path: root/include/net/request_sock.h
2013-10-10inet: includes a sock_common in request_sockEric Dumazet
TCP listener refactoring, part 5 : We want to be able to insert request sockets (SYN_RECV) into main ehash table instead of the per listener hash table to allow RCU lookups and remove listener lock contention. This patch includes the needed struct sock_common in front of struct request_sock This means there is no more inet6_request_sock IPv6 specific structure. Following inet_request_sock fields were renamed as they became macros to reference fields from struct sock_common. Prefix ir_ was chosen to avoid name collisions. loc_port -> ir_loc_port loc_addr -> ir_loc_addr rmt_addr -> ir_rmt_addr rmt_port -> ir_rmt_port iif -> ir_iif Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-23request_sock.h: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22net: remove a stale comment for dl_nextEric Dumazet
dl_next member in struct request_sock doesn't need to be first. We expect to insert a "struct common_sock" or a subset of it, so this claim had to be verified. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-17tcp: Remove TCPCTChristoph Paasch
TCPCT uses option-number 253, reserved for experimental use and should not be used in production environments. Further, TCPCT does not fully implement RFC 6013. As a nice side-effect, removing TCPCT increases TCP's performance for very short flows: Doing an apache-benchmark with -c 100 -n 100000, sending HTTP-requests for files of 1KB size. before this patch: average (among 7 runs) of 20845.5 Requests/Second after: average (among 7 runs) of 21403.6 Requests/Second Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-03tcp: better retrans tracking for defer-acceptEric Dumazet
For passive TCP connections using TCP_DEFER_ACCEPT facility, we incorrectly increment req->retrans each time timeout triggers while no SYNACK is sent. SYNACK are not sent for TCP_DEFER_ACCEPT that were established (for which we received the ACK from client). Only the last SYNACK is sent so that we can receive again an ACK from client, to move the req into accept queue. We plan to change this later to avoid the useless retransmit (and potential problem as this SYNACK could be lost) TCP_INFO later gives wrong information to user, claiming imaginary retransmits. Decouple req->retrans field into two independent fields : num_retrans : number of retransmit num_timeout : number of timeouts num_timeout is the counter that is incremented at each timeout, regardless of actual SYNACK being sent or not, and used to compute the exponential timeout. Introduce inet_rtx_syn_ack() helper to increment num_retrans only if ->rtx_syn_ack() succeeded. Use inet_rtx_syn_ack() from tcp_check_req() to increment num_retrans when we re-send a SYNACK in answer to a (retransmitted) SYN. Prior to this patch, we were not counting these retransmits. Change tcp_v[46]_rtx_synack() to increment TCP_MIB_RETRANSSEGS only if a synack packet was successfully queued. Reported-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Julian Anastasov <ja@ssi.bg> Cc: Vijay Subramanian <subramanian.vijay@gmail.com> Cc: Elliott Hughes <enh@google.com> Cc: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31tcp: TCP Fast Open Server - support TFO listenersJerry Chu
This patch builds on top of the previous patch to add the support for TFO listeners. This includes - 1. allocating, properly initializing, and managing the per listener fastopen_queue structure when TFO is enabled 2. changes to the inet_csk_accept code to support TFO. E.g., the request_sock can no longer be freed upon accept(), not until 3WHS finishes 3. allowing a TCP_SYN_RECV socket to properly poll() and sendmsg() if it's a TFO socket 4. properly closing a TFO listener, and a TFO socket before 3WHS finishes 5. supporting TCP_FASTOPEN socket option 6. modifying tcp_check_req() to use to check a TFO socket as well as request_sock 7. supporting TCP's TFO cookie option 8. adding a new SYN-ACK retransmit handler to use the timer directly off the TFO socket rather than the listener socket. Note that TFO server side will not retransmit anything other than SYN-ACK until the 3WHS is completed. The patch also contains an important function "reqsk_fastopen_remove()" to manage the somewhat complex relation between a listener, its request_sock, and the corresponding child socket. See the comment above the function for the detail. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31tcp: TCP Fast Open Server - header & support functionsJerry Chu
