path: root/include/net/udplite.h
2011-03-01udp: Switch to ip_finish_skbHerbert Xu
This patch converts UDP to use the new ip_finish_skb API. This would then allows us to more easily use ip_make_skb which allows UDP to run without a socket lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29udp: introduce struct udp_table and multiple spinlocksEric Dumazet
UDP sockets are hashed in a 128 slots hash table. This hash table is protected by *one* rwlock. This rwlock is readlocked each time an incoming UDP message is handled. This rwlock is writelocked each time a socket must be inserted in hash table (bind time), or deleted from this table (close time) This is not scalable on SMP machines : 1) Even in read mode, lock() and unlock() are atomic operations and must dirty a contended cache line, shared by all cpus. 2) A writer might be starved if many readers are 'in flight'. This can happen on a machine with some NIC receiving many UDP messages. User process can be delayed a long time at socket creation/dismantle time. This patch prepares RCU migration, by introducing 'struct udp_table and struct udp_hslot', and using one spinlock per chain, to reduce contention on central rwlock. Introducing one spinlock per chain reduces latencies, for port randomization on heavily loaded UDP servers. This also speedup bindings to specific ports. udp_lib_unhash() was uninlined, becoming to big. Some cleanups were done to ease review of following patch (RCUification of UDP Unicast lookups) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Restore missing inDatagrams incrementsHerbert Xu
The previous move of the the UDP inDatagrams counter caused the counting of encapsulated packets, SUNRPC data (as opposed to call) packets and RXRPC packets to go missing. This patch restores all of these. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[UDP]: Revert 2-pass hashing changes.David S. Miller
This reverts changesets: 6aaf47fa48d3c44280810b1b470261d340e4ed87 b7b5f487ab39bc10ed0694af35651a03d9cb97ff de34ed91c4ffa4727964a832c46e624dd1495cf5 fc038410b4b1643766f8033f4940bcdb1dace633 There are still some correctness issues recently discovered which do not have a known fix that doesn't involve doing a full hash table scan on port bind. So revert for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[UDP]: Fix AF-specific references in AF-agnostic code.David S. Miller
__udp_lib_port_inuse() cannot make direct references to inet_sk(sk)->rcv_saddr as that is ipv4 specific state and this code is used by ipv6 too. Use an operations vector to solve this, and this also paves the way for ipv6 support for non-wild saddr hashing in UDP. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce udp_hdr(), remove skb->h.uhArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: Clean up UDP-Lite receive checksumHerbert Xu
This patch eliminates some duplicate code for the verification of receive checksums between UDP-Lite and UDP. It does this by introducing __skb_checksum_complete_head which is identical to __skb_checksum_complete_head apart from the fact that it takes a length parameter rather than computing the first skb->len bytes. As a result UDP-Lite will be able to use hardware checksum offload for packets which do not use partial coverage checksums. It also means that UDP-Lite loopback no longer does unnecessary checksum verification. If any NICs start support UDP-Lite this would also start working automatically. This patch removes the assumption that msg_flags has MSG_TRUNC clear upon entry in recvmsg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Fix assorted misannotations (from md5 and udplite merges).Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[UDPLite]: udplite.h needs ip6_checksum.hDavid S. Miller
2006-12-02[NET]: annotate csum_ipv6_magic() callers in net/*Al Viro
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
