path: root/include/net
2015-02-05ipv6: fix sparse errors in ip6_make_flowlabel()Eric Dumazet
include/net/ipv6.h:713:22: warning: incorrect type in assignment (different base types) include/net/ipv6.h:713:22: expected restricted __be32 [usertype] hash include/net/ipv6.h:713:22: got unsigned int include/net/ipv6.h:719:25: warning: restricted __be32 degrades to integer include/net/ipv6.h:719:22: warning: invalid assignment: ^= include/net/ipv6.h:719:22: left side has type restricted __be32 include/net/ipv6.h:719:22: right side has type unsigned int Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05flow_keys: n_proto type should be __be16Eric Dumazet
(struct flow_keys)->n_proto is in network order, use proper type for this. Fixes following sparse errors : net/core/flow_dissector.c:139:39: warning: incorrect type in assignment (different base types) net/core/flow_dissector.c:139:39: expected unsigned short [unsigned] [usertype] n_proto net/core/flow_dissector.c:139:39: got restricted __be16 [assigned] [usertype] proto net/core/flow_dissector.c:237:23: warning: incorrect type in assignment (different base types) net/core/flow_dissector.c:237:23: expected unsigned short [unsigned] [usertype] n_proto net/core/flow_dissector.c:237:23: got restricted __be16 [assigned] [usertype] proto Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-03ipv6: Select fragment id during UFO segmentation if not set.Vlad Yasevich
If the IPv6 fragment id has not been set and we perform fragmentation due to UFO, select a new fragment id. We now consider a fragment id of 0 as unset and if id selection process returns 0 (after all the pertrubations), we set it to 0x80000000, thus giving us ample space not to create collisions with the next packet we may have to fragment. When doing UFO integrity checking, we also select the fragment id if it has not be set yet. This is stored into the skb_shinfo() thus allowing UFO to function correclty. This patch also removes duplicate fragment id generation code and moves ipv6_select_ident() into the header as it may be used during GSO. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/IPVS fixes for net The following patchset contains Netfilter/IPVS fixes for your net tree, they are: 1) Validate hooks for nf_tables NAT expressions, otherwise users can crash the kernel when using them from the wrong hook. We already got one user trapped on this when configuring masquerading. 2) Fix a BUG splat in nf_tables with CONFIG_DEBUG_PREEMPT=y. Reported by Andreas Schultz. 3) Avoid unnecessary reroute of traffic in the local input path in IPVS that triggers a crash in in xfrm. Reported by Florian Wiessner and fixes by Julian Anastasov. 4) Fix memory and module refcount leak from the error path of nf_tables_newchain(). ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-01ipv4: tcp: get rid of ugly unicast_sockEric Dumazet
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock") I tried to address contention on a socket lock, but the solution I chose was horrible : commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside of TCP stack") addressed a selinux regression. commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1") took care of another regression. commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression. commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate") was another shot in the dark. Really, just use a proper socket per cpu, and remove the skb_orphan() call, to re-enable flow control. This solves a serious problem with FQ packet scheduler when used in hostile environments, as we do not want to allocate a flow structure for every RST packet sent in response to a spoofed packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-31net: sched: fix panic in rate estimatorsEric Dumazet
Doing the following commands on a non idle network device panics the box instantly, because cpu_bstats gets overwritten by stats. tc qdisc add dev eth0 root <your_favorite_qdisc> ... some traffic (one packet is enough) ... tc qdisc replace dev eth0 root est 1sec 4sec <your_favorite_qdisc> [ 325.355596] BUG: unable to handle kernel paging request at ffff8841dc5a074c [ 325.362609] IP: [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90 [ 325.369158] PGD 1fa7067 PUD 0 [ 325.372254] Oops: 0000 [#1] SMP [ 325.375514] Modules linked in: ... [ 325.398346] CPU: 13 PID: 14313 Comm: tc Not tainted 3.19.0-smp-DEV #1163 [ 325.412042] task: ffff8800793ab5d0 ti: ffff881ff2fa4000 task.ti: ffff881ff2fa4000 [ 325.419518] RIP: 0010:[<ffffffff81541c9e>] [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90 [ 325.428506] RSP: 0018:ffff881ff2fa7928 EFLAGS: 00010286 [ 325.433824] RAX: 000000000000000c RBX: ffff881ff2fa796c RCX: 000000000000000c [ 325.440988] RDX: ffff8841dc5a0744 RSI: 0000000000000060 RDI: 0000000000000060 [ 325.448120] RBP: ffff881ff2fa7948 R08: ffffffff81cd4f80 R09: 0000000000000000 [ 325.455268] R10: ffff883ff223e400 R11: 0000000000000000 R12: 000000015cba0744 [ 325.462405] R13: ffffffff81cd4f80 R14: ffff883ff223e460 R15: ffff883feea0722c [ 325.469536] FS: 00007f2ee30fa700(0000) GS:ffff88407fa20000(0000) knlGS:0000000000000000 [ 325.477630] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 325.483380] CR2: ffff8841dc5a074c CR3: 0000003feeae9000 CR4: 00000000001407e0 [ 325.490510] Stack: [ 325.492524] ffff883feea0722c ffff883fef719dc0 ffff883feea0722c ffff883ff223e4a0 [ 325.499990] ffff881ff2fa79a8 ffffffff815424ee ffff883ff223e49c 000000015cba0744 [ 325.507460] 00000000f2fa7978 0000000000000000 ffff881ff2fa79a8 ffff883ff223e4a0 [ 325.514956] Call Trace: [ 325.517412] [<ffffffff815424ee>] gen_new_estimator+0x8e/0x230 [ 325.523250] [<ffffffff815427aa>] gen_replace_estimator+0x4a/0x60 [ 325.529349] [<ffffffff815718ab>] tc_modify_qdisc+0x52b/0x590 [ 325.535117] [<ffffffff8155edd0>] rtnetlink_rcv_msg+0xa0/0x240 [ 325.540963] [<ffffffff8155ed30>] ? __rtnl_unlock+0x20/0x20 [ 325.546532] [<ffffffff8157f811>] netlink_rcv_skb+0xb1/0xc0 [ 325.552145] [<ffffffff8155b355>] rtnetlink_rcv+0x25/0x40 [ 325.557558] [<ffffffff8157f0d8>] netlink_unicast+0x168/0x220 [ 325.563317] [<ffffffff8157f47c>] netlink_sendmsg+0x2ec/0x3e0 Lets play safe and not use an union : percpu 'pointers' are mostly read anyway, and we have typically few qdiscs per host. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: John Fastabend <john.fastabend@gmail.com> Fixes: 22e0f8b9322c ("net: sched: make bstats per cpu and estimator RCU safe") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: stretch ACK fixes prepNeal Cardwell
LRO, GRO, delayed ACKs, and middleboxes can cause "stretch ACKs" that cover more than the RFC-specified maximum of 2 packets. These stretch ACKs can cause serious performance shortfalls in common congestion control algorithms that were designed and tuned years ago with receiver hosts that were not using LRO or GRO, and were instead politely ACKing every other packet. This patch series fixes Reno and CUBIC to handle stretch ACKs. This patch prepares for the upcoming stretch ACK bug fix patches. It adds an "acked" parameter to tcp_cong_avoid_ai() to allow for future fixes to tcp_cong_avoid_ai() to correctly handle stretch ACKs, and changes all congestion control algorithms to pass in 1 for the ACKed count. It also changes tcp_slow_start() to return the number of packet ACK "credits" that were not processed in slow start mode, and can be processed by the congestion control module in additive increase mode. In future patches we will fix tcp_cong_avoid_ai() to handle stretch ACKs, and fix Reno and CUBIC handling of stretch ACKs in slow start and additive increase mode. Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26ipv4: try to cache dst_entries which would cause a redirectHannes Frederic Sowa
Not caching dst_entries which cause redirects could be exploited by hosts on the same subnet, causing a severe DoS attack. This effect aggravated since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()"). Lookups causing redirects will be allocated with DST_NOCACHE set which will force dst_release to free them via RCU. Unfortunately waiting for RCU grace period just takes too long, we can end up with >1M dst_entries waiting to be released and the system will run OOM. rcuos threads cannot catch up under high softirq load. Attaching the flag to emit a redirect later on to the specific skb allows us to cache those dst_entries thus reducing the pressure on allocation and deallocation. This issue was discovered by Marcelo Leitner. Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-19netfilter: nf_tables: validate hooks in NAT expressionsPablo Neira Ayuso
The user can crash the kernel if it uses any of the existing NAT expressions from the wrong hook, so add some code to validate this when loading the rule. This patch introduces nft_chain_validate_hooks() which is based on an existing function in the bridge version of the reject expression. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-01-16genetlink: synchronize socket closing and family removalJohannes Berg
