path: root/include/scsi/fc
2013-09-04libfc: Source code comment spelling fixesBart Van Assche
Change 'initiaive' into 'initiative', 'remainig' into 'remaining' and change 'exected' into 'expected'. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Robert Love <robert.w.love@intel.com>
2013-01-07UAPI: (Scripted) Disintegrate include/scsi/fcDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-07[SCSI] libfc: fix lun reset failure bugs in fc_fcp_resp handling of FCP_RSP_INFOYi Zou
In LUN RESET testing involving NetApp targets, it is observed that LUN RESET is failing. The fc_fcp_resp() is not completing the completion for the LUN RESET task since fc_fcp_resp assumes that the FCP_RSP_INFO is 8 bytes with the 4 byte reserved field, where in case of NetApp targets the FCP_RSP to LUN RESET only has 4 bytes of FCP_RSP_INFO. This leads fc_fcp_resp to error out w/o completing the task completion, eventually causing LUN RESET to be escalated to host reset, which is not very nice. Per FCP-3 r04, clause 9.5.15 and Table 23, the FCP_RSP_INFO field can be either 4 bytes or 8 bytes, with the last 4 bytes as "Reserved (if any)". Therefore it is valid to have 4 bytes FCP_RSP_INFO like some of the NetApp targets behave. Fixing this by validating the FCP_RSP_INFO against both the two spec allowed length. Reported-by: Frank Zhang <frank_1.zhang@intel.com> Signed-off-by: Yi Zou <yi.zou@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-22Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates from James Bottomley: "The update includes the usual assortment of driver updates (lpfc, qla2xxx, qla4xxx, bfa, bnx2fc, bnx2i, isci, fcoe, hpsa) plus a huge amount of infrastructure work in the SAS library and transport class as well as an iSCSI update. There's also a new SCSI based virtio driver." * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (177 commits) [SCSI] qla4xxx: Update driver version to 5.02.00-k15 [SCSI] qla4xxx: trivial cleanup [SCSI] qla4xxx: Fix sparse warning [SCSI] qla4xxx: Add support for multiple session per host. [SCSI] qla4xxx: Export CHAP index as sysfs attribute [SCSI] scsi_transport: Export CHAP index as sysfs attribute [SCSI] qla4xxx: Add support to display CHAP list and delete CHAP entry [SCSI] iscsi_transport: Add support to display CHAP list and delete CHAP entry [SCSI] pm8001: fix endian issue with code optimization. [SCSI] pm8001: Fix possible racing condition. [SCSI] pm8001: Fix bogus interrupt state flag issue. [SCSI] ipr: update PCI ID definitions for new adapters [SCSI] qla2xxx: handle default case in qla2x00_request_firmware() [SCSI] isci: improvements in driver unloading routine [SCSI] isci: improve phy event warnings [SCSI] isci: debug, provide state-enum-to-string conversions [SCSI] scsi_transport_sas: 'enable' phys on reset [SCSI] libsas: don't recover end devices attached to disabled phys [SCSI] libsas: fixup target_port_protocols for expanders that don't report sata [SCSI] libsas: set attached device type and target protocols for local phys ...
2012-02-25scsi: Use struct scsi_lun in fc/fcp.hAndy Grover
This allows us to use scsilun_to_int without an ugly cast. Fix up places that use scsilun_to_int on fcp->fc_lun accordingly. In fc target, this leaves ft_cmd.lun unused, so remove it. Signed-off-by: Andy Grover <agrover@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Kiran Patil <kiran.patil@intel.com> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-19[SCSI] libfc: Add support for FDMINeerav Parikh
This patch adds support for Fabric Device Management Interface as per FC-GS-4 spec. in libfc. Any driver making use of libfc can enable fdmi state machine for a given lport. If lport has enabled FDMI support the lport state machine will transition into FDMI after completing the DNS states and before entering the SCR state. The FDMI state transition is such that if there is an error, it won't stop the lport state machine from transitioning and the it will behave as if there was no FDMI support. The FDMI HBA attributes are registed with the Management server via Register HBA (RHBA) command and the port attributes are reigstered using the Register Port(RPA) command. Signed-off-by: Neerav Parikh <neerav.parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Acked-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-02-25[SCSI] fc: Add GSPN_ID request to header fileChristof Schmitt
Add request code and corresponding structs for "Get Symbolic Port Name" (GSPN_ID) request. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-28[SCSI] libfcoe: add protocol description of FIP VN2VN modeJoe Eykholt
The FC-BB-6 committee is proposing a new FIP usage model called VN_port to VN_port mode. It allows VN_ports to discover each other over a loss-free L2 Ethernet without any FCF or Fibre-channel fabric services. This is point-to-multipoint. There is also a variant of this called point-to-point which provides for making sure there is just one pair of ports operating over the Ethernet fabric. This patch defines the new message type and subtypes as well as one new descriptor type used by VN2VN mode. These are all still at the proposed stage and subject to change. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] libfc: add FLOGI state to rport for VN2VNJoe Eykholt
The FIP proposal for VN_port to VN_port point-to-multipoint operation requires a FLOGI be sent to each remote port. The FLOGI is sent with the assigned S_ID and D_IDs of the local and remote ports. This and the response get FIP-encapsulated for Ethernet. Add FLOGI state to the remote port state machine. This will be skipped if not in point-to-multipoint mode. To reduce a little duplication between PLOGI and FLOGI response handling, added fc_rport_login_complete(), which handles the parameters for the rdata struct. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] libfc: Handle unsolicited PRLO requestBhanu Prakash Gollapudi
