This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Avoid double seq adjustment for loopback traffic
because it causes silent repetition of TCP data. One
example is passive FTP with DNAT rule and difference in the
length of IP addresses.
This patch adds check if packet is sent and
received via loopback device. As the same conntrack is
used both for outgoing and incoming direction, we restrict
seq adjustment to happen only in POSTROUTING.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
These header files are never installed to user consumption, so any
__KERNEL__ cpp checks are superfluous.
Projects should also not copy these files into their userland utility
sources and try to use them there. If they insist on doing so, the
onus is on them to sanitize the headers as needed.
Documentation/feature-removal-schedule.txt
drivers/net/e1000e/netdev.c
net/xfrm/xfrm_policy.c
Assigning a socket in timewait state to skb->sk can trigger
kernel oops, e.g. in nfnetlink_log, which does:
if (skb->sk) {
read_lock_bh(&skb->sk->sk_callback_lock);
if (skb->sk->sk_socket && skb->sk->sk_socket->file) ...
in the timewait case, accessing sk->sk_callback_lock and sk->sk_socket
is invalid.
Either all of these spots will need to add a test for sk->sk_state != TCP_TIME_WAIT,
or xt_TPROXY must not assign a timewait socket to skb->sk.
This does the latter.
If a TW socket is found, assign the tproxy nfmark, but skip the skb->sk assignment,
thus mimicking behaviour of a '-m socket .. -j MARK/ACCEPT' re-routing rule.
The 'SYN to TW socket' case is left unchanged -- we try to redirect to the
listener socket.
Cc: Balazs Scheidler <bazsi@balabit.hu>
Cc: KOVACS Krisztian <hidden@balabit.hu>
Signed-off-by: Florian Westphal <fwestphal@astaro.com>
For the following rule:
iptables -I PREROUTING -t raw -j CT --ctevents assured
The event delivered looks like the following:
[UPDATE] tcp 6 src=192.168.0.2 dst=192.168.1.2 sport=37041 dport=80 src=192.168.1.2 dst=192.168.1.100 sport=80 dport=37041 [ASSURED]
Note that the TCP protocol state is not included. For that reason
the CT event filtering is not very useful for conntrackd.
To resolve this issue, instead of conditionally setting the CT events
bits based on the ctmask, we always set them and perform the filtering
in the late stage, just before the delivery.
Thus, the event delivered looks like the following:
[UPDATE] tcp 6 432000 ESTABLISHED src=192.168.0.2 dst=192.168.1.2 sport=37041 dport=80 src=192.168.1.2 dst=192.168.1.100 sport=80 dport=37041 [ASSURED]
net/built-in.o: In function `nf_conntrack_init_net':
net/netfilter/nf_conntrack_core.c:1521:
undefined reference to `nf_conntrack_tstamp_init'
net/netfilter/nf_conntrack_core.c:1531:
undefined reference to `nf_conntrack_tstamp_fini'
Add dummy inline functions for the =n case to fix this.
Reported-by: John Fastabend <john.r.fastabend@intel.com>
This patch adds flow-based timestamping for conntracks. This
conntrack extension is disabled by default. Basically, we use
two 64-bits variables to store the creation timestamp once the
conntrack has been confirmed and the other to store the deletion
time. This extension is disabled by default, to enable it, you
have to:
echo 1 > /proc/sys/net/netfilter/nf_conntrack_timestamp
This patch allows to save memory for user-space flow-based
loogers such as ulogd2. In short, ulogd2 does not need to
keep a hashtable with the conntrack in user-space to know
when they were created and destroyed, instead we use the
kernel timestamp. If we want to have a sane IPFIX implementation
in user-space, this nanosecs resolution timestamps are also
useful. Other custom user-space applications can benefit from
this via libnetfilter_conntrack.
This patch modifies the /proc output to display the delta time
in seconds since the flow start. You can also obtain the
flow-start date by means of the conntrack-tools.
