path: root/include/net/inet_sock.h
2011-08-07ipv4: route non-local sources for raw socketJulian Anastasov
The raw sockets can provide source address for routing but their privileges are not considered. We can provide non-local source address, make sure the FLOWI_FLAG_ANYSRC flag is set if socket has privileges for this, i.e. based on hdrincl (IP_HDRINCL) and transparent flags. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-06inet: Decrease overhead of on-stack inet_cork.David S. Miller
When we fast path datagram sends to avoid locking by putting the inet_cork on the stack we use up lots of space that isn't necessary. This is because inet_cork contains a "struct flowi" which isn't used in these code paths. Split inet_cork to two parts, "inet_cork" and "inet_cork_full". Only the latter of which has the "struct flowi" and is what is stored in inet_sock. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01inet: Remove explicit write references to sk/inet in ip_append_dataHerbert Xu
In order to allow simultaneous calls to ip_append_data on the same socket, it must not modify any shared state in sk or inet (other than those that are designed to allow that such as atomic counters). This patch abstracts out write references to sk and inet_sk in ip_append_data and its friends so that we may use the underlying code in parallel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-27net: Pre-COW metrics for TCP.David S. Miller
TCP is going to record metrics for the connection, so pre-COW the route metrics at route cache entry creation time. This avoids several atomic operations that have to occur if we COW the metrics after the entry reaches global visibility. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-09net: optimize INET input path furtherEric Dumazet
Followup of commit b178bb3dfc30 (net: reorder struct sock fields) Optimize INET input path a bit further, by : 1) moving sk_refcnt close to sk_lock. This reduces number of dirtied cache lines by one on 64bit arches (and 64 bytes cache line size). 2) moving inet_daddr & inet_rcv_saddr at the beginning of sk (same cache line than hash / family / bound_dev_if / nulls_node) This reduces number of accessed cache lines in lookups by one, and dont increase size of inet and timewait socks. inet and tw sockets now share same place-holder for these fields. Before patch : offsetof(struct sock, sk_refcnt) = 0x10 offsetof(struct sock, sk_lock) = 0x40 offsetof(struct sock, sk_receive_queue) = 0x60 offsetof(struct inet_sock, inet_daddr) = 0x270 offsetof(struct inet_sock, inet_rcv_saddr) = 0x274 After patch : offsetof(struct sock, sk_refcnt) = 0x44 offsetof(struct sock, sk_lock) = 0x48 offsetof(struct sock, sk_receive_queue) = 0x68 offsetof(struct inet_sock, inet_daddr) = 0x0 offsetof(struct inet_sock, inet_rcv_saddr) = 0x4 compute_score() (udp or tcp) now use a single cache line per ignored item, instead of two. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12igmp: RCU conversion of in_dev->mc_listEric Dumazet
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock). This can easily be converted to a RCU protection. Writers hold RTNL, so mc_list_lock is removed, not replaced by a spinlock. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Cypher Wu <cypher.w@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23net - IP_NODEFRAG option for IPv4 socketJiri Olsa
this patch is implementing IP_NODEFRAG option for IPv4 socket. The reason is, there's no other way to send out the packet with user customized header of the reassembly part. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27net: Make RFS socket operations not be inet specific.David S. Miller
Idea from Eric Dumazet. As for placement inside of struct sock, I tried to choose a place that otherwise has a 32-bit hole on 64-bit systems. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-04-27rps: inet_rps_save_rxhash() argument is not constEric Dumazet
const qualifier on sock argument is misleading, since we can modify rxhash. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-16rfs: Receive Flow SteeringTom Herbert
