commit f06b7549b79e29a672336d4e134524373fb7a232 upstream.
Lennert reported a failure to add different mpls encaps in a multipath
route:
$ ip -6 route add 1234::/16 \
nexthop encap mpls 10 via fe80::1 dev ens3 \
nexthop encap mpls 20 via fe80::1 dev ens3
RTNETLINK answers: File exists
The problem is that the duplicate nexthop detection does not compare
lwtunnel configuration. Add it.
Fixes: 19e42e451506 ("ipv6: support for fib route lwtunnel encap attributes")
Signed-off-by: David Ahern <dsahern@gmail.com>
Reported-by: João Taveira Araújo <joao.taveira@gmail.com>
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Tested-by: Lennert Buytenhek <buytenh@wantstofly.org>
[ Upstream commit 2f460933f58eee3393aba64f0f6d14acb08d1724 ]
Andrey reported a crash on init_net.ipv6.ip6_null_entry->rt6i_idev
since it is always NULL.
This is clearly wrong, we have code to initialize it to loopback_dev,
unfortunately the order is still not correct.
loopback_dev is registered very early during boot, we lose a chance
to re-initialize it in notifier. addrconf_init() is called after
ip6_route_init(), which means we have no chance to correct it.
Fix it by moving this initialization explicitly after
ipv6_add_dev(init_net.loopback_dev) in addrconf_init().
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Similar to IPv4, do not consider link state when validating next hops.
Currently, if the link is down default routes can fail to insert:
$ ip -6 ro add vrf blue default via 2100:2::64 dev eth2
RTNETLINK answers: No route to host
With this patch the command succeeds.
Fixes: 8c14586fc320 ("net: ipv6: Use passed in table for nexthop lookups")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Make ip6_route_input_lookup available outside of ipv6 the module
similar to ip_route_input_noref in the IPv4 world.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
VRF driver needs access to ip6_route_get_saddr code. Since it does
little beyond ipv6_dev_get_saddr and ipv6_dev_get_saddr is already
exported for modules move ip6_route_get_saddr to the header as an
inline.
Code move only; no functional change.
IPv6 multicast and link-local addresses require special handling by the
VRF driver:
1. Rather than using the VRF device index and full FIB lookups,
packets to/from these addresses should use direct FIB lookups based on
the VRF device table.
2. fail sends/receives on a VRF device to/from a multicast address
(e.g, make ping6 ff02::1%<vrf> fail)
3. move the setting of the flow oif to the first dst lookup and revert
the change in icmpv6_echo_reply made in ca254490c8dfd ("net: Add VRF
support to IPv6 stack"). Linklocal/mcast addresses require use of the
skb->dev.
With this change connections into and out of a VRF enslaved device work
for multicast and link-local addresses work (icmp, tcp, and udp)
e.g.,
1. packets into VM with VRF config:
ping6 -c3 fe80::e0:f9ff:fe1c:b974%br1
ping6 -c3 ff02::1%br1
ssh -6 fe80::e0:f9ff:fe1c:b974%br1
2. packets going out a VRF enslaved device:
ping6 -c3 fe80::18f8:83ff:fe4b:7a2e%eth1
ping6 -c3 ff02::1%eth1
ssh -6 root@fe80::18f8:83ff:fe4b:7a2e%eth1
Vivek reported a kernel exception deleting a VRF with an active
connection through it. The root cause is that the socket has a cached
reference to a dst that is destroyed. Converting the dst_destroy to
dst_release and letting proper reference counting kick in does not
work as the dst has a reference to the device which needs to be released
as well.
I talked to Hannes about this at netdev and he pointed out the ipv4 and
ipv6 dst handling has dst_ifdown for just this scenario. Rather than
continuing with the reinvented dst wheel in VRF just remove it and
leverage the ipv4 and ipv6 versions.
Fixes: 193125dbd8eb2 ("net: Introduce VRF device driver")
Fixes: 35402e3136634 ("net: Add IPv6 support to VRF device")
The current implementation of ip6_dst_lookup_tail basically
ignore the egress ifindex match: if the saddr is set,
ip6_route_output() purposefully ignores flowi6_oif, due
to the commit d46a9d678e4c ("net: ipv6: Dont add RT6_LOOKUP_F_IFACE
flag if saddr set"), if the saddr is 'any' the first route lookup
in ip6_dst_lookup_tail fails, but upon failure a second lookup will
be performed with saddr set, thus ignoring the ifindex constraint.
This commit adds an output route lookup function variant, which
allows the caller to specify lookup flags, and modify
ip6_dst_lookup_tail() to enforce the ifindex match on the second
lookup via said helper.
ip6_route_output() becames now a static inline function build on
top of ip6_route_output_flags(); as a side effect, out-of-tree
modules need now a GPL license to access the output route lookup
functionality.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
While testing the np->opt RCU conversion, I found that UDP/IPv6 was
using a mixture of xchg() and sk_dst_lock to protect concurrent changes
to sk->sk_dst_cache, leading to possible corruptions and crashes.
ip6_sk_dst_lookup_flow() uses sk_dst_check() anyway, so the simplest
way to fix the mess is to remove sk_dst_lock completely, as we did for
IPv4.
