path: root/include/net/transp_v6.h
2014-01-19ipv6: make IPV6_RECVPKTINFO work for ipv4 datagramsHannes Frederic Sowa
We currently don't report IPV6_RECVPKTINFO in cmsg access ancillary data for IPv4 datagrams on IPv6 sockets. This patch splits the ip6_datagram_recv_ctl into two functions, one which handles both protocol families, AF_INET and AF_INET6, while the ip6_datagram_recv_specific_ctl only handles IPv6 cmsg data. ip6_datagram_recv_*_ctl never reported back any errors, so we can make them return void. Also provide a helper for protocols which don't offer dual personality to further use ip6_datagram_recv_ctl, which is exported to modules. I needed to shuffle the code for ping around a bit to make it easier to implement dual personality for ping ipv6 sockets in future. Reported-by: Gert Doering <gert@space.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04transp_v6.h: style neateningJoe Perches
Use a more current code style. Remove extern from function prototypes. Align function arguments and reflow to 80 cols. Use network comment styles. Signed-off-by: Joe Perches <joe@perches.com> cc: Lorenzo Colitti <lorenzo@google.com>, Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04net: ipv6: Unify {raw,udp}6_sock_seq_show.Lorenzo Colitti
udp6_sock_seq_show and raw6_sock_seq_show are identical, except the UDP version displays ports and the raw version displays the protocol. Refactor most of the code in these two functions into a new common ip6_dgram_sock_seq_show function, in preparation for using it to display ICMPv6 sockets as well. Also reduce the indentation in parts of include/net/transp_v6.h to improve readability. Compiles and displays reasonable results with CONFIG_IPV6={n,m,y} Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04Clean up indentation in net/ipv6/transp_v6.hLorenzo Colitti
Reduce the indentation of most of the functions and make it a bit more consistent. This allows longer function and arg names to be consistently indented without wrapping. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-25net: ipv6: Add IPv6 support to the ping socket.Lorenzo Colitti
This adds the ability to send ICMPv6 echo requests without a raw socket. The equivalent ability for ICMPv4 was added in 2011. Instead of having separate code paths for IPv4 and IPv6, make most of the code in net/ipv4/ping.c dual-stack and only add a few IPv6-specific bits (like the protocol definition) to a new net/ipv6/ping.c. Hopefully this will reduce divergence and/or duplication of bugs in the future. Caveats: - Setting options via ancillary data (e.g., using IPV6_PKTINFO to specify the outgoing interface) is not yet supported. - There are no separate security settings for IPv4 and IPv6; everything is controlled by /proc/net/ipv4/ping_group_range. - The proc interface does not yet display IPv6 ping sockets properly. Tested with a patched copy of ping6 and using raw socket calls. Compiles and works with all of CONFIG_IPV6={n,m,y}. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31ipv6: rename datagram_send_ctl and datagram_recv_ctlTom Parkin
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since datagram_send_ctl is publicly exported it should be appropriately named to reflect the fact that it's for IPv6 only. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30net: relax PKTINFO non local ipv6 udp xmit checkMaciej Żenczykowski
Allow transparent sockets to be less restrictive about the source ip of ipv6 udp packets being sent. Google-Bug-Id: 5018138 Signed-off-by: Maciej Żenczykowski <maze@google.com> CC: "Erik Kline" <ek@google.com> CC: "Lorenzo Colitti" <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-24net: Remove __KERNEL__ cpp checks from include/netDavid S. Miller
These header files are never installed to user consumption, so any __KERNEL__ cpp checks are superfluous. Projects should also not copy these files into their userland utility sources and try to use them there. If they insist on doing so, the onus is on them to sanitize the headers as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2010-04-23IPv6: Add dontfrag argument to relevant functionsBrian Haley
Add dontfrag argument to relevant functions for IPV6_DONTFRAG support, as well as allowing the value to be passed-in via ancillary cmsg data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02inet: inet_connection_sock_af_ops constStephen Hemminger
The function block inet_connect_sock_af_ops contains no data make it constant. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-14net: replace __constant_{endian} uses in net headersHarvey Harrison
Base versions handle constant folding now. For headers exposed to userspace, we must only expose the __ prefixed versions. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-14net: change proto destroy method to return voidBrian Haley
Change struct proto destroy function pointer to return void. Noticed by Al Viro. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-05[IPV6] NETNS: Handle ancillary data in appropriate namespace.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[IPV6]: make the protocol initialization to return an error codeDaniel Lezcano
This patchset makes the different protocols to return an error code, so the af_inet6 module can check the initialization was correct or not. The raw6 was taken into account to be consistent with the rest of the protocols, but the registration is at the same place. Because the raw6 has its own init function, the proto and the ops structure can be moved inside the raw6.c file. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: make frag to return an error at initializationDaniel Lezcano
This patch makes the frag_init to return an error code, so the af_inet6 module can handle the error. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: make extended headers to return an error at initializationDaniel Lezcano
This patch factorize the code for the differents init functions for rthdr, nodata, destopt in a single function exthdrs_init. This function returns an error so the af_inet6 module can check correctly the initialization. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Rename struct tcp_func to struct inet_connection_sock_af_opsArnaldo Carvalho de Melo
And move it to struct inet_connection_sock. DCCP will use it in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[IPV6]: Support IPV6_{RECV,}TCLASS socket options / ancillary data.YOSHIFUJI Hideaki
Based on patch from David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
