[ Upstream commit 3a0ed3e9619738067214871e9cb826fa23b2ddb9 ]
Al Viro mentioned (Message-ID
<20170626041334.GZ10672@ZenIV.linux.org.uk>)
that there is probably a race condition
lurking in accesses of sk_stamp on 32-bit machines.
sock->sk_stamp is of type ktime_t which is always an s64.
On a 32 bit architecture, we might run into situations of
unsafe access as the access to the field becomes non atomic.
Use seqlocks for synchronization.
This allows us to avoid using spinlocks for readers as
readers do not need mutual exclusion.
Another approach to solve this is to require sk_lock for all
modifications of the timestamps. The current approach allows
for timestamps to have their own lock: sk_stamp_lock.
This allows for the patch to not compete with already
existing critical sections, and side effects are limited
to the paths in the patch.
The addition of the new field maintains the data locality
optimizations from
commit 9115e8cd2a0c ("net: reorganize struct sock for better data
locality")
Note that all the instances of the sk_stamp accesses
are either through the ioctl or the syscall recvmsg.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
[ Upstream commit d7efc6c11b277d9d80b99b1334a78bfe7d7edf10 ]
Alexander Potapenko reported use of uninitialized memory [1]
This happens when inserting a request socket into TCP ehash,
in __sk_nulls_add_node_rcu(), since sk_reuseport is not initialized.
Bug was added by commit d894ba18d4e4 ("soreuseport: fix ordering for
mixed v4/v6 sockets")
Note that d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6
ordering fix") missed the opportunity to get rid of
hlist_nulls_add_tail_rcu() :
Both UDP sockets and TCP/DCCP listeners no longer use
__sk_nulls_add_node_rcu() for their hash insertion.
Since all other sockets have unique 4-tuple, the reuseport status
has no special meaning, so we can always use hlist_nulls_add_head_rcu()
for them and save few cycles/instructions.
[1]
BUG: KMSAN: use of uninitialized memory in inet_ehash_insert+0xd40/0x1050
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.13.0+ #3288
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x185/0x1d0 lib/dump_stack.c:52
kmsan_report+0x13f/0x1c0 mm/kmsan/kmsan.c:1016
__msan_warning_32+0x69/0xb0 mm/kmsan/kmsan_instr.c:766
__sk_nulls_add_node_rcu ./include/net/sock.h:684
inet_ehash_insert+0xd40/0x1050 net/ipv4/inet_hashtables.c:413
reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:754
inet_csk_reqsk_queue_hash_add+0x1cc/0x300 net/ipv4/inet_connection_sock.c:765
tcp_conn_request+0x31e7/0x36f0 net/ipv4/tcp_input.c:6414
tcp_v4_conn_request+0x16d/0x220 net/ipv4/tcp_ipv4.c:1314
tcp_rcv_state_process+0x42a/0x7210 net/ipv4/tcp_input.c:5917
tcp_v4_do_rcv+0xa6a/0xcd0 net/ipv4/tcp_ipv4.c:1483
tcp_v4_rcv+0x3de0/0x4ab0 net/ipv4/tcp_ipv4.c:1763
ip_local_deliver_finish+0x6bb/0xcb0 net/ipv4/ip_input.c:216
NF_HOOK ./include/linux/netfilter.h:248
ip_local_deliver+0x3fa/0x480 net/ipv4/ip_input.c:257
dst_input ./include/net/dst.h:477
ip_rcv_finish+0x6fb/0x1540 net/ipv4/ip_input.c:397
ip_rcv+0x10f6/0x15c0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x36f6/0x3f60 net/core/dev.c:4298
__netif_receive_skb net/core/dev.c:4336
netif_receive_skb_internal+0x63c/0x19c0 net/core/dev.c:4497
napi_skb_finish net/core/dev.c:4858
napi_gro_receive+0x629/0xa50 net/core/dev.c:4889
e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4018
e1000_clean_rx_irq+0x1492/0x1d30
drivers/net/ethernet/intel/e1000/e1000_main.c:4474
