Get rid of the confusing mix of pid and portid and use portid consistently
for all netlink related socket identities.
This patch modifies the conntrack subsystem so that all existing
allocated conntrack objects can be found in any of the following
places:
* the hash table, this is the typical place for alive conntrack objects.
* the unconfirmed list, this is the place for newly created conntrack objects
that are still traversing the stack.
* the dying list, this is where you can find conntrack objects that are dying
or that should die anytime soon (eg. once the destroy event is delivered to
the conntrackd daemon).
Thus, we make sure that we follow the track for all existing conntrack
objects. This patch, together with some extension of the ctnetlink interface
to dump the content of the dying and unconfirmed lists, will help in case
to debug suspected nf_conn object leaks.
This patch uses the new variable length conntrack extensions.
Instead of using union nf_conntrack_help that contain all the
helper private data information, we allocate variable length
area to store the private helper data.
This patch includes the modification of all existing helpers.
It also includes a couple of include header to avoid compilation
warnings.
this_cpu_inc() is IRQ safe and faster than
local_bh_disable()/__this_cpu_inc()/local_bh_enable(), at least on x86.
Cc: Patrick McHardy <kaber@trash.net>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Reviewed-by: Christoph Lameter <cl@linux.com>
Marcell Zambo and Janos Farago noticed and reported that when
new conntrack entries are added via netlink and the conntrack table
gets full, soft lockup happens. This is because the nf_conntrack_lock
is held while nf_conntrack_alloc is called, which is in turn wants
to lock nf_conntrack_lock while evicting entries from the full table.
The patch fixes the soft lockup with limiting the holding of the
nf_conntrack_lock to the minimum, where it's absolutely required.
It required to extend (and thus change) nf_conntrack_hash_insert
so that it makes sure conntrack and ctnetlink do not add the same entry
twice to the conntrack table.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
The implicit presence of module.h everywhere meant that this header
also was getting moduleparam.h which defines struct kernel_param.
Since it only needs to know that kernel_param is a struct, call that
out instead of adding an include of moduleparam.h -- to get rid of this:
include/net/netfilter/nf_conntrack.h:316: warning: 'struct kernel_param' declared inside parameter list
include/net/netfilter/nf_conntrack.h:316: warning: its scope is only this definition or declaration, which is probably not what you want
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Avoid double seq adjustment for loopback traffic
because it causes silent repetition of TCP data. One
example is passive FTP with DNAT rule and difference in the
length of IP addresses.
This patch adds check if packet is sent and
received via loopback device. As the same conntrack is
used both for outgoing and incoming direction, we restrict
seq adjustment to happen only in POSTROUTING.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
These header files are never installed to user consumption, so any
__KERNEL__ cpp checks are superfluous.
Projects should also not copy these files into their userland utility
sources and try to use them there. If they insist on doing so, the
onus is on them to sanitize the headers as needed.
Use is_vmalloc_addr() in nf_ct_free_hashtable() and get rid of
the vmalloc flags to indicate that a hash table has been allocated
using vmalloc().
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 into HEAD
Since nf_ct_expect_dst_hash() may be called without nf_conntrack_lock
locked, nf_ct_expect_hash_rnd should be initialized in the atomic way.
In this patch, we use nf_conntrack_hash_rnd instead of
nf_ct_expect_hash_rnd.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
ct->proto is big(60 bytes) due to structure ip_ct_tcp, and we don't need
to initialize the whole for all the other protocols. This patch moves
proto to the end of structure nf_conn, and pushes the initialization down
to the individual protocols.
Acked-by: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
include/net/netfilter/xt_rateest.h
net/bridge/br_netfilter.c
net/netfilter/nf_conntrack_core.c
NOTRACK makes all cpus share a cache line on nf_conntrack_untracked
twice per packet, slowing down performance.
This patch converts it to a per_cpu variable.
twice per packet. This is bad for performance.
__read_mostly annotation is also a bad choice.
This patch introduces IPS_UNTRACKED bit so that we can use later a
per_cpu untrack structure more easily.
A new helper, nf_ct_untracked_get() returns a pointer to
nf_conntrack_untracked.
Another one, nf_ct_untracked_status_or() is used by nf_nat_init() to add
IPS_NAT_DONE_MASK bits to untracked status.
nf_ct_is_untracked() prototype is changed to work on a nf_conn pointer.
Use read_pnet() and write_pnet() to reduce number of ifdef CONFIG_NET_NS
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
Support initializing selected parameters of new conntrack entries from a
"conntrack template", which is a specially marked conntrack entry attached
to the skb.