In addition to the problem Jeff Layton reported, I looked at the code and reproduced the same warning by subscribing and removing the genl family with a socket still open. This is a fairly tricky race which originates in the fact that generic netlink allows the family to go away while sockets are still open - unlike regular netlink which has a module refcount for every open socket so in general this cannot be triggered. Trying to resolve this issue by the obvious locking isn't possible as it will result in deadlocks between unregistration and group unbind notification (which incidentally lockdep doesn't find due to the home grown locking in the netlink table.) To really resolve this, introduce a "closing socket" reference counter (for generic netlink only, as it's the only affected family) in the core netlink code and use that in generic netlink to wait for all the sockets that are being closed at the same time as a generic netlink family is removed. This fixes the race that when a socket is closed, it will should call the unbind, but if the family is removed at the same time the unbind will not find it, leading to the warning. The real problem though is that in this case the unbind could actually find a new family that is registered to have a multicast group with the same ID, and call its mcast_unbind() leading to confusing. Also remove the warning since it would still trigger, but is now no longer a problem. This also moves the code in af_netlink.c to before unreferencing the module to avoid having the same problem in the normal non-genl case. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-16genetlink: document parallel_opsJohannes Berg
The kernel-doc for the parallel_ops family struct member is missing, add it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-06Merge tag 'mac80211-for-davem-2015-01-06' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Here's just a single fix - a revert of a patch that broke the p54 and cw2100 drivers (arguably due to bad assumptions there.) Since this affects kernels since 3.17, I decided to revert for now and we'll revisit this optimisation properly for -next. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-05Revert "mac80211: Fix accounting of the tailroom-needed counter"Johannes Berg
This reverts commit ca34e3b5c808385b175650605faa29e71e91991b. It turns out that the p54 and cw2100 drivers assume that there's tailroom even when they don't say they really need it. However, there's currently no way for them to explicitly say they do need it, so for now revert this. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=90331. Cc: stable@vger.kernel.org Fixes: ca34e3b5c808 ("mac80211: Fix accounting of the tailroom-needed counter") Reported-by: Christopher Chavez <chrischavez@gmx.us> Bisected-by: Larry Finger <Larry.Finger@lwfinger.net> Debugged-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-12-27netlink/genetlink: pass network namespace to bind/unbindJohannes Berg
Netlink families can exist in multiple namespaces, and for the most part multicast subscriptions are per network namespace. Thus it only makes sense to have bind/unbind notifications per network namespace. To achieve this, pass the network namespace of a given client socket to the bind/unbind functions. Also do this in generic netlink, and there also make sure that any bind for multicast groups that only exist in init_net is rejected. This isn't really a problem if it is accepted since a client in a different namespace will never receive any notifications from such a group, but it can confuse the family if not rejected (it's also possible to silently (without telling the family) accept it, but it would also have to be ignored on unbind so families that take any kind of action on bind/unbind won't do unnecessary work for invalid clients like that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-27genetlink: pass multicast bind/unbind to familiesJohannes Berg
In order to make the newly fixed multicast bind/unbind functionality in generic netlink, pass them down to the appropriate family. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-27genetlink: pass only network namespace to genl_has_listeners()Johannes Berg
There's no point to force the caller to know about the internal genl_sock to use inside struct net, just have them pass the network namespace. This doesn't really change code generation since it's an inline, but makes the caller less magic - there's never any reason to pass another socket. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-26net: Generalize ndo_gso_check to ndo_features_checkJesse Gross
