This change replaces sk_buff_head struct in Qdiscs with new qdisc_skb_head.
Its similar to the skb_buff_head api, but does not use skb->prev pointers.
Qdiscs will commonly enqueue at the tail of a list and dequeue at head.
While skb_buff_head works fine for this, enqueue/dequeue needs to also
adjust the prev pointer of next element.
The ->prev pointer is not required for qdiscs so we can just leave
it undefined and avoid one cacheline write access for en/dequeue.
Suggested-by: Eric Dumazet <edumazet@google.com>
Moves qdisc stat accouting to qdisc_dequeue_head.
The only direct caller of the __qdisc_dequeue_head version open-codes
this now.
This allows us to later use __qdisc_dequeue_head as a replacement
of __skb_dequeue() (which operates on sk_buff_head list).
per_cpu_inc() is faster (at least on x86) than per_cpu_ptr(xxx)++;
Acked-by: John Fastabend <john.r.fastabend@intel.com>
Convert the per-device linked list into a hashtable. The primary
motivation for this change is that currently, we're not tracking all the
qdiscs in hierarchy (e.g. excluding default qdiscs), as the lookup
performed over the linked list by qdisc_match_from_root() is rather
expensive.
The ultimate goal is to get rid of hidden qdiscs completely, which will
bring much more determinism in user experience.
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
When qdisc bulk dequeue was added in linux-3.18 (commit
5772e9a3463b "qdisc: bulk dequeue support for qdiscs
with TCQ_F_ONETXQUEUE"), it was constrained to some
specific qdiscs.
With some extra care, we can extend this to all qdiscs,
so that typical traffic shaping solutions can benefit from
small batches (8 packets in this patch).
For example, HTB is often used on some multi queue device.
And bonding/team are multi queue devices...
Idea is to bulk-dequeue packets mapping to the same transmit queue.
This brings between 35 and 80 % performance increase in HTB setup
under pressure on a bonding setup :
1) NUMA node contention : 610,000 pps -> 1,110,000 pps
2) No node contention : 1,380,000 pps -> 1,930,000 pps
Now we should work to add batches on the enqueue() side ;)
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Florian Westphal <fw@strlen.de>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Qdisc performance suffers when packets are dropped at enqueue()
time because drops (kfree_skb()) are done while qdisc lock is held,
delaying a dequeue() draining the queue.
Nominal throughput can be reduced by 50 % when this happens,
at a time we would like the dequeue() to proceed as fast as possible.
Even FQ is vulnerable to this problem, while one of FQ goals was
to provide some flow isolation.
This patch adds a 'struct sk_buff **to_free' parameter to all
qdisc->enqueue(), and in qdisc_drop() helper.
I measured a performance increase of up to 12 %, but this patch
is a prereq so that future batches in enqueue() can fly.
qdisc are changed under RTNL protection and often
while blocking BH and root qdisc spinlock.
When lots of skbs need to be dropped, we free
them under these locks causing TX/RX freezes,
and more generally latency spikes.
This commit adds rtnl_kfree_skbs(), used to queue
skbs for deferred freeing.
Actual freeing happens right after RTNL is released,
with appropriate scheduling points.
rtnl_qdisc_drop() can also be used in place
of disc_drop() when RTNL is held.
qdisc_reset_queue() and __qdisc_reset_queue() get
the new behavior, so standard qdiscs like pfifo, pfifo_fast...
have their ->reset() method automatically handled.
__QDISC_STATE_THROTTLED bit manipulation is rather expensive
for HTB and few others.
I already removed it for sch_fq in commit f2600cf02b5b
("net: sched: avoid costly atomic operation in fq_dequeue()")
and so far nobody complained.
When one ore more packets are stuck in one or more throttled
HTB class, a htb dequeue() performs two atomic operations
to clear/set __QDISC_STATE_THROTTLED bit, while root qdisc
lock is held.
Removing this pair of atomic operations bring me a 8 % performance
increase on 200 TCP_RR tests, in presence of throttled classes.
