path: root/include/rdma/ib_verbs.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-18IB/core: Add GID change eventOr Gerlitz
Add IB GID change event type. This is needed for IBoE when the HW driver updates the GID (e.g when new VLANs are added/deleted) table and the change should be reflected to the IB core cache. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.co.il> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-01-16RDMA: Update workqueue usageTejun Heo
* ib_wq is added, which is used as the common workqueue for infiniband instead of the system workqueue. All system workqueue usages including flush_scheduled_work() callers are converted to use and flush ib_wq. * cancel_delayed_work() + flush_scheduled_work() converted to cancel_delayed_work_sync(). * qib_wq is removed and ib_wq is used instead. This is to prepare for deprecation of flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-27IB/core: Add link layer property to portsEli Cohen
This patch allows ports to have different link layers: IB_LINK_LAYER_INFINIBAND or IB_LINK_LAYER_ETHERNET. This is required for adding IBoE (InfiniBand-over-Ethernet, aka RoCE) support. For devices that do not provide an implementation for querying the link layer property of a port, we return a default value based on the transport: RMA_TRANSPORT_IB nodes will return IB_LINK_LAYER_INFINIBAND and RDMA_TRANSPORT_IWARP nodes will return IB_LINK_LAYER_ETHERNET. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-08-04IB: Rename RAW_ETY to RAW_ETHERTYPEAleksey Senin
Change abbreviated IB_QPT_RAW_ETY to IB_QPT_RAW_ETHERTYPE to make the special QP type easier to understand. cf http://www.mail-archive.com/linux-rdma@vger.kernel.org/msg04530.html Signed-off-by: Aleksey Senin <alekseys@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-21IB/core: Allow device-specific per-port sysfs filesRalph Campbell
Add a new parameter to ib_register_device() so that low-level device drivers can pass in a pointer to a callback function that will be called for each port that is registered in sysfs. This allows low-level device drivers to create files in /sys/class/infiniband/<hca>/ports/<N>/ without having to poke through the internals of the RDMA sysfs handling. There is no need for an unregister function since the kobject reference will go to zero when ib_unregister_device() is called. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-21IB/core: Add support for masked atomic operationsVladimir Sokolovsky
- Add new IB_WR_MASKED_ATOMIC_CMP_AND_SWP and IB_WR_MASKED_ATOMIC_FETCH_AND_ADD send opcodes that can be used to post "masked atomic compare and swap" and "masked atomic fetch and add" work request respectively. - Add masked_atomic_cap capability. - Add mask fields to atomic struct of ib_send_wr - Add new opcodes to ib_wc_opcode The new operations are described more precisely below: * Masked Compare and Swap (MskCmpSwap) The MskCmpSwap atomic operation is an extension to the CmpSwap operation defined in the IB spec. MskCmpSwap allows the user to select a portion of the 64 bit target data for the “compare” check as well as to restrict the swap to a (possibly different) portion. The pseudo code below describes the operation: | atomic_response = *va | if (!((compare_add ^ *va) & compare_add_mask)) then | *va = (*va & ~(swap_mask)) | (swap & swap_mask) | | return atomic_response The additional operands are carried in the Extended Transport Header. Atomic response generation and packet format for MskCmpSwap is as for standard IB Atomic operations. * Masked Fetch and Add (MFetchAdd) The MFetchAdd Atomic operation extends the functionality of the standard IB FetchAdd by allowing the user to split the target into multiple fields of selectable length. The atomic add is done independently on each one of this fields. A bit set in the field_boundary parameter specifies the field boundaries. The pseudo code below describes the operation: | bit_adder(ci, b1, b2, *co) | { | value = ci + b1 + b2 | *co = !!(value & 2) | | return value & 1 | } | | #define MASK_IS_SET(mask, attr) (!!((mask)&(attr))) | bit_position = 1 | carry = 0 | atomic_response = 0 | | for i = 0 to 63 | { | if ( i != 0 ) | bit_position = bit_position << 1 | | bit_add_res = bit_adder(carry, MASK_IS_SET(*va, bit_position), | MASK_IS_SET(compare_add, bit_position), &new_carry) | if (bit_add_res) | atomic_response |= bit_position | | carry = ((new_carry) && (!MASK_IS_SET(compare_add_mask, bit_position))) | } | | return atomic_response Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-24IB/core: Pack struct ib_device a little tighterAlexander Chiang
A small change to reduce the size of ib_device to 1112 bytes (from 1128). Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-12-09IB: Clarify the documentation of ib_post_send()Bart Van Assche
