commit 5f3e2bf008c2221478101ee72f5cb4654b9fc363 upstream.
Some TCP peers announce a very small MSS option in their SYN and/or
SYN/ACK messages.
This forces the stack to send packets with a very high network/cpu
overhead.
Linux has enforced a minimal value of 48. Since this value includes
the size of TCP options, and that the options can consume up to 40
bytes, this means that each segment can include only 8 bytes of payload.
In some cases, it can be useful to increase the minimal value
to a saner value.
We still let the default to 48 (TCP_MIN_SND_MSS), for compatibility
reasons.
Note that TCP_MAXSEG socket option enforces a minimal value
of (TCP_MIN_MSS). David Miller increased this minimal value
in commit c39508d6f118 ("tcp: Make TCP_MAXSEG minimum more correct.")
from 64 to 88.
We might in the future merge TCP_MIN_SND_MSS and TCP_MIN_MSS.
CVE-2019-11479 -- tcp mss hardcoded to 48
Suggested-by: Jonathan Looney <jtl@netflix.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Bruce Curtis <brucec@netflix.com>
Cc: Jonathan Lemon <jonathan.lemon@gmail.com>
[ Upstream commit df453700e8d81b1bdafdf684365ee2b9431fb702 ]
According to Amit Klein and Benny Pinkas, IP ID generation is too weak
and might be used by attackers.
Even with recent net_hash_mix() fix (netns: provide pure entropy for net_hash_mix())
having 64bit key and Jenkins hash is risky.
It is time to switch to siphash and its 128bit keys.
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The FIB notification chain is currently soley used by IPv4 code.
However, we're going to introduce IPv6 FIB offload support, which
requires these notification as well.
As explained in commit c3852ef7f2f8 ("ipv4: fib: Replay events when
registering FIB notifier"), upon registration to the chain, the callee
receives a full dump of the FIB tables and rules by traversing all the
net namespaces. The integrity of the dump is ensured by a per-namespace
sequence counter that is incremented whenever a change to the tables or
rules occurs.
In order to allow more address families to use the chain, each family is
expected to register its fib_notifier_ops in its pernet init. These
operations allow the common code to read the family's sequence counter
as well as dump its tables and rules in the given net namespace.
Additionally, a 'family' parameter is added to sent notifications, so
that listeners could distinguish between the different families.
Implement the common code that allows listeners to register to the chain
and for address families to register their fib_notifier_ops. Subsequent
patches will implement these operations in IPv6.
In the future, ipmr and ip6mr will be extended to provide these
notifications as well.
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Certain system process significant unconnected UDP workload.
It would be preferrable to disable UDP early demux for those systems
and enable it for TCP only.
By disabling UDP demux, we see these slight gains on an ARM64 system-
782 -> 788Mbps unconnected single stream UDPv4
633 -> 654Mbps unconnected UDPv4 different sources
The performance impact can change based on CPU architecure and cache
sizes. There will not much difference seen if entire UDP hash table
is in cache.
Both sysctls are enabled by default to preserve existing behavior.
v1->v2: Change function pointer instead of adding conditional as
suggested by Stephen.
v2->v3: Read once in callers to avoid issues due to compiler
optimizations. Also update commit message with the tests.
v3->v4: Store and use read once result instead of querying pointer
again incorrectly.
v4->v5: Refactor to avoid errors due to compilation with IPV6={m,n}
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Suggested-by: Eric Dumazet <edumazet@google.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Tom Herbert <tom@herbertland.com>
This patch adds support for ECMP hash policy choice via a new sysctl
called fib_multipath_hash_policy and also adds support for L4 hashes.
The current values for fib_multipath_hash_policy are:
0 - layer 3 (default)
1 - layer 4
If there's an skb hash already set and it matches the chosen policy then it
will be used instead of being calculated (currently only for L4).
In L3 mode we always calculate the hash due to the ICMP error special
case, the flow dissector's field consistentification should handle the
address order thus we can remove the address reversals.
If the skb is provided we always use it for the hash calculation,
otherwise we fallback to fl4, that is if skb is NULL fl4 has to be set.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
The tcp_tw_recycle was already broken for connections
behind NAT, since the per-destination timestamp is not
monotonically increasing for multiple machines behind
a single destination address.
