In P2P client mode, the GO (AP) to connect to might
have periods of time where it is not available due
to powersave. To allow the driver to sync with it
and send frames to the GO only when it is available
add a new callback tx_sync (and the corresponding
finish_tx_sync). These callbacks can sleep unlike
the actual TX.
Some P2P scans are not allowed to advertise
11b rates, but that is a rather special case
so instead of having that, allow userspace
to request the rate sets (per band) that are
advertised in scan probe request frames.
Since it's needed in two places now, factor
out some common code parsing a rate array.
In the future dst entries will be neigh-less. In that environment we
need to have an easy transition point for current users of
dst->neighbour outside of the packet output fast path.
dst_{get,set}_neighbour()
It just makes it harder to see 1) what the code is doing
and 2) grep for all users of dst{->,.}neighbour
This will get us closer to being able to do "neigh stuff"
completely independent of the underlying dst_entry for
protocols (ipv4/ipv6) that wish to do so.
We will also be able to make dst entries neigh-less.
It is always dev_queue_xmit().
It's just taking on one of two possible values, either
neigh_ops->output or dev_queue_xmit(). And this is purely depending
upon whether nud_state has NUD_CONNECTED set or not.
It's always dev_queue_xmit().
ieee80211_iter_keys() currently returns keys in
the backward order they were installed in, which
is a bit confusing. Add them to the tail of the
key list to make sure iterations go in the same
order that keys were originally installed in.
When the driver wants to pre-program the TKIP
RX phase 1 key, it needs to be able to obtain
it for the peer's TA. Add API to allow it to
generate it.
The generation uses a dummy on-stack context
since it doesn't know the RX queue.
Some chips may support different lengths of user-supplied IEs with a
single scheduled scan command than with a single normal scan command.
To support this, this patch creates a separate hardware description
element that describes the maximum size of user-supplied information
element data supported in scheduled scans.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Some chips can scan more SSIDs with a single scheduled scan command
than with a single normal scan command (eg. wl12xx chips).
element that describes the amount of SSIDs supported in scheduled
scans.
Since we now have the necessary API in place to support
GTK rekeying, applications will need to know whether it
is supported by a device. Add a pseudo-trigger that is
used only to advertise that capability. Also, add some
new triggers that match what iwlagn devices can do.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
net/bluetooth/l2cap_core.c
Now that there is a one-to-one correspondance between neighbour
and hh_cache entries, we no longer need:
1) dynamic allocation
2) attachment to dst->hh
3) refcounting
Initialization of the hh_cache entry is indicated by hh_len
being non-zero, and such initialization is always done with
the neighbour's lock held as a writer.
In WoWLAN, devices may use crypto keys for TX/RX
and could also implement GTK rekeying. If the
driver isn't able to retrieve replay counters and
similar information from the device upon resume,
or if the device isn't responsive due to platform
issues, it isn't safe to keep the connection up
as GTK rekey messages from during the sleep time
could be replayed against it.
The only protection against that is disconnecting
from the AP. Modifying mac80211 to do that while
it is resuming would be very complex and invasive
in the case that the driver requires a reconfig,
so do it after it has resumed completely. In that
case, however, packets might be replayed since it
can then only happen after TX/RX are up again, so
mark keys for interfaces that need to disconnect
as "tainted" and drop all packets that are sent
or received with those keys.
Get rid of all of the useless and costly indirection
by doing the neigh hash table lookup directly inside
of the neighbour binding.
Rename from arp_bind_neighbour to rt_bind_neighbour.
Use new helpers {__,}ipv4_neigh_lookup()
In rt_bind_neighbour() get rid of useless tests which
are never true in the context this function is called,
namely dev is never NULL and the dst->neighbour is
always NULL.
Looks like I forgot to document the "gfp" parameter
to cfg80211_gtk_rekey_notify, add it.
mac80211 maintains a running average of the RSSI when a STA
is associated to an AP. Report threshold events to any driver
that has registered callbacks for getting RSSI measurements.
Implement callbacks in mac80211 so that driver can set thresholds.
Add callbacks in mac80211 which is invoked when an RSSI threshold
event occurs.
mac80211: add tracing to rssi_reports api and remove extraneous fn argument
mac80211: scale up rssi thresholds from driver by 16 before storing
Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
master.kernel.org:/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
We need to make sure the multiplier is odd.
And mask the hash function result by simply shifting
down the "->hash_shift" most significant bits.
Currently which bits we use is arbitrary since jhash
produces entropy evenly across the whole hash function
result.
But soon we'll be using universal hashing functions,
and in those cases more entropy exists in the higher
bits than the lower bits, because they use multiplies.
There can 3 reasons for the "command reject" reply produced
by the stack. Each such reply should be accompanied by the
relevand data ( as defined in spec. ). Currently there is one
instance of "command reject" reply with reason "invalid cid"
wich is fixed. Also, added clean-up definitions related to the
"command reject" replies.
Signed-off-by: Ilia Kolomisnky <iliak@ti.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
This will be useful when userspace wants to restrict some kinds of
operations based on the length of the key size used to encrypt the
link.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
In some cases it will be useful having the key size used for
encrypting the link. For example, some profiles may restrict
some operations depending on the key length.
The key size is stored in the key that is passed to userspace
using the pin_length field in the key structure.
For now this field is only valid for LE controllers. 3.0+HS
controllers define the Read Encryption Key Size command, this
field is intended for storing the value returned by that
command.
As the LTK (the new type of key being handled now) has more data
associated with it, we need to store this extra data and retrieve
the keys based on that data.
