[ Upstream commit 5ee4433efe99b9f39f6eff5052a177bbcfe72cea ]
By definition net_generic should never be called when it can return
NULL. Fail conspicously with a BUG_ON to make it clear when people mess
up that a NULL return should never happen.
Recently there was a bug in the CAIF subsystem where it was registered
with register_pernet_device instead of register_pernet_subsys. It was
erroneously concluded that net_generic could validly return NULL and
that net_assign_generic was buggy (when it was just inefficient).
Hopefully this BUG_ON will prevent people to coming to similar erroneous
conclusions in the futrue.
Tested-by: Sasha Levin <levinsasha928@gmail.com>
Change-Id: I7936b0403664d9745e4932aad72fd09c100f526c
Reviewed-on: http://git-master/r/79690
Add a comment pointing out the use of enum station_info_flags for
all new struct station_info fields. In addition, memset the sinfo
buffer to zero before use on all paths in the current tree to avoid
leaving uninitialized pointers in the data.
(cherry picked from commit 87159de9c30dab02b84cbaffa7498140d4ebc1a1 from
android.googlesource.com/common.git)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
Change-Id: I24301d45108587e66c8421a7f2a94ea98300ebeb
Reviewed-on: http://git-master/r/78887
When user space SME/MLME (e.g., hostapd) is not used in AP mode, the
IEs from the (Re)Association Request frame that was processed in
firmware need to be made available for user space (e.g., RSN IE for
hostapd). Allow this to be done with cfg80211_new_sta().
(cherry picked from commit d692df224b8605095cb7f770c1c99d3150834daf from
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Change-Id: I211171ca4953832cc998402c149ecf3fc429f9e6
Reviewed-on: http://git-master/r/78886
[ Upstream commit e688a604807647c9450f9c12a7cb6d027150a895 ]
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Change-Id: Id23270aae3214c26691f95922a63c70549232c22
Reviewed-on: http://git-master/r/74224
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
[ Upstream commit c0ed1c14a72ca9ebacd51fb94a8aca488b0d361e ]
flow_cach_flush() might sleep but can be called from
atomic context via the xfrm garbage collector. So add
a flow_cache_flush_deferred() function and use this if
the xfrm garbage colector is invoked from within the
packet path.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Timo Teräs <timo.teras@iki.fi>
Change-Id: I6561c4fa576a9e83f4e2faf7b62dbd1d9b598c39
Reviewed-on: http://git-master/r/74221
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ]
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Change-Id: I74631fca684d7a475f1eed5f6823c11b62bbd2bc
Reviewed-on: http://git-master/r/74219
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
[ Upstream commit ea6a5d3b97b768561db6358f15e4c84ced0f4f7e ]
Since commit a4a710c4a7490587 (pkt_sched: Change PSCHED_SHIFT from 10 to
6) it seems RED/GRED are broken.
red_calc_qavg_from_idle_time() computes a delay in us units, but this
delay is now 16 times bigger than real delay, so the final qavg result
smaller than expected.
Use standard kernel time services since there is no need to obfuscate
them.
[ Upstream commit de68dca1816660b0d3ac89fa59ffb410007a143f ]
Now inetpeer is the place where we cache redirect information for ipv4
destinations, we must be able to invalidate informations when a route is
added/removed on host.
As inetpeer is not yet namespace aware, this patch adds a shared
redirect_genid, and a per inetpeer redirect_genid. This might be changed
later if inetpeer becomes ns aware.
Cache information for one inerpeer is valid as long as its
redirect_genid has the same value than global redirect_genid.
Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
A new driver is implemented to actively manage the bluetooth module
power. bluesleep also tries to manage the power of the transport used.
Two signals (GPIOs) are used to manage the power events.
BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep.
HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/
activate the transport modules required for BT communication.
Bug 791669, 773186
(cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8)
Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15
Reviewed-on: http://git-master/r/19858
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
Update the code to handle some of the differences between
RFC 3041 and RFC 4941, which obsoletes it. Also a couple
of janitorial fixes.
- Allow router advertisements to increase the lifetime of
temporary addresses. This was not allowed by RFC 3041,
but is specified by RFC 4941. It is useful when RA
lifetimes are lower than TEMP_{VALID,PREFERRED}_LIFETIME:
in this case, the previous code would delete or deprecate
addresses prematurely.