Adding support for SNMP broadcast connection tracking. The SNMP
broadcast requests are now paired with the SNMP responses.
Thus allowing using SNMP broadcasts with firewall enabled.
Please refer to the following conversation:
http://marc.info/?l=netfilter-devel&m=125992205006600&w=2
Patrick McHardy wrote:
> > The best solution would be to add generic broadcast tracking, the
> > use of expectations for this is a bit of abuse.
> > The second best choice I guess would be to move the help() function
> > to a shared module and generalize it so it can be used for both.
This patch implements the "second best choice".
Since the netbios-ns conntrack module uses the same helper
functionality as the snmp, only one helper function is added
for both snmp and netbios-ns modules into the new object -
nf_conntrack_broadcast.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
My previous patch (netfilter: nf_nat: don't use atomic bit operation)
made a mistake when converting atomic_set to a normal bit 'or'.
IPS_*_BIT should be replaced with IPS_*.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Cc: Tim Gardner <tim.gardner@canonical.com>
Use is_vmalloc_addr() in nf_ct_free_hashtable() and get rid of
the vmalloc flags to indicate that a hash table has been allocated
using vmalloc().
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 into HEAD
The IPv6 tproxy patches split IPv6 defragmentation off of conntrack, but
failed to update the #ifdef stanzas guarding the defragmentation related
fields and code in skbuff and conntrack related code in nf_defrag_ipv6.c.
This patch adds the required #ifdefs so that IPv6 tproxy can truly be used
without connection tracking.
Original report:
http://marc.info/?l=linux-netdev&m=129010118516341&w=2
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
Since nf_ct_expect_dst_hash() may be called without nf_conntrack_lock
locked, nf_ct_expect_hash_rnd should be initialized in the atomic way.
In this patch, we use nf_conntrack_hash_rnd instead of
nf_ct_expect_hash_rnd.
Original report:
Add some __rcu annotations and use helpers to reduce number of sparse
warnings (CONFIG_SPARSE_RCU_POINTER=y)
Less IDs make nf_ct_ext smaller.
As we own the conntrack and the others can't see it until we confirm it,
we don't need to use atomic bit operation on ct->status.
ct->proto is big(60 bytes) due to structure ip_ct_tcp, and we don't need
to initialize the whole for all the other protocols. This patch moves
proto to the end of structure nf_conn, and pushes the initialization down
to the individual protocols.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
Like with IPv4, TProxy needs IPv6 defragmentation but does not
require connection tracking. Since defragmentation was coupled
with conntrack, I split off the two, creating an nf_defrag_ipv6 module,
similar to the already existing nf_defrag_ipv4.
Also, inline this function as the lookup_type is always a literal
and inlining removes branches performed at runtime.
the same tuple
Without tproxy redirections an incoming SYN kicks out conflicting
TIME_WAIT sockets, in order to handle clients that reuse ports
within the TIME_WAIT period.
The same mechanism didn't work in case TProxy is involved in finding
the proper socket, as the time_wait processing code looked up the
listening socket assuming that the listener addr/port matches those
of the established connection.
This is not the case with TProxy as the listener addr/port is possibly
changed with the tproxy rule.
This patch allows to listen to events that inform about
expectations destroyed.
Forgot to add xt_log.h in commit a8defca0 (netfilter: ipt_LOG:
add bufferisation to call printk() once)
The functions nf_nat_proto_find_get and nf_nat_proto_put are
only used internally in nf_nat_core. This might break some out
of tree NAT module.
This patch adds the basic infrastructure to support user-space
expectation helpers via ctnetlink and the netfilter queuing
infrastructure NFQUEUE. Basically, this patch:
* adds NF_CT_EXPECT_USERSPACE flag to identify user-space
created expectations. I have also added a sanity check in
__nf_ct_expect_check() to avoid that kernel-space helpers
may create an expectation if the master conntrack has no
helper assigned.