After the randomization of TCP timestamp offsets
in commit 8a5bd45f6616 (tcp: randomize tcp timestamp offsets
for each connection), the tcp_tw_recycle is broken for all
types of connections for the same reason: the timestamps
received from a single machine is not monotonically increasing,
anymore.
Remove tcp_tw_recycle, since it is not functional. Also, remove
the PAWSPassive SNMP counter since it is only used for
tcp_tw_recycle, and simplify tcp_v4_route_req and tcp_v6_route_req
since the strict argument is only set when tcp_tw_recycle is
enabled.
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Cc: Lutz Vieweg <lvml@5t9.de>
Cc: Florian Westphal <fw@strlen.de>
Packets arriving in a VRF currently are delivered to UDP sockets that
aren't bound to any interface. TCP defaults to not delivering packets
arriving in a VRF to unbound sockets. IP route lookup and socket
transmit both assume that unbound means using the default table and
UDP applications that haven't been changed to be aware of VRFs may not
function correctly in this case since they may not be able to handle
overlapping IP address ranges, or be able to send packets back to the
original sender if required.
So add a sysctl, udp_l3mdev_accept, to control this behaviour with it
being analgous to the existing tcp_l3mdev_accept, namely to allow a
process to have a VRF-global listen socket. Have this default to off
as this is the behaviour that users will expect, given that there is
no explicit mechanism to set unmodified VRF-unaware application into a
default VRF.
Signed-off-by: Robert Shearman <rshearma@brocade.com>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
Tested-by: David Ahern <dsa@cumulusnetworks.com>
Add net.ipv4.ip_unprivileged_port_start, which is a per namespace sysctl
that denotes the first unprivileged inet port in the namespace. To
disable all privileged ports set this to zero. It also checks for
overlap with the local port range. The privileged and local range may
not overlap.
The use case for this change is to allow containerized processes to bind
to priviliged ports, but prevent them from ever being allowed to modify
their container's network configuration. The latter is accomplished by
ensuring that the network namespace is not a child of the user
namespace. This modification was needed to allow the container manager
to disable a namespace's priviliged port restrictions without exposing
control of the network namespace to processes in the user namespace.
Signed-off-by: Krister Johansen <kjlx@templeofstupid.com>
Different namespace application might require different maximal
number of remembered connection requests.
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
Different namespace application might require fast recycling
TIME-WAIT sockets independently of the host.
Different namespaces might have different requirements to reuse
TIME-WAIT sockets for new connections. This might be required in
cases where different namespace applications are in place which
require TIME_WAIT socket connections to be reduced independently
of the host.
The next patch will enable listeners of the FIB notification chain to
request a dump of the FIB tables. However, since RTNL isn't taken during
the dump, it's possible for the FIB tables to change mid-dump, which
will result in inconsistency between the listener's table and the
kernel's.
Allow listeners to know about changes that occurred mid-dump, by adding
a change sequence counter to each net namespace. The counter is
incremented just before a notification is sent in the FIB chain.
After commit 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
fib_local is set but not used. Remove it.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Multipath route lookups should consider knowledge about next hops and not
select a hop that is known to be failed.
Example:
[h2] [h3] 15.0.0.5
3| 3|
[SP1] [SP2]--+
1 2 1 2
| X |
1 2 1 2
12.0.0.2 [TOR1] 3-----------------3 [TOR2] 12.0.0.3
4 4
1 2
[TOR3]
3|
[h1] 12.0.0.1
host h1 with IP 12.0.0.1 has 2 paths to host h3 at 15.0.0.5:
root@h1:~# ip ro ls
12.0.0.0/24 dev swp1 proto kernel scope link src 12.0.0.1
15.0.0.0/16
nexthop via 12.0.0.2 dev swp1 weight 1
nexthop via 12.0.0.3 dev swp1 weight 1
If the link between tor3 and tor1 is down and the link between tor1
and tor2 then tor1 is effectively cut-off from h1. Yet the route lookups
in h1 are alternating between the 2 routes: ping 15.0.0.5 gets one and
ssh 15.0.0.5 gets the other. Connections that attempt to use the
12.0.0.2 nexthop fail since that neighbor is not reachable:
root@h1:~# ip neigh show
12.0.0.3 dev swp1 lladdr 00:02:00:00:00:1b REACHABLE
12.0.0.2 dev swp1 FAILED
The failed path can be avoided by considering known neighbor information
when selecting next hops. If the neighbor lookup fails we have no
knowledge about the nexthop, so give it a shot. If there is an entry
then only select the nexthop if the state is sane. This is similar to
what fib_detect_death does.