- Change the default of MAX_RETRY to 3 per RFC 4941.
- Add a comment to clarify that the preferred and valid
lifetimes in inet6_ifaddr are relative to the timestamp.
- Shorten lines to 80 characters in a couple of places.
Change-Id: I4da097664d4b1de7c1cebf410895319601c7f1cc
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: JP Abgrall <jpa@google.com>
This patch adds support for disconnecting the link when SMP procedure
takes more than 30 seconds.
SMP begins when either the Pairing Request command is sent or the
Pairing Response is received, and it ends when the link is encrypted
(or terminated). Vol 3, Part H Section 3.4.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Fix lines longer than 80 chars in length.
Change-Id: I448077965c5f7723a4a9537977bfa664cfe104fd
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise
selection of SCO/eSCO packet types. Currently those bits are:
0x0001 HV1 may be used.
0x0002 HV2 may be used.
0x0004 HV3 may be used.
0x0008 EV3 may be used.
0x0010 EV4 may be used.
0x0020 EV5 may be used.
0x0040 2-EV3 may be used.
0x0080 3-EV3 may be used.
0x0100 2-EV5 may be used.
0x0200 3-EV5 may be used.
This is similar to the Packet Type parameter in the HCI Setup Synchronous
Connection Command, except that we are not reversing the logic on the EDR bits.
This makes the use of sco_pkt_tpye forward portable for the use case of
white-listing packet types, which we expect will be the primary use case.
If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco,
then the default behavior is to allow all packet types.
Packet type selection is just a request made to the Bluetooth chipset, and
it is up to the link manager on the chipset to negiotiate and decide on the
actual packet types used. Furthermore, when a SCO/eSCO connection is eventually
made there is no way for the host stack to determine which packet type was used
(however it is possible to get the link type of SCO or eSCO).
sco_pkt_type is ignored for incoming SCO connections. It is possible
to add this in the future as a parameter to the Accept Synchronous Connection
Command, however its a little trickier because the kernel does not
currently preserve sockaddr_sco data between userspace calls to accept().
The most common use for sco_pkt_type will be to white-list only SCO packets,
which can be done with the hci.h constant SCO_ESCO_MASK.
This patch is motivated by broken Bluetooth carkits such as the Motorolo
HF850 (it claims to support eSCO, but will actually reject eSCO connections
after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio
if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain
a list of compatible packet types to workaround remote devices such as these.
Based on a patch by Marcel Holtmann.
Rebased to 2.6.39.
Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315
Signed-off-by: Nick Pelly <npelly@google.com>
On Linux, when an interface goes down all its IPv6
addresses are deleted, so relying on knowing the previous
IPv6 addresses on the interface is brittle. Instead,
support nuking all sockets that are bound to IP addresses
that are not configured and up on the system. This
behaviour is triggered by specifying the unspecified
address (:: or 0.0.0.0). If an IP address is specified, the
behaviour is unchanged, except the ioctl now supports IPv6
as well as IPv4.
When enabled, tracks the frequency of network transmissions
(inbound and outbound) and buckets them accordingly.
Buckets are determined by time between network activity.
Each bucket represents the number of network transmisions that were
N sec or longer apart. Where N is defined as 1 << bucket index.
This network pattern tracking is particularly useful for wireless
networks (ie: 3G) where batching network activity closely together
is more power efficient than far apart.
New file: /proc/net/stat/activity
output:
Min Bucket(sec) Count
1 7
2 0
4 1
8 0
16 0
32 2
64 1
128 0
Change-Id: I4c4cd8627b872a55f326b1715c51bc3bdd6e8d92
Signed-off-by: Mike Chan <mike@android.com>
This provides userspace debugging tools access to ACL flow control state.