GSO isn't the only offload feature with restrictions that potentially can't be expressed with the current features mechanism. Checksum is another although it's a general issue that could in theory apply to anything. Even if it may be possible to implement these restrictions in other ways, it can result in duplicate code or inefficient per-packet behavior. This generalizes ndo_gso_check so that drivers can remove any features that don't make sense for a given packet, similar to netif_skb_features(). It also converts existing driver restrictions to the new format, completing the work that was done to support tunnel protocols since the issues apply to checksums as well. By actually removing features from the set that are used to do offloading, it solves another problem with the existing interface. In these cases, GSO would run with the original set of features and not do anything because it appears that segmentation is not required. CC: Tom Herbert <therbert@google.com> CC: Joe Stringer <joestringer@nicira.com> CC: Eric Dumazet <edumazet@google.com> CC: Hayes Wang <hayeswang@realtek.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Tom Herbert <therbert@google.com> Fixes: 04ffcb255f22 ("net: Add ndo_gso_check") Tested-by: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-26neigh: remove next ptr from struct neigh_tableNicolas Dichtel
After commit d7480fd3b173 ("neigh: remove dynamic neigh table registration support"), this field is not used anymore. CC: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - The crypto API is now documented :) - Disallow arbitrary module loading through crypto API. - Allow get request with empty driver name through crypto_user. - Allow speed testing of arbitrary hash functions. - Add caam support for ctr(aes), gcm(aes) and their derivatives. - nx now supports concurrent hashing properly. - Add sahara support for SHA1/256. - Add ARM64 version of CRC32. - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (77 commits) crypto: tcrypt - Allow speed testing of arbitrary hash functions crypto: af_alg - add user space interface for AEAD crypto: qat - fix problem with coalescing enable logic crypto: sahara - add support for SHA1/256 crypto: sahara - replace tasklets with kthread crypto: sahara - add support for i.MX53 crypto: sahara - fix spinlock initialization crypto: arm - replace memset by memzero_explicit crypto: powerpc - replace memset by memzero_explicit crypto: sha - replace memset by memzero_explicit crypto: sparc - replace memset by memzero_explicit crypto: algif_skcipher - initialize upon init request crypto: algif_skcipher - removed unneeded code crypto: algif_skcipher - Fixed blocking recvmsg crypto: drbg - use memzero_explicit() for clearing sensitive data crypto: drbg - use MODULE_ALIAS_CRYPTO crypto: include crypto- module prefix in template crypto: user - add MODULE_ALIAS crypto: sha-mb - remove a bogus NULL check crytpo: qat - Fix 64 bytes requests ...
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-10Merge branch 'akpm' (patchbomb from Andrew)Linus Torvalds
Merge first patchbomb from Andrew Morton: - a few minor cifs fixes - dma-debug upadtes - ocfs2 - slab - about half of MM - procfs - kernel/exit.c - panic.c tweaks - printk upates - lib/ updates - checkpatch updates - fs/binfmt updates - the drivers/rtc tree - nilfs - kmod fixes - more kernel/exit.c - various other misc tweaks and fixes * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (190 commits) exit: pidns: fix/update the comments in zap_pid_ns_processes() exit: pidns: alloc_pid() leaks pid_namespace if child_reaper is exiting exit: exit_notify: re-use "dead" list to autoreap current exit: reparent: call forget_original_parent() under tasklist_lock exit: reparent: avoid find_new_reaper() if no children exit: reparent: introduce find_alive_thread() exit: reparent: introduce find_child_reaper() exit: reparent: document the ->has_child_subreaper checks exit: reparent: s/while_each_thread/for_each_thread/ in find_new_reaper() exit: reparent: fix the cross-namespace PR_SET_CHILD_SUBREAPER reparenting exit: reparent: fix the dead-parent PR_SET_CHILD_SUBREAPER reparenting exit: proc: don't try to flush /proc/tgid/task/tgid exit: release_task: fix the comment about group leader accounting exit: wait: drop tasklist_lock before psig->c* accounting exit: wait: don't use zombie->real_parent exit: wait: cleanup the ptrace_reparented() checks usermodehelper: kill the kmod_thread_locker logic usermodehelper: don't use CLONE_VFORK for ____call_usermodehelper() fs/hfs/catalog.c: fix comparison bug in hfs_cat_keycmp nilfs2: fix the nilfs_iget() vs. nilfs_new_inode() races ...