This patch implements receive flow steering (RFS). RFS steers received packets for layer 3 and 4 processing to the CPU where the application for the corresponding flow is running. RFS is an extension of Receive Packet Steering (RPS). The basic idea of RFS is that when an application calls recvmsg (or sendmsg) the application's running CPU is stored in a hash table that is indexed by the connection's rxhash which is stored in the socket structure. The rxhash is passed in skb's received on the connection from netif_receive_skb. For each received packet, the associated rxhash is used to look up the CPU in the hash table, if a valid CPU is set then the packet is steered to that CPU using the RPS mechanisms. The convolution of the simple approach is that it would potentially allow OOO packets. If threads are thrashing around CPUs or multiple threads are trying to read from the same sockets, a quickly changing CPU value in the hash table could cause rampant OOO packets-- we consider this a non-starter. To avoid OOO packets, this solution implements two types of hash tables: rps_sock_flow_table and rps_dev_flow_table. rps_sock_table is a global hash table. Each entry is just a CPU number and it is populated in recvmsg and sendmsg as described above. This table contains the "desired" CPUs for flows. rps_dev_flow_table is specific to each device queue. Each entry contains a CPU and a tail queue counter. The CPU is the "current" CPU for a matching flow. The tail queue counter holds the value of a tail queue counter for the associated CPU's backlog queue at the time of last enqueue for a flow matching the entry. Each backlog queue has a queue head counter which is incremented on dequeue, and so a queue tail counter is computed as queue head count + queue length. When a packet is enqueued on a backlog queue, the current value of the queue tail counter is saved in the hash entry of the rps_dev_flow_table. And now the trick: when selecting the CPU for RPS (get_rps_cpu) the rps_sock_flow table and the rps_dev_flow table for the RX queue are consulted. When the desired CPU for the flow (found in the rps_sock_flow table) does not match the current CPU (found in the rps_dev_flow table), the current CPU is changed to the desired CPU if one of the following is true: - The current CPU is unset (equal to RPS_NO_CPU) - Current CPU is offline - The current CPU's queue head counter >= queue tail counter in the rps_dev_flow table. This checks if the queue tail has advanced beyond the last packet that was enqueued using this table entry. This guarantees that all packets queued using this entry have been dequeued, thus preserving in order delivery. Making each queue have its own rps_dev_flow table has two advantages: 1) the tail queue counters will be written on each receive, so keeping the table local to interrupting CPU s good for locality. 2) this allows lockless access to the table-- the CPU number and queue tail counter need to be accessed together under mutual exclusion from netif_receive_skb, we assume that this is only called from device napi_poll which is non-reentrant. This patch implements RFS for TCP and connected UDP sockets. It should be usable for other flow oriented protocols. There are two configuration parameters for RFS. The "rps_flow_entries" kernel init parameter sets the number of entries in the rps_sock_flow_table, the per rxqueue sysfs entry "rps_flow_cnt" contains the number of entries in the rps_dev_flow table for the rxqueue. Both are rounded to power of two. The obvious benefit of RFS (over just RPS) is that it achieves CPU locality between the receive processing for a flow and the applications processing; this can result in increased performance (higher pps, lower latency). The benefits of RFS are dependent on cache hierarchy, application load, and other factors. On simple benchmarks, we don't necessarily see improvement and sometimes see degradation. However, for more complex benchmarks and for applications where cache pressure is much higher this technique seems to perform very well. Below are some benchmark results which show the potential benfit of this patch. The netperf test has 500 instances of netperf TCP_RR test with 1 byte req. and resp. The RPC test is an request/response test similar in structure to netperf RR test ith 100 threads on each host, but does more work in userspace that netperf. e1000e on 8 core Intel No RFS or RPS 104K tps at 30% CPU No RFS (best RPS config): 290K tps at 63% CPU RFS 303K tps at 61% CPU RPC test tps CPU% 50/90/99% usec latency Latency StdDev No RFS/RPS 103K 48% 757/900/3185 4472.35 RPS only: 174K 73% 415/993/2468 491.66 RFS 223K 73% 379/651/1382 315.61 Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11tcp: Generalized TTL Security MechanismStephen Hemminger