Legacy pairing is a bit of a problem because on the incoming end it is
impossible to know pairing has begun:
2009-09-18 18:29:24.115692 > HCI Event: Connect Request (0x04) plen 10
bdaddr 00:23:D4:04:51:7A class 0x58020c type ACL
2009-09-18 18:29:24.115966 < HCI Command: Accept Connection Request (0x01|0x0009) plen 7
bdaddr 00:23:D4:04:51:7A role 0x00
Role: Master
2009-09-18 18:29:24.117065 > HCI Event: Command Status (0x0f) plen 4
Accept Connection Request (0x01|0x0009) status 0x00 ncmd 1
2009-09-18 18:29:24.282928 > HCI Event: Role Change (0x12) plen 8
status 0x00 bdaddr 00:23:D4:04:51:7A role 0x00
Role: Master
2009-09-18 18:29:24.291534 > HCI Event: Connect Complete (0x03) plen 11
status 0x00 handle 1 bdaddr 00:23:D4:04:51:7A type ACL encrypt 0x00
2009-09-18 18:29:24.291839 < HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2
handle 1
2009-09-18 18:29:24.292144 > HCI Event: Page Scan Repetition Mode Change (0x20) plen 7
bdaddr 00:23:D4:04:51:7A mode 1
2009-09-18 18:29:24.293823 > HCI Event: Command Status (0x0f) plen 4
Read Remote Supported Features (0x01|0x001b) status 0x00 ncmd 1
2009-09-18 18:29:24.303588 > HCI Event: Max Slots Change (0x1b) plen 3
handle 1 slots 5
2009-09-18 18:29:24.309448 > HCI Event: Read Remote Supported Features (0x0b) plen 11
Features: 0xff 0xff 0x2d 0xfe 0x9b 0xff 0x79 0x83
2009-09-18 18:29:24.345916 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:23:D4:04:51:7A mode 2 clkoffset 0x0000
2009-09-18 18:29:24.346923 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 1
2009-09-18 18:29:24.375793 > HCI Event: Remote Name Req Complete (0x07) plen 255
status 0x00 bdaddr 00:23:D4:04:51:7A name 'test'
2009-09-18 18:29:34.332190 < HCI Command: Disconnect (0x01|0x0006) plen 3
handle 1 reason 0x13
There are some mainline patches such as "Add different pairing timeout for
Legacy Pairing" but they do not address the HCI sequence above.
I think the real solution is to avoid using CreateBond(), and instead make
the profile connection immediately. This way both sides will use a longer
timeout because there is a higher level connection in progress, and we will
not end up with the useless HCI sequence above.
Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets
bound to the same local address. This is useful in situations with
dynamic IPs, to kill stuck connections.
Signed-off-by: Brian Swetland <swetland@google.com>
net: fix tcp_v4_nuke_addr
Signed-off-by: Dima Zavin <dima@android.com>
net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke.
We can't hold the lock while calling to tcp_done(), so we drop
it before calling. We then have to start at the top of the chain again.
net: ipv4: Fix race in tcp_v4_nuke_addr().
To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock
across tcp_done() calls. This fixed the deadlock, but introduced a race where
the socket could die or change state.
Fix: Before unlocking the hash table, we grab a reference to the socket. We
can then unlock the hash table without risk of the socket going away. We then
lock the socket, which is safe because it is pinned. We can then call
tcp_done() without recursive deadlock and without race. Upon return, we unlock
the socket and then unpin it, killing it.
Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045
Signed-off-by: Robert Love <rlove@google.com>
Acked-by: Dima Zavin <dima@android.com>
ipv4: disable bottom halves around call to tcp_done().
Signed-off-by: Colin Cross <ccross@android.com>
ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr
When sk_error_report is called, it wakes up the user-space thread, which then
calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr
ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON.
This patch moves the call to sk_error_report inside the bh_lock_sock, which
matches the locking used in tcp_v4_err.
Commit 903ab86d195cca295379699299c5fc10beba31c7 of 1 March this year ("udp: Add
lockless transmit path") introduced a new fast TX path that broke the checksum
coverage computation of UDP-lite, which so far depended on up->len (only set
if the socket is locked and 0 in the fast path).
Fixed by providing both fast- and slow-path computation of checksum coverage.
The latter can be removed when UDP(-lite)v6 also uses a lockless transmit path.