e1000_clean+0x43aa/0x5970 drivers/net/ethernet/intel/e1000/e1000_main.c:3819
napi_poll net/core/dev.c:5500
net_rx_action+0x73c/0x1820 net/core/dev.c:5566
__do_softirq+0x4b4/0x8dd kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364
irq_exit+0x203/0x240 kernel/softirq.c:405
exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:638
do_IRQ+0x15e/0x1a0 arch/x86/kernel/irq.c:263
common_interrupt+0x86/0x86
Fixes: d894ba18d4e4 ("soreuseport: fix ordering for mixed v4/v6 sockets")
Fixes: d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6 ordering fix")
Reported-by: Alexander Potapenko <glider@google.com>
Acked-by: Craig Gallek <kraig@google.com>
Andrey Konovalov reported following error while fuzzing with syzkaller :
IPv4: Attempt to release alive inet socket ffff880068e98940
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 3905 Comm: a.out Not tainted 4.9.0-rc3+ #333
task: ffff88006b9e0000 task.stack: ffff880068770000
RIP: 0010:[<ffffffff819ead5f>] [<ffffffff819ead5f>]
selinux_socket_sock_rcv_skb+0xff/0x6a0 security/selinux/hooks.c:4639
RSP: 0018:ffff8800687771c8 EFLAGS: 00010202
RAX: ffff88006b9e0000 RBX: 1ffff1000d0eee3f RCX: 1ffff1000d1d312a
RDX: 1ffff1000d1d31a6 RSI: dffffc0000000000 RDI: 0000000000000010
RBP: ffff880068777360 R08: 0000000000000000 R09: 0000000000000002
R10: dffffc0000000000 R11: 0000000000000006 R12: ffff880068e98940
R13: 0000000000000002 R14: ffff880068777338 R15: 0000000000000000
FS: 00007f00ff760700(0000) GS:ffff88006cd00000(0000) knlGS:0000000000000000
CR2: 0000000020008000 CR3: 000000006a308000 CR4: 00000000000006e0
Stack:
ffff8800687771e0 ffffffff812508a5 ffff8800686f3168 0000000000000007
ffff88006ac8cdfc ffff8800665ea500 0000000041b58ab3 ffffffff847b5480
ffffffff819eac60 ffff88006b9e0860 ffff88006b9e0868 ffff88006b9e07f0
Call Trace:
[<ffffffff819c8dd5>] security_sock_rcv_skb+0x75/0xb0 security/security.c:1317
[<ffffffff82c2a9e7>] sk_filter_trim_cap+0x67/0x10e0 net/core/filter.c:81
[<ffffffff82b81e60>] __sk_receive_skb+0x30/0xa00 net/core/sock.c:460
[<ffffffff838bbf12>] dccp_v4_rcv+0xdb2/0x1910 net/dccp/ipv4.c:873
[<ffffffff83069d22>] ip_local_deliver_finish+0x332/0xad0
[< inline >] NF_HOOK_THRESH ./include/linux/netfilter.h:232
[< inline >] NF_HOOK ./include/linux/netfilter.h:255
[<ffffffff8306abd2>] ip_local_deliver+0x1c2/0x4b0 net/ipv4/ip_input.c:257
[< inline >] dst_input ./include/net/dst.h:507
[<ffffffff83068500>] ip_rcv_finish+0x750/0x1c40 net/ipv4/ip_input.c:396
[<ffffffff8306b82f>] ip_rcv+0x96f/0x12f0 net/ipv4/ip_input.c:487
[<ffffffff82bd9fb7>] __netif_receive_skb_core+0x1897/0x2a50 net/core/dev.c:4213
[<ffffffff82bdb19a>] __netif_receive_skb+0x2a/0x170 net/core/dev.c:4251
[<ffffffff82bdb493>] netif_receive_skb_internal+0x1b3/0x390 net/core/dev.c:4279
[<ffffffff82bdb6b8>] netif_receive_skb+0x48/0x250 net/core/dev.c:4303
[<ffffffff8241fc75>] tun_get_user+0xbd5/0x28a0 drivers/net/tun.c:1308
[<ffffffff82421b5a>] tun_chr_write_iter+0xda/0x190 drivers/net/tun.c:1332
[< inline >] new_sync_write fs/read_write.c:499
[<ffffffff8151bd44>] __vfs_write+0x334/0x570 fs/read_write.c:512
[<ffffffff8151f85b>] vfs_write+0x17b/0x500 fs/read_write.c:560
[< inline >] SYSC_write fs/read_write.c:607
[<ffffffff81523184>] SyS_write+0xd4/0x1a0 fs/read_write.c:599
[<ffffffff83fc02c1>] entry_SYSCALL_64_fastpath+0x1f/0xc2
It turns out DCCP calls __sk_receive_skb(), and this broke when
lookups no longer took a reference on listeners.