2014-12-10Merge branch 'nsfs' into for-nextAl Viro
2014-12-10mm: memcontrol: lockless page countersJohannes Weiner
Memory is internally accounted in bytes, using spinlock-protected 64-bit counters, even though the smallest accounting delta is a page. The counter interface is also convoluted and does too many things. Introduce a new lockless word-sized page counter API, then change all memory accounting over to it. The translation from and to bytes then only happens when interfacing with userspace. The removed locking overhead is noticable when scaling beyond the per-cpu charge caches - on a 4-socket machine with 144-threads, the following test shows the performance differences of 288 memcgs concurrently running a page fault benchmark: vanilla: 18631648.500498 task-clock (msec) # 140.643 CPUs utilized ( +- 0.33% ) 1,380,638 context-switches # 0.074 K/sec ( +- 0.75% ) 24,390 cpu-migrations # 0.001 K/sec ( +- 8.44% ) 1,843,305,768 page-faults # 0.099 M/sec ( +- 0.00% ) 50,134,994,088,218 cycles # 2.691 GHz ( +- 0.33% ) <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 8,049,712,224,651 instructions # 0.16 insns per cycle ( +- 0.04% ) 1,586,970,584,979 branches # 85.176 M/sec ( +- 0.05% ) 1,724,989,949 branch-misses # 0.11% of all branches ( +- 0.48% ) 132.474343877 seconds time elapsed ( +- 0.21% ) lockless: 12195979.037525 task-clock (msec) # 133.480 CPUs utilized ( +- 0.18% ) 832,850 context-switches # 0.068 K/sec ( +- 0.54% ) 15,624 cpu-migrations # 0.001 K/sec ( +- 10.17% ) 1,843,304,774 page-faults # 0.151 M/sec ( +- 0.00% ) 32,811,216,801,141 cycles # 2.690 GHz ( +- 0.18% ) <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 9,999,265,091,727 instructions # 0.30 insns per cycle ( +- 0.10% ) 2,076,759,325,203 branches # 170.282 M/sec ( +- 0.12% ) 1,656,917,214 branch-misses # 0.08% of all branches ( +- 0.55% ) 91.369330729 seconds time elapsed ( +- 0.45% ) On top of improved scalability, this also gets rid of the icky long long types in the very heart of memcg, which is great for 32 bit and also makes the code a lot more readable. Notable differences between the old and new API: - res_counter_charge() and res_counter_charge_nofail() become page_counter_try_charge() and page_counter_charge() resp. to match the more common kernel naming scheme of try_do()/do() - res_counter_uncharge_until() is only ever used to cancel a local counter and never to uncharge bigger segments of a hierarchy, so it's replaced by the simpler page_counter_cancel() - res_counter_set_limit() is replaced by page_counter_limit(), which expects its callers to serialize against themselves - res_counter_memparse_write_strategy() is replaced by page_counter_limit(), which rounds down to the nearest page size - rather than up. This is more reasonable for explicitely requested hard upper limits. - to keep charging light-weight, page_counter_try_charge() charges speculatively, only to roll back if the result exceeds the limit. Because of this, a failing bigger charge can temporarily lock out smaller charges that would otherwise succeed. The error is bounded to the difference between the smallest and the biggest possible charge size, so for memcg, this means that a failing THP charge can send base page charges into reclaim upto 2MB (4MB) before the limit would have been reached. This should be acceptable. [akpm@linux-foundation.org: add includes for WARN_ON_ONCE and memparse] [akpm@linux-foundation.org: add includes for WARN_ON_ONCE, memparse, strncmp, and PAGE_SIZE] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS changes from Al Viro: "First pile out of several (there _definitely_ will be more). Stuff in this one: - unification of d_splice_alias()/d_materialize_unique() - iov_iter rewrite - killing a bunch of ->f_path.dentry users (and f_dentry macro). Getting that completed will make life much simpler for unionmount/overlayfs, since then we'll be able to limit the places sensitive to file _dentry_ to reasonably few. Which allows to have file_inode(file) pointing to inode in a covered layer, with dentry pointing to (negative) dentry in union one. Still not complete, but much closer now. - crapectomy in lustre (dead code removal, mostly) - "let's make seq_printf return nothing" preparations - assorted cleanups and fixes There _definitely_ will be more piles" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) copy_from_iter_nocache() new helper: iov_iter_kvec() csum_and_copy_..._iter() iov_iter.c: handle ITER_KVEC directly iov_iter.c: convert copy_to_iter() to iterate_and_advance iov_iter.c: convert copy_from_iter() to iterate_and_advance iov_iter.c: get rid of bvec_copy_page_{to,from}_iter() iov_iter.c: convert iov_iter_zero() to iterate_and_advance iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds iov_iter.c: convert iov_iter_npages() to iterate_all_kinds iov_iter.c: iterate_and_advance iov_iter.c: macros for iterating over iov_iter kill f_dentry macro dcache: fix kmemcheck warning in switch_names new helper: audit_file() nfsd_vfs_write(): use file_inode() ncpfs: use file_inode() kill f_dentry uses lockd: get rid of ->f_path.dentry->d_sb ...