To maintain backward compatibility use of the neighbor information is
based on a new sysctl, fib_multipath_use_neigh.
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
This was initially introduced in df2cf4a78e488d26 ("IGMP: Inhibit
reports for local multicast groups") by defining the sysctl in the
ipv4_net_table array, however it was never implemented to be
namespace aware. Fix this by changing the code accordingly.
This is the final part required to namespaceify the tcp
keep alive mechanism.
This is required to have full tcp keepalive mechanism namespace
support.
Different net namespaces might have different requirements as to
the keepalive time of tcp sockets. This might be required in cases
where different firewall rules are in place which require tcp
timeout sockets to be increased/decreased independently of the host.
Allow accepted sockets to derive their sk_bound_dev_if setting from the
l3mdev domain in which the packets originated. A sysctl setting is added
to control the behavior which is similar to sk_mark and
sysctl_tcp_fwmark_accept.
This effectively allow a process to have a "VRF-global" listen socket,
with child sockets bound to the VRF device in which the packet originated.
A similar behavior can be achieved using sk_mark, but a solution using marks
is incomplete as it does not handle duplicate addresses in different L3
domains/VRFs. Allowing sockets to inherit the sk_bound_dev_if from l3mdev
domain provides a complete solution.
After commit 07f4c90062f8f ("tcp/dccp: try to not exhaust
ip_local_port_range in connect()") it is advised to have an even number
of ports described in /proc/sys/net/ipv4/ip_local_port_range
This means start/end values should have a different parity.
Let's warn sysadmins of this, so that they can update their settings
if they want to.
Suggested-by: David S. Miller <davem@davemloft.net>
This work as a follow-up of commit f7b3bec6f516 ("net: allow setting ecn
via routing table") and adds RFC3168 section 6.1.1.1. fallback for outgoing
ECN connections. In other words, this work adds a retry with a non-ECN
setup SYN packet, as suggested from the RFC on the first timeout:
[...] A host that receives no reply to an ECN-setup SYN within the
normal SYN retransmission timeout interval MAY resend the SYN and
any subsequent SYN retransmissions with CWR and ECE cleared. [...]
Schematic client-side view when assuming the server is in tcp_ecn=2 mode,
that is, Linux default since 2009 via commit 255cac91c3c9 ("tcp: extend
ECN sysctl to allow server-side only ECN"):
1) Normal ECN-capable path:
SYN ECE CWR ----->
<----- SYN ACK ECE
ACK ----->
2) Path with broken middlebox, when client has fallback:
SYN ECE CWR ----X crappy middlebox drops packet
(timeout, rtx)
SYN ----->
<----- SYN ACK
ACK ----->
In case we would not have the fallback implemented, the middlebox drop
point would basically end up as:
(timeout, rtx)
(timeout, rtx)
(timeout, rtx)
In any case, it's rather a smaller percentage of sites where there would
occur such additional setup latency: it was found in end of 2014 that ~56%
of IPv4 and 65% of IPv6 servers of Alexa 1 million list would negotiate
ECN (aka tcp_ecn=2 default), 0.42% of these webservers will fail to connect
when trying to negotiate with ECN (tcp_ecn=1) due to timeouts, which the
fallback would mitigate with a slight latency trade-off. Recent related
paper on this topic:
Brian Trammell, Mirja Kühlewind, Damiano Boppart, Iain Learmonth,
Gorry Fairhurst, and Richard Scheffenegger:
"Enabling Internet-Wide Deployment of Explicit Congestion Notification."
Proc. PAM 2015, New York.
http://ecn.ethz.ch/ecn-pam15.pdf
Thus, when net.ipv4.tcp_ecn=1 is being set, the patch will perform RFC3168,
section 6.1.1.1. fallback on timeout. For users explicitly not wanting this
which can be in DC use case, we add a net.ipv4.tcp_ecn_fallback knob that
allows for disabling the fallback.
tp->ecn_flags are not being cleared in tcp_ecn_clear_syn() on output, but
rather we let tcp_ecn_rcv_synack() take that over on input path in case a
SYN ACK ECE was delayed. Thus a spurious SYN retransmission will not prevent
ECN being negotiated eventually in that case.