Currently the helper and the event delivery masks can be initialized this
way.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
Vitezslav Samel discovered that since 2.6.30.4+ active FTP can not work
over NAT. The "cause" of the problem was a fix of unacknowledged data
detection with NAT (commit a3a9f79e361e864f0e9d75ebe2a0cb43d17c4272).
However, actually, that fix uncovered a long standing bug in TCP conntrack:
when NAT was enabled, we simply updated the max of the right edge of
the segments we have seen (td_end), by the offset NAT produced with
changing IP/port in the data. However, we did not update the other parameter
(td_maxend) which is affected by the NAT offset. Thus that could drift
away from the correct value and thus resulted breaking active FTP.
The patch below fixes the issue by *not* updating the conntrack parameters
from NAT, but instead taking into account the NAT offsets in conntrack in a
consistent way. (Updating from NAT would be more harder and expensive because
it'd need to re-calculate parameters we already calculated in conntrack.)
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: David Miller <davem@davemloft.net>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
When NAT helpers change the TCP packet size, the highest seen sequence
number needs to be corrected. This is currently only done upwards, when
the packet size is reduced the sequence number is unchanged. This causes
TCP conntrack to falsely detect unacknowledged data and decrease the
timeout.
Fix by updating the highest seen sequence number in both directions after
packet mangling.
Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl>
This patch improves ctnetlink event reliability if one broadcast
listener has set the NETLINK_BROADCAST_ERROR socket option.
The logic is the following: if an event delivery fails, we keep
the undelivered events in the missed event cache. Once the next
packet arrives, we add the new events (if any) to the missed
events in the cache and we try a new delivery, and so on. Thus,
if ctnetlink fails to deliver an event, we try to deliver them
once we see a new packet. Therefore, we may lose state
transitions but the userspace process gets in sync at some point.
At worst case, if no events were delivered to userspace, we make
sure that destroy events are successfully delivered. Basically,
if ctnetlink fails to deliver the destroy event, we remove the
conntrack entry from the hashes and we insert them in the dying
list, which contains inactive entries. Then, the conntrack timer
is added with an extra grace timeout of random32() % 15 seconds
to trigger the event again (this grace timeout is tunable via
/proc). The use of a limited random timeout value allows
distributing the "destroy" resends, thus, avoiding accumulating
lots "destroy" events at the same time. Event delivery may
re-order but we can identify them by means of the tuple plus
the conntrack ID.
The maximum number of conntrack entries (active or inactive) is
still handled by nf_conntrack_max. Thus, we may start dropping
packets at some point if we accumulate a lot of inactive conntrack
entries that did not successfully report the destroy event to
userspace.
During my stress tests consisting of setting a very small buffer
of 2048 bytes for conntrackd and the NETLINK_BROADCAST_ERROR socket
flag, and generating lots of very small connections, I noticed
very few destroy entries on the fly waiting to be resend.
A simple way to test this patch consist of creating a lot of
entries, set a very small Netlink buffer in conntrackd (+ a patch
which is not in the git tree to set the BROADCAST_ERROR flag)
and invoke `conntrack -F'.
For expectations, no changes are introduced in this patch.
Currently, event delivery is only done for new expectations (no
events from expectation expiration, removal and confirmation).
In that case, they need a per-expectation event cache to implement
the same idea that is exposed in this patch.
This patch can be useful to provide reliable flow-accouting. We
still have to add a new conntrack extension to store the creation
and destroy time.
Introduce per-conntrack locks and use them instead of the global protocol
locks to avoid contention. Especially tcp_lock shows up very high in
profiles on larger machines.
This will also allow to simplify the upcoming reliable event delivery patches.
Current conntrack code kills the ICMP conntrack entry as soon as
the first reply is received. This is incorrect, as we then see only
the first ICMP echo reply out of several possible duplicates as
ESTABLISHED, while the rest will be INVALID. Also this unnecessarily
increases the conntrackd traffic on H-A firewalls.
Make all the ICMP conntrack entries (including the replied ones)
last for the default of nf_conntrack_icmp{,v6}_timeout seconds.
Signed-off-by: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
During the module removal there are no possible event listeners
since ctnetlink must be removed before to allow removing
nf_conntrack. This patch removes the event reporting for the
module removal case which is not of any use in the existing code.
This patch move the internal tuple() macro definition to the
header file as nf_ct_tuple().
Use "hlist_nulls" infrastructure we added in 2.6.29 for RCUification of UDP & TCP.
This permits an easy conversion from call_rcu() based hash lists to a
SLAB_DESTROY_BY_RCU one.
Avoiding call_rcu() delay at nf_conn freeing time has numerous gains.
First, it doesnt fill RCU queues (up to 10000 elements per cpu).