Clarify the behavior of ib_post_send() when a list of work requests is passed in and an immediate error is returned. Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-02-14net: replace __constant_{endian} uses in net headersHarvey Harrison
Base versions handle constant folding now. For headers exposed to userspace, we must only expose the __ prefixed versions. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14RDMA/core: Add local DMA L_Key supportSteve Wise
- Change the IB_DEVICE_ZERO_STAG flag to the transport-neutral name IB_DEVICE_LOCAL_DMA_LKEY, which is used by iWARP RNICs to indicate 0 STag support and IB HCAs to indicate reserved L_Key support. - Add a u32 local_dma_lkey member to struct ib_device. Drivers fill this in with the appropriate local DMA L_Key (if they support it). - Fix up the drivers using this flag. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/core: Add support for multicast loopback blockingRon Livne
This patch also adds a creation flag for QPs, IB_QP_CREATE_MULTICAST_BLOCK_LOOPBACK, which when set means that multicast sends from the QP to a group that the QP is attached to will not be looped back to the QP's receive queue. This can be used to save receive resources when a consumer does not want a local copy of multicast traffic; for example IPoIB must waste CPU time throwing away such local copies of multicast traffic. This patch also adds a device capability flag that shows whether a device supports this feature or not. Signed-off-by: Ron Livne <ronli@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/core: Add iWARP protocol statistics attributes in sysfsSteve Wise
This patch adds a sysfs attribute group called "proto_stats" under /sys/class/infiniband/$device/ and populates this group with protocol statistics if they exist for a given device. Currently, only iWARP stats are defined, but the code is designed to allow InfiniBand protocol stats if they become available. These stats are per-device and more importantly -not- per port. Details: - Add union rdma_protocol_stats in ib_verbs.h. This union allows defining transport-specific stats. Currently only iwarp stats are defined. - Add struct iw_protocol_stats to define the current set of iwarp protocol stats. - Add new ib_device method called get_proto_stats() to return protocol statistics. - Add logic in core/sysfs.c to create iwarp protocol stats attributes if the device is an RNIC and has a get_proto_stats() method. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/core: Add memory management extensions supportSteve Wise
This patch adds support for the IB "base memory management extension" (BMME) and the equivalent iWARP operations (which the iWARP verbs mandates all devices must implement). The new operations are: - Allocate an ib_mr for use in fast register work requests. - Allocate/free a physical buffer lists for use in fast register work requests. This allows device drivers to allocate this memory as needed for use in posting send requests (eg via dma_alloc_coherent). - New send queue work requests: * send with remote invalidate * fast register memory region * local invalidate memory region * RDMA read with invalidate local memory region (iWARP only) Consumer interface details: - A new device capability flag IB_DEVICE_MEM_MGT_EXTENSIONS is added to indicate device support for these features. - New send work request opcodes IB_WR_FAST_REG_MR, IB_WR_LOCAL_INV, IB_WR_RDMA_READ_WITH_INV are added. - A new consumer API function, ib_alloc_mr() is added to allocate fast register memory regions. - New consumer API functions, ib_alloc_fast_reg_page_list() and ib_free_fast_reg_page_list() are added to allocate and free device-specific memory for fast registration page lists. - A new consumer API function, ib_update_fast_reg_key(), is added to allow the key portion of the R_Key and L_Key of a fast registration MR to be updated. Consumers call this if desired before posting a IB_WR_FAST_REG_MR work request. Consumers can use this as follows: - MR is allocated with ib_alloc_mr(). - Page list memory is allocated with ib_alloc_fast_reg_page_list(). - MR R_Key/L_Key "key" field is updated with ib_update_fast_reg_key(). - MR made VALID and bound to a specific page list via ib_post_send(IB_WR_FAST_REG_MR) - MR made INVALID via ib_post_send(IB_WR_LOCAL_INV), ib_post_send(IB_WR_RDMA_READ_WITH_INV) or an incoming send with invalidate operation. - MR is deallocated with ib_dereg_mr() - page lists dealloced via ib_free_fast_reg_page_list(). Applications can allocate a fast register MR once, and then can repeatedly bind the MR to different physical block lists (PBLs) via posting work requests to a send queue (SQ). For each outstanding MR-to-PBL binding in the SQ pipe, a fast_reg_page_list needs to be allocated (the fast_reg_page_list is owned by the low-level driver from the consumer posting a work request until the request completes). Thus pipelining can be achieved while still allowing device-specific page_list processing. The 32-bit fast register memory key/STag is composed of a 24-bit index and an 8-bit key. The application can change the key each time it fast registers thus allowing more control over the peer's use of the key/STag (ie it can effectively be changed each time the rkey is rebound to a page list). Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA: Improve include file coding styleDotan Barak