This patch adds the kernel portions needed to implement RFC 5082 Generalized TTL Security Mechanism (GTSM). It is a lightweight security measure against forged packets causing DoS attacks (for BGP). This is already implemented the same way in BSD kernels. For the necessary Quagga patch http://www.gossamer-threads.com/lists/quagga/dev/17389 Description from Cisco http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gt_btsh.html It does add one byte to each socket structure, but I did a little rearrangement to reuse a hole (on 64 bit), but it does grow the structure on 32 bit This should be documented on ip(4) man page and the Glibc in.h file also needs update. IPV6_MINHOPLIMIT should also be added (although BSD doesn't support that). Only TCP is supported, but could also be added to UDP, DCCP, SCTP if desired. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: (39 commits) signal: fix __send_signal() false positive kmemcheck warning fs: fix do_mount_root() false positive kmemcheck warning fs: introduce __getname_gfp() trace: annotate bitfields in struct ring_buffer_event net: annotate struct sock bitfield c2port: annotate bitfield for kmemcheck net: annotate inet_timewait_sock bitfields ieee1394/csr1212: fix false positive kmemcheck report ieee1394: annotate bitfield net: annotate bitfields in struct inet_sock net: use kmemcheck bitfields API for skbuff kmemcheck: introduce bitfield API kmemcheck: add opcode self-testing at boot x86: unify pte_hidden x86: make _PAGE_HIDDEN conditional kmemcheck: make kconfig accessible for other architectures kmemcheck: enable in the x86 Kconfig kmemcheck: add hooks for the page allocator kmemcheck: add hooks for page- and sg-dma-mappings kmemcheck: don't track page tables ...
2009-06-15net: annotate bitfields in struct inet_sockVegard Nossum
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-02ipv4: New multicast-all socket optionNivedita Singhvi
After some discussion offline with Christoph Lameter and David Stevens regarding multicast behaviour in Linux, I'm submitting a slightly modified patch from the one Christoph submitted earlier. This patch provides a new socket option IP_MULTICAST_ALL. In this case, default behaviour is _unchanged_ from the current Linux standard. The socket option is set by default to provide original behaviour. Sockets wishing to receive data only from multicast groups they join explicitly will need to clear this socket option. Signed-off-by: Nivedita Singhvi <niv@us.ibm.com> Signed-off-by: Christoph Lameter<cl@linux.com> Acked-by: David Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01tcp: Port redirection support for TCPKOVACS Krisztian
Current TCP code relies on the local port of the listening socket being the same as the destination address of the incoming connection. Port redirection used by many transparent proxying techniques obviously breaks this, so we have to store the original destination port address. This patch extends struct inet_request_sock and stores the incoming destination port value there. It also modifies the handshake code to use that value as the source port when sending reply packets. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01tcp: Handle TCP SYN+ACK/ACK/RST transparencyKOVACS Krisztian
The TCP stack sends out SYN+ACK/ACK/RST reply packets in response to incoming packets. The non-local source address check on output bites us again, as replies for transparently redirected traffic won't have a chance to leave the node. This patch selectively sets the FLOWI_FLAG_ANYSRC flag when doing the route lookup for those replies. Transparent replies are enabled if the listening socket has the transparent socket flag set. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make inet_sock.h independent of route.hKOVACS Krisztian
inet_iif() in inet_sock.h requires route.h. Since users of inet_iif() usually require other route.h functionality anyway this patch moves inet_iif() to route.h. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Implement IP_TRANSPARENT socket optionKOVACS Krisztian
This patch introduces the IP_TRANSPARENT socket option: enabling that will make the IPv4 routing omit the non-local source address check on output. Setting IP_TRANSPARENT requires NET_ADMIN capability. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16netns: introduce the net_hash_mix "salt" for hashesPavel Emelyanov
There are many possible ways to add this "salt", thus I made this patch to be the last in the series to change it if required. Currently I propose to use the struct net pointer itself as this salt, but since this pointer is most often cache-line aligned, shift this right to eliminate the bits, that are most often zeroed. After this, simply add this mix to prepared hashfn-s. For CONFIG_NET_NS=n case this salt is 0 and no changes in hashfn appear. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16inet: add struct net argument to inet_ehashfnPavel Emelyanov
