path: root/include/net/rtnetlink.h
2011-06-09rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-11-27rtnl: make link af-specific updates atomicThomas Graf
As David pointed out correctly, updates to af-specific attributes are currently not atomic. If multiple changes are requested and one of them fails, previous updates may have been applied already leaving the link behind in a undefined state. This patch splits the function parse_link_af() into two functions validate_link_af() and set_link_at(). validate_link_af() is placed to validate_linkmsg() check for errors as early as possible before any changes to the link have been made. set_link_af() is called to commit the changes later. This method is not fail proof, while it is currently sufficient to make set_link_af() inerrable and thus 100% atomic, the validation function method will not be able to detect all error scenarios in the future, there will likely always be errors depending on states which are f.e. not protected by rtnl_mutex and thus may change between validation and setting. Also, instead of silently ignoring unknown address families and config blocks for address families which did not register a set function the errors EAFNOSUPPORT respectively EOPNOSUPPORT are returned to avoid comitting 4 out of 5 update requests without notifying the user. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17rtnetlink: Link address family APIThomas Graf
Each net_device contains address family specific data such as per device settings and statistics. We already expose this data via procfs/sysfs and partially netlink. The netlink method requires the requester to send one RTM_GETLINK request for each address family it wishes to receive data of and then merge this data itself. This patch implements a new API which combines all address family specific link data in a new netlink attribute IFLA_AF_SPEC. IFLA_AF_SPEC contains a sequence of nested attributes, one for each address family which in turn defines the structure of its own attribute. Example: [IFLA_AF_SPEC] = { [AF_INET] = { [IFLA_INET_CONF] = ..., }, [AF_INET6] = { [IFLA_INET6_FLAGS] = ..., [IFLA_INET6_CONF] = ..., } } The API also allows for address families to implement a function which parses the IFLA_AF_SPEC attribute sent by userspace to implement address family specific link options. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21rtnetlink: remove rtnl_kill_linksstephen hemminger
The function rtnl_kill_links is defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-27rtnetlink: support specifying device flags on device creationPatrick McHardy
commit e8469ed959c373c2ff9e6f488aa5a14971aebe1f Author: Patrick McHardy <kaber@trash.net> Date: Tue Feb 23 20:41:30 2010 +0100 Support specifying the initial device flags when creating a device though rtnl_link. Devices allocated by rtnl_create_link() are marked as INITIALIZING in order to surpress netlink registration notifications. To complete setup, rtnl_configure_link() must be called, which performs the device flag changes and invokes the deferred notifiers if everything went well. Two examples: # add macvlan to eth0 # $ ip link add link eth0 up allmulticast on type macvlan [LINK]11: macvlan0@eth0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN link/ether 26:f8:84:02:f9:2a brd ff:ff:ff:ff:ff:ff [ROUTE]ff00::/8 dev macvlan0 table local metric 256 mtu 1500 advmss 1440 hoplimit 0 [ROUTE]fe80::/64 dev macvlan0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0 [LINK]11: macvlan0@eth0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500 link/ether 26:f8:84:02:f9:2a [ADDR]11: macvlan0 inet6 fe80::24f8:84ff:fe02:f92a/64 scope link valid_lft forever preferred_lft forever [ROUTE]local fe80::24f8:84ff:fe02:f92a via :: dev lo table local proto none metric 0 mtu 16436 advmss 16376 hoplimit 0 [ROUTE]default via fe80::215:e9ff:fef0:10f8 dev macvlan0 proto kernel metric 1024 mtu 1500 advmss 1440 hoplimit 0 [NEIGH]fe80::215:e9ff:fef0:10f8 dev macvlan0 lladdr 00:15:e9:f0:10:f8 router STALE [ROUTE]2001:6f8:974::/64 dev macvlan0 proto kernel metric 256 expires 0sec mtu 1500 advmss 1440 hoplimit 0 [PREFIX]prefix 2001:6f8:974::/64 dev macvlan0 onlink autoconf valid 14400 preferred 131084 [ADDR]11: macvlan0 inet6 2001:6f8:974:0:24f8:84ff:fe02:f92a/64 scope global dynamic valid_lft 86399sec preferred_lft 14399sec # add VLAN to eth1, eth1 is down # $ ip link add link eth1 up type vlan id 1000 RTNETLINK answers: Network is down <no events> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net: Support specifying the network namespace upon device creation.Eric W. Biederman
There is no good reason to not support userspace specifying the network namespace during device creation, and it makes it easier to create a network device and pass it to a child network namespace with a well known name. We have to be careful to ensure that the target network namespace for the new device exists through the life of the call. To keep that logic clear I have factored out the network namespace grabbing logic into rtnl_link_get_net. In addtion we need to continue to pass the source network namespace to the rtnl_link_ops.newlink method so that we can find the base device source network namespace. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-10Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-09-02vlan: multiqueue vlan deviceEric Dumazet
vlan devices are currently not multi-queue capable. We can do that with a new rtnl_link_ops method, get_tx_queues(), called from rtnl_create_link() This new method gets num_tx_queues/real_num_tx_queues from real device. register_vlan_device() is also handled. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-25netlink: constify nlmsghdr argumentsPatrick McHardy
Consitfy nlmsghdr arguments to a couple of functions as preparation for the next patch, which will constify the netlink message data in all nfnetlink users. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-16[RTNL]: Introduce the rtnl_kill_links helper.Pavel Emelyanov
This one is responsible for calling ->dellink on each net device found in net to help with vlan net_exit hook in the nearest future. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[RTNETLINK]: Introduce generic rtnl_create_link().Pavel Emelianov
This routine gets the parsed rtnl attributes and creates a new link with generic info (IFLA_LINKINFO policy). Its intention is to help the drivers, that need to create several links at once (like VETH). This is nothing but a copy-paste-ed part of rtnl_newlink() function that is responsible for creation of new device. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[RTNETLINK]: Link creation APIPatrick McHardy
Add rtnetlink API for creating, changing and deleting software devices. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NETLINK]: Possible cleanups.Adrian Bunk
- make the following needlessly global variables static: - core/rtnetlink.c: struct rtnl_msg_handlers[] - netfilter/nf_conntrack_proto.c: struct nf_ct_protos[] - make the following needlessly global functions static: - core/rtnetlink.c: rtnl_dump_all() - netlink/af_netlink.c: netlink_queue_skip() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] rules: Unified rules dumpingThomas Graf
Implements a unified, protocol independant rules dumping function which is capable of both, dumping a specific protocol family or all of them. This speeds up dumping as less lookups are required. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[RTNL]: Message handler registration interfaceThomas Graf
This patch adds a new interface to register rtnetlink message handlers replacing the exported rtnl_links[] array which required many message handlers to be exported unnecessarly. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