__ip6_dst_store() and ip6_dst_store() share same implementation.
sk_setup_caps() being called with socket lock being held or not,
we have to use sk_dst_set() instead of __sk_dst_set()
Note that I had to move the "np->dst_cookie = rt6_get_cookie(rt);"
in ip6_dst_store() before the sk_setup_caps(sk, dst) call.
This is because ip6_dst_store() can be called from process context,
without any lock held.
As soon as the dst is installed in sk->sk_dst_cache, dst can be freed
from another cpu doing a concurrent ip6_dst_store()
Doing the dst dereference before doing the install is needed to make
sure no use after free would trigger.
Instead of doing the rt6->rt6i_node check whenever we need
to get the route's cookie. Refactor it into rt6_get_cookie().
It is a prep work to handle FLOWI_FLAG_KNOWN_NH and also
percpu rt6_info later.
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Julian Anastasov <ja@ssi.bg>
This patch creates a RTF_CACHE routes only after encountering a pmtu
exception.
After ip6_rt_update_pmtu() has inserted the RTF_CACHE route to the fib6
tree, the rt->rt6i_node->fn_sernum is bumped which will fail the
ip6_dst_check() and trigger a relookup.
When creating a RTF_CACHE route, RTF_ANYCAST is set based on rt6i_dst.
Also, rt6i_gateway is always set to the nexthop while the nexthop
could be a gateway or the rt6i_dst.addr.
After removing the rt6i_dst and rt6i_src dependency in the last patch,
we also need to stop the caller from depending on rt6i_gateway and
RTF_ANYCAST.
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
RFC 4861 states in 7.2.5:
The IsRouter flag in the cache entry MUST be set based on the
Router flag in the received advertisement. In those cases
where the IsRouter flag changes from TRUE to FALSE as a result
of this update, the node MUST remove that router from the
Default Router List and update the Destination Cache entries
for all destinations using that neighbor as a router as
specified in Section 7.3.3. This is needed to detect when a
node that is used as a router stops forwarding packets due to
being configured as a host.
Currently, when dealing with NA Message which IsRouter flag changes from
TRUE to FALSE, the kernel only removes router from the Default Router List,
and don't update the Destination Cache entries.
Now in order to update those Destination Cache entries, i introduce
function rt6_clean_tohost().
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
As suggested by several people, rename local_df to ignore_df,
since it means "ignore df bit if it is set".
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Florian Westphal <fw@strlen.de>
Acked-by: Maciej Żenczykowski <maze@google.com>
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Move the whole rt6_need_strict as static inline into ip6_route.h,
so that it can be reused
Signed-off-by: Wang Yufen <wangyufen@huawei.com>
This option has the same semantic as IP_PMTUDISC_OMIT for IPv4 which
got recently introduced. It doesn't honor the path mtu discovered by the
host but in contrary to IPV6_PMTUDISC_INTERFACE allows the generation of
fragments if the packet size exceeds the MTU of the outgoing interface
MTU.
Fixes: 93b36cf3425b9b ("ipv6: support IPV6_PMTU_INTERFACE on sockets")
Cc: Florian Weimer <fweimer@redhat.com>
This change allows to follow a recommandation of RFC4942.
- Add "anycast_src_echo_reply" sysctl to control the use of anycast addresses
as source addresses for ICMPv6 echo reply. This sysctl is false by default
to preserve existing behavior.
- Add inline check ipv6_anycast_destination().
- Use them in icmpv6_echo_reply().
Reference:
RFC4942 - IPv6 Transition/Coexistence Security Considerations
(http://tools.ietf.org/html/rfc4942#section-2.1.6)
2.1.6. Anycast Traffic Identification and Security
To avoid exposing knowledge about the internal structure of the
network, it is recommended that anycast servers now take advantage of
the ability to return responses with the anycast address as the
source address if possible.
Signed-off-by: Francois-Xavier Le Bail <fx.lebail@yahoo.com>
Running 'make namespacecheck' shows:
net/ipv6/route.o
ipv6_route_table_template
rt6_bind_peer
net/ipv6/icmp.o
icmpv6_route_lookup
ipv6_icmp_table_template
This addresses some of those warnings by:
* make icmpv6_route_lookup static
* move inline's out of ip6_route.h since only used into route.c
* move rt6_bind_peer into route.c
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
IPV6_PMTU_INTERFACE is the same as IPV6_PMTU_PROBE for ipv6. Add it
nontheless for symmetry with IPv4 sockets. Also drop incoming MTU
information if this mode is enabled.
The additional bit in ipv6_pinfo just eats in the padding behind the
bitfield. There are no changes to the layout of the struct at all.
drivers/net/usb/qmi_wwan.c
include/net/dst.h
Trivial merge conflicts, both were overlapping changes.