Fix this issue by adding a @refcounted parameter to __sk_receive_skb(),
so that sock_put() is used only when needed.
Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
The skbuff and sock structure both had missing parameter annotation
values.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
A malicious TCP receiver, sending SACK, can force the sender to split
skbs in write queue and increase its memory usage.
Then, when socket is closed and its write queue purged, we might
overflow sk_forward_alloc (It becomes negative)
sk_mem_reclaim() does nothing in this case, and more than 2GB
are leaked from TCP perspective (tcp_memory_allocated is not changed)
Then warnings trigger from inet_sock_destruct() and
sk_stream_kill_queues() seeing a not zero sk_forward_alloc
All TCP stack can be stuck because TCP is under memory pressure.
A simple fix is to preemptively reclaim from sk_mem_uncharge().
This makes sure a socket wont have more than 2 MB forward allocated,
after burst and idle period.
We no longer use this handler, we can delete it.
Since we no longer use SLAB_DESTROY_BY_RCU for UDP,
we do not need sk_prot_clear_portaddr_nulls() helper.
As recently discussed during the task_under_cgroup_hierarchy() addition,
we should get rid of the ifdefs surrounding the bpf_skb_under_cgroup()
helper. If related functionality is not built-in, the helper cannot be
used anyway, which is also in line with what we do for all other helpers.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Dccp verifies packet integrity, including length, at initial rcv in
dccp_invalid_packet, later pulls headers in dccp_enqueue_skb.
A call to sk_filter in-between can cause __skb_pull to wrap skb->len.
skb_copy_datagram_msg interprets this as a negative value, so
(correctly) fails with EFAULT. The negative length is reported in
ioctl SIOCINQ or possibly in a DCCP_WARN in dccp_close.
Introduce an sk_receive_skb variant that caps how small a filter
program can trim packets, and call this in dccp with the header
length. Excessively trimmed packets are now processed normally and
queued for reception as 0B payloads.
Fixes: 7c657876b63c ("[DCCP]: Initial implementation")
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
->sk_shutdown bits share one bitfield with some other bits in sock struct,
such as ->sk_no_check_[r,t]x, ->sk_userlocks ...
sock_setsockopt() may write to these bits, while holding the socket lock.
In case of AF_UNIX sockets, we change ->sk_shutdown bits while holding only
unix_state_lock(). So concurrent setsockopt() and shutdown() may lead
to corrupting these bits.
Fix this by moving ->sk_shutdown bits out of bitfield into a separate byte.
This will not change the 'struct sock' size since ->sk_shutdown moved into
previously unused 16-bit hole.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
tcp_snd_una_update() and tcp_rcv_nxt_update() call
u64_stats_update_begin() either from process context or BH handler.
This triggers a lockdep splat on 32bit & SMP builds.
We could add u64_stats_update_begin_bh() variant but this would
slow down 32bit builds with useless local_disable_bh() and
local_enable_bh() pairs, since we own the socket lock at this point.
I add sock_owned_by_me() helper to have proper lockdep support
even on 64bit builds, and new u64_stats_update_begin_raw()
and u64_stats_update_end_raw methods.
