path: root/include/rdma/ib_verbs.h
2006-01-10IB: Add node_guid to struct ib_deviceSean Hefty
Add a node_guid field to struct ib_device. It is the responsibility of the low-level driver to initialize this field before registering a device with the midlayer. Convert everyone to looking at this field instead of calling ib_query_device() when all they want is the node GUID, and remove the node_guid field from struct ib_device_attr. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-11-10[IB] Have cq_resize() method take an int, not int*Roland Dreier
Change the struct ib_device.resize_cq() method to take a plain integer that holds the new CQ size, rather than a pointer to an integer that it uses to return the new size. This makes the interface match the exported ib_resize_cq() signature, and allows the low-level driver to update the CQ size with proper locking if necessary. No in-tree drivers are exporting this method yet. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-25[IB] Fix MAD layer DMA mappings to avoid touching data buffer once mappedSean Hefty
The MAD layer was violating the DMA API by touching data buffers used for sends after the DMA mapping was done. This causes problems on non-cache-coherent architectures, because the device doing DMA won't see updates to the payload buffers that exist only in the CPU cache. Fix this by having all MAD consumers use ib_create_send_mad() to allocate their send buffers, and moving the DMA mapping into the MAD layer so it can be done just before calling send (and after any modifications of the send buffer by the MAD layer). Tested on a non-cache-coherent PowerPC 440SPe system. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-17[IB] uverbs: Add a mask of device methods allowed for userspaceRoland Dreier
Give each device a uverbs_cmd_mask, so that a low-level driver can control which methods may be called on behalf of userspace. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-17[IB] uverbs: Add device-specific ABI version attributeRoland Dreier
Add abi_version attribute to uverbs class devices to allow for ABI versioning of device-specific interfaces. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-09-26[IB] uverbs: Close some exploitable racesRoland Dreier
Al Viro pointed out that the current IB userspace verbs interface allows userspace to cause mischief by closing file descriptors before we're ready, or issuing the same command twice at the same time. This patch closes those races, and fixes other obvious problems such as a module reference leak. Some other interface bogosities will require an ABI change to fix properly, so I'm deferring those fixes until 2.6.15. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-08-26[PATCH] IB: move include files to include/rdmaRoland Dreier
Move the InfiniBand headers from drivers/infiniband/include to include/rdma. This allows InfiniBand-using code to live elsewhere, and lets us remove the ugly EXTRA_CFLAGS include path from the InfiniBand Makefiles. Signed-off-by: Roland Dreier <rolandd@cisco.com>