This patch has no side effect, since nothing actually uses
disc_is_throttled() anymore.
net/sched/act_police.c
net/sched/sch_drr.c
net/sched/sch_hfsc.c
net/sched/sch_prio.c
net/sched/sch_red.c
net/sched/sch_tbf.c
In net-next the drop methods of the packet schedulers got removed, so
the bug fixes to them in 'net' are irrelevant.
A packet action unload crash fix conflicts with the addition of the
new firstuse timestamp.
1) qdisc_run_begin() is really using the equivalent of a trylock.
Instead of using write_seqcount_begin(), use a combination of
raw_write_seqcount_begin() and correct lockdep annotation.
2) sch_direct_xmit() should use regular spin_lock(root_lock)
Fixes: f9eb8aea2a1e ("net_sched: transform qdisc running bit into a seqcount")
Reported-by: David Ahern <dsa@cumulusnetworks.com>
Earlier commits removed two members from struct Qdisc which places
next_sched/gso_skb into a different cacheline than ->state.
This restores the struct layout to what it was before the removal.
Move the two members, then add an annotation so they all reside in the
same cacheline.
This adds a 16 byte hole after cpu_qstats.
The hole could be closed but as it doesn't decrease total struct size just
do it this way.
Reported-by: Eric Dumazet <edumazet@google.com>
after removal of TCA_CBQ_OVL_STRATEGY from cbq scheduler, there are no
more callers of ->drop() outside of other ->drop functions, i.e.
nothing calls them.
After the removal of TCA_CBQ_POLICE in cbq scheduler qdisc->reshape_fail
is always NULL, i.e. qdisc_rehape_fail is now the same as qdisc_drop.
iproute2 doesn't implement any cbq option that results in this attribute
being sent to kernel.
To make use of it, user would have to
- patch iproute2
- add a class
- attach a qdisc to the class (default pfifo doesn't work as
q->handle is 0 and cbq_set_police() is a no-op in this case)
- re-'add' the same class (tc class change ...) again
- user must also specifiy a defmap (e.g. 'split 1:0 defmap 3f'), since
this 'police' feature relies on its presence
- the added qdisc must be one of bfifo, pfifo or netem
If all of these conditions are met and _some_ leaf qdiscs, namely
p/bfifo, netem, plug or tbf would drop a packet, kernel calls back into
cbq, which will attempt to re-queue the skb into a different class
as indicated by the parents' defmap entry for TC_PRIO_BESTEFFORT.
[ i.e. we behave as if tc_classify returned TC_ACT_RECLASSIFY ].
This feature, which isn't documented or implemented in iproute2,
and isn't implemented consistently (most qdiscs like sfq, codel, etc
drop right away instead of attempting this reclassification) is the
sole reason for the reshape_fail and __parent member in Qdisc struct.
So remove TCA_CBQ_POLICE support from the kernel, reject it via EOPNOTSUPP
so userspace knows we don't support it, and then remove no-longer needed
infrastructure in followup commit.
When offloading classifiers such as u32 or flower to hardware, and the
qdisc is clsact (TC_H_CLSACT), then we need to differentiate its classes,
since not all of them handle ingress, therefore we must leave those in
software path. Add a .tcf_cl_offload() callback, so we can generically
handle them, tested on ixgbe.
Fixes: 10cbc6843446 ("net/sched: cls_flower: Hardware offloaded filters statistics support")
Fixes: 5b33f48842fa ("net/flower: Introduce hardware offload support")
Fixes: a1b7c5fd7fe9 ("net: sched: add cls_u32 offload hooks for netdevs")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Large tc dumps (tc -s {qdisc|class} sh dev ethX) done by Google BwE host
agent [1] are problematic at scale :
For each qdisc/class found in the dump, we currently lock the root qdisc
spinlock in order to get stats. Sampling stats every 5 seconds from
thousands of HTB classes is a challenge when the root qdisc spinlock is
under high pressure. Not only the dumps take time, they also slow
down the fast path (queue/dequeue packets) by 10 % to 20 % in some cases.