Reported-by: Thomas Volkert <thomas@homer-conferencing.com>
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
ip_vs_mutext is used by both netns shutdown code and startup
and both implicit uses sk_lock-AF_INET mutex.
cleanup CPU-1 startup CPU-2
ip_vs_dst_event() ip_vs_genl_set_cmd()
sk_lock-AF_INET __ip_vs_mutex
sk_lock-AF_INET
__ip_vs_mutex
* DEAD LOCK *
A new mutex placed in ip_vs netns struct called sync_mutex is added.
Comments from Julian and Simon added.
This patch has been running for more than 3 month now and it seems to work.
Ver. 3
IP_VS_SO_GET_DAEMON in do_ip_vs_get_ctl protected by sync_mutex
instead of __ip_vs_mutex as sugested by Julian.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit 946cedccbd7387 (tcp: Change possible SYN flooding messages)
added a build error if CONFIG_SYN_COOKIES=n
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
* git://github.com/davem330/net: (62 commits)
ipv6: don't use inetpeer to store metrics for routes.
can: ti_hecc: include linux/io.h
IRDA: Fix global type conflicts in net/irda/irsysctl.c v2
net: Handle different key sizes between address families in flow cache
net: Align AF-specific flowi structs to long
ipv4: Fix fib_info->fib_metrics leak
caif: fix a potential NULL dereference
sctp: deal with multiple COOKIE_ECHO chunks
ibmveth: Fix checksum offload failure handling
ibmveth: Checksum offload is always disabled
ibmveth: Fix issue with DMA mapping failure
ibmveth: Fix DMA unmap error
pch_gbe: support ML7831 IOH
pch_gbe: added the process of FIFO over run error
pch_gbe: fixed the issue which receives an unnecessary packet.
sfc: Use 64-bit writes for TX push where possible
Revert "sfc: Use write-combining to reduce TX latency" and follow-ups
bnx2x: Fix ethtool advertisement
bnx2x: Fix 578xx link LED
bnx2x: Fix XMAC loopback test
With the conversion of struct flowi to a union of AF-specific structs, some
operations on the flow cache need to account for the exact size of the key.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
AF-specific flowi structs are now passed to flow_key_compare, which must
also be aligned to a long.
Attempt to reduce the number of IP packets emitted in response to single
SCTP packet (2e3216cd) introduced a complication - if a packet contains
two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the
socket while processing first COOKIE_ECHO and then loses the association
and forgets to uncork the socket. To deal with the issue add new SCTP
command which can be used to set association explictly. Use this new
command when processing second COOKIE_ECHO chunk to restore the context
for SCTP state machine.
Signed-off-by: Max Matveev <makc@redhat.com>
"Possible SYN flooding on port xxxx " messages can fill logs on servers.
Change logic to log the message only once per listener, and add two new
SNMP counters to track :
TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client
TCPReqQFullDrop : number of times a SYN request was dropped because
syncookies were not enabled.
Based on a prior patch from Tom Herbert, and suggestions from David.
CC: Tom Herbert <therbert@google.com>
Fix kernel-doc warning in net/cfg80211.h:
Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Some of the flags are OS/arch dependent we add a 9p
protocol value which maps to asm-generic/fcntl.h values in Linux
Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
Do not call ->suspend, ->resume methods after we unregister wiphy. Also
delete sta_clanup timer after we finish wiphy unregister to avoid this:
WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0()
Hardware name: 6369CTO
ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211]
Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode]
Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19
Call Trace:
[<c0454cfd>] warn_slowpath_common+0x6d/0xa0
[<c05e05e5>] ? debug_print_object+0x85/0xa0
[<c0454dae>] warn_slowpath_fmt+0x2e/0x30
[<c05e05e5>] debug_print_object+0x85/0xa0
[<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211]
[<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180
[<c051175b>] kfree+0x8b/0x150
[<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211]
[<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211]
[<c068d959>] device_release+0x19/0x80
[<c05d06ba>] kobject_release+0x7a/0x1c0
[<c07646a8>] ? rtnl_unlock+0x8/0x10
[<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211]
[<c05d0640>] ? kobject_del+0x30/0x30
[<c05d1a6d>] kref_put+0x2d/0x60
[<c05d056d>] kobject_put+0x1d/0x50
[<c08015f4>] ? mutex_lock+0x14/0x40
[<c068d60f>] put_device+0xf/0x20
[<c069716a>] dpm_resume+0xca/0x160
[<c04912bd>] hibernation_snapshot+0xcd/0x260
[<c04903df>] ? freeze_processes+0x3f/0x90
[<c049151b>] hibernate+0xcb/0x1e0
[<c048fdc0>] ? pm_async_store+0x40/0x40
[<c048fe60>] state_store+0xa0/0xb0
[<c05d0200>] kobj_attr_store+0x20/0x30
[<c0575ea4>] sysfs_write_file+0x94/0xf0
[<c051e26a>] vfs_write+0x9a/0x160
[<c0575e10>] ? sysfs_open_file+0x200/0x200
[<c051e3fd>] sys_write+0x3d/0x70
[<c080959f>] sysenter_do_call+0x12/0x28
Cc: stable@kernel.org
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
The raw sockets can provide source address for
routing but their privileges are not considered. We
can provide non-local source address, make sure the
FLOWI_FLAG_ANYSRC flag is set if socket has privileges
for this, i.e. based on hdrincl (IP_HDRINCL) and
transparent flags.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
Gergely Kalman reported crashes in check_peer_redir().
