path: root/include/scsi/scsi_transport_fc.h
2010-10-07[SCSI] fc class: add fc host dev loss sysfs fileMike Christie
This adds a fc host dev loss sysfs file. Instead of calling into the driver using the get_host_def_dev_loss_tmo callback, we allow drivers to init the dev loss like is done for other fc host params, and then the fc class will handle updating the value if the user writes to the new sysfs file. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] fc class: add fc host default default dev loss settingMike Christie
This patch adds a fc_host setting to store the default dev_loss_tmo. It is used if the driver has a callack to get the value from the LLD. If the callback is not set, then we use the fc class module default value. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] Allow FC LLD to fast-fail scsi eh by introducing new eh returnChristof Schmitt
If the scsi eh is running and then a FC LLD calls fc_remote_port_delete, the SCSI commands sent from the eh will fail. To prevent this, a FC LLD can call fc_block_scsi_eh from the eh callback, blocking the eh thread until the dev_loss_tmo fires or the remote port is available again. If (e.g. for a multipathing setup) the dev_loss_tmo is set to a very large value, thus preventing the scsi device removal , the scsi eh can block for a long time. For multipathing, the fast_io_fail_tmo is then set to a low value to detect path problems sooner. This patch introduces a new return code FAST_IO_FAIL. The function fc_block_scsi_eh now returns FAST_IO_FAIL when the fast_io_fail_tmo fires. This indicates that the LLD terminated all pending I/O requests and there are no more pending SCSI commands for the scsi eh to wait for. This return code can be passed back to the scsi eh to stop the escalation and finish the recovery process for this device. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] scsi_transport_fc: Introduce helper function for blocking scsi_ehChristof Schmitt
Move the duplicated code from FC LLDs to SCSI FC transport class. Acked-by: James Smart <james.smart@emulex.com> Acked-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Acked-by: Abhijeet Joglekar <abjoglek@cisco.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-12[SCSI] FC Pass Thru supportJames Smart
Attached is the ELS/CT pass-thru patch for the FC Transport. The patch creates a generic framework that lays on top of bsg and the SGIO v4 ioctl in order to pass transaction requests to LLDD's. The interface supports the following operations: On an fc_host basis: Request login to the specified N_Port_ID, creating an fc_rport. Request logout of the specified N_Port_ID, deleting an fc_rport Send ELS request to specified N_Port_ID w/o requiring a login, and wait for ELS response. Send CT request to specified N_Port_ID and wait for CT response. Login is required, but LLDD is allowed to manage login and decide whether it stays in place after the request is satisfied. Vendor-Unique request. Allows a LLDD-specific request to be passed to the LLDD, and the passing of a response back to the application. On an fc_rport basis: Send ELS request to nport and wait for ELS response. Send CT request to nport and wait for CT response. The patch also exports several headers from include/scsi such that they can be available to user-space applications: include/scsi/scsi.h include/scsi/scsi_netlink.h include/scsi/scsi_netlink_fc.h include/scsi/scsi_bsg_fc.h For further information, refer to the last RFC: http://marc.info/?l=linux-scsi&m=123436574018579&w=2 Note: Documentation is still spotty and will be added later. [bharrosh@panasas.com: update for new block API] Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-15[SCSI] fc-transport: Close state transition-window during rport deletion.Andrew Vasquez
Andrew Vasquez wrote: > fc-transport: Close state transition-window during rport deletion. > > After an rport's state has transitioned to FC_PORTSTATE_BLOCKED, > but, prior to making the upcall to 'block' the scsi-target > associated with an rport, queued commands can recycle and > ultimately run out of retries causing failures to propagate to > upper-level drivers. Close this transition-window by returning > the non-'retries' modifying DID_IMM_RETRY status for submitted > I/Os. The same can happen for iscsi when transitioning from logged in to failed and blocking the sdevs. This patch converts iscsi and fc's transitions back to use DID_IMM_RETRY instead of DID_TRANSPORT_DISRUPTED which has a limited number of retries that we do not want to use for handling this race. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> [Addition of iscsi and fc port online devloss case conversion by Mike Christie] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-06[SCSI] fc transport: restore missing dev_loss_tmo callback to LLDDJames Smart
When we reworked the transport for the rport lifetimes, in cases where the rport was reused as a container for tgt id bindings, we inadvertantly removed the callback to the driver indicating that dev_loss_tmo had fired. This patch restores that functionality. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-11-21[SCSI] fc_transport: fix old bug on bitflag definitionsJames Smart
When the fastfail flag was added, it did not account for the flags being bit fields. Correct the definition so there is no longer a conflict. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] fc class: Add support for new transport errorsMike Christie