Remove subversion $Id lines and improve readability by fixing other coding style problems pointed out by checkpatch.pl. Signed-off-by: Dotan Barak <dotanba@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-06-09IB/core: Remove IB_DEVICE_SEND_W_INV capability flagRoland Dreier
In 2.6.26, we added some support for send with invalidate work requests, including a device capability flag to indicate whether a device supports such requests. However, the support was incomplete: the completion structure was not extended with a field for the key contained in incoming send with invalidate requests. Full support for memory management extensions (send with invalidate, local invalidate, fast register through a send queue, etc) is planned for 2.6.27. Since send with invalidate is not very useful by itself, just remove the IB_DEVICE_SEND_W_INV bit before the 2.6.26 final release; we will add an IB_DEVICE_MEM_MGT_EXTENSIONS bit in 2.6.27, which makes things simpler for applications, since they will not have quite as confusing an array of fine-grained bits to check. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-29IB: expand ib_umem_get() prototypeArthur Kepner
Add a new parameter, dmasync, to the ib_umem_get() prototype. Use dmasync = 1 when mapping user-allocated CQs with ib_umem_get(). Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19IB: convert struct class_device to struct deviceTony Jones
This converts the main ib_device to use struct device instead of struct class_device as class_device is going away. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-16IB/core: Add support for modify CQEli Cohen
Add support for modifying CQ parameters for controlling event generation moderation. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/core: Add support for "send with invalidate" work requestsRoland Dreier
Add a new IB_WR_SEND_WITH_INV send opcode that can be used to mark a "send with invalidate" work request as defined in the iWARP verbs and the InfiniBand base memory management extensions. Also put "imm_data" and a new "invalidate_rkey" member in a new "ex" union in struct ib_send_wr. The invalidate_rkey member can be used to pass in an R_Key/STag to be invalidated. Add this new union to struct ib_uverbs_send_wr. Add code to copy the invalidate_rkey field in ib_uverbs_post_send(). Fix up low-level drivers to deal with the change to struct ib_send_wr, and just remove the imm_data initialization from net/sunrpc/xprtrdma/, since that code never does any send with immediate operations. Also, move the existing IB_DEVICE_SEND_W_INV flag to a new bit, since the iWARP drivers currently in the tree set the bit. The amso1100 driver at least will silently fail to honor the IB_SEND_INVALIDATE bit if passed in as part of userspace send requests (since it does not implement kernel bypass work request queueing). Remove the flag from all existing drivers that set it until we know which ones are OK. The values chosen for the new flag is not consecutive to avoid clashing with flags defined in the XRC patches, which are not merged yet but which are already in use and are likely to be merged soon. This resurrects a patch sent long ago by Mikkel Hagen <mhagen@iol.unh.edu>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/core: Add IPoIB UD LSO supportEli Cohen
LSO (large send offload) allows the networking stack to pass SKBs with data size larger than the MTU to the IPoIB driver and have the HCA HW fragment the data to multiple MSS-sized packets. Add a device capability flag IB_DEVICE_UD_TSO for devices that can perform TCP segmentation offload, a new send work request opcode IB_WR_LSO, header, hlen and mss fields for the work request structure, and a new IB_WC_LSO completion type. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB/core: Add creation flags to struct ib_qp_init_attrEli Cohen
