path: root/include/pcmcia
2011-05-06pcmcia: Make declaration and uses of struct pcmcia_device_id constJoe Perches
Const allows tables to be moved into text sections. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-02-20pcmcia: re-enable Zoomed Video supportDominik Brodowski
Allow drivers to enable Zoomed Video support. Currently, this is only used by out-of-tree drivers (L64020 DVB driver in particular). CC: <stable@kernel.org> [for 2.6.37] Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-10-22pcmcia: IOCARD is also required for using IRQsDominik Brodowski
Dave Hinds pointed out to me that 37979e1546a7 will break b43 and ray_cs, as IOCARD is not -- as the name would suggest -- only needed for cards using IO ports. Instead, as it re-deines several pins, it is also required for using interrupts. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move config_{base,index,regs} to struct pcmcia_deviceDominik Brodowski
Several drivers prefer to explicitly set config_{base,index,regs}, formerly known as ConfigBase, ConfigIndex and Present. Instead of passing these values inside config_req_t, store it in struct pcmcia_device. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify Status, ExtStatus register accessDominik Brodowski
The Status (CISREG_CCSR) and ExtStatus (CISREG_ESR) registers were only accessed to enable audio output for some drivers and IRQ for serial_cs.c. The former also required setting config_req_t.Attributes to CONF_ENABLE_SPKR; the latter can be simplified to setting this field to CONF_ENABLE_ESR. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: remove Pin, Copy configuration register accessDominik Brodowski
The "Pin" and "Copy" configuration registers (CISREG_SCR, CISREG_PPR) do not seem to be utilized anywhere. If a device would request a write to these registers, "0" would be written. Continue to do so, but warn of unexpected behavior -- and remove the "Pin" and "Copy" entries from config_req_t. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move Vpp setup to struct pcmcia_deviceDominik Brodowski
Some drivers prefer to explicitly set Vpp. Instead of passing the voltage inside config_req_t, store it in struct pcmcia_device. CC: linux-ide@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-usb@vger.kernel.org CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: split up modify_configuration() into two fixup functionsDominik Brodowski
pcmcia_modify_configuration() was only used by two drivers to fix up one issue each: setting the Vpp to a different value, and reducing the IO width to 8 bit. Introduce two explicitly named functions handling these things, and remove one further typedef. CC: netdev@vger.kernel.org CC: linux-mtd@lists.infradead.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: do not use win_req_t when calling pcmcia_request_window()Dominik Brodowski
Instead of win_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[2,3,4,5] for up to four iomem ranges. After a call to pcmcia_request_window(), the windows found there are reserved and may be used until pcmcia_release_window() is called. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: use struct resource for PCMCIA devices, part 2Dominik Brodowski
Use struct resource * also for iomem resources. CC: linux-mtd@lists.infradead.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: remove memreq_tDominik Brodowski
Page already had to be set to 0; Offset can easily be passed as parameter to pcmcia_map_mem_page. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: move local definitions out of include/pcmcia/cs.hDominik Brodowski
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: use struct resource for PCMCIA devicesDominik Brodowski
Introduce a new field into struct pcmcia_device named "resource" and of type struct resource *, which contains the IO port ranges allocated for this device. Memory window ranges and registration with the resource trees will follow at a later date. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: clean up cs.hDominik Brodowski
Remove some obsolete definitions from cs.h Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: use pcmica_{read,write}_config_byteDominik Brodowski
Use pcmcia_read_config_byte and pcmcia_write_config_byte instead of pcmcia_access_configuration_register. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove unused flag, simplify headersDominik Brodowski
As we only provide one way to set up resources now, we can remove the resource-setup-related bitfield (except resource_setup_done). In addition, pcmcia_state only consisted of one entry, so remove this bitfield as well. Suggested-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove obsolete CS_EVENT_ definitionsDominik Brodowski
Remove some definitions which became obsolete when the central event handler got removed. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove obsolete ioctlDominik Brodowski
2010-05-10pcmcia: remove unused mem_op.hDominik Brodowski
2010-05-10pcmcia: clarify alloc_io_space, move it to resource handlersDominik Brodowski
Clean up the alloc_io_space() function by moving most of it to the actual resource_ops. This allows for a bit less re-directions. Future cleanups will follow, and will make up for the code duplication currently present between rsrc_iodyn and rsrc_nonstatic (which are hardly ever built at the same time anyway, therefore no increase in built size). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: dev_node removal (core)Dominik Brodowski
Remove the dev_node declaration. We now only pass the device name to the deprecated userspace tools. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: clean up cs.hDominik Brodowski
With req_irq_t gone, we can get rid of some definitions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: pass FORCED_PULSE parameter in pcmcia_request_configuration()Dominik Brodowski
As it's only used there it makes no sense relying on pcmcia_request_irq(). CC: alsa-devel@alsa-project.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: replace struct irq with uint pcmcia_irq in struct pcmcia_socketDominik Brodowski