An audit of existing qdiscs showed that sch_fq_codel is the only qdisc
that might need the qdisc lock in fq_codel_dump_stats() and
fq_codel_dump_class_stats()
In v2 of this patch, I now use the Qdisc running seqcount to provide
consistent reads of packets/bytes counters, regardless of 32/64 bit arches.
I also changed rate estimators to use the same infrastructure
so that they no longer need to lock root qdisc lock.
[1]
http://static.googleusercontent.com/media/research.google.com/en//pubs/archive/43838.pdf
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: Kevin Athey <kda@google.com>
Cc: Xiaotian Pei <xiaotian@google.com>
Instead of using a single bit (__QDISC___STATE_RUNNING)
in sch->__state, use a seqcount.
This adds lockdep support, but more importantly it will allow us
to sample qdisc/class statistics without having to grab qdisc root lock.
For gso_skb we only update qlen, backlog should be updated too.
Note, it is correct to just update these stats at one layer,
because the gso_skb is cached there.
Reported-by: Stas Nichiporovich <stasn77@gmail.com>
Fixes: 2ccccf5fb43f ("net_sched: update hierarchical backlog too")
Introduce stats_update callback. netdev driver could call it for offloaded
actions to update the basic statistics (packets, bytes and last use).
Since bstats_update() and bstats_cpu_update() use skb as an argument to
get the counters, _bstats_update() and _bstats_cpu_update(), that get
bytes and packets as arguments, were added.
Signed-off-by: Amir Vadai <amirva@mellanox.com>
Some devices declare a high number of TX queues, then set a much
lower real_num_tx_queues
This cause setups using fq_codel, sfq or fq as the default qdisc to consume
more memory than really needed.
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Remove nearly duplicated code and prepare for the following patch.
Add a skb_at_tc_ingress() as this will be needed elsewhere as well and
can hide the ugly ifdef.
Acked-by: Alexei Starovoitov <ast@kernel.org>
qdisc_tree_decrease_qlen() suffers from two problems on multiqueue
devices.
One problem is that it updates sch->q.qlen and sch->qstats.drops
on the mq/mqprio root qdisc, while it should not : Daniele
reported underflows errors :
[ 681.774821] PAX: sch->q.qlen: 0 n: 1
[ 681.774825] PAX: size overflow detected in function qdisc_tree_decrease_qlen net/sched/sch_api.c:769 cicus.693_49 min, count: 72, decl: qlen; num: 0; context: sk_buff_head;
[ 681.774954] CPU: 2 PID: 19 Comm: ksoftirqd/2 Tainted: G O 4.2.6.201511282239-1-grsec #1
[ 681.774955] Hardware name: ASUSTeK COMPUTER INC. X302LJ/X302LJ, BIOS X302LJ.202 03/05/2015
[ 681.774956] ffffffffa9a04863 0000000000000000 0000000000000000 ffffffffa990ff7c
[ 681.774959] ffffc90000d3bc38 ffffffffa95d2810 0000000000000007 ffffffffa991002b
[ 681.774960] ffffc90000d3bc68 ffffffffa91a44f4 0000000000000001 0000000000000001
[ 681.774962] Call Trace:
[ 681.774967] [<ffffffffa95d2810>] dump_stack+0x4c/0x7f
[ 681.774970] [<ffffffffa91a44f4>] report_size_overflow+0x34/0x50
[ 681.774972] [<ffffffffa94d17e2>] qdisc_tree_decrease_qlen+0x152/0x160
[ 681.774976] [<ffffffffc02694b1>] fq_codel_dequeue+0x7b1/0x820 [sch_fq_codel]
[ 681.774978] [<ffffffffc02680a0>] ? qdisc_peek_dequeued+0xa0/0xa0 [sch_fq_codel]
[ 681.774980] [<ffffffffa94cd92d>] __qdisc_run+0x4d/0x1d0
[ 681.774983] [<ffffffffa949b2b2>] net_tx_action+0xc2/0x160
[ 681.774985] [<ffffffffa90664c1>] __do_softirq+0xf1/0x200
[ 681.774987] [<ffffffffa90665ee>] run_ksoftirqd+0x1e/0x30
[ 681.774989] [<ffffffffa90896b0>] smpboot_thread_fn+0x150/0x260
[ 681.774991] [<ffffffffa9089560>] ? sort_range+0x40/0x40
[ 681.774992] [<ffffffffa9085fe4>] kthread+0xe4/0x100
[ 681.774994] [<ffffffffa9085f00>] ? kthread_worker_fn+0x170/0x170
[ 681.774995] [<ffffffffa95d8d1e>] ret_from_fork+0x3e/0x70
mq/mqprio have their own ways to report qlen/drops by folding stats on
all their queues, with appropriate locking.