Add a create_flags member to struct ib_qp_init_attr that will allow a kernel verbs consumer to create a pass special flags when creating a QP. Add a flag value for telling low-level drivers that a QP will be used for IPoIB UD LSO. The create_flags member will also be useful for XRC and ehca low-latency QP support. Since no create_flags handling is implemented yet, add code to all low-level drivers to return -EINVAL if create_flags is non-zero. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB: Make struct ib_uobject.id a signed intRoland Dreier
IDR IDs are signed, so struct ib_uobject.id should be signed. This avoids some sparse pointer signedness warnings. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-08IB/core: Remove unused struct ib_device.flags memberRoland Dreier
Avoid confusion about what it might mean, since it's never initialized. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-08IB/core: Add IP checksum offload supportEli Cohen
Add a device capability to show when it can handle checksum offload. Also add a send flag for inserting checksums and a csum_ok field to the completion record. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-01-24Kobject: change drivers/infiniband to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <mshefty@ichips.intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-08-03IB: Move the macro IB_UMEM_MAX_PAGE_CHUNK() to umem.cDotan Barak
After moving the definition of struct ib_umem_chunk from ib_verbs.h to ib_umem.h there isn't any reason for the macro IB_UMEM_MAX_PAGE_CHUNK to stay in ib_verbs.h. Move the macro to umem.c, the only place where it is used. Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-08-03IB: Include <linux/list.h> and <linux/rwsem.h> from <rdma/ib_verbs.h>Dotan Barak
ib_verbs.h uses struct list_head and rw_semaphore, so while the files <linux/list.h> and <linux/rwsem.h> seem to be pulled in indirectly by the other header files it includes, the right thing is to include those files directly. Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-19IB/core: Add helpers for uncached GID and P_Key searchesYosef Etigin
Add ib_find_gid() and ib_find_pkey() functions that use uncached device queries. The calls might block but the returns are always up-to-date. Cache P_Key and GID table lengths in core to avoid extra port info queries. Signed-off-by: Yosef Etigin <yosefe@voltaire.com> Acked-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/uverbs: Export ib_umem_get()/ib_umem_release() to modulesRoland Dreier
Export ib_umem_get()/ib_umem_release() and put low-level drivers in control of when to call ib_umem_get() to pin and DMA map userspace, rather than always calling it in ib_uverbs_reg_mr() before calling the low-level driver's reg_user_mr method. Also move these functions to be in the ib_core module instead of ib_uverbs, so that driver modules using them do not depend on ib_uverbs. This has a number of advantages: - It is better design from the standpoint of making generic code a library that can be used or overridden by device-specific code as the details of specific devices dictate. - Drivers that do not need to pin userspace memory regions do not need to take the performance hit of calling ib_mem_get(). For example, although I have not tried to implement it in this patch, the ipath driver should be able to avoid pinning memory and just use copy_{to,from}_user() to access userspace memory regions. - Buffers that need special mapping treatment can be identified by the low-level driver. For example, it may be possible to solve some Altix-specific memory ordering issues with mthca CQs in userspace by mapping CQ buffers with extra flags. - Drivers that need to pin and DMA map userspace memory for things other than memory regions can use ib_umem_get() directly, instead of hacks using extra parameters to their reg_phys_mr method. For example, the mlx4 driver that is pending being merged needs to pin and DMA map QP and CQ buffers, but it does not need to create a memory key for these buffers. So the cleanest solution is for mlx4 to call ib_umem_get() in the create_qp and create_cq methods. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-06IB: Return "maybe missed event" hint from ib_req_notify_cq()Roland Dreier
The semantics defined by the InfiniBand specification say that completion events are only generated when a completions is added to a completion queue (CQ) after completion notification is requested. In other words, this means that the following race is possible: while (CQ is not empty) ib_poll_cq(CQ); // new completion is added after while loop is exited ib_req_notify_cq(CQ); // no event is generated for the existing completion To close this race, the IB spec recommends doing another poll of the CQ after requesting notification. However, it is not always possible to arrange code this way (for example, we have found that NAPI for IPoIB cannot poll after requesting notification). Also, some hardware (eg Mellanox