As we don't need the "Config" counter any more, we can simplify struct pcmcia_socket. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: setup IRQ to be used by PCMCIA drivers at card insertDominik Brodowski
Setup the IRQ to be used by PCMCIA drivers already during the device registration stage, making use of a new function pcmcia_setup_irq(). This will allow us to get rid of quite a lot of indirection in the future. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-04-21pcmcia: pcmcia_dev_present bugfixDominik Brodowski
pcmcia_dev_present is in and by itself buggy. Add a note specifying why it is broken, and replace the broken locking -- taking a mutex is a bad idea in IRQ context, from which this function is rarely called -- by an atomic_t. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-24pcmcia: use dev_pm_ops for class pcmcia_socket_classDominik Brodowski
Instead of requiring PCMCIA socket drivers to call various functions during their (bus) resume and suspend functions, register an own dev_pm_ops for this class. This fixes several suspend/resume bugs seen on db1xxx-ss, and probably on some other socket drivers, too. With regard to the asymmetry with only _noirq suspend, but split up resume, please see bug 14334 and commit 9905d1b411946fb3 . Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-25Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/rt2x00/rt2800pci.c
2010-02-19Introduce PCMCIA_DEVICE_PROD_ID3Pavel Roskin
...and use it in hostap_cs and orinoco_cs. Another PCMCIA device with Intersil Prism chipset has been reported: Socket 0: product info: "Gigabyte", "GN-WLM01_P25L_ADAPTER", "ISL37300P", "Eval-RevA" manfid: 0x02e0, 0x1011 function: 6 (network) As it's the case with some other Prism based devices, the third ID string contains a design name that should be sufficient to identify the card as having Intersil Prism chipset and thus compatible with both orinoco_cs and hostap_cs. Introduce PCMCIA_DEVICE_PROD_ID3 that matches the third ID string only. Use it in orinoco_cs and hostap_cs to match cards with the third ID string indicating Prism chipset. Remove corresponding entries that use PCMCIA_DEVICE_PROD_ID123. Reported-by: Ozzy <ozzymud@gmail.com> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-17pcmcia: use state machine for extended requeryDominik Brodowski
The requery callback now also handles the addition of a second pseudo multifunction device. Avoids messing with dev_{g,s}et_drvdata(), and fixes any workqueue <-> skt_mutex deadlock. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: use pccardd to handle eject, insert, suspend and resume requestsDominik Brodowski
This avoids any sysfs-related deadlock (or lockdep warning), such as reported at http://lkml.org/lkml/2010/1/17/88 . Reported-by: Ming Lei <tom.leiming@gmail.com> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: use mutex for dynid lockDominik Brodowski
Even though we weren't calling a blocking function within the dynid spinlock, we do not need a spinlock here but can and should be using a mutex. Reported-by: Jiri Slaby <jirislaby@gmail.com> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: simplify lockingDominik Brodowski
replace pcmcia_socket->lock and pcmcia_dev_list_lock by using the per-socket "ops_mutex", as we do neither need different locks nor a spinlock here. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: add locking to set_mem_map()Dominik Brodowski
Protect the pccard_operations callback "set_mem_map" by a new mutex ops_mutex. This mutex also protects the following values in struct pcmcia_socket: pccard_mem_map win[] pccard_mem_map cis_mem void __iomem *cis_virt Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: do not use resource manager on !PCMCIADominik Brodowski
If only CardBus cards are used, but not PCMCIA cards, we do not need the extensive resource management functions provided for by rsrc_nonstatic.c (~240K). Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-02-17pcmcia: m8xx_pcmcia.c should use iodyn resource managerDominik Brodowski
The socket driver m8xx_pcmcia.c uses a static memory assignment, but io_offset is set to 0. Therefore, it seems proper to use the iodyn resource manager for this driver, as was previously the case (before commit 80128ff79d282cf71b1819dbca9b8dd47d8ed3e8). CC: Vitaly Bordug <vitb@kernel.crashing.org> CC: Arnd Bergmann <arnd@arndb.de> CC: Olof Johansson <olof@lixom.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-01-17pcmcia: CardBus doesn't need CIS accessDominik Brodowski
At least no in-kernel CardBus-capable PCI driver makes use of the CIS access functions. Therefore, it seems sensible to remove this unused code, and cleanup cardbus.c a lot. CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-01-17pcmcia: improve check for same card in slot after resumeDominik Brodowski
During a suspend/resume cycle, an user may change the card in the PCMCIA/CardBus slot. The pcmcia_core can at least look at the socket state to check whether it is the same. For PCMCIA devices, move the detection and handling of such a change to ds.c. For CardBus devices, the PCI hotplug interface doesn't offer a "rescan" facility which also _removes_ devices no longer to be found behind a bridge. Therefore, remove and re-add all devices unconditionally. CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-07pcmcia: CodingStyle fixesDominik Brodowski
Fix several CodingStyle issues in drivers/pcmcia/ . checkpatch.pl no longer reports errors in the PCMCIA core. The remaining warnings mostly relate to wrong indent -- PCMCIA historically used 4 spaces --, to lines over 80 characters and to hundreds of typedefs. The cleanup of those will follow in the future. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-07pcmcia: remove unused IRQ_FIRST_SHAREDDominik Brodowski
Komuro pointed out that IRQ_FIRST_SHARED is not used at all in the PCMCIA subsystem, so remove it. Also, remove two bogus assignments. CC: Karsten Keil <keil@b1-systems.de> CC: netdev@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
