path: root/include/net/lib80211.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-26lib80211: remove unused host_build_iv optionJohn W. Linville
2008-11-21wireless: missing include in lib80211.hRami Rosen
This patch adds #include <linux/timer.h> in lib80211.h to avoid these compilation erros. > In file included from /work/src/wireless-testing/net/wireless/lib80211.c:24: > /work/src/wireless-testing/include/net/lib80211.h:113: error: field > 'crypt_deinit_timer' has incomplete type > /work/src/wireless-testing/net/wireless/lib80211.c: In function > 'lib80211_crypt_info_init': > /work/src/wireless-testing/net/wireless/lib80211.c:83: error: implicit > declaration of function 'setup_timer' > /work/src/wireless-testing/net/wireless/lib80211.c: In function > 'lib80211_crypt_info_free': > /work/src/wireless-testing/net/wireless/lib80211.c:95: error: implicit > declaration of function 'del_timer_sync' > /work/src/wireless-testing/net/wireless/lib80211.c: In function > 'lib80211_crypt_deinit_handler': > /work/src/wireless-testing/net/wireless/lib80211.c:157: error: > implicit declaration of function 'add_timer' > /work/src/wireless-testing/net/wireless/lib80211.c: In function > 'lib80211_crypt_delayed_deinit': > /work/src/wireless-testing/net/wireless/lib80211.c:182: error: > implicit declaration of function 'timer_pending' > make[3]: *** [net/wireless/lib80211.o] Error 1 > make[2]: *** [net/wireless] Error 2 > make[1]: *** [net] Error 2 > make: *** [sub-make] Error 2 Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21lib80211: consolidate crypt init routinesJohn W. Linville
2008-11-21lib80211: absorb crypto bits from net/ieee80211John W. Linville
These bits are shared already between ipw2x00 and hostap, and could probably be shared both more cleanly and with other drivers. This commit simply relocates the code to lib80211 and adjusts the drivers appropriately. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: avoid some net/ieee80211.h vs. linux/ieee80211.h conflictsJohn W. Linville
There is quite a lot of overlap in definitions between these headers... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: use individual buffers for printing ssid valuesJohn W. Linville
Also change escape_ssid to print_ssid to match print_mac semantics. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: remove NETWORK_EMPTY_ESSID flagJohn W. Linville
It is unnecessary and of questionable value. Also remove is_empty_ssid, as it is also unnecessary. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: consolidate on a single escape_essid implementationJohn W. Linville