Make sure rt6i_gateway contains nexthop information in
all routes returned from lookup or when routes are directly
attached to skb for generated ICMP packets.
The effect of this patch should be a faster version of
rt6_nexthop() and the consideration of local addresses as
nexthop.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
In v3.9 6fd6ce2056de2709 ("ipv6: Do not depend on rt->n in
ip6_finish_output2()." changed the behaviour of ip6_finish_output2()
such that the recently introduced rt6_nexthop() is used
instead of an assigned neighbor.
As rt6_nexthop() prefers rt6i_gateway only for gatewayed
routes this causes a problem for users like IPVS, xt_TEE and
RAW(hdrincl) if they want to use different address for routing
compared to the destination address.
Another case is when redirect can create RTF_DYNAMIC
route without RTF_GATEWAY flag, we ignore the rt6i_gateway
in rt6_nexthop().
Fix the above problems by considering the rt6i_gateway if
present, so that traffic routed to address on local subnet is
not wrongly diverted to the destination address.
Thanks to Simon Horman and Phil Oester for spotting the
problematic commit.
Thanks to Hannes Frederic Sowa for his review and help in testing.
Reported-by: Phil Oester <kernel@linuxace.com>
Reported-by: Mark Brooks <mark@loadbalancer.org>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
It will be used by vxlan, and may not be inlined.
Signed-off-by: Cong Wang <amwang@redhat.com>
rfc 4861 says the Redirected Header option is optional, so
the kernel should not drop the Redirect Message that has no
Redirected Header option. In this patch, the function
ip6_redirect_no_header() is introduced to deal with that
condition.
Because of rt->n removal, we do not need neigh argument any more.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
For RTF_GATEWAY route, return rt->rt6i_gateway.
Otherwise, return 2nd argument (destination address).
This will be used by following patches which remove rt->n
dependency patches in ip6_dst_lookup_tail() and ip6_finish_output2().
The kernel uses some default metric when routes are managed. For example, a
static route added with a metric set to 0 is inserted in the kernel with
metric 1024 (IP6_RT_PRIO_USER).
It is useful for routing daemons to know these values, to be able to set routes
without interfering with what the kernel does.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
We should provide to inet6_csk_route_socket a struct flowi6 pointer,
so that net6_csk_xmit() works correctly instead of sending garbage.
Also add some consts
Reported-by: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
And delete rt6_redirect(), since it is no longer used.
This sets things up so that we can have the protocol error handlers
call down into the ipv6 route code for redirects just as ipv4 already
does.
One tricky issue on the ipv6 side vs. ipv4 is that the ICMP callouts
to handle the error pass the 32-bit info cookie in network byte order
whereas ipv4 passes it around in host byte order.
Like the ipv4 side, we have two helper functions. One for when we
have a socket context and one for when we do not.
ip6ip6 tunnels are not handled here, because they handle PMTU events
by essentially relaying another ICMP packet-too-big message back to
the original sender.
This patch allows us to get rid of rt6_do_pmtu_disc(). It handles all
kinds of situations that simply cannot happen when we do the PMTU
update directly using a fully resolved route.
In fact, the "plen == 128" check in ip6_rt_update_pmtu() can very
likely be removed or changed into a BUG_ON() check. We should never
have a prefixed ipv6 route when we get there.
Another piece of strange history here is that TCP and DCCP, unlike in
ipv4, never invoke the update_pmtu() method from their ICMP error
handlers. This is incredibly astonishing since this is the context
where we have the most accurate context in which to make a PMTU
update, namely we have a fully connected socket and associated cached
socket route.
If no peer actually gets attached (either because create is zero or
the peer allocation fails) we'll trigger a BUG because we
unconditionally do an rt{,6}_peer_ptr() afterwards.
Fix this by guarding it with the proper check.
We encode the pointer(s) into an unsigned long with one state bit.
The state bit is used so we can store the inetpeer tree root to use
when resolving the peer later.
Later the peer roots will be per-FIB table, and this change works to
facilitate that.
There's a lot of places that open-code rt{,6}_get_peer() only because
they want to set 'create' to one. So add an rt{,6}_get_peer_create()
for their sake.
There were also a few spots open-coding plain rt{,6}_get_peer() and
those are transformed here as well.
Mostly bool conversions, some inline removals and const additions.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
And return error pointers.
like rt6_lookup, but allows caller to pass in flowi6 structure.
Will be used by the upcoming ipv6 netfilter reverse path filter
match.
These header files are never installed to user consumption, so any
__KERNEL__ cpp checks are superfluous.
Projects should also not copy these files into their userland utility
sources and try to use them there. If they insist on doing so, the
onus is on them to sanitize the headers as needed.
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
[ipv6] Add support for RTA_PREFSRC
This patch allows a user to select the preferred source address
for a specific IPv6-Route. It can be set via a netlink message
setting RTA_PREFSRC to a valid IPv6 address which must be
up on the device the route will be bound to.
Signed-off-by: Daniel Walter <dwalter@barracuda.com>