A second problem is that qdisc_tree_decrease_qlen() calls qdisc_lookup()
without proper locking : concurrent qdisc updates could corrupt the list
that qdisc_match_from_root() parses to find a qdisc given its handle.
Fix first problem adding a TCQ_F_NOPARENT qdisc flag that
qdisc_tree_decrease_qlen() can use to abort its tree traversal,
as soon as it meets a mq/mqprio qdisc children.
Second problem can be fixed by RCU protection.
Qdisc are already freed after RCU grace period, so qdisc_list_add() and
qdisc_list_del() simply have to use appropriate rcu list variants.
A future patch will add a per struct netdev_queue list anchor, so that
qdisc_tree_decrease_qlen() can have more efficient lookups.
Reported-by: Daniele Fucini <dfucini@gmail.com>
Cc: Cong Wang <cwang@twopensource.com>
Existing bpf_clone_redirect() helper clones skb before redirecting
it to RX or TX of destination netdev.
Introduce bpf_redirect() helper that does that without cloning.
Benchmarked with two hosts using 10G ixgbe NICs.
One host is doing line rate pktgen.
Another host is configured as:
$ tc qdisc add dev $dev ingress
$ tc filter add dev $dev root pref 10 u32 match u32 0 0 flowid 1:2 \
action bpf run object-file tcbpf1_kern.o section clone_redirect_xmit drop
so it receives the packet on $dev and immediately xmits it on $dev + 1
The section 'clone_redirect_xmit' in tcbpf1_kern.o file has the program
that does bpf_clone_redirect() and performance is 2.0 Mpps
action bpf run object-file tcbpf1_kern.o section redirect_xmit drop
which is using bpf_redirect() - 2.4 Mpps
and using cls_bpf with integrated actions as:
$ tc filter add dev $dev root pref 10 \
bpf run object-file tcbpf1_kern.o section redirect_xmit integ_act classid 1
performance is 2.5 Mpps
To summarize:
u32+act_bpf using clone_redirect - 2.0 Mpps
u32+act_bpf using redirect - 2.4 Mpps
cls_bpf using redirect - 2.5 Mpps
For comparison linux bridge in this setup is doing 2.1 Mpps
and ixgbe rx + drop in ip_rcv - 7.8 Mpps
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Often cls_bpf classifier is used with single action drop attached.
Optimize this use case and let cls_bpf return both classid and action.
For backwards compatibility reasons enable this feature under
TCA_BPF_FLAG_ACT_DIRECT flag.
Then more interesting programs like the following are easier to write:
int cls_bpf_prog(struct __sk_buff *skb)
/* classify arp, ip, ipv6 into different traffic classes
* and drop all other packets
switch (skb->protocol) {
case htons(ETH_P_ARP):
skb->tc_classid = 1;
break;
case htons(ETH_P_IP):
skb->tc_classid = 2;
break;
case htons(ETH_P_IPV6):
skb->tc_classid = 3;
break;
default:
return TC_ACT_SHOT;
return TC_ACT_OK;
Joint work with Daniel Borkmann.