It appears commit f39925dbde778 (ipv4: Cache learned redirect
information in inetpeer.) added a race, leading to possible NULL ptr
dereference.
Since we can now change dst neighbour, we should make sure a reader can
safely use a neighbour.
Add RCU protection to dst neighbour, and make sure check_peer_redir()
can be called safely by different cpus in parallel.
As neighbours are already freed after one RCU grace period, this patch
should not add typical RCU penalty (cache cold effects)
Many thanks to Gergely for providing a pretty report pointing to the
bug.
Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu>
My @hp.com will no longer be valid starting August 5, 2011 so an update is
necessary. My new email address is employer independent so we don't have
to worry about doing this again any time soon.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits)
bnx2x: use pci_pcie_cap()
bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task
bnx2x: enable internal target-read for 57712 and up only
bnx2x: count statistic ramrods on EQ to prevent MC assert
bnx2x: fix loopback for non 10G link
bnx2x: dcb - send all unmapped priorities to same COS as L2
iwlwifi: Fix build with CONFIG_PM disabled.
gre: fix improper error handling
ipv4: use RT_TOS after some rt_tos conversions
via-velocity: remove duplicated #include
qlge: remove duplicated #include
igb: remove duplicated #include
can: c_can: remove duplicated #include
bnad: remove duplicated #include
net: allow netif_carrier to be called safely from IRQ
bna: Header File Consolidation
bna: HW Error Counter Fix
bna: Add HW Semaphore Unlock Logic
bna: IOC Event Name Change
bna: Mboxq Flush When IOC Disabled
unlinkat - Remove a directory entry
size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4]
size[4] Runlinkat tag[2]
older Tremove have the below request format
size[4] Tremove tag[2] fid[4]
The remove message is used to remove a directory entry either file or directory
The remove opreation is actually a directory opertation and should ideally have
dirfid, if not we cannot represent the fid on server with anything other than
name. We will have to derive the directory name from fid in the Tremove request.
NOTE: The operation doesn't clunk the unlink fid.
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
renameat - change name of file or directory
size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s]
size[4] Rrenameat tag[2]
older Trename have the below request format
size[4] Trename tag[2] fid[4] newdirfid[4] name[s]
The rename message is used to change the name of a file, possibly moving it
to a new directory. The rename opreation is actually a directory opertation
and should ideally have olddirfid, if not we cannot represent the fid on server
with anything other than name. We will have to derive the old directory name
from fid in the Trename request.
Signed-off-by: Prem Karat <prem.karat@linux.vnet.ibm.com>
Switch to generic kernel hexdump library and cleanup macros to
be more consistent with the way we do normal debug prints.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
IPv6 fragment identification generation is way beyond what we use for
IPv4 : It uses a single generator. Its not scalable and allows DOS
attacks.
Now inetpeer is IPv6 aware, we can use it to provide a more secure and
scalable frag ident generator (per destination, instead of system wide)
This patch :
1) defines a new secure_ipv6_id() helper
2) extends inet_getid() to provide 32bit results
3) extends ipv6_select_ident() with a new dest parameter
Reported-by: Fernando Gont <fernando@gont.com.ar>
