path: root/include/rdma/ib_mad.h
2009-03-24Merge branches 'cxgb3', 'endian', 'ipath', 'ipoib', 'iser', 'mad', 'misc', ↵Roland Dreier
'mlx4', 'mthca', 'nes' and 'sysfs' into for-next
2009-02-27IB/mad: Fix RMPP header RRespTime manipulationRamachandra K
Fix ib_set_rmpp_flags() to use the correct bit mask for RRespTime. In the 8-bit field of the RMPP header, the first 5 bits are RRespTime and next 3 bits are RMPPFlags. Hence to retain the first 5 bits, the mask should be 0xF8 instead of 0xF1. ack_recv()-->format_ack() calls ib_set_rmpp_flags() and due to the incorrect ANDing with 0xF1, RRespTime got changed incorrectly and RMPP Acks sent back always had a RRespTime of 0x1E (30) which caused the other end to consider the time outs to be approximately 4297 seconds (i.e. in the order of 4*2^30) instead of the usual ~4 seconds (order of 4*2^20). Signed-off-by: Ramachandra K <ramachandra.kuchimanchi@qlogic.com> Acked-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-01-17IB: Remove __constant_{endian} usesHarvey Harrison
The base versions handle constant folding just fine, use them directly. The replacements are OK in the include/ files as they are not exported to userspace so we don't need the __ prefixed versions. This patch does not affect code generation at all. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA: Improve include file coding styleDotan Barak
Remove subversion $Id lines and improve readability by fixing other coding style problems pointed out by checkpatch.pl. Signed-off-by: Dotan Barak <dotanba@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-25IB/mad: Report number of times a mad was retriedSean Hefty
To allow ULPs to tune timeout values and capture retry statistics, report the number of times that a mad send operation was retried. For RMPP mads, report the total number of times that the any portion (send window) of the send operation was retried. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-08-03IB: Include <linux/list.h> from <rdma/ib_mad.h>Dotan Barak
ib_mad.h uses struct list_head, so while linux/list.h seems to be pulled in indirectly by one of the headers it includes, the right thing is to include linux/list.h directly. Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-10IB/sa: Make sure SA queries use default P_KeySean Hefty
MADs sent to the SA should use the the default P_Key (0x7fff/0xffff). There's no requirement that the default P_Key is stored at index 0 in the local P_Key table, so add code to the sa_query module to look up the index of the default P_Key when creating an address handle for the SA (which is done any time the P_Key table might change), and use this index for all SA queries. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24IB/mad: Validate MADs for spec complianceSean Hefty
Validate MADs sent by userspace clients for spec compliance with C13-18.1.1 (prevent duplicate requests and responses sent on the same port). Without this, RMPP transactions get aborted because of duplicate packets. This patch is similar to that provided by Jack Morgenstein. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-30IB/mad: RMPP support for additional classesHal Rosenstock
Add RMPP support for additional management classes that support it. Also, validate RMPP is consistent with management class specified. Signed-off-by: Hal Rosenstock <halr@voltaire.com> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB/umad: Add support for large RMPP transfersJack Morgenstein
Add support for sending and receiving large RMPP transfers. The old code supports transfers only as large as a single contiguous kernel memory allocation. This patch uses linked list of memory buffers when sending and receiving data to avoid needing contiguous pages for larger transfers. Receive side: copy the arriving MADs in chunks instead of coalescing to one large buffer in kernel space. Send side: split a multipacket MAD buffer to a list of segments, (multipacket_list) and send these using a gather list of size 2. Also, save pointer to last sent segment, and retrieve requested segments by walking list starting at last sent segment. Finally, save pointer to last-acked segment. When retrying, retrieve segments for resending relative to this pointer. When updating last ack, start at this pointer. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-25[IB] Fix MAD layer DMA mappings to avoid touching data buffer once mappedSean Hefty
The MAD layer was violating the DMA API by touching data buffers used for sends after the DMA mapping was done. This causes problems on non-cache-coherent architectures, because the device doing DMA won't see updates to the payload buffers that exist only in the CPU cache. Fix this by having all MAD consumers use ib_create_send_mad() to allocate their send buffers, and moving the DMA mapping into the MAD layer so it can be done just before calling send (and after any modifications of the send buffer by the MAD layer). Tested on a non-cache-coherent PowerPC 440SPe system. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[IB] Add MAD data field size definitionsSean Hefty
Clean up code by using enums instead of hard-coded magic numbers. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-09-09[PATCH] IB: Add struct for ClassPortInfoRoland Dreier
Add structure definition for ClassPortInfo format. This is needed for (at least) handling CM redirects. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-26[PATCH] IB: move include files to include/rdmaRoland Dreier
Move the InfiniBand headers from drivers/infiniband/include to include/rdma. This allows InfiniBand-using code to live elsewhere, and lets us remove the ugly EXTRA_CFLAGS include path from the InfiniBand Makefiles. Signed-off-by: Roland Dreier <rolandd@cisco.com>