If the target is blocked and fast io fail tmo has not fired then we requeue with DID_TRANSPORT_DISRUPTED. Once that tmo fires we fail with DID_TRANSPORT_FAILFAST. v2 - seperate from "fc class: unblock target after calling terminate callback" to make it easier to review. - Add JamesS's ack from list. v2 - initial patch Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] fc class: unblock target after calling terminate callback (take 2)Mike Christie
When we block a rport and the driver implements the terminate callback we will fail IO that was running quickly. However IO that was in the scsi_device/block queue sits there until the dev_loss_tmo fires, and this can make it look like IO is lost because new IO will get executed but that IO stuck in the blocked queue sits there for some time longer. With this patch when the fast io fail tmo fires, we will fail the blocked IO and any new IO. This patch also allows all drivers to partially support the fast io fail tmo. If the terminate io callback is not implemented, we will still fail blocked IO and any new IO, so multipath can handle that. This patch also allows the fc and iscsi classes to implement the same behavior. The timers are just unfornately named differently. This patch also fixes the problem where drivers were unblocking the target in their terminate callback, which was needed for rport removal, but for fast io fail timeout it would cause IO to bounce arround the scsi/block layer and the LLD queuecommand. And it for drivers that could have IO stuck but did not have a terminate callback the unblock calls in the class will fix them. v2. - fix up bit setting style to meet JamesS's pref. - Broke out new host byte error changes to make it easier to read. - added JamesS's ack from list. v1 - initial patch Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-03[SCSI] fc_transport: Add an API to allow an LLD to create vportsAndrew Vasquez
There's already a fc_vport_termintate() call exported by the transport. This patch adds a symmetric call to the API to allow an NPIV-capable LLD to instantiate vports sans user intervention. Additional comments/updates: Re: scsi_fc_transport.txt Add a function prototype for fc_vport_terminate similar to what's done for fc_vport_create Re: fc_vport_create I recommend we pass the channel number in fc_vport_create rather than fixing it at zero. Also, ids->vport_type should be set to FC_PORTTYPE_NPIV prior to calling fc_vport_create. The comment is also meaningless. Added-by and Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-03include/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12[SCSI] fc_transport: add target driver supportFUJITA Tomonori
This adds minimum target driver support like the srp transport does: - fc_remote_port_{rolechg,delete} calls scsi_tgt_it_nexus_{create,destroy} for target drivers. - add callbacks to notify target drivers of the nexus and tmf operation results to fc_function_template. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] scsi_transport_fc: Introduce disable_target_scan flagChristof Schmitt
This change has already been discussed on linux-scsi: http://marc.info/?t=118771096400003 http://marc.info/?t=118760913100005 Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Acked-by: James Smart <James.Smart@Emulex.Com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] fc_transport: fix sysfs deadlock on vport deleteJames Smart
When the vport attribute "delete" is used to delete the vport, sysfs deadlocks waiting for the write to complete, which is waiting for the sysfs teardown to complete. Moved this effort to a work_q element. Took the opportunity to make some other cosmetic changes: - removed tabs in Doc file - replaced with expanded spaces - minor copyright text and author text updates - removed a bunch of trailing whitespace Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-16[SCSI] FC Transport support for vports based on NPIVJames Smart
This patch provides support for FC virtual ports based on NPIV. For information on the interfaces and design, please read the Documentation/scsi/scsi_fc_transport.txt file enclosed within the patch. The RFC was originally posted here: http://marc.info/?l=linux-scsi&m=117226959918393&w=2 Changes from the initial RFC: - Bug fix: needed a transport_class_unregister() for the vport class - Create a symlink to the vport in the shost device if it is not the parent of the vport. - Made symbolic name writable so it can be set after creation - Made the temporary fc_vport_identifiers struct private to the transport. - Deleted the vport_id field from the vport. I couldn't find any good use for it (and symname is a good replacement). - Made the vport_state and vport_last_state "private" attributes. Added the fc_vport_set_state() helper function to manage state transitions - Updated vport_create() to allow a vport to be created in a disabled state. - Added INITIALIZING and FAILED vport states - Added VPCERR_xxx defines for errors to be returned from vport_create() - Created a Documentation/scsi/scsi_fc_transport.txt file that describes the interfaces and expected LLDD behaviors. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] fc_transport: update potential link speedsJames Smart