This way users can attach noqueue just like any other qdisc using tc
without having to mess with tx_queue_len first.
Signed-off-by: Phil Sutter <phil@nwl.cc>
qdisc_bstats_update_cpu() and other helpers were added to support
percpu stats for qdisc.
We want to add percpu stats for tc action, so this patch add common
helpers.
qdisc_bstats_update_cpu() is renamed to qdisc_bstats_cpu_update()
qdisc_qstats_drop_cpu() is renamed to qdisc_qstats_cpu_drop()
Cc: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Seems all we want here is to avoid endless 'goto reclassify' loop.
tc_classify_compat even resets this counter when something other
than TC_ACT_RECLASSIFY is returned, so this skb-counter doesn't
break hypothetical loops induced by something other than perpetual
TC_ACT_RECLASSIFY return values.
skb_act_clone is now identical to skb_clone, so just use that.
Tested with following (bogus) filter:
tc filter add dev eth0 parent ffff: \
protocol ip u32 match u32 0 0 police rate 10Kbit burst \
64000 mtu 1500 action reclassify
Only left enqueue_root() user is netem, and it looks not necessary :
qdisc_skb_cb(skb)->pkt_len is preserved after one skb_clone()
Not used.
pedit sets TC_MUNGED when packet content was altered, but all the core
does is unset MUNGED again and then set OK2MUNGE.
And the latter isn't tested anywhere. So lets remove both
TC_MUNGED and TC_OK2MUNGE.
Kernel automatically creates a tp for each
(kind, protocol, priority) tuple, which has handle 0,
when we add a new filter, but it still is left there
after we remove our own, unless we don't specify the
handle (literally means all the filters under
the tuple). For example this one is left:
# tc filter show dev eth0
filter parent 8001: protocol arp pref 49152 basic
The user-space is hard to clean up these for kernel
because filters like u32 are organized in a complex way.
So kernel is responsible to remove it after all filters
are gone. Each type of filter has its own way to
store the filters, so each type has to provide its
way to check if all filters are gone.
Signed-off-by: Cong Wang <cwang@twopensource.com>
Acked-by: Jamal Hadi Salim<jhs@mojatatu.com>
Doing the following commands on a non idle network device
panics the box instantly, because cpu_bstats gets overwritten
by stats.
tc qdisc add dev eth0 root <your_favorite_qdisc>
... some traffic (one packet is enough) ...
tc qdisc replace dev eth0 root est 1sec 4sec <your_favorite_qdisc>
[ 325.355596] BUG: unable to handle kernel paging request at ffff8841dc5a074c
[ 325.362609] IP: [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90
[ 325.369158] PGD 1fa7067 PUD 0
[ 325.372254] Oops: 0000 [#1] SMP
[ 325.375514] Modules linked in: ...