This reduces OOM possibility, if queued elements are not taken into account
This reduces latency problems when RCU queue size hits hilimit and triggers
emergency mode.
- It allows fast reuse of just freed elements, permitting better use of
CPU cache.
- We delete rcu_head from "struct nf_conn", shrinking size of this structure
by 8 or 16 bytes.
This patch only takes care of "struct nf_conn".
call_rcu() is still used for less critical conntrack parts, that may
be converted later if necessary.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Table size is defined as unsigned, wheres the table maximum size is
defined as a signed integer. The calculation of max is 8 or 4,
multiplied the table size. Therefore the max value is aligned to
unsigned.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
As for now, the creation and update of conntracks via ctnetlink do not
propagate an event to userspace. This can result in inconsistent situations
if several userspace processes modify the connection tracking table by means
of ctnetlink at the same time. Specifically, using the conntrack command
line tool and conntrackd at the same time can trigger unconsistencies.
This patch also modifies the event cache infrastructure to pass the
process PID and the ECHO flag to nfnetlink_send() to report back
to userspace if the process that triggered the change needs so.
Based on a suggestion from Patrick McHardy.
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a
way to provide generic and persistent aliases for the connection
tracking helpers.
This next patch requires this patch.
sysctl
* make per-netns conntrack hash
Other solution is to add ->ct_net pointer to tuplehashes and still has one
hash, I tried that it's ugly and requires more code deep down in protocol
modules et al.
* propagate netns pointer to where needed, e. g. to conntrack iterators.
Sysctls and proc files are stubbed to init_net's one. This is temporary.
Conntrack (struct nf_conn) gets pointer to netns: ->ct_net -- netns in which
it was created. It comes from netdevice.
->ct_net is write-once field.
Every conntrack in system has ->ct_net initialized, no exceptions.
->ct_net doesn't pin netns: conntracks are recycled after timeouts and
pinning background traffic will prevent netns from even starting shutdown
sequence.
Right now every conntrack is created in init_net.
Initially netfilter has had 64bit counters for conntrack-based accounting, but
it was changed in 2.6.14 to save memory. Unfortunately in-kernel 64bit counters are
still required, for example for "connbytes" extension. However, 64bit counters
waste a lot of memory and it was not possible to enable/disable it runtime.
This patch:
- reimplements accounting with respect to the extension infrastructure,
- makes one global version of seq_print_acct() instead of two seq_print_counters(),
- makes it possible to enable it at boot time (for CONFIG_SYSCTL/CONFIG_SYSFS=n),
- makes it possible to enable/disable it at runtime by sysctl or sysfs,
- extends counters from 32bit to 64bit,
- renames ip_conntrack_counter -> nf_conn_counter,
- enables accounting code unconditionally (no longer depends on CONFIG_NF_CT_ACCT),
- set initial accounting enable state based on CONFIG_NF_CT_ACCT
- removes buggy IPCT_COUNTER_FILLING event handling.
If accounting is enabled newly created connections get additional acct extend.
Old connections are not changed as it is not possible to add a ct_extend area
to confirmed conntrack. Accounting is performed for all connections with
acct extend regardless of a current state of "net.netfilter.nf_conntrack_acct".
Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl>
ctnetlink does not need to allocate the conntrack entries with GFP_ATOMIC
as its code is executed in user context.
Currently the last packet of a connection isn't accounted when its causing
abnormal termination.
Introduces nf_ct_kill_acct() which increments the accounting counters on
conntrack kill. The new function was necessary, because there are calls
to nf_ct_kill() which don't need accounting:
nf_conntrack_proto_tcp.c line ~847:
Kills ct and returns NF_REPEAT. We don't want to count twice.
nf_conntrack_proto_tcp.c line ~880:
Kills ct and returns NF_DROP. I think we don't want to count dropped
packets.
nf_conntrack_netlink.c line ~824:
As far as I can see ctnetlink_del_conntrack() is used to destroy a
conntrack on behalf of the user. There is an sk_buff, but I don't think
this is an actual packet. Incrementing counters here is therefore not
desired.
Signed-off-by: Fabian Hugelshofer <hugelshofer2006@gmx.ch>
Encapsulate the common
if (del_timer(&ct->timeout))
ct->timeout.function((unsigned long)ct)
sequence in a new function.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Add accessors for l3num and protonum and get rid of some overly long
expressions.
New extensions may only be added to unconfirmed conntracks to avoid races
when reallocating the storage.
Also change NF_CT_ASSERT to use WARN_ON to get backtraces.
Add DCCP conntrack helper. Thanks to Gerrit Renker <gerrit@erg.abdn.ac.uk>
for review and testing.
Add support for multiple media channels and use it to create
expectations for video streams when present.