Resubmitting after incorporating Joe's review comment. Unsolicited PRLO request is now handled by sending LS_ACC, and then relogin to the remote port if an N-port login session exists for that remote port. Note that this patch should be applied on top of Joe Eykholt's "Fix remote port restart problem" patch. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] fcoe: clean up TBD comments in FCoE prototype headerJoe Eykholt
Some old comments in fc_fcoe.h say TBD long after the standard has been passed by T11. Clean them up. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] libfc: add definition for task attribute maskJoe Eykholt
The FCP command header definition should define a mask for the task attribute field. This adds that #define. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: Add target reset flag to FCP header fileChristof Schmitt
While the target reset task management function has been deprecated in newer specs, it is still in use by SCSI FC drivers and there is no real replacement. Add the target reset flag to the FCP header file to allow usage of this definition in SCSI FC drivers. Reviewed-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: add fcoe_fc_els_lesb to fc_fcoe.h for FC-BB-5 LESB definitionsYi Zou
Add struct fcoe_fc_els_lesb as described in FC-BB-5 LESB for FCoE. It has the same size as LESB defined in FC-FS-3 (struct fc_els_lesb) but members have different meanings according to FC-BB-5. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfcoe: add checking disable flag in FIP_FKA_ADVYi Zou
When the D bit is set if the FKA_ADV_Period of the FIP Discovery Advertisement, the ENode should not transmit period ENode FIP Keep Alive and VN_Port FIP Keep Alive (FC-BB-5 Rev2, 7.8.3.13). Note that fcf->flags is taken directly from the fip_header, I am claiming one bit for the purpose of the FIP_FKA_Period D bit as FIP_FL_FK_ADV_B, and use FIP_HEADER_FLAGS as bitmask for bits used in fip_header. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: register FC4 features with the FC switchJoe Eykholt
Customers and certification tests have pointed out that we don't show up on the switch management software as an initiator. On some MDS switches 'show fcns database' command shows libfc initiators as 'fcp' not 'fcp:init' like other initiators. On others switches, I think the switch gets the features by doing a PRLI, but it may be only certain models or under certain configurations. Fix this by registering our FC4 features with the RFF_ID CT request after local port login and after the RFT_ID. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: Export FC headersRobert Love
Export fc_els.h, fc_fs.h, fc_gs.h and fc_ns.h so that they may be used by applications. This will be needed for FC Passthrough applications like fcping, but could be used by other applications. Fix to include <linux/types.h> to exported files provided by Chris Leech <christopher.leech@intel.com>. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: Register Symbolic Port Name (RSPN_ID)Chris Leech
Register the fc_host symbolic name as the symbolic port name with the fabric name server. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc: Register Symbolic Node Name (RSNN_NN)Chris Leech
Register the fc_host symbolic name as the symbolic node name with the fabric name server. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] libfc, libfcoe: FDISC ELS for NPIVChris Leech
Add FDISC ELS handling to libfc and libfcoe, treat it the same as FLOGI where appropriate. Add checking for NPIV support in the FLOGI LS_ACC service parameters. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-10[SCSI] libfc: fix: empty zone causes endless discovery retries.Joe Eykholt
On some switches, an empty zone causes GPN_FT to be rejected with reason 9 (unable) explanation 7 (FC-4 types not registered), which causes discovery to be retried endlessly. Treat this as just an empty response and consider discovery complete. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-08[SCSI] net, libfcoe: Add the FCoE Initialization Protocol ethertypeJoe Eykholt
FIP is the FCoE Initialization Protocol and this patch adds the protocol ethertype to the kernel's list of ethertypes. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] libfc: Fix compilation warnings with allmodconfigRobert Love
When building with a .config generated from 'make allmodconfig' some build warnings are generated. This patch corrects the warnings, adds a FC_FID_NONE (= 0) enumeration for FC-IDs and cleans up one variable naming to meet our variable naming conventions. For example, fc_lport's should be named "lport," not "lp." Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: Add a header file defining the FIP protocol for FCoE.Joe Eykholt
Adds include/scsi/fc/fc_fip.h for FIP protocol definitions. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] net, fcoe: add ETH_P_FCOE for Fibre Channel over Ethernet (FCoE)Yi Zou
This adds eth type ETH_P_FCOE for Fibre Channel over Ethernet (FCoE), consequently, the ETH_P_FCOE from fc_fcoe.h and fcoe skb->protocol is not set as ETH_P_FCOE. Signed-off-by: Yi Zou <yi.zou@intel.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-10[SCSI] fcoe: ETH_P_8021Q is already in if_ether and fcoe is not using it anywayYi Zou
Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-06[SCSI] libfc: rport retry on LS_RJT from certain ELSChris Leech
This allows any rport ELS to retry on LS_RJT. The rport error handling would only retry on resource allocation failures and exchange timeouts. I have a target that will occasionally reject PLOGI when we do a quick LOGO/PLOGI. When a critical ELS was rejected, libfc would fail silently leaving the rport in a dead state. The retry count and delay are managed by fc_rport_error_retry. If the retry count is exceeded fc_rport_error will be called. When retrying is not the correct course of action, fc_rport_error can be called directly. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] FC protocol definition header filesRobert Love