Reference: https://www.ietf.org/proceedings/92/slides/slides-92-iccrg-1.pdf
Reference: https://www.ietf.org/proceedings/89/slides/slides-89-tsvarea-1.pdf
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Mirja Kühlewind <mirja.kuehlewind@tik.ee.ethz.ch>
Signed-off-by: Brian Trammell <trammell@tik.ee.ethz.ch>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Dave That <dave.taht@gmail.com>
Now that all of the operations are safe on a single hash table
accross network namespaces, allocate a single global hash table
and update the code to use it.
As per RFC4821 7.3. Selecting Probe Size, a probe timer should
be armed once probing has converged. Once this timer expired,
probing again to take advantage of any path PMTU change. The
recommended probing interval is 10 minutes per RFC1981. Probing
interval could be sysctled by sysctl_tcp_probe_interval.
Eric Dumazet suggested to implement pseudo timer based on 32bits
jiffies tcp_time_stamp instead of using classic timer for such
rare event.
Signed-off-by: Fan Du <fan.du@intel.com>
Current probe_size is chosen by doubling mss_cache,
the probing process will end shortly with a sub-optimal
mss size, and the link mtu will not be taken full
advantage of, in return, this will make user to tweak
tcp_base_mss with care.
Use binary search to choose probe_size in a fine
granularity manner, an optimal mss will be found
to boost performance as its maxmium.
In addition, introduce a sysctl_tcp_probe_threshold
to control when probing will stop in respect to
the width of search range.
Test env:
Docker instance with vxlan encapuslation(82599EB)
iperf -c 10.0.0.24 -t 60
before this patch:
1.26 Gbits/sec
After this patch: increase 26%
1.59 Gbits/sec
Acked-by: John Heffner <johnwheffner@gmail.com>
If something goes wrong with IPv4 FIB offload, mark entire net offload
disabled. This is brute force policy to basically shut down IPv4 FIB offload
permanently if there is a problem offloading any route to an external device.
We can refine the policy in the future, to handle failures on a per-device or
per-route basis, but for now, this policy is per-net.
What we're trying to avoid is an inconsistent split between the kernel's FIB
and the offload device's FIB. We don't want the device to fwd a pkt
inconsitent with what the kernel would do. An example of a split is if device
has 10.0.0.0/16 and kernel has 10.0.0.0/16 and 10.0.0.0/24, the device wouldn't
see the longest prefix 10.0.0.0/24 and potentially forward pkts incorrectly.
Limited capacity or limited capability are two ways a route may fail to install
to the offload device. We'll not differentiate between failures at this time,
and treat any failure as fatal and mark the net as fib_offload_disabled.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
The fib_table was wrapped in several places with an
rcu_read_lock/rcu_read_unlock however after looking over the code I found
several spots where the tables were being accessed as just standard
pointers without any protections. This change fixes that so that all of
the proper protections are in place when accessing the table to take RCU
replacement or removal of the table into account.
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Joining multicast group on ethernet level via "ip maddr" command would
not work if we have an Ethernet switch that does igmp snooping since
the switch would not replicate multicast packets on ports that did not
have IGMP reports for the multicast addresses.
Linux vxlan interfaces created via "ip link add vxlan" have the group option
that enables then to do the required join.
By extending ip address command with option "autojoin" we can get similar
functionality for openvswitch vxlan interfaces as well as other tunneling
mechanisms that need to receive multicast traffic. The kernel code is
structured similar to how the vxlan driver does a group join / leave.
example:
ip address add 224.1.1.10/24 dev eth5 autojoin
ip address del 224.1.1.10/24 dev eth5
Signed-off-by: Madhu Challa <challa@noironetworks.com>
Packetization Layer Path MTU Discovery works separately beside
Path MTU Discovery at IP level, different net namespace has
various requirements on which one to chose, e.g., a virutalized
container instance would require TCP PMTU to probe an usable
effective mtu for underlying tunnel, while the host would
employ classical ICMP based PMTU to function.
Hence making TCP PMTU mechanism per net namespace to decouple
two functionality. Furthermore the probe base MSS should also
be configured separately for each namespace.
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
Get rid of nr_cpu_ids and use modern percpu allocation.
Note that the sockets themselves are not yet allocated
using NUMA affinity.
