some users of nf_ct_ext_exist() know ct->ext isn't NULL. For these users, the
check for ct->ext isn't necessary, the function __nf_ct_ext_exist() can be
used instead.
the type of the return value of nf_ct_ext_exist() is changed to bool.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
This patch reworks the per-cpu event caching to use the conntrack
extension infrastructure.
The main drawback is that we consume more memory per conntrack
if event delivery is enabled. This patch is required by the
reliable event delivery that follows to this patch.
BTW, this patch allows you to enable/disable event delivery via
/proc/sys/net/netfilter/nf_conntrack_events in runtime, although
you can still disable event caching as compilation option.
Initially netfilter has had 64bit counters for conntrack-based accounting, but
it was changed in 2.6.14 to save memory. Unfortunately in-kernel 64bit counters are
still required, for example for "connbytes" extension. However, 64bit counters
waste a lot of memory and it was not possible to enable/disable it runtime.
This patch:
- reimplements accounting with respect to the extension infrastructure,
- makes one global version of seq_print_acct() instead of two seq_print_counters(),
- makes it possible to enable it at boot time (for CONFIG_SYSCTL/CONFIG_SYSFS=n),
- makes it possible to enable/disable it at runtime by sysctl or sysfs,
- extends counters from 32bit to 64bit,
- renames ip_conntrack_counter -> nf_conn_counter,
- enables accounting code unconditionally (no longer depends on CONFIG_NF_CT_ACCT),
- set initial accounting enable state based on CONFIG_NF_CT_ACCT
- removes buggy IPCT_COUNTER_FILLING event handling.
If accounting is enabled newly created connections get additional acct extend.
Old connections are not changed as it is not possible to add a ct_extend area
to confirmed conntrack. Accounting is performed for all connections with
acct extend regardless of a current state of "net.netfilter.nf_conntrack_acct".
Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl>
Fix three ct_extend/NAT extension related races:
- When cleaning up the extension area and removing it from the bysource hash,
the nat->ct pointer must not be set to NULL since it may still be used in
a RCU read side
- When replacing a NAT extension area in the bysource hash, the nat->ct
pointer must be assigned before performing the replacement
- When reallocating extension storage in ct_extend, the old memory must
not be freed immediately since it may still be used by a RCU read side
Possibly fixes https://bugzilla.redhat.com/show_bug.cgi?id=449315
and/or http://bugzilla.kernel.org/show_bug.cgi?id=10875
There's a horrible slab abuse in net/netfilter/nf_conntrack_extend.c
that can be replaced with a call to ksize().
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
The ->move operation has two bugs:
- It is called with the same extension as source and destination,
so it doesn't update the new extension.
- The address of the old extension is calculated incorrectly,
instead of (void *)ct->ext + ct->ext->offset[i] it uses
ct->ext + ct->ext->offset[i].
Fixes a crash on x86_64 reported by Chuck Ebbert <cebbert@redhat.com>
and Thomas Woerner <twoerner@redhat.com>.
Tested-by: Thomas Woerner <twoerner@redhat.com>
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
Old space allocator of conntrack had problems about extensibility.
- It required slab cache per combination of extensions.
- It expected what extensions would be assigned, but it was impossible
to expect that completely, then we allocated bigger memory object than
really required.
- It needed to search helper twice due to lock issue.
Now basic informations of a connection are stored in 'struct nf_conn'.
And a storage for extension (helper, NAT) is allocated by kmalloc.