[ 325.398346] CPU: 13 PID: 14313 Comm: tc Not tainted 3.19.0-smp-DEV #1163
[ 325.412042] task: ffff8800793ab5d0 ti: ffff881ff2fa4000 task.ti: ffff881ff2fa4000
[ 325.419518] RIP: 0010:[<ffffffff81541c9e>] [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90
[ 325.428506] RSP: 0018:ffff881ff2fa7928 EFLAGS: 00010286
[ 325.433824] RAX: 000000000000000c RBX: ffff881ff2fa796c RCX: 000000000000000c
[ 325.440988] RDX: ffff8841dc5a0744 RSI: 0000000000000060 RDI: 0000000000000060
[ 325.448120] RBP: ffff881ff2fa7948 R08: ffffffff81cd4f80 R09: 0000000000000000
[ 325.455268] R10: ffff883ff223e400 R11: 0000000000000000 R12: 000000015cba0744
[ 325.462405] R13: ffffffff81cd4f80 R14: ffff883ff223e460 R15: ffff883feea0722c
[ 325.469536] FS: 00007f2ee30fa700(0000) GS:ffff88407fa20000(0000) knlGS:0000000000000000
[ 325.477630] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 325.483380] CR2: ffff8841dc5a074c CR3: 0000003feeae9000 CR4: 00000000001407e0
[ 325.490510] Stack:
[ 325.492524] ffff883feea0722c ffff883fef719dc0 ffff883feea0722c ffff883ff223e4a0
[ 325.499990] ffff881ff2fa79a8 ffffffff815424ee ffff883ff223e49c 000000015cba0744
[ 325.507460] 00000000f2fa7978 0000000000000000 ffff881ff2fa79a8 ffff883ff223e4a0
[ 325.514956] Call Trace:
[ 325.517412] [<ffffffff815424ee>] gen_new_estimator+0x8e/0x230
[ 325.523250] [<ffffffff815427aa>] gen_replace_estimator+0x4a/0x60
[ 325.529349] [<ffffffff815718ab>] tc_modify_qdisc+0x52b/0x590
[ 325.535117] [<ffffffff8155edd0>] rtnetlink_rcv_msg+0xa0/0x240
[ 325.540963] [<ffffffff8155ed30>] ? __rtnl_unlock+0x20/0x20
[ 325.546532] [<ffffffff8157f811>] netlink_rcv_skb+0xb1/0xc0
[ 325.552145] [<ffffffff8155b355>] rtnetlink_rcv+0x25/0x40
[ 325.557558] [<ffffffff8157f0d8>] netlink_unicast+0x168/0x220
[ 325.563317] [<ffffffff8157f47c>] netlink_sendmsg+0x2ec/0x3e0
Lets play safe and not use an union : percpu 'pointers' are mostly read
anyway, and we have typically few qdiscs per host.
Fixes: 22e0f8b9322c ("net: sched: make bstats per cpu and estimator RCU safe")
It is never called and implementations are void. So just remove it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Based on DaveM's recent API work on dev_hard_start_xmit(), that allows
sending/processing an entire skb list.
This patch implements qdisc bulk dequeue, by allowing multiple packets
to be dequeued in dequeue_skb().
The optimization principle for this is two fold, (1) to amortize
locking cost and (2) avoid expensive tailptr update for notifying HW.
(1) Several packets are dequeued while holding the qdisc root_lock,
amortizing locking cost over several packet. The dequeued SKB list is
processed under the TXQ lock in dev_hard_start_xmit(), thus also
amortizing the cost of the TXQ lock.
(2) Further more, dev_hard_start_xmit() will utilize the skb->xmit_more
API to delay HW tailptr update, which also reduces the cost per
packet.
One restriction of the new API is that every SKB must belong to the
same TXQ. This patch takes the easy way out, by restricting bulk
dequeue to qdisc's with the TCQ_F_ONETXQUEUE flag, that specifies the
qdisc only have attached a single TXQ.
Some detail about the flow; dev_hard_start_xmit() will process the skb
list, and transmit packets individually towards the driver (see
xmit_one()). In case the driver stops midway in the list, the
remaining skb list is returned by dev_hard_start_xmit(). In
sch_direct_xmit() this returned list is requeued by dev_requeue_skb().
To avoid overshooting the HW limits, which results in requeuing, the
patch limits the amount of bytes dequeued, based on the drivers BQL
limits. In-effect bulking will only happen for BQL enabled drivers.
Small amounts for extra HoL blocking (2x MTU/0.24ms) were
measured at 100Mbit/s, with bulking 8 packets, but the
oscillating nature of the measurement indicate something, like
sched latency might be causing this effect. More comparisons
show, that this oscillation goes away occationally. Thus, we
disregard this artifact completely and remove any "magic" bulking
limit.
For now, as a conservative approach, stop bulking when seeing TSO and
segmented GSO packets. They already benefit from bulking on their own.
A followup patch add this, to allow easier bisect-ability for finding
regressions.
