path: root/include/net/request_sock.h
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-10[Syncookies]: Add support for TCP options via timestamps.Florian Westphal
Allow the use of SACK and window scaling when syncookies are used and the client supports tcp timestamps. Options are encoded into the timestamp sent in the syn-ack and restored from the timestamp echo when the ack is received. Based on earlier work by Glenn Griffin. This patch avoids increasing the size of structs by encoding TCP options into the least significant bits of the timestamp and by not using any 'timestamp offset'. The downside is that the timestamp sent in the packet after the synack will increase by several seconds. changes since v1: don't duplicate timestamp echo decoding function, put it into ipv4/syncookie.c and have ipv6/syncookies.c use it. Feedback from Glenn Griffin: fix line indented with spaces, kill redundant if () Reviewed-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[INET]: Remove struct dst_entry *dst from request_sock_ops.rtx_syn_ack.Denis V. Lunev
It looks like dst parameter is used in this API due to historical reasons. Actually, it is really used in the direct call to tcp_v4_send_synack only. So, create a wrapper for tcp_v4_send_synack and remove dst from rtx_syn_ack. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-15[INET]: Fix potential kfree on vmalloc-ed area of request_sock_queuePavel Emelyanov
The request_sock_queue's listen_opt is either vmalloc-ed or kmalloc-ed depending on the number of table entries. Thus it is expected to be handled properly on free, which is done in the reqsk_queue_destroy(). However the error path in inet_csk_listen_start() calls the lite version of reqsk_queue_destroy, called __reqsk_queue_destroy, which calls the kfree unconditionally. Fix this and move the __reqsk_queue_destroy into a .c file as it looks too big to be inline. As David also noticed, this is an error recovery path only, so no locking is required and the lopt is known to be not NULL. reqsk_queue_yank_listen_sk is also now only used in net/core/request_sock.c so we should move it there too. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Size listen hash tables using backlog hintEric Dumazet
We currently allocate a fixed size (TCP_SYNQ_HSIZE=512) slots hash table for each LISTEN socket, regardless of various parameters (listen backlog for example) On x86_64, this means order-1 allocations (might fail), even for 'small' sockets, expecting few connections. On the contrary, a huge server wanting a backlog of 50000 is slowed down a bit because of this fixed limit. This patch makes the sizing of listen hash table a dynamic parameter, depending of : - net.core.somaxconn tunable (default is 128) - net.ipv4.tcp_max_syn_backlog tunable (default : 256, 1024 or 128) - backlog value given by user application (2nd parameter of listen()) For large allocations (bigger than PAGE_SIZE), we use vmalloc() instead of kmalloc(). We still limit memory allocation with the two existing tunables (somaxconn & tcp_max_syn_backlog). So for standard setups, this patch actually reduce RAM usage. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-09-22[MLSXFRM]: Auto-labeling of child socketsVenkat Yekkirala
This automatically labels the TCP, Unix stream, and dccp child sockets as well as openreqs to be at the same MLS level as the peer. This will result in the selection of appropriately labeled IPSec Security Associations. This also uses the sock's sid (as opposed to the isec sid) in SELinux enforcement of secmark in rcv_skb and postroute_last hooks. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-26[NET]: drop duplicate assignment in request_sockNorbert Kiesel
Just noticed that request_sock.[ch] contain a useless assignment of rskq_accept_head to itself. I assume this is a typo and the 2nd one was supposed to be _tail. However, setting _tail to NULL is not needed, so the patch below just drops the 2nd assignment. Signed-off-By: Norbert Kiesel <nkiesel@tbdnetworks.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Move generalised functions from tcp to inet_connection_sockArnaldo Carvalho de Melo
This also improves reqsk_queue_prune and renames it to inet_csk_reqsk_queue_prune, as it deals with both inet_connection_sock and inet_request_sock objects, not just with request_sock ones thus belonging to inet_request_sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Introduce reqsk_queue_prune from code in tcp_synack_timerArnaldo Carvalho de Melo
With this we're very close to getting all of the current TCP refactorings in my dccp-2.6 tree merged, next changeset will export some functions needed by the current DCCP code and then dccp-2.6.git will be born! Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce inet_connection_sockArnaldo Carvalho de Melo
This creates struct inet_connection_sock, moving members out of struct tcp_sock that are shareable with other INET connection oriented protocols, such as DCCP, that in my private tree already uses most of these members. The functions that operate on these members were renamed, using a inet_csk_ prefix while not being moved yet to a new file, so as to ease the review of these changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[REQSK]: Move the syn_table destroy from tcp_listen_stop to reqsk_queue_destroyArnaldo Carvalho de Melo
2005-06-18[NET] rename struct tcp_listen_opt to struct listen_sockArnaldo Carvalho de Melo
2005-06-18[NET] Generalise tcp_listen_optArnaldo Carvalho de Melo
This chunks out the accept_queue and tcp_listen_opt code and moves them to net/core/request_sock.c and include/net/request_sock.h, to make it useful for other transport protocols, DCCP being the first one to use it. Next patches will rename tcp_listen_opt to accept_sock and remove the inline tcp functions that just call a reqsk_queue_ function. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise TCP's struct open_request minisock infrastructureArnaldo Carvalho de Melo
Kept this first changeset minimal, without changing existing names to ease peer review. Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn has two new members: ->slab, that replaces tcp_openreq_cachep ->obj_size, to inform the size of the openreq descendant for a specific protocol The protocol specific fields in struct open_request were moved to a class hierarchy, with the things that are common to all connection oriented PF_INET protocols in struct inet_request_sock, the TCP ones in tcp_request_sock, that is an inet_request_sock, that is an open_request. I.e. this uses the same approach used for the struct sock class hierarchy, with sk_prot indicating if the protocol wants to use the open_request infrastructure by filling in sk_prot->rsk_prot with an or_calltable. Results? Performance is improved and TCP v4 now uses only 64 bytes per open request minisock, down from 96 without this patch :-) Next changeset will rename some of the structs, fields and functions mentioned above, struct or_calltable is way unclear, better name it struct request_sock_ops, s/struct open_request/struct request_sock/g, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