Although this hash takes addresses into account, the ehash chains can also be too long when, for instance, communications via lo occur. So, prepare the inet_hashfn to take struct net into account. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10inet{6}_request_sock: Init ->opt and ->pktopts in the constructorArnaldo Carvalho de Melo
Wei Yongjun noticed that we may call reqsk_free on request sock objects where the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc where we initialize ->opt to NULL and set ->pktopts to NULL in inet6_reqsk_alloc. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[IPV4,IPV6]: Share cork.rt between IPv4 and IPv6.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-22[IPV4]: Remove unused ip_options->is_data.Denis V. Lunev
ip_options->is_data is assigned only and never checked. The structure is not a part of kernel interface to the userspace. So, it is safe to remove this field. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[IPV4]: Add 'rtable' field in struct sk_buff to alias 'dst' and avoid castsEric Dumazet
(Anonymous) unions can help us to avoid ugly casts. A common cast it the (struct rtable *)skb->dst one. Defining an union like : union { struct dst_entry *dst; struct rtable *rtable; }; permits to use skb->rtable in place. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[TCP]: Improve ipv4 established hash function.David S. Miller
If all of the entropy is in the local and foreign addresses, but xor'ing together would cancel out that entropy, the current hash performs poorly. Suggested by Cosmin Ratiu: Basically, the situation is as follows: There is a client machine and a server machine. Both create 15000 virtual interfaces, open up a socket for each pair of interfaces and do SIP traffic. By profiling I noticed that there is a lot of time spent walking the established hash chains with this particular setup. The addresses were distributed like this: client interfaces were 198.18.0.1/16 with increments of 1 and server interfaces were 198.18.128.1/16 with increments of 1. As I said, there were 15000 interfaces. Source and destination ports were 5060 for each connection. So in this case, ports don't matter for hashing purposes, and the bits from the address pairs used cancel each other, meaning there are no differences in the whole lot of pairs, so they all end up in the same hash chain. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-25[UDP]: Make use of inet_iif() when doing socket lookups.Vlad Yasevich
UDP currently uses skb->dev->ifindex which may provide the wrong information when the socket bound to a specific interface. This patch makes inet_iif() accessible to UDP and makes UDP use it. The scenario we are trying to fix is when a client is running on the same system and the server and both client and server bind to a non-loopback device. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[INET]: Use jhash + random secret for ehash.David S. Miller
The days are gone when this was not an issue, there are folks out there with huge bot networks that can be used to attack the established hash tables on remote systems. So just like the routing cache and connection tracking hash, use Jenkins hash with random secret input. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate inet_lookup() and friendsAl Viro
inet_lookup() annotated along with helper functions (__inet_lookup(), __inet_lookup_established(), inet_lookup_established(), inet_lookup_listener(), __inet_lookup_listener() and inet_ehashfn()) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: struct inet_request_sock annotationsAl Viro
->port is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ports in struct inet_sock are net-endianAl Viro
2006-09-28[IPV4]: struct ip_options annotationsAl Viro
->faddr is net-endian; annotated as such, variables inferred to be net-endian annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate address in inet_request_sockAl Viro
2006-09-28[IPV4]: annotated ipv4 addresses in struct inet_sockAl Viro
2006-09-22[INET]: Remove is_setbyuser patchLouis Nyffenegger
The value is_setbyuser from struct ip_options is never used and set only one time (http://linux-net.osdl.org/index.php/TODO#IPV4). This little patch removes it from the kernel source. Signed-off-by: Louis Nyffenegger <louis.nyffenegger@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: core network changesPaul Moore
Changes to the core network stack to support the NetLabel subsystem. This includes changes to the IPv4 option handling to support CIPSO labels. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