Fixes: c10d9310edf5 ("tcp: do not assume TCP code is non preemptible")
Reported-by: Fabio Estevam <festevam@gmail.com>
Diagnosed-by: Francois Romieu <romieu@fr.zoreil.com>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Hosts sending lot of ACK packets exhibit high sock_wfree() cost
because of cache line miss to test SOCK_USE_WRITE_QUEUE
We could move this flag close to sk_wmem_alloc but it is better
to perform the atomic_sub_and_test() on a clean cache line,
as it avoid one extra bus transaction.
skb_orphan_partial() can also have a fast track for packets that either
are TCP acks, or already went through another skb_orphan_partial()
Large sendmsg()/write() hold socket lock for the duration of the call,
unless sk->sk_sndbuf limit is hit. This is bad because incoming packets
are parked into socket backlog for a long time.
Critical decisions like fast retransmit might be delayed.
Receivers have to maintain a big out of order queue with additional cpu
overhead, and also possible stalls in TX once windows are full.
Bidirectional flows are particularly hurt since the backlog can become
quite big if the copy from user space triggers IO (page faults)
Some applications learnt to use sendmsg() (or sendmmsg()) with small
chunks to avoid this issue.
Kernel should know better, right ?
Add a generic sk_flush_backlog() helper and use it right
before a new skb is allocated. Typically we put 64KB of payload
per skb (unless MSG_EOR is requested) and checking socket backlog
every 64KB gives good results.
As a matter of fact, tests with TSO/GSO disabled give very nice
results, as we manage to keep a small write queue and smaller
perceived rtt.
Note that sk_flush_backlog() maintains socket ownership,
so is not equivalent to a {release_sock(sk); lock_sock(sk);},
to ensure implicit atomicity rules that sendmsg() was
giving to (possibly buggy) applications.
In this simple implementation, I chose to not call tcp_release_cb(),
but we might consider this later.
Cc: Alexei Starovoitov <ast@fb.com>
Cc: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
SOCKWQ_ASYNC_WAITDATA is set/cleared in sk_wait_data()
and equivalent functions, so that sock_wake_async() can send
a SIGIO only when necessary.
Since these atomic operations are really not needed unless
socket expressed interest in FASYNC, we can omit them in most
cases.
SOCKWQ_ASYNC_NOSPACE is tested in sock_wake_async()
so that a SIGIO signal is sent when needed.
tcp_sendmsg() clears the bit.
tcp_poll() sets the bit when stream is not writeable.
We can avoid two atomic operations by first checking if socket
is actually interested in the FASYNC business (most sockets in
real applications do not use AIO, but select()/poll()/epoll())
This also removes one cache line miss to access sk->sk_wq->flags
in tcp_sendmsg()
was merged as a bug fix to the net tree. Two conflicting changes
were committed to net-next before the above fix was merged back to
net-next:
ca065d0cf80f ("udp: no longer use SLAB_DESTROY_BY_RCU")
These changes switched the datastructure used for TCP and UDP sockets
from hlist_nulls to hlist. This patch applies the necessary parts
of the net tree fix to net-next which were not automatic as part of the
merge.
Fixes: 1602f49b58ab ("Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net")
Signed-off-by: Craig Gallek <kraig@google.com>
Valdis reported tons of stack dumps caused by WARN_ON() in
sock_owned_by_user()
This test needs to be relaxed if/when lockdep disables itself.
Note that other lockdep_sock_is_held() callers are all from
rcu_dereference_protected() sections which already are disabled
if/when lockdep has been disabled.
Fixes: fafc4e1ea1a4 ("sock: tigthen lockdep checks for sock_owned_by_user")
Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Conflicts were two cases of simple overlapping changes,
nothing serious.
In the UDP case, we need to add a hlist_add_tail_rcu()
to linux/rculist.h, because we've moved UDP socket handling
away from using nulls lists.
With the SO_REUSEPORT socket option, it is possible to create sockets
in the AF_INET and AF_INET6 domains which are bound to the same IPv4 address.
