commit 55667441c84fa5e0911a0aac44fb059c15ba6da2 upstream.
UDP IPv6 packets auto flowlabels are using a 32bit secret
(static u32 hashrnd in net/core/flow_dissector.c) and
apply jhash() over fields known by the receivers.
Attackers can easily infer the 32bit secret and use this information
to identify a device and/or user, since this 32bit secret is only
set at boot time.
Really, using jhash() to generate cookies sent on the wire
is a serious security concern.
Trying to change the rol32(hash, 16) in ip6_make_flowlabel() would be
a dead end. Trying to periodically change the secret (like in sch_sfq.c)
could change paths taken in the network for long lived flows.
Let's switch to siphash, as we did in commit df453700e8d8
("inet: switch IP ID generator to siphash")
Using a cryptographically strong pseudo random function will solve this
privacy issue and more generally remove other weak points in the stack.
Packet schedulers using skb_get_hash_perturb() benefit from this change.
Fixes: b56774163f99 ("ipv6: Enable auto flow labels by default")
Fixes: 42240901f7c4 ("ipv6: Implement different admin modes for automatic flow labels")
Fixes: 67800f9b1f4e ("ipv6: Call skb_get_hash_flowi6 to get skb->hash in ip6_make_flowlabel")
Fixes: cb1ce2ef387b ("ipv6: Implement automatic flow label generation on transmit")
Reported-by: Jonathan Berger <jonathann1@walla.com>
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
Cc: Tom Herbert <tom@herbertland.com>
The reusable fairness queueing implementation (fq.h) lacks the memory
usage limit that the fq_codel qdisc has. This means that small
devices (e.g. WiFi routers) can run out of memory when flooded with a
large number of packets. This ports the memory limit feature from
fq_codel to fq.h.
Signed-off-by: Toke Høiland-Jørgensen <toke@toke.dk>
This works on the same implementation principle as
codel*.h, i.e. there's a generic header with
structures and macros and a implementation header
carrying function definitions to include in given,
e.g. driver or module.
The fairness logic comes from
net/sched/sch_fq_codel.c but is generalized so it
is more flexible and easier to re-use.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