This patch adds all the necessary data structure and support functions to implement TFO server side. It also documents a number of flags for the sysctl_tcp_fastopen knob, and adds a few Linux extension MIBs. In addition, it includes the following: 1. a new TCP_FASTOPEN socket option an application must call to supply a max backlog allowed in order to enable TFO on its listener. 2. A number of key data structures: "fastopen_rsk" in tcp_sock - for a big socket to access its request_sock for retransmission and ack processing purpose. It is non-NULL iff 3WHS not completed. "fastopenq" in request_sock_queue - points to a per Fast Open listener data structure "fastopen_queue" to keep track of qlen (# of outstanding Fast Open requests) and max_qlen, among other things. "listener" in tcp_request_sock - to point to the original listener for book-keeping purpose, i.e., to maintain qlen against max_qlen as part of defense against IP spoofing attack. 3. various data structure and functions, many in tcp_fastopen.c, to support server side Fast Open cookie operations, including /proc/sys/net/ipv4/tcp_fastopen_key to allow manual rekeying. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15tcp: Change possible SYN flooding messagesEric Dumazet
"Possible SYN flooding on port xxxx " messages can fill logs on servers. Change logic to log the message only once per listener, and add two new SNMP counters to track : TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client TCPReqQFullDrop : number of times a SYN request was dropped because syncookies were not enabled. Based on a prior patch from Tom Herbert, and suggestions from David. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17tcp: account SYN-ACK timeouts & retransmissionsOctavian Purdila
Currently we don't increment SYN-ACK timeouts & retransmissions although we do increment the same stats for SYN. We seem to have lost the SYN-ACK accounting with the introduction of tcp_syn_recv_timer (commit 2248761e in the netdev-vger-cvs tree). This patch fixes this issue. In the process we also rename the v4/v6 syn/ack retransmit functions for clarity. We also add a new request_socket operations (syn_ack_timeout) so we can keep code in inet_connection_sock.c protocol agnostic. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1a: add request_values parameter for sending SYNACKWilliam Allen Simpson
Add optional function parameters associated with sending SYNACK. These parameters are not needed after sending SYNACK, and are not used for retransmission. Avoids extending struct tcp_request_sock, and avoids allocating kernel memory. Also affects DCCP as it uses common struct request_sock_ops, but this parameter is currently reserved for future use. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21net: Fix memory leak in the proto_register functionCatalin Marinas
If the slub allocator is used, kmem_cache_create() may merge two or more kmem_cache's into one but the cache name pointer is not updated and kmem_cache_name() is no longer guaranteed to return the pointer passed to the former function. This patch stores the kmalloc'ed pointers in the corresponding request_sock_ops and timewait_sock_ops structures. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-06tcp: Fix kernel panic when calling tcp_v(4/6)_md5_do_lookupGui Jianfeng
If the following packet flow happen, kernel will panic. MathineA MathineB SYN ----------------------> SYN+ACK <---------------------- ACK(bad seq) ----------------------> When a bad seq ACK is received, tcp_v4_md5_do_lookup(skb->sk, ip_hdr(skb)->daddr)) is finally called by tcp_v4_reqsk_send_ack(), but the first parameter(skb->sk) is NULL at that moment, so kernel panic happens. This patch fixes this bug. OOPS output is as following: [ 302.812793] IP: [<c05cfaa6>] tcp_v4_md5_do_lookup+0x12/0x42 [ 302.817075] Oops: 0000 [#1] SMP [ 302.819815] Modules linked in: ipv6 loop dm_multipath rtc_cmos rtc_core rtc_lib pcspkr pcnet32 mii i2c_piix4 parport_pc i2c_core parport ac button ata_piix libata dm_mod mptspi mptscsih mptbase scsi_transport_spi sd_mod scsi_mod crc_t10dif ext3 jbd mbcache uhci_hcd ohci_hcd ehci_hcd [last unloaded: scsi_wait_scan] [ 302.849946] [ 302.851198] Pid: 0, comm: swapper Not tainted (2.6.27-rc1-guijf #5) [ 302.855184] EIP: 0060:[<c05cfaa6>] EFLAGS: 00010296 CPU: 0 [ 302.858296] EIP is at tcp_v4_md5_do_lookup+0x12/0x42 [ 302.861027] EAX: 0000001e EBX: 00000000 ECX: 00000046 EDX: 00000046 [ 302.864867] ESI: ceb69e00 EDI: 1467a8c0 EBP: cf75f180 ESP: c0792e54 [ 302.868333] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [ 302.871287] Process swapper (pid: 0, ti=c0792000 task=c0712340 task.ti=c0746000) [ 302.875592] Stack: c06f413a 00000000 cf75f180 ceb69e00 00000000 c05d0d86 000016d0 ceac5400 [ 302.883275] c05d28f8 000016d0 ceb69e00 ceb69e20 681bf6e3 00001000 00000000 0a67a8c0 [ 302.890971] ceac5400 c04250a3 c06f413a c0792eb0 c0792edc cf59a620 cf59a620 cf59a634 [ 302.900140] Call Trace: [ 302.902392] [<c05d0d86>] tcp_v4_reqsk_send_ack+0x17/0x35 [ 302.907060] [<c05d28f8>] tcp_check_req+0x156/0x372 [ 302.910082] [<c04250a3>] printk+0x14/0x18 [ 302.912868] [<c05d0aa1>] tcp_v4_do_rcv+0x1d3/0x2bf [ 302.917423] [<c05d26be>] tcp_v4_rcv+0x563/0x5b9 [ 302.920453] [<c05bb20f>] ip_local_deliver_finish+0xe8/0x183 [ 302.923865] [<c05bb10a>] ip_rcv_finish+0x286/0x2a3 [ 302.928569] [<c059e438>] dev_alloc_skb+0x11/0x25 [ 302.931563] [<c05a211f>] netif_receive_skb+0x2d6/0x33a [ 302.934914] [<d0917941>] pcnet32_poll+0x333/0x680 [pcnet32] [ 302.938735] [<c05a3b48>] net_rx_action+0x5c/0xfe [ 302.941792] [<c042856b>] __do_softirq+0x5d/0xc1 [ 302.944788] [<c042850e>] __do_softirq+0x0/0xc1 [ 302.948999] [<c040564b>] do_softirq+0x55/0x88 [ 302.951870] [<c04501b1>] handle_fasteoi_irq+0x0/0xa4 [ 302.954986] [<c04284da>] irq_exit+0x35/0x69 [ 302.959081] [<c0405717>] do_IRQ+0x99/0xae [ 302.961896] [<c040422b>] common_interrupt+0x23/0x28 [ 302.966279] [<c040819d>] default_idle+0x2a/0x3d [ 302.969212] [<c0402552>] cpu_idle+0xb2/0xd2 [ 302.972169] ======================= [ 302.974274] Code: fc ff 84 d2 0f 84 df fd ff ff e9 34 fe ff ff 83 c4 0c 5b 5e 5f 5d c3 90 90 57 89 d7 56 53 89 c3 50 68 3a 41 6f c0 e8 e9 55 e5 ff <8b> 93 9c 04 00 00 58 85 d2 59 74 1e 8b 72 10 31 db 31 c9 85 f6 [ 303.011610] EIP: [<c05cfaa6>] tcp_v4_md5_do_lookup+0x12/0x42 SS:ESP 0068:c0792e54 [ 303.018360] Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-10[Syncookies]: Add support for TCP options via timestamps.Florian Westphal
Allow the use of SACK and window scaling when syncookies are used and the client supports tcp timestamps. Options are encoded into the timestamp sent in the syn-ack and restored from the timestamp echo when the ack is received. Based on earlier work by Glenn Griffin. This patch avoids increasing the size of structs by encoding TCP options into the least significant bits of the timestamp and by not using any 'timestamp offset'. The downside is that the timestamp sent in the packet after the synack will increase by several seconds. changes since v1: don't duplicate timestamp echo decoding function, put it into ipv4/syncookie.c and have ipv6/syncookies.c use it. Feedback from Glenn Griffin: fix line indented with spaces, kill redundant if () Reviewed-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[INET]: Remove struct dst_entry *dst from request_sock_ops.rtx_syn_ack.Denis V. Lunev
It looks like dst parameter is used in this API due to historical reasons. Actually, it is really used in the direct call to tcp_v4_send_synack only. So, create a wrapper for tcp_v4_send_synack and remove dst from rtx_syn_ack. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-15[INET]: Fix potential kfree on vmalloc-ed area of request_sock_queuePavel Emelyanov
The request_sock_queue's listen_opt is either vmalloc-ed or kmalloc-ed depending on the number of table entries. Thus it is expected to be handled properly on free, which is done in the reqsk_queue_destroy(). However the error path in inet_csk_listen_start() calls the lite version of reqsk_queue_destroy, called __reqsk_queue_destroy, which calls the kfree unconditionally. Fix this and move the __reqsk_queue_destroy into a .c file as it looks too big to be inline. As David also noticed, this is an error recovery path only, so no locking is required and the lopt is known to be not NULL. reqsk_queue_yank_listen_sk is also now only used in net/core/request_sock.c so we should move it there too. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Size listen hash tables using backlog hintEric Dumazet