This is only possible with SO_REUSEPORT and when not using IPV6_V6ONLY on
the AF_INET6 sockets.
Prior to the commits referenced below, an incoming IPv4 packet would
always be routed to a socket of type AF_INET when this mixed-mode was used.
After those changes, the same packet would be routed to the most recently
bound socket (if this happened to be an AF_INET6 socket, it would
have an IPv4 mapped IPv6 address).
The change in behavior occurred because the recent SO_REUSEPORT optimizations
short-circuit the socket scoring logic as soon as they find a match. They
did not take into account the scoring logic that favors AF_INET sockets
over AF_INET6 sockets in the event of a tie.
To fix this problem, this patch changes the insertion order of AF_INET
and AF_INET6 addresses in the TCP and UDP socket lists when the sockets
have SO_REUSEPORT set. AF_INET sockets will be inserted at the head of the
list and AF_INET6 sockets with SO_REUSEPORT set will always be inserted at
the tail of the list. This will force AF_INET sockets to always be
considered first.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Fixes: 125e80b88687 ("soreuseport: fast reuseport TCP socket selection")
Reported-by: Maciej Żenczykowski <maze@google.com>
Sometimes gcc mysteriously doesn't inline
very small functions we expect to be inlined. See
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66122
Arguably, gcc should do better, but gcc people aren't willing
to invest time into it, asking to use __always_inline instead.
With this .config:
http://busybox.net/~vda/kernel_config_OPTIMIZE_INLINING_and_Os,
the following functions get deinlined many times.
netif_tx_stop_queue: 207 copies, 590 calls:
55 push %rbp
48 89 e5 mov %rsp,%rbp
f0 80 8f e0 01 00 00 01 lock orb $0x1,0x1e0(%rdi)
5d pop %rbp
c3 retq
netif_tx_start_queue: 47 copies, 111 calls
55 push %rbp
f0 80 a7 e0 01 00 00 fe lock andb $0xfe,0x1e0(%rdi)
5d pop %rbp
c3 retq
sock_hold: 39 copies, 124 calls
55 push %rbp
f0 ff 87 80 00 00 00 lock incl 0x80(%rdi)
5d pop %rbp
c3 retq
__sock_put: 6 copies, 13 calls
55 push %rbp
f0 ff 8f 80 00 00 00 lock decl 0x80(%rdi)
5d pop %rbp
c3 retq
This patch fixes this via s/inline/__always_inline/.
Code size decrease after the patch is ~2.5k:
56719876 56364551 36196352 149280779 8e5d80b vmlinux_before
56717440 56364551 36196352 149278343 8e5ce87 vmlinux
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
CC: David S. Miller <davem@davemloft.net>
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
CC: netfilter-devel@vger.kernel.org
sock_owned_by_user should not be used without socket lock held. It seems
to be a common practice to check .owned before lock reclassification, so
provide a little help to abstract this check away.
Cc: linux-cifs@vger.kernel.org
Cc: linux-bluetooth@vger.kernel.org
Cc: linux-nfs@vger.kernel.org
Needs to be protected with CONFIG_LOCKDEP.
Based upon a patch by Hannes Frederic Sowa.
I forgot to add inline to lockdep_sock_is_held, so it generated all
kinds of build warnings if not build with lockdep support.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
The socket is either locked if we hold the slock spin_lock for
lock_sock_fast and unlock_sock_fast or we own the lock (sk_lock.owned
!= 0). Check for this and at the same time improve that the current
thread/cpu is really holding the lock.
During release_sock we use callbacks to finish the processing
of outstanding skbs on the socket. We actually are still locked,
sk_locked.owned == 1, but we already told lockdep that the mutex
is released. This could lead to false positives in lockdep for
lockdep_sock_is_held (we don't hold the slock spinlock during processing
the outstanding skbs).
I took over this patch from Eric Dumazet and tested it.
Enable peeking at UDP datagrams at the offset specified with socket
option SOL_SOCKET/SO_PEEK_OFF. Peek at any datagram in the queue, up
to the end of the given datagram.