This patch updates the FC transport for all speeds identified in SM-HBA. Note: it does not sync the "bit" definitions, as that is actually insulated from user-space via the sysfs text string. (I could do it, but it does introduce a potential binary-incompatibility). Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-04[SCSI] FC transport: Add dev_loss_tmo callbacks, and new fast_io_fail_tmo w/ ↵James Smart
callback This patch adds the following functionality to the FC transport: - dev_loss_tmo LLDD callback : Called to essentially confirm the deletion of an rport. Thus, it is called whenever the dev_loss_tmo fires, or when the rport is deleted due to other circumstances (module unload, etc). It is expected that the callback will initiate the termination of any outstanding i/o on the rport. - fast_io_fail_tmo and LLD callback: There are some cases where it may take a long while to truly determine device loss, but the system is in a multipathing configuration that if the i/o was failed quickly (faster than dev_loss_tmo), it could be redirected to a different path and completed sooner. Many thanks to Mike Reed who cleaned up the initial RFC in support of this post. The original RFC is at: http://marc.theaimsgroup.com/?l=linux-scsi&m=115505981027246&w=2 Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-02[SCSI] SCSI & FC transport: extend event vendor id's to 64bitsJames Smart
During discussions with Mike Christie, I became convinced that we needed a larger vendor id. This patch extends the id from 32 to 64 bits. This applies on top of the prior patches that add SCSI transport events via netlink. Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-02[SCSI] SCSI and FC Transport: add netlink support for posting of transport ↵James Smart
events This patch formally adds support for the posting of FC events via netlink. It is a followup to the original RFC at: http://marc.theaimsgroup.com/?l=linux-scsi&m=114530667923464&w=2 and the initial posting at: http://marc.theaimsgroup.com/?l=linux-scsi&m=115507374832500&w=2 The patch has been updated to optimize the send path, per the discussions in the initial posting. Per discussions at the Storage Summit and at OLS, we are to use netlink for async events from transports. Also per discussions, to avoid a netlink protocol per transport, I've create a single NETLINK_SCSITRANSPORT protocol, which can then be used by all transports. This patch: - Creates new files scsi_netlink.c and scsi_netlink.h, which contains the single and shared definitions for the SCSI Transport. It is tied into the base SCSI subsystem intialization. Contains a single interface routine, scsi_send_transport_event(), for a transport to send an event (via multicast to a protocol specific group). - Creates a new scsi_netlink_fc.h file, which contains the FC netlink event messages - Adds 3 new routines to the fc transport: fc_get_event_number() - to get a FC event # fc_host_post_event() - to send a simple FC event (32 bits of data) fc_host_post_vendor_event() - to send a Vendor unique event, with arbitrary amounts of data. Note: the separation of event number allows for a LLD to send a standard event, followed by vendor-specific data for the event. Note: This patch assumes 2 prior fc transport patches have been installed: http://marc.theaimsgroup.com/?l=linux-scsi&m=115555807316329&w=2 http://marc.theaimsgroup.com/?l=linux-scsi&m=115581614930261&w=2 Sorry - next time I'll do something like making these individual patches of the same posting when I know they'll be posted closely together. Signed-off-by: James Smart <James.Smart@emulex.com> Tidy up configuration not to make SCSI always select NET Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] fc transport: add fc_host system_hostname attribute and u64_to_wwn()James Smart
This patch updates the fc transport for the following: - Addition of a new attribute "system_hostname" which can be used to set the fully qualified hostname that the fc_host is attached to. The fc_host can then register this string as the FDMI-based host name attribute. Note: for NPIV, a fc_host could be associated with a system which is not the local system. - Add the inline function u64_to_wwn(), which is the inverse of the existing wwn_to_u64() function. - Slight reorg, just to keep dynamic attributes with each other, etc Signed-off-by: James Smart <James.Smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] fc transport: convert fc_host symbolic_name attribute to a dynamic ↵James Smart
attribute Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-13[SCSI] FC transport: fixes for workq deadlocksJames Smart
As previously reported via Michael Reed, the FC transport took a hit in 2.6.15 (perhaps a little earlier) when we solved a recursion error. There are 2 deadlocks occurring: - With scan and the delete items sharing the same workq, flushing the workq for the delete code was getting it stalled behind a very long running scan code path. - There's a deadlock where scsi_remove_target() has to sit behind scsi_scan_target() due to contention over the scan_lock(). This patch resolves the 1st deadlock and significantly reduces the odds of the second. So far, we have only replicated the 2nd deadlock on a highly-parallel SMP system. More on the 2nd deadlock in a following email. This patch reworks the transport to: - Only use the scsi host workq for scanning - Use 2 other workq's internally. One for deletions, the other for scheduled deletions. Originally, we tried this with a single workq, but the occassional flushes of the scheduled queues was hitting the second deadlock with a slightly