Methods for searching for a key and for adding a new LTK are
introduced here.
We need these changes because SMP keys may have more information
associated with them, for example, in the LTK case, it has an
encrypted diversifier (ediv) and a random number (rand).
Since ca5ecddf (rcu: define __rcu address space modifier for sparse)
rcu_dereference_check use rcu_read_lock_held as a part of condition
automatically so callers do not have to do that as well.
This adds support for generating and distributing all the keys
specified in the third phase of SMP.
This will make possible to re-establish secure connections, resolve
private addresses and sign commands.
For now, the values generated are random.
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
In order to support pre-populating the P1K cache in
iwlwifi hardware for WoWLAN, we need to calculate
the P1K for the current IV32. Allow drivers to get
the P1K for any given IV32 instead of for a given
packet, but keep the packet-based version around as
an inline.
In order to implement GTK rekeying, the device needs
to be able to encrypt frames with the right PN/IV and
check the PN/IV in RX frames. To be able to tell it
about all those counters, we need to be able to get
them from mac80211, this adds the required API.
Our current TKIP code races against itself on TX
since we can process multiple packets at the same
time on different ACs, but they all share the TX
context for TKIP. This can lead to bad IVs etc.
Also, the crypto offload helper code just obtains
the P1K/P2K from the cache, and can update it as
well, but there's no guarantee that packets are
really processed in order.
To fix these issues, first introduce a spinlock
that will protect the IV16/IV32 values in the TX
context. This first step makes sure that we don't
assign the same IV multiple times or get confused
in other ways.
Secondly, change the way the P1K cache works. I
add a field "p1k_iv32" that stores the value of
the IV32 when the P1K was last recomputed, and
if different from the last time, then a new P1K
is recomputed. This can cause the P1K computation
to flip back and forth if packets are processed
out of order. All this also happens under the new
spinlock.
Finally, because there are argument differences,
split up the ieee80211_get_tkip_key() API into
ieee80211_get_tkip_p1k() and ieee80211_get_tkip_p2k()
and give them the correct arguments.
When initiating a graceful shutdown while having data chunks
on the retransmission queue with a peer which is in zero
window mode the shutdown is never completed because the
retransmission error count is reset periodically by the
following two rules:
- Do not timeout association while doing zero window probe.
- Reset overall error count when a heartbeat request has
been acknowledged.
The graceful shutdown will wait for all outstanding TSN to
be acknowledged before sending the SHUTDOWN request. This
never happens due to the peer's zero window not acknowledging
the continuously retransmitted data chunks. Although the
error counter is incremented for each failed retransmission,
the receiving of the SACK announcing the zero window clears
the error count again immediately. Also heartbeat requests
continue to be sent periodically. The peer acknowledges these
requests causing the error counter to be reset as well.
This patch changes behaviour to only reset the overall error
counter for the above rules while not in shutdown. After
reaching the maximum number of retransmission attempts, the
T5 shutdown guard timer is scheduled to give the receiver
some additional time to recover. The timer is stopped as soon
as the receiver acknowledges any data.
The issue can be easily reproduced by establishing a sctp
association over the loopback device, constantly queueing
data at the sender while not reading any at the receiver.
Wait for the window to reach zero, then initiate a shutdown
by killing both processes simultaneously. The association
will never be freed and the chunks on the retransmission
queue will be retransmitted indefinitely.
The ERTM receive buffer is now handled in a way that does not require
the busy queue and the associated polling code.
Signed-off-by: Mat Martineau <mathewm@codeaurora.org>
This change moves most L2CAP ERTM receive buffer handling out of the
L2CAP core and in to the socket code. It's up to the higher layer
(the socket code, in this case) to tell the core when its buffer is
full or has space available. The recv op should always accept
incoming ERTM data or else the connection will go down.
Within the socket layer, an skb that does not fit in the socket
receive buffer will be temporarily stored. When the socket is read
from, that skb will be placed in the receive buffer if possible. Once
adequate buffer space becomes available, the L2CAP core is informed
and the ERTM local busy state is cleared.
Receive buffer management for non-ERTM modes is unchanged.
Signed-off-by: Shirley Ma <xma@us.ibm.com>
Since we have the extended LMP features properly implemented, we
should check the LMP_HOST_LE bit to know if the host supports LE.
Signed-off-by: Andre Guedes <andre.guedes@openbossa.org>
This patch adds a new module parameter to enable/disable host LE
support. By default host LE support is disabled.
This patch adds a handler to Write LE Host Supported command complete
events. Once this commands has completed successfully, we should
read the extended LMP features and update the extfeatures field in
hci_dev.
This new field holds the extended LMP features value. Some LE
mechanism such as discovery procedure needs to read the extended
LMP features to work properly.
This adds the necessary mac80211 APIs to support
GTK rekey offload, mirroring the functionality
from cfg80211.
In certain circumstances, like WoWLAN scenarios,
devices may implement (partial) GTK rekeying on
the device to avoid waking up the host for it.
In order to successfully go through GTK rekeying,
the KEK, KCK and the replay counter are required.
Add API to let the supplicant hand the parameters
to the driver which may store it for future GTK
rekey operations.
Note that, of course, if GTK rekeying is done by
the device, the EAP frame must not be passed up
to userspace, instead a rekey event needs to be
sent to let userspace update its replay counter.
When in suspend/wowlan, devices might implement crypto
offload differently (more features), and might require
reprogramming keys for the WoWLAN (as it is the case
for Intel devices that use another uCode image). Thus
allow the driver to iterate all keys in this context.