2014-12-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/amd/xgbe/xgbe-desc.c drivers/net/ethernet/renesas/sh_eth.c Overlapping changes in both conflict cases. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10irda: Convert function pointer arrays and uses to constJoe Perches
Making things const is a good thing. (x86-64 defconfig with all irda) $ size net/irda/built-in.o* text data bss dec hex filename 109276 1868 244 111388 1b31c net/irda/built-in.o.new 108828 2316 244 111388 1b31c net/irda/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make llc_sap_action_t function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Net change: $ size net/llc/built-in.o.* text data bss dec hex filename 61193 12758 1344 75295 1261f net/llc/built-in.o.new 47113 27030 1344 75487 126df net/llc/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make llc_conn_ev_qfyr_t function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Net change from original: $ size net/llc/built-in.o.* text data bss dec hex filename 61065 12886 1344 75295 1261f net/llc/built-in.o.new 47113 27030 1344 75487 126df net/llc/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10llc: Make function pointer arrays constJoe Perches
It's better when function pointer arrays aren't modifiable. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10Merge branch 'for-davem-2' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs More iov_iter work for the networking from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle are: - 'Nested Sleep Debugging', activated when CONFIG_DEBUG_ATOMIC_SLEEP=y. This instruments might_sleep() checks to catch places that nest blocking primitives - such as mutex usage in a wait loop. Such bugs can result in hard to debug races/hangs. Another category of invalid nesting that this facility will detect is the calling of blocking functions from within schedule() -> sched_submit_work() -> blk_schedule_flush_plug(). There's some potential for false positives (if secondary blocking primitives themselves are not ready yet for this facility), but the kernel will warn once about such bugs per bootup, so the warning isn't much of a nuisance. This feature comes with a number of fixes, for problems uncovered with it, so no messages are expected normally. - Another round of sched/numa optimizations and refinements, for CONFIG_NUMA_BALANCING=y. - Another round of sched/dl fixes and refinements. Plus various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits) sched: Add missing rcu protection to wake_up_all_idle_cpus sched/deadline: Introduce start_hrtick_dl() for !CONFIG_SCHED_HRTICK sched/numa: Init numa balancing fields of init_task sched/deadline: Remove unnecessary definitions in cpudeadline.h sched/cpupri: Remove unnecessary definitions in cpupri.h sched/deadline: Fix rq->dl.pushable_tasks bug in push_dl_task() sched/fair: Fix stale overloaded status in the busiest group finding logic sched: Move p->nr_cpus_allowed check to select_task_rq() sched/completion: Document when to use wait_for_completion_io_*() sched: Update comments about CLONE_NEWUTS and CLONE_NEWIPC sched/fair: Kill task_struct::numa_entry and numa_group::task_list sched: Refactor task_struct to use numa_faults instead of numa_* pointers sched/deadline: Don't check CONFIG_SMP in switched_from_dl() sched/deadline: Reschedule from switched_from_dl() after a successful pull sched/deadline: Push task away if the deadline is equal to curr during wakeup sched/deadline: Add deadline rq status print sched/deadline: Fix artificial overrun introduced by yield_task_dl() sched/rt: Clean up check_preempt_equal_prio() sched/core: Use dl_bw_of() under rcu_read_lock_sched() sched: Check if we got a shallowest_idle_cpu before searching for least_loaded_cpu ...