HCAs) actually will generate an event for completions added before the call to ib_req_notify_cq() -- which is allowed by the spec, since there's no way for any upper-layer consumer to know exactly when a completion was really added -- so the extra poll of the CQ is just a waste. Motivated by this, we add a new flag "IB_CQ_REPORT_MISSED_EVENTS" for ib_req_notify_cq() so that it can return a hint about whether the a completion may have been added before the request for notification. The return value of ib_req_notify_cq() is extended so: < 0 means an error occurred while requesting notification == 0 means notification was requested successfully, and if IB_CQ_REPORT_MISSED_EVENTS was passed in, then no events were missed and it is safe to wait for another event. > 0 is only returned if IB_CQ_REPORT_MISSED_EVENTS was passed in. It means that the consumer must poll the CQ again to make sure it is empty to avoid the race described above. We add a flag to enable this behavior rather than turning it on unconditionally, because checking for missed events may incur significant overhead for some low-level drivers, and consumers that don't care about the results of this test shouldn't be forced to pay for the test. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-06IB: Add CQ comp_vector supportMichael S. Tsirkin
Add a num_comp_vectors member to struct ib_device and extend ib_create_cq() to pass in a comp_vector parameter -- this parallels the userspace libibverbs API. Update all hardware drivers to set num_comp_vectors to 1 and have all ULPs pass 0 for the comp_vector value. Pass the value of num_comp_vectors to userspace rather than hard-coding a value of 1. We want multiple CQ event vector support (via MSI-X or similar for adapters that can generate multiple interrupts), but it's not clear how many vectors we want, or how we want to deal with policy issues such as how to decide which vector to use or how to set up interrupt affinity. This patch is useful for experimenting, since no core changes will be necessary when updating a driver to support multiple vectors, and we know that we want to make at least these changes anyway. Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-04IB: Return qp pointer as part of ib_wcMichael S. Tsirkin
struct ib_wc currently only includes the local QP number: this matches the IB spec, but seems mostly useless. The following patch replaces this with the pointer to qp itself, and updates all low level drivers and all users. This has the following advantages: - Ability to get a per-qp context through wc->qp->qp_context - Existing drivers already have the qp pointer ready in poll cq, so this change actually saves a tiny bit (extra memory read) on data path (for ehca it would actually be expensive to find the QP pointer when polling a CQ, but ehca does not support SRQ so we can leave wc->qp as NULL for ehca) - Users that need the QP number can still get it through wc->qp->qp_num Use case: In IPoIB connected mode code, I have a common CQ shared by multiple QPs. To track connection usage, I need a way to get at some per-QP context upon the completion, and I would like to avoid allocating context object per work request just to stick a QP pointer into it. With this code, I can just use wc->qp->qp_context. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-04IB: Include <linux/kref.h> explicitly in <rdma/ib_verbs.h>Michael S. Tsirkin
<rdma/ib_verbs.h> uses struct kref, so it should include <linux/kref.h> explicitly to avoid hidden include dependencies. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-12-15IB: Fix ib_dma_alloc_coherent() wrapperRoland Dreier
The ib_dma_alloc_coherent() wrapper uses a u64* for the dma_handle parameter, unlike dma_alloc_coherent, which uses dma_addr_t*. This means that we need a temporary variable to handle the case when ib_dma_alloc_coherent() just falls through directly to dma_alloc_coherent() on architectures where sizeof u64 != sizeof dma_addr_t. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-12-13[PATCH] ib_verbs: Use explicit if-else statements to avoid errors with ↵Ben Collins
do-while macros At least on PPC, the "op ? op : dma" construct causes a compile failure because the dma_* is a do{}while(0) macro. This turns all of them into proper if/else to avoid this problem. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12IB: Add DMA mapping functions to allow device drivers to interposeRalph Campbell
The QLogic InfiniPath HCAs use programmed I/O instead of HW DMA. This patch allows a verbs device driver to interpose on DMA mapping function calls in order to avoid relying on bus_to_virt() and phys_to_virt() to undo the mappings created by dma_map_single(), dma_map_sg(), etc. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22RDMA: iWARP Core Changes.Tom Tucker