Implement the SO_PEEK_OFF semantics introduced in commit ef64a54f6e55
("sock: Introduce the SO_PEEK_OFF sock option"). Increase the offset
on peek, decrease it on regular reads.
When peeking, always checksum the packet immediately, to avoid
recomputation on subsequent peeks and final read.
The socket lock is not held for the duration of udp_recvmsg, so
peek and read operations can run concurrently. Only the last store
to sk_peek_off is preserved.
Signed-off-by: Sam Kumar <samanthakumar@google.com>
Remove UDP transport headers before queueing packets for reception.
This change simplifies a follow-up patch to add MSG_PEEK support.
Make the peek offset interface safe to use in lockless environments.
Use READ_ONCE and WRITE_ONCE to avoid race conditions between testing
and updating the peek offset.
Suggested-by: Eric Dumazet <edumazet@google.com>
Now ss can report sk_drops, we can instruct TCP to increment
this per socket counter when it drops an incoming frame, to refine
monitoring and debugging.
Following patch takes care of listeners drops.
Tom Herbert would like not touching UDP socket refcnt for encapsulated
traffic. For this to happen, we need to use normal RCU rules, with a grace
period before freeing a socket. UDP sockets are not short lived in the
high usage case, so the added cost of call_rcu() should not be a concern.
This actually removes a lot of complexity in UDP stack.
Multicast receives no longer need to hold a bucket spinlock.
Note that ip early demux still needs to take a reference on the socket.
Same remark for functions used by xt_socket and xt_PROXY netfilter modules,
but this might be changed later.
Performance for a single UDP socket receiving flood traffic from
many RX queues/cpus.
Simple udp_rx using simple recvfrom() loop :
438 kpps instead of 374 kpps : 17 % increase of the peak rate.
v2: Addressed Willem de Bruijn feedback in multicast handling
- keep early demux break in __udp4_lib_demux_lookup()
Cc: Tom Herbert <tom@herbertland.com>
Cc: Willem de Bruijn <willemb@google.com>
Tested-by: Tom Herbert <tom@herbertland.com>
We want a generic way to insert an RCU grace period before socket
freeing for cases where RCU_SLAB_DESTROY_BY_RCU is adding too
much overhead.
SLAB_DESTROY_BY_RCU strict rules force us to take a reference
on the socket sk_refcnt, and it is a performance problem for UDP
encapsulation, or TCP synflood behavior, as many CPUs might
attempt the atomic operations on a shared sk_refcnt
UDP sockets and TCP listeners can set SOCK_RCU_FREE so that their
lookup can use traditional RCU rules, without refcount changes.
They can set the flag only once hashed and visible by other cpus.
Currently, SOL_TIMESTAMPING can only be enabled using setsockopt.
This is very costly when users want to sample writes to gather
tx timestamps.
Add support for enabling SO_TIMESTAMPING via control messages by
using tsflags added in `struct sockcm_cookie` (added in the previous
patches in this series) to set the tx_flags of the last skb created in
a sendmsg. With this patch, the timestamp recording bits in tx_flags
of the skbuff is overridden if SO_TIMESTAMPING is passed in a cmsg.
Please note that this is only effective for overriding the recording
timestamps flags. Users should enable timestamp reporting (e.g.,
SOF_TIMESTAMPING_SOFTWARE | SOF_TIMESTAMPING_OPT_ID) using
socket options and then should ask for SOF_TIMESTAMPING_TX_*
using control messages per sendmsg to sample timestamps for each
write.
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Willem de Bruijn <willemb@google.com>
Accept SO_TIMESTAMPING in control messages of the SOL_SOCKET level
as a basis to accept timestamping requests per write.
This implementation only accepts TX recording flags (i.e.,
SOF_TIMESTAMPING_TX_HARDWARE, SOF_TIMESTAMPING_TX_SOFTWARE,
SOF_TIMESTAMPING_TX_SCHED, and SOF_TIMESTAMPING_TX_ACK) in
control messages. Users need to set reporting flags (e.g.,
SOF_TIMESTAMPING_OPT_ID) per socket via socket options.
