The nat extension structure is 32bytes in size on x86_64:
struct nf_conn_nat {
struct hlist_node bysource; /* 0 16 */
struct nf_conn * ct; /* 16 8 */
union nf_conntrack_nat_help help; /* 24 4 */
int masq_index; /* 28 4 */
/* size: 32, cachelines: 1, members: 4 */
/* last cacheline: 32 bytes */
The hlist is needed to quickly check for possible tuple collisions
when installing a new nat binding. Storing this in the extension
area has two drawbacks:
1. We need ct backpointer to get the conntrack struct from the extension.
2. When reallocation of extension area occurs we need to fixup the bysource
hash head via hlist_replace_rcu.
We can avoid both by placing the hlist_head in nf_conn and place nf_conn in
the bysource hash rather than the extenstion.
We can also remove the ->move support; no other extension needs it.
Moving the entire nat extension into nf_conn would be possible as well but
then we have to add yet another callback for deletion from the bysource
hash table rather than just using nat extension ->destroy hook for this.
nf_conn size doesn't increase due to aligment, followup patch replaces
hlist_node with single pointer.
Curently we store zone information as a conntrack extension.
This has one drawback: for every lookup we need to fetch the zone data
from the extension area.
This change place the zone data directly into the main conntrack object
structure and then removes the zone conntrack extension.
The zone data is just 4 bytes, it fits into a padding hole before
the tuplehash info, so we do not even increase the nf_conn structure size.
"len" contains sizeof(nf_ct_ext) and size of extensions. In a worst
case it can contain all extensions. Bellow you can find sizes for all
types of extensions. Their sum is definitely bigger than 256.
nf_ct_ext_types[0]->len = 24
nf_ct_ext_types[1]->len = 32
nf_ct_ext_types[2]->len = 24
nf_ct_ext_types[3]->len = 32
nf_ct_ext_types[4]->len = 152
nf_ct_ext_types[5]->len = 2
nf_ct_ext_types[6]->len = 16
nf_ct_ext_types[7]->len = 8
I have seen "len" up to 280 and my host has crashes w/o this patch.
The right way to fix this problem is reducing the size of the ecache
extension (4) and Florian is going to do this, but these changes will
be quite large to be appropriate for a stable tree.
Fixes: 5b423f6a40a0 (netfilter: nf_conntrack: fix racy timer handling with reliable)
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Encapsulate counters for both directions into nf_conn_acct. During
that process also consistently name pointers to the extend 'acct',
not 'counters'. This patch is a cleanup.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
Commit 68b80f11 (netfilter: nf_nat: fix RCU races) introduced
RCU protection for freeing extension data when reallocation
moves them to a new location. We need the same protection when
freeing them in nf_ct_ext_free() in order to prevent a
use-after-free by other threads referencing a NAT extension data
via bysource list.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Add a SYNPROXY for netfilter. The code is split into two parts, the synproxy
core with common functions and an address family specific target.
The SYNPROXY receives the connection request from the client, responds with
a SYN/ACK containing a SYN cookie and announcing a zero window and checks
whether the final ACK from the client contains a valid cookie.
It then establishes a connection to the original destination and, if
successful, sends a window update to the client with the window size
announced by the server.
Support for timestamps, SACK, window scaling and MSS options can be
statically configured as target parameters if the features of the server
are known. If timestamps are used, the timestamp value sent back to
the client in the SYN/ACK will be different from the real timestamp of
the server. In order to now break PAWS, the timestamps are translated in
the direction server->client.
Tested-by: Martin Topholm <mph@one.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Split out sequence number adjustments from NAT and move them to the conntrack
core to make them usable for SYN proxying. The sequence number adjustment
information is moved to a seperate extend. The extend is added to new
conntracks when a NAT mapping is set up for a connection using a helper.
As a side effect, this saves 24 bytes per connection with NAT in the common
case that a connection does not have a helper assigned.
similar to connmarks, except labels are bit-based; i.e.
all labels may be attached to a flow at the same time.
Up to 128 labels are supported. Supporting more labels
is possible, but requires increasing the ct offset delta
from u8 to u16 type due to increased extension sizes.
Mapping of bit-identifier to label name is done in userspace.
The extension is enabled at run-time once "-m connlabel" netfilter
rules are added.
We can now define conntrack extensions of variable size. This
patch is useful to get rid of these unions:
union nf_conntrack_help
union nf_conntrack_proto
This patch adds the timeout extension, which allows you to attach
specific timeout policies to flows.
