where the char type defaults to unsigned some of the arithmetic in the AX.25 stack to fail, resulting in some packets being dropped on receive. Credits for tracking this down and the original patch to Bob Brose N0QBJ <linuxhams@n0qbj-11.ampr.org>. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-12[AX.25]: Add descriptions to constantsRalf Baechle
Comment the names used for the AX.25 state machine. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[AX.25]: Add more PIDsRalf Baechle
Add a few more PID definitions. AX.25 PIDs are the equivalent to IP protocol numbers. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[AX.25]: Rename ax25_encapsulate to ax25_hard_headerRalf Baechle
Rename ax25_encapsulate to ax25_hard_header which these days more accurately describes what the function is supposed to do. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[AX.25]: Make asc2ax() thread-proofRalf Baechle
Asc2ax was still using a static buffer for all invocations which isn't exactly SMP-safe. Change asc2ax to take an additional result buffer as the argument. Change all callers to provide such a buffer. This one only really is a fix for ROSE and as per recent discussions there's still much more to fix in ROSE ... Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-06[AX25]: Make ax2asc thread-proofRalf Baechle
Ax2asc was still using a static buffer for all invocations which isn't exactly SMP-safe. Change ax2asc to take an additional result buffer as the argument. Change all callers to provide such a buffer. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-23[AX25]: UID fixesRalf Baechle
o Brown paperbag bug - ax25_findbyuid() was always returning a NULL pointer as the result. Breaks ROSE completly and AX.25 if UID policy set to deny. o While the list structure of AX.25's UID to callsign mapping table was properly protected by a spinlock, it's elements were not refcounted resulting in a race between removal and usage of an element. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[AX25]: endian-annotate ax25_type_trans()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[AX25] Introduce ax25_type_transArnaldo Carvalho de Melo
Replacing the open coded equivalents and making ax25 look more like a linux network protocol, i.e. more similar to inet. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-21[AX25]: make ax25_queue_xmit a net_device parameterArnaldo Carvalho de Melo
I.e. not using skb->dev as a way to pass the parameter used to fill... skb->dev :-) Also to get the _type_trans open coded sequence grouped, next changesets will introduce ax25_type_trans. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