2014-12-09Merge tag 'master-2014-12-08' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next John W. Linville says: ==================== pull request: wireless-next 2014-12-08 Please pull this last batch of pending wireless updates for the 3.19 tree... For the wireless bits, Johannes says: "This time I have Felix's no-status rate control work, which will allow drivers to work better with rate control even if they don't have perfect status reporting. In addition to this, a small hwsim fix from Patrik, one of the regulatory patches from Arik, and a number of cleanups and fixes I did myself. Of note is a patch where I disable CFG80211_WEXT so that compatibility is no longer selectable - this is intended as a wake-up call for anyone who's still using it, and is still easily worked around (it's a one-line patch) before we fully remove the code as well in the future." For the Bluetooth bits, Johan says: "Here's one more bluetooth-next pull request for 3.19: - Minor cleanups for ieee802154 & mac802154 - Fix for the kernel warning with !TASK_RUNNING reported by Kirill A. Shutemov - Support for another ath3k device - Fix for tracking link key based security level - Device tree bindings for btmrvl + a state update fix - Fix for wrong ACL flags on LE links" And... "In addition to the previous one this contains two more cleanups to mac802154 as well as support for some new HCI features from the Bluetooth 4.2 specification. From the original request: 'Here's what should be the last bluetooth-next pull request for 3.19. It's rather large but the majority of it is the Low Energy Secure Connections feature that's part of the Bluetooth 4.2 specification. The specification went public only this week so we couldn't publish the corresponding code before that. The code itself can nevertheless be considered fairly mature as it's been in development for over 6 months and gone through several interoperability test events. Besides LE SC the pull request contains an important fix for command complete events for mgmt sockets which also fixes some leaks of hci_conn objects when powering off or unplugging Bluetooth adapters. A smaller feature that's part of the pull request is service discovery support. This is like normal device discovery except that devices not matching specific UUIDs or strong enough RSSI are filtered out. Other changes that the pull request contains are firmware dump support to the btmrvl driver, firmware download support for Broadcom BCM20702A0 variants, as well as some coding style cleanups in 6lowpan & ieee802154/mac802154 code.'" For the NFC bits, Samuel says: "With this one we get: - NFC digital improvements for DEP support: Chaining, NACK and ATN support added. - NCI improvements: Support for p2p target, SE IO operand addition, SE operands extensions to support proprietary implementations, and a few fixes. - NFC HCI improvements: OPEN_PIPE and NOTIFY_ALL_CLEARED support, and SE IO operand addition. - A bunch of minor improvements and fixes for STMicro st21nfcb and st21nfca" For the iwlwifi bits, Emmanuel says: "Major works are CSA and TDLS. On top of that I have a new firmware API for scan and a few rate control improvements. Johannes find a few tricks to improve our CPU utilization and adds support for a new spin of 7265 called 7265D. Along with this a few random things that don't stand out." And... "I deprecate here -8.ucode since -9 has been published long ago. Along with that I have a new activity, we have now better a infrastructure for firmware debugging. This will allow to have configurable probes insides the firmware. Luca continues his work on NetDetect, this feature is now complete. All the rest is minor fixes here and there." For the Atheros bits, Kalle says: "Only ath10k changes this time and no major changes. Most visible are: o new debugfs interface for runtime firmware debugging (Yanbo) o fix shared WEP (Sujith) o don't rebuild whenever kernel version changes (Johannes) o lots of refactoring to make it easier to add new hw support (Michal) There's also smaller fixes and improvements with no point of listing here." In addition, there are a few last minute updates to ath5k, ath9k, brcmfmac, brcmsmac, mwifiex, rt2x00, rtlwifi, and wil6210. Also included is a pull of the wireless tree to pick-up the fixes originally included in "pull request: wireless 2014-12-03"... Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09first fruits - kill l2cap ->memcpy_fromiovec()Al Viro
Just use copy_from_iter(). That's what this method is trying to do in all cases, in a very convoluted fashion. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-09put iov_iter into msghdrAl Viro
Note that the code _using_ ->msg_iter at that point will be very unhappy with anything other than unshifted iovec-backed iov_iter. We still need to convert users to proper primitives. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-09switch l2cap ->memcpy_fromiovec() to msghdrAl Viro
it'll die soon enough - now that kvec-backed iov_iter works regardless of set_fs(), both instances will become copy_from_iter() as soon as we introduce ->msg_iter... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-09ip_generic_getfrag, udplite_getfrag: switch to passing msghdrAl Viro
2014-12-09net: sched: cls: remove unused op put from tcf_proto_opsJiri Pirko
