path: root/include/net/ip6_checksum.h
2013-10-09net: fix build errors if ipv6 is disabledEric Dumazet
CONFIG_IPV6=n is still a valid choice ;) It appears we can remove dead code. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08ipv6: move csum_ipv6_magic() and udp6_csum_init() into static libraryCong Wang
As suggested by David, udp6_csum_init() is too big to be inlined, move it to ipv6 static library, net/ipv6/ip6_checksum.c. And the generic csum_ipv6_magic() too. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-15ipv6: Separate tcp offload functionalityVlad Yasevich
Pull TCPv6 offload functionality into its won file in preparation for moving it out of the module. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-22[IPV6]: Dumb typo in generic csum_ipv6_magic()Al Viro
... duh Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Generic checksum annotations and cleanups.Al Viro