* adds some branches to check if the master conntrack helper
exists, otherwise we skip the code that refers to kernel-space
helper such as the local expectation list and the expectation
policy.
* allows to set the timeout for user-space expectations with
no helper assigned.
* a list of expectations created from user-space that depends
on ctnetlink (if this module is removed, they are deleted).
* includes USERSPACE in the /proc output for expectations
that have been created by a user-space helper.
This patch also modifies ctnetlink to skip including the helper
name in the Netlink messages if no kernel-space helper is set
(since no user-space expectation has not kernel-space kernel
assigned).
You can access an example user-space FTP conntrack helper at:
http://people.netfilter.org/pablo/userspace-conntrack-helpers/nf-ftp-helper-userspace-POC.tar.bz
With this patch, you can specify the expectation flags for user-space
Acked-by: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The only user of unique_tuple() get_unique_tuple() doesn't care about the
return value of unique_tuple(), so make unique_tuple() return void (nothing).
some users of nf_ct_ext_exist() know ct->ext isn't NULL. For these users, the
check for ct->ext isn't necessary, the function __nf_ct_ext_exist() can be
used instead.
the type of the return value of nf_ct_ext_exist() is changed to bool.
This patch moves NFULNL_COPY_PACKET definition from
linux/netfilter/nfnetlink_log.h to net/netfilter/nfnetlink_log.h
since this copy mode is only for internal use.
I have also changed the value from 0x03 to 0xff. Thus, we avoid
a gap from user-space that may confuse users if we add new
copy modes in the future.
This change was introduced in:
http://www.spinics.net/lists/netfilter-devel/msg13535.html
Since this change is not included in any stable Linux kernel,
I think it's safe to make this change now. Anyway, this copy
mode does not make any sense from user-space, so this patch
should not break any existing setup.
Check at rule install time that CT accounting is enabled. Force it
to be enabled if not while also emitting a warning since this is not
the default state.
This is in preparation for deprecating CONFIG_NF_CT_ACCT upon which
CONFIG_NETFILTER_XT_MATCH_CONNBYTES depended being set.
Added 2 CT accounting support functions:
nf_ct_acct_enabled() - Get CT accounting state.
nf_ct_set_acct() - Enable/disable CT accountuing.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Acked-by: Jan Engelhardt <jengelh@medozas.de>
2.6.34 introduced 'conntrack zones' to deal with cases where packets
from multiple identical networks are handled by conntrack/NAT. Packets
are looped through veth devices, during which they are NATed to private
addresses, after which they can continue normally through the stack
and possibly have NAT rules applied a second time.
This works well, but is needlessly complicated for cases where only
a single SNAT/DNAT mapping needs to be applied to these packets. In that
case, all that needs to be done is to assign each network to a seperate
zone and perform NAT as usual. However this doesn't work for packets
destined for the machine performing NAT itself since its corrently not
possible to configure SNAT mappings for the LOCAL_IN chain.
This patch adds a new INPUT chain to the NAT table and changes the
targets performing SNAT to be usable in that chain.