This extension is only used by the template conntrack.
This patch adds flow-based timestamping for conntracks. This
conntrack extension is disabled by default. Basically, we use
two 64-bits variables to store the creation timestamp once the
conntrack has been confirmed and the other to store the deletion
time. This extension is disabled by default, to enable it, you
have to:
echo 1 > /proc/sys/net/netfilter/nf_conntrack_timestamp
This patch allows to save memory for user-space flow-based
loogers such as ulogd2. In short, ulogd2 does not need to
keep a hashtable with the conntrack in user-space to know
when they were created and destroyed, instead we use the
kernel timestamp. If we want to have a sane IPFIX implementation
in user-space, this nanosecs resolution timestamps are also
useful. Other custom user-space applications can benefit from
this via libnetfilter_conntrack.
This patch modifies the /proc output to display the delta time
in seconds since the flow start. You can also obtain the
flow-start date by means of the conntrack-tools.
Less IDs make nf_ct_ext smaller.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
some users of nf_ct_ext_exist() know ct->ext isn't NULL. For these users, the
check for ct->ext isn't necessary, the function __nf_ct_ext_exist() can be
used instead.
the type of the return value of nf_ct_ext_exist() is changed to bool.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
This patch reworks the per-cpu event caching to use the conntrack
extension infrastructure.
The main drawback is that we consume more memory per conntrack
if event delivery is enabled. This patch is required by the
reliable event delivery that follows to this patch.
BTW, this patch allows you to enable/disable event delivery via
/proc/sys/net/netfilter/nf_conntrack_events in runtime, although
you can still disable event caching as compilation option.
Initially netfilter has had 64bit counters for conntrack-based accounting, but
it was changed in 2.6.14 to save memory. Unfortunately in-kernel 64bit counters are
still required, for example for "connbytes" extension. However, 64bit counters
waste a lot of memory and it was not possible to enable/disable it runtime.
This patch:
- reimplements accounting with respect to the extension infrastructure,
- makes one global version of seq_print_acct() instead of two seq_print_counters(),
- makes it possible to enable it at boot time (for CONFIG_SYSCTL/CONFIG_SYSFS=n),
- makes it possible to enable/disable it at runtime by sysctl or sysfs,
- extends counters from 32bit to 64bit,
- renames ip_conntrack_counter -> nf_conn_counter,
- enables accounting code unconditionally (no longer depends on CONFIG_NF_CT_ACCT),
- set initial accounting enable state based on CONFIG_NF_CT_ACCT
- removes buggy IPCT_COUNTER_FILLING event handling.
If accounting is enabled newly created connections get additional acct extend.
Old connections are not changed as it is not possible to add a ct_extend area
to confirmed conntrack. Accounting is performed for all connections with
acct extend regardless of a current state of "net.netfilter.nf_conntrack_acct".
Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl>
Fix three ct_extend/NAT extension related races:
- When cleaning up the extension area and removing it from the bysource hash,
the nat->ct pointer must not be set to NULL since it may still be used in
a RCU read side
- When replacing a NAT extension area in the bysource hash, the nat->ct
pointer must be assigned before performing the replacement
- When reallocating extension storage in ct_extend, the old memory must
not be freed immediately since it may still be used by a RCU read side
Possibly fixes https://bugzilla.redhat.com/show_bug.cgi?id=449315
and/or http://bugzilla.kernel.org/show_bug.cgi?id=10875
There's a horrible slab abuse in net/netfilter/nf_conntrack_extend.c
that can be replaced with a call to ksize().
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
The ->move operation has two bugs:
- It is called with the same extension as source and destination,
so it doesn't update the new extension.
- The address of the old extension is calculated incorrectly,
instead of (void *)ct->ext + ct->ext->offset[i] it uses
ct->ext + ct->ext->offset[i].
Fixes a crash on x86_64 reported by Chuck Ebbert <cebbert@redhat.com>
and Thomas Woerner <twoerner@redhat.com>.
Tested-by: Thomas Woerner <twoerner@redhat.com>
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
Old space allocator of conntrack had problems about extensibility.
- It required slab cache per combination of extensions.
- It expected what extensions would be assigned, but it was impossible
to expect that completely, then we allocated bigger memory object than
really required.
- It needed to search helper twice due to lock issue.
Now basic informations of a connection are stored in 'struct nf_conn'.
And a storage for extension (helper, NAT) is allocated by kmalloc.