This commit adds a tsflags field in sockcm_cookie which is
set in __sock_cmsg_send. It only override the SOF_TIMESTAMPING_TX_*
bits in sockcm_cookie.tsflags allowing the control message
to override the recording behavior per write, yet maintaining
the value of other flags.
This patch implements validating the control message and setting
tsflags in struct sockcm_cookie. Next commits in this series will
actually implement timestamping per write for different protocols.
To process cmsg's of the SOL_SOCKET level in addition to
cmsgs of another level, protocols can call sock_cmsg_send().
This causes a double walk on the cmsghdr list, one for SOL_SOCKET
and one for the other level.
Extract the inner demultiplex logic from the loop that walks the list,
to allow having this called directly from a walker in the protocol
specific code.
In order to support fast reuseport lookups in TCP, the hash function
defined in struct proto must be capable of returning an error code.
This patch changes the function signature of all related hash functions
to return an integer and handles or propagates this return value at
all call sites.
The cgroup methods are no longer used after baac50bbc3cd ("net:
tcp_memcontrol: simplify linkage between socket and page counter").
The hunk to delete them was included in the original patch but must
have gotten lost during conflict resolution on the way upstream.
Fixes: baac50bbc3cd ("net: tcp_memcontrol: simplify linkage between socket and page counter")
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
The unified hierarchy memory controller is going to use this jump label
as well to control the networking callbacks. Move it to the memory
controller code and give it a more generic name.
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
There won't be any separate counters for socket memory consumed by
protocols other than TCP in the future. Remove the indirection and link
sockets directly to their owning memory cgroup.
There won't be a tcp control soft limit, so integrating the memcg code
into the global skmem limiting scheme complicates things unnecessarily.
Replace this with simple and clear charge and uncharge calls--hidden
behind a jump label--to account skb memory.
Note that this is not purely aesthetic: as a result of shoehorning the
per-memcg code into the same memory accounting functions that handle the
global level, the old code would compare the per-memcg consumption
against the smaller of the per-memcg limit and the global limit. This
allowed the total consumption of multiple sockets to exceed the global
limit, as long as the individual sockets stayed within bounds. After
this change, the code will always compare the per-memcg consumption to
the per-memcg limit, and the global consumption to the global limit, and
thus close this loophole.
Without a soft limit, the per-memcg memory pressure state in sockets is
generally questionable. However, we did it until now, so we continue to
enter it when the hard limit is hit, and packets are dropped, to let
other sockets in the cgroup know that they shouldn't grow their transmit
windows, either. However, keep it simple in the new callback model and
leave memory pressure lazily when the next packet is accepted (as
opposed to doing it synchroneously when packets are processed). When
packets are dropped, network performance will already be in the toilet,
so that should be a reasonable trade-off.
As described above, consumption is now checked on the per-memcg level
and the global level separately. Likewise, memory pressure states are
maintained on both the per-memcg level and the global level, and a
socket is considered under pressure when either level asserts as much.
tcp_memcontrol replicates the global sysctl_mem limit array per cgroup,
but it only ever sets these entries to the value of the memory_allocated
page_counter limit. Use the latter directly.
The number of allocated sockets is used for calculations in the soft
limit phase, where packets are accepted but the socket is under memory
pressure.
Since there is no soft limit phase in tcp_memcontrol, and memory
pressure is only entered when packets are already dropped, this is
actually dead code. Remove it.
As this is the last user of parent_cg_proto(), remove that too.
When a cgroup currently breaches its socket memory limit, it enters
memory pressure mode for itself and its *ancestors*. This throttles
transmission in unrelated sibling and cousin subtrees that have nothing
to do with the breached limit.
On the contrary, breaching a limit should make that group and its
*children* enter memory pressure mode. But this happens already, albeit
lazily: if an ancestor limit is breached, siblings will enter memory
pressure on their own once the next packet arrives for them.