It is never called and implementations are void. So just remove it. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-08Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2014-12-03 1) Fix a set but not used warning. From Fabian Frederick. 2) Currently we make sequence number values available to userspace only if we use ESN. Make the sequence number values also available for non ESN states. From Zhi Ding. 3) Remove socket policy hashing. We don't need it because socket policies are always looked up via a linked list. From Herbert Xu. 4) After removing socket policy hashing, we can use __xfrm_policy_link in xfrm_policy_insert. From Herbert Xu. 5) Add a lookup method for vti6 tunnels with wildcard endpoints. I forgot this when I initially implemented vti6. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-08fib_trie: Fix /proc/net/fib_trie when CONFIG_IP_MULTIPLE_TABLES is not definedAlexander Duyck
In recent testing I had disabled CONFIG_IP_MULTIPLE_TABLES and as a result when I ran "cat /proc/net/fib_trie" the main trie was displayed multiple times. I found that the problem line of code was in the function fib_trie_seq_next. Specifically the line below caused the indexes to go in the opposite direction of our traversal: h = tb->tb_id & (FIB_TABLE_HASHSZ - 1); This issue was that the RT tables are defined such that RT_TABLE_LOCAL is ID 255, while it is located at TABLE_LOCAL_INDEX of 0, and RT_TABLE_MAIN is 254 with a TABLE_MAIN_INDEX of 1. This means that the above line will return 1 for the local table and 0 for main. The result is that fib_trie_seq_next will return NULL at the end of the local table, fib_trie_seq_start will return the start of the main table, and then fib_trie_seq_next will loop on main forever as h will always return 0. The fix for this is to reverse the ordering of the two tables. It has the advantage of making it so that the tables now print in the same order regardless of if multiple tables are enabled or not. In order to make the definition consistent with the multiple tables case I simply masked the to RT_TABLE_XXX values by (FIB_TABLE_HASHSZ - 1). This way the two table layouts should always stay consistent. Fixes: 93456b6 ("[IPV4]: Unify access to the routing tables") Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-08Merge branch 'iov_iter' into for-nextAl Viro
2014-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-nextDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter updates for net-next The following batch contains netfilter updates for net-next. Basically, enhancements for xt_recent, skip zeroing of timer in conntrack, fix linking problem with recent redirect support for nf_tables, ipset updates and a couple of cleanups. More specifically, they are: 1) Rise maximum number per IP address to be remembered in xt_recent while retaining backward compatibility, from Florian Westphal. 2) Skip zeroing timer area in nf_conn objects, also from Florian. 3) Inspect IPv4 and IPv6 traffic from the bridge to allow filtering using using meta l4proto and transport layer header, from Alvaro Neira. 4) Fix linking problems in the new redirect support when CONFIG_IPV6=n and IP6_NF_IPTABLES=n. And ipset updates from Jozsef Kadlecsik: 5) Support updating element extensions when the set is full (fixes netfilter bugzilla id 880). 6) Fix set match with 32-bits userspace / 64-bits kernel. 7) Indicate explicitly when /0 networks are supported in ipset. 8) Simplify cidr handling for hash:*net* types. 9) Allocate the proper size of memory when /0 networks are supported. 10) Explicitly add padding elements to hash:net,net and hash:net,port, because the elements must be u32 sized for the used hash function. Jozsef is also cooking ipset RCU conversion which should land soon if they reach the merge window in time. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-05Merge branch 'for-upstream' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
2014-12-05Bluetooth: Enabled LE Direct Advertising Report event if supportedMarcel Holtmann
When the controller supports the Extended Scanner Filter Policies, it supports the LE Direct Advertising Report event. However by default that event is blocked by the LE event mask. It is required to enable it during controller setup. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Add definitions for LE Direct Advertising Report eventMarcel Holtmann
This patch adds the event id and data structures for the LE Direct Advertising Report event. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Move LE advertising report defines to the right locationMarcel Holtmann
All Bluetooth commands and events are ordered by its opcode or event id, but for some reason this one now stands out. So move it to its correct spot in the list. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Report invalid RSSI for service discovery and background scanMarcel Holtmann
When using Start Service Discovery and when background scanning is used to report devices, the RSSI is reported or the value 127 is provided in case RSSI in unavailable. For Start Discovery the value 0 is reported to keep backwards compatibility with the existing users. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Add helper function for clearing the discovery filterMarcel Holtmann
The discovery filter allocates memory for its UUID list. So use a helper function to free it and reset it to default states. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Add extra discovery fields for storing filter informationJakub Pawlowski
With the upcoming addition of support for Start Service Discovery, the discovery handling needs to filter on RSSI and UUID values. For that they need to be stored in the discovery handling. This patch adds the appropiate fields and also make sure they are reset when discovery has been stopped. Signed-off-by: Jakub Pawlowski <jpawlowski@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-05Bluetooth: Add definitions for MGMT_OP_START_SERVICE_DISCOVERYJakub Pawlowski
This patch adds the opcode and structure for Start Service Discovery operation. Signed-off-by: Jakub Pawlowski <jpawlowski@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