Jointed work with Hannes, Daniel and Florian.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
After previous patches to simplify qstats the qstats can be
made per cpu with a packed union in Qdisc struct.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
This adds helpers to manipulate qstats logic and replaces locations
that touch the counters directly. This simplifies future patches
to push qstats onto per cpu counters.
In order to run qdisc's without locking statistics and estimators
need to be handled correctly.
To resolve bstats make the statistics per cpu. And because this is
only needed for qdiscs that are running without locks which is not
the case for most qdiscs in the near future only create percpu
stats when qdiscs set the TCQ_F_CPUSTATS flag.
Next because estimators use the bstats to calculate packets per
second and bytes per second the estimator code paths are updated
to use the per cpu statistics.
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
overlapping changes.
We cannot make struct qdisc_skb_cb bigger without impacting IPoIB,
or increasing skb->cb[] size.
Commit e0f31d849867 ("flow_keys: Record IP layer protocol in
skb_flow_dissect()") broke IPoIB.
Only current offender is sch_choke, and this one do not need an
absolutely precise flow key.
If we store 17 bytes of flow key, its more than enough. (Its the actual
size of flow_keys if it was a packed structure, but we might add new
fields at the end of it later)
Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()")
rcu'ify tcf_proto this allows calling tc_classify() without holding
any locks. Updaters are protected by RTNL.
This patch prepares the core net_sched infrastracture for running
the classifier/action chains without holding the qdisc lock however
it does nothing to ensure cls_xxx and act_xxx types also work without
locking. Additional patches are required to address the fall out.
Add __rcu notation to qdisc handling by doing this we can make
smatch output more legible. And anyways some of the cases should
be using rcu_dereference() see qdisc_all_tx_empty(),
qdisc_tx_chainging(), and so on.
Also *wake_queue() API is commonly called from driver timer routines
without rcu lock or rtnl lock. So I added rcu_read_lock() blocks
around netif_wake_subqueue and netif_tx_wake_queue.
skb_flow_dissect() dissects only transport header type in ip_proto. It dose not
give any information about IPv4 or IPv6.
This patch adds new member, n_proto, to struct flow_keys. Which records the
IP layer type. i.e IPv4 or IPv6.
This can be used in netdev->ndo_rx_flow_steer driver function to dissect flow.
Adding new member to flow_keys increases the struct size by around 4 bytes.
This causes BUILD_BUG_ON(sizeof(qcb->data) < sz); to fail in
qdisc_cb_private_validate()
So increase data size by 4
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
When actions are attached to a filter, they are a part of the filter
itself, so when changing a filter we should allow to overwrite the actions
inside as well.
In my specific case, when I tried to _append_ a new action to an existing
filter which already has an action, I got EEXIST since kernel refused
to overwrite the existing one in kernel.
This patch checks if we are changing the filter checking NLM_F_CREATE flag
(Sigh, filters don't use NLM_F_REPLACE...) and then passes the boolean down
to actions. This fixes the problem above.
It will be needed by the next patch.
We don't need to maintain our own singly linked list code.
Add an extra u64 rate parameter to psched_ratecfg_precompute()
so that some qdisc can opt-in for 64bit rates in the future,
to overcome the ~34 Gbits limit.
psched_ratecfg_getrate() reports a legacy structure to
tc utility, so if actual rate is above the 32bit rate field,
cap it to the 34Gbit limit.
Fixes warnings introduced by the qdisc default patch.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
By default, the pfifo_fast queue discipline has been used by default
for all devices. But we have better choices now.
This patch allow setting the default queueing discipline with sysctl.
This allows easy use of better queueing disciplines on all devices
without having to use tc qdisc scripts. It is intended to allow
an easy path for distributions to make fq_codel or sfq the default
qdisc.
This patch also makes pfifo_fast more of a first class qdisc, since
it is now possible to manually override the default and explicitly
use pfifo_fast. The behavior for systems who do not use the sysctl
is unchanged, they still get pfifo_fast
Also removes leftover random # in sysctl net core.