Example usage with two identical networks (192.168.0.0/24) on eth0/eth1:
iptables -t raw -A PREROUTING -i eth0 -j CT --zone 1
iptables -t raw -A PREROUTING -i eth0 -j MARK --set-mark 1
iptables -t raw -A PREROUTING -i eth1 -j CT --zone 2
iptabels -t raw -A PREROUTING -i eth1 -j MARK --set-mark 2
iptables -t nat -A INPUT -m mark --mark 1 -j NETMAP --to 10.0.0.0/24
iptables -t nat -A POSTROUTING -m mark --mark 1 -j NETMAP --to 10.0.0.0/24
iptables -t nat -A INPUT -m mark --mark 2 -j NETMAP --to 10.0.1.0/24
iptables -t nat -A POSTROUTING -m mark --mark 2 -j NETMAP --to 10.0.1.0/24
iptables -t raw -A PREROUTING -d 10.0.0.0/24 -j CT --zone 1
iptables -t raw -A OUTPUT -d 10.0.0.0/24 -j CT --zone 1
iptables -t raw -A PREROUTING -d 10.0.1.0/24 -j CT --zone 2
iptables -t raw -A OUTPUT -d 10.0.1.0/24 -j CT --zone 2
iptables -t nat -A PREROUTING -d 10.0.0.0/24 -j NETMAP --to 192.168.0.0/24
iptables -t nat -A OUTPUT -d 10.0.0.0/24 -j NETMAP --to 192.168.0.0/24
iptables -t nat -A PREROUTING -d 10.0.1.0/24 -j NETMAP --to 192.168.0.0/24
iptables -t nat -A OUTPUT -d 10.0.1.0/24 -j NETMAP --to 192.168.0.0/24
include/net/netfilter/xt_rateest.h
net/bridge/br_netfilter.c
gen_kill_estimator() API is incomplete or not well documented, since
caller should make sure an RCU grace period is respected before
freeing stats_lock.
This was partially addressed in commit 5d944c640b4
(gen_estimator: deadlock fix), but same problem exist for all
gen_kill_estimator() users, if lock they use is not already RCU
protected.
A code review shows xt_RATEEST.c, act_api.c, act_police.c have this
problem. Other are ok because they use qdisc lock, already RCU
protected.
NOTRACK makes all cpus share a cache line on nf_conntrack_untracked
twice per packet, slowing down performance.
This patch converts it to a per_cpu variable.
twice per packet. This is bad for performance.
__read_mostly annotation is also a bad choice.
This patch introduces IPS_UNTRACKED bit so that we can use later a
per_cpu untrack structure more easily.
A new helper, nf_ct_untracked_get() returns a pointer to
nf_conntrack_untracked.
Another one, nf_ct_untracked_status_or() is used by nf_nat_init() to add
IPS_NAT_DONE_MASK bits to untracked status.
nf_ct_is_untracked() prototype is changed to work on a nf_conn pointer.
We currently dirty two cache lines in struct xt_rateest, this hurts SMP
performance.
This patch moves lock/bstats/rstats at beginning of structure so that
they share a single cache line.
Use read_pnet() and write_pnet() to reduce number of ifdef CONFIG_NET_NS
nf_ct_get_next_corpse()
This race was triggered by a 'conntrack -F' command running in parallel
to the insertion of a hash for a new connection. Losing this race led to
a dead conntrack entry effectively blocking traffic for a particular
connection until timeout or flushing the conntrack hashes again.
Now the check for an already dying connection is done inside the lock.
Signed-off-by: Joerg Marx <joerg.marx@secunet.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
As reported by Randy Dunlap <randy.dunlap@oracle.com>, compilation
of nf_defrag_ipv4 fails with:
include/net/netfilter/nf_conntrack.h:94: error: field 'ct_general' has incomplete type
include/net/netfilter/nf_conntrack.h:178: error: 'const struct sk_buff' has no member named 'nfct'
include/net/netfilter/nf_conntrack.h:185: error: implicit declaration of function 'nf_conntrack_put'
include/net/netfilter/nf_conntrack.h:294: error: 'const struct sk_buff' has no member named 'nfct'
net/ipv4/netfilter/nf_defrag_ipv4.c:45: error: 'struct sk_buff' has no member named 'nfct'
net/ipv4/netfilter/nf_defrag_ipv4.c:46: error: 'struct sk_buff' has no member named 'nfct'
net/nf_conntrack.h must not be included with NF_CONNTRACK=n, add a
few #ifdefs. Long term the header file should be fixed to be usable
even with NF_CONNTRACK=n.
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
The error handlers might need the template to get the conntrack zone
introduced in the next patches to perform a conntrack lookup.
Remove #ifdef at nf_ct_exp_net() by using nf_ct_net().