Modifications to the existing rdma header files, core files, drivers, and ulp files to support iWARP, including: - Hook iWARP CM into the build system and use it in rdma_cm. - Convert enum ib_node_type to enum rdma_node_type, which includes the possibility of RDMA_NODE_RNIC, and update everything for this. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/uverbs: Pass userspace data to modify_srq and modify_qp methodsRalph Campbell
Pass a struct ib_udata to the low-level driver's ->modify_srq() and ->modify_qp() methods, so that it can get to the device-specific data passed in by the userspace driver. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB/uverbs: Don't serialize with ib_uverbs_idr_mutexRoland Dreier
Currently, all userspace verbs operations that call into the kernel are serialized by ib_uverbs_idr_mutex. This can be a scalability issue for some workloads, especially for devices driven by the ipath driver, which needs to call into the kernel even for datapath operations. Fix this by adding reference counts to the userspace objects, and then converting ib_uverbs_idr_mutex into a spinlock that only protects the idrs long enough to take a reference on the object being looked up. Because remove operations may fail, we have to do a slightly funky two-step deletion, which is described in the comments at the top of uverbs_cmd.c. This also still leaves ib_uverbs_idr_lock as a single lock that is possibly subject to contention. However, the lock hold time will only be a single idr operation, so multiple threads should still be able to make progress, even if ib_uverbs_idr_lock is being ping-ponged. Surprisingly, these changes even shrink the object code: add/remove: 23/5 grow/shrink: 4/21 up/down: 633/-693 (-60) Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB: Add ib_init_ah_from_wc()Sean Hefty
Add a function to initialize address handle attributes from a work completion. This functionality is duplicated by both verbs and the CM. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB: Add client reregister event typeLeonid Arsh
Add IB_EVENT_CLIENT_REREGISTER to enum so low-level drivers can generate "client reregister" events. Signed-off-by: Leonid Arsh <leonida@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-06-17IB: Add caching of ports' LMCJack Morgenstein
Add an LMC cache to struct ib_device, and add a function ib_get_cached_lmc() to query the cache. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-04-10IB: simplify static rate encodingJack Morgenstein
Push translation of static rate to HCA format into low-level drivers, where it belongs. For static rate encoding, use encoding of rate field from IB standard PathRecord, with addition of value 0, for backwards compatibility with current usage. The changes are: - Add enum ib_rate to midlayer includes. - Get rid of static rate translation in IPoIB; just use static rate directly from Path and MulticastGroup records. - Update mthca driver to translate absolute static rate into the format used by hardware. This also fixes mthca's static rate handling for HCAs that are capable of 4X DDR. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB/mthca: Return actual capacity from create_srqDotan Barak
Have mthca's create_srq method return the actual capacity of the SRQ that gets created. Also update comments in <rdma/ib_verbs.h> to clarify that this is what is expected from ib_create_srq(). Signed-off-by: Dotan Barak <dotanb@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB: Add ib_modify_qp_is_ok() library functionRoland Dreier
The in-kernel mthca driver contains a table of which attributes are valid for each queue pair state transition. It turns out that both other IB drivers -- ipath and ehca -- which are being prepared for merging have copied this table, errors and all. To forestall this code duplication, move this table and the code to check parameters against it into a midlayer library function, ib_modify_qp_is_ok(). Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB: Enable FMR pool user to set page sizeOr Gerlitz
This patch allows the consumer to set the page size of "pages" mapped by the pool FMRs, which is a feature already existing in the base verbs API. On the cosmetic side it changes ib_fmr_attr.page_size field to be named page_shift. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-03-20IB: Allow userspace to set node descriptionRoland Dreier
Expose a writable "node_desc" sysfs attribute for InfiniBand devices. This allows userspace to update the node description with information such as the node's hostname, so that IB network management software can tie its view to the real world. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