We currently allocate a fixed size (TCP_SYNQ_HSIZE=512) slots hash table for each LISTEN socket, regardless of various parameters (listen backlog for example) On x86_64, this means order-1 allocations (might fail), even for 'small' sockets, expecting few connections. On the contrary, a huge server wanting a backlog of 50000 is slowed down a bit because of this fixed limit. This patch makes the sizing of listen hash table a dynamic parameter, depending of : - net.core.somaxconn tunable (default is 128) - net.ipv4.tcp_max_syn_backlog tunable (default : 256, 1024 or 128) - backlog value given by user application (2nd parameter of listen()) For large allocations (bigger than PAGE_SIZE), we use vmalloc() instead of kmalloc(). We still limit memory allocation with the two existing tunables (somaxconn & tcp_max_syn_backlog). So for standard setups, this patch actually reduce RAM usage. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-09-22[MLSXFRM]: Auto-labeling of child socketsVenkat Yekkirala
This automatically labels the TCP, Unix stream, and dccp child sockets as well as openreqs to be at the same MLS level as the peer. This will result in the selection of appropriately labeled IPSec Security Associations. This also uses the sock's sid (as opposed to the isec sid) in SELinux enforcement of secmark in rcv_skb and postroute_last hooks. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-26[NET]: drop duplicate assignment in request_sockNorbert Kiesel
Just noticed that request_sock.[ch] contain a useless assignment of rskq_accept_head to itself. I assume this is a typo and the 2nd one was supposed to be _tail. However, setting _tail to NULL is not needed, so the patch below just drops the 2nd assignment. Signed-off-By: Norbert Kiesel <nkiesel@tbdnetworks.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Move generalised functions from tcp to inet_connection_sockArnaldo Carvalho de Melo
This also improves reqsk_queue_prune and renames it to inet_csk_reqsk_queue_prune, as it deals with both inet_connection_sock and inet_request_sock objects, not just with request_sock ones thus belonging to inet_request_sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Introduce reqsk_queue_prune from code in tcp_synack_timerArnaldo Carvalho de Melo
With this we're very close to getting all of the current TCP refactorings in my dccp-2.6 tree merged, next changeset will export some functions needed by the current DCCP code and then dccp-2.6.git will be born! Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce inet_connection_sockArnaldo Carvalho de Melo
This creates struct inet_connection_sock, moving members out of struct tcp_sock that are shareable with other INET connection oriented protocols, such as DCCP, that in my private tree already uses most of these members. The functions that operate on these members were renamed, using a inet_csk_ prefix while not being moved yet to a new file, so as to ease the review of these changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[REQSK]: Move the syn_table destroy from tcp_listen_stop to reqsk_queue_destroyArnaldo Carvalho de Melo
2005-06-18[NET] rename struct tcp_listen_opt to struct listen_sockArnaldo Carvalho de Melo
2005-06-18[NET] Generalise tcp_listen_optArnaldo Carvalho de Melo
This chunks out the accept_queue and tcp_listen_opt code and moves them to net/core/request_sock.c and include/net/request_sock.h, to make it useful for other transport protocols, DCCP being the first one to use it. Next patches will rename tcp_listen_opt to accept_sock and remove the inline tcp functions that just call a reqsk_queue_ function. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise TCP's struct open_request minisock infrastructureArnaldo Carvalho de Melo
Kept this first changeset minimal, without changing existing names to ease peer review. Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn has two new members: ->slab, that replaces tcp_openreq_cachep ->obj_size, to inform the size of the openreq descendant for a specific protocol The protocol specific fields in struct open_request were moved to a class hierarchy, with the things that are common to all connection oriented PF_INET protocols in struct inet_request_sock, the TCP ones in tcp_request_sock, that is an inet_request_sock, that is an open_request. I.e. this uses the same approach used for the struct sock class hierarchy, with sk_prot indicating if the protocol wants to use the open_request infrastructure by filling in sk_prot->rsk_prot with an or_calltable. Results? Performance is improved and TCP v4 now uses only 64 bytes per open request minisock, down from 96 without this patch :-) Next changeset will rename some of the structs, fields and functions mentioned above, struct or_calltable is way unclear, better name it struct request_sock_ops, s/struct open_request/struct request_sock/g, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