So no additional hierarchy code is needed. Remove the bogus stuff.
When charging socket memory, the code currently checks only the local
page counter for excess to determine whether the memcg is under socket
pressure. But even if the local counter is fine, one of the ancestors
could have breached its limit, which should also force this child to
enter socket pressure. This currently doesn't happen.
Fix this by using page_counter_try_charge() first. If that fails, it
means that either the local counter or one of the ancestors are in
excess of their limit, and the child should enter socket pressure.
Fixes: 3e32cb2e0a12 ("mm: memcontrol: lockless page counters")
struct sock_reuseport is an optional shared structure referenced by each
socket belonging to a reuseport group. When a socket is bound to an
address/port not yet in use and the reuseport flag has been set, the
structure will be allocated and attached to the newly bound socket.
When subsequent calls to bind are made for the same address/port, the
shared structure will be updated to include the new socket and the
newly bound socket will reference the group structure.
Usually, when an incoming packet was destined for a reuseport group,
all sockets in the same group needed to be considered before a
dispatching decision was made. With this structure, an appropriate
socket can be found after looking up just one socket in the group.
This shared structure will also allow for more complicated decisions to
be made when selecting a socket (eg a BPF filter).
This work is based off a similar implementation written by
Ying Cai <ycai@google.com> for implementing policy-based reuseport
selection.
drivers/net/geneve.c
Here we had an overlapping change, where in 'net' the extraneous stats
bump was being removed whilst in 'net-next' the final argument to
udp_tunnel6_xmit_skb() was being changed.
declaration
Docbook does not like the definition of macros inside a field declaration
and adds a warning. Move the definition out.
Fixes: 79462ad02e86180 ("net: add validation for the socket syscall protocol argument")
Reported-by: kbuild test robot <lkp@intel.com>
This patch adds a SOCK_DESTROY operation, a destroy function
pointer to sock_diag_handler, and a diag_destroy function
pointer. It does not include any implementation code.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
In tcp_send_sendpage and tcp_sendmsg we check the route capabilities to
determine if checksum offload can be performed. This check currently
does not take the IP protocol into account for devices that advertise
only one of NETIF_F_IPV6_CSUM or NETIF_F_IP_CSUM. This patch adds a
function to check capabilities for checksum offload with a socket
called sk_check_csum_caps. This function checks for specific IPv4 or
IPv6 offload support based on the family of the socket.
Signed-off-by: Tom Herbert <tom@herbertland.com>
David Wilder reported crashes caused by dst reuse.
<quote David>
I am seeing a crash on a distro V4.2.3 kernel caused by a double
release of a dst_entry. In ipv4_dst_destroy() the call to
list_empty() finds a poisoned next pointer, indicating the dst_entry
has already been removed from the list and freed. The crash occurs
18 to 24 hours into a run of a network stress exerciser.
</quote>
Thanks to his detailed report and analysis, we were able to understand
the core issue.
IP early demux can associate a dst to skb, after a lookup in TCP/UDP
sockets.
When socket cache is not properly set, we want to store into
sk->sk_dst_cache the dst for future IP early demux lookups,
by acquiring a stable refcount on the dst.
Problem is this acquisition is simply using an atomic_inc(),
which works well, unless the dst was queued for destruction from
dst_release() noticing dst refcount went to zero, if DST_NOCACHE
was set on dst.
We need to make sure current refcount is not zero before incrementing
it, or risk double free as David reported.
This patch, being a stable candidate, adds two new helpers, and use
them only from IP early demux problematic paths.
It might be possible to merge in net-next skb_dst_force() and
skb_dst_force_safe(), but I prefer having the smallest patch for stable
kernels : Maybe some skb_dst_force() callers do not expect skb->dst
can suddenly be cleared.
Can probably be backported back to linux-3.6 kernels
Reported-by: David J. Wilder <dwilder@us.ibm.com>
Tested-by: David J. Wilder <dwilder@us.ibm.com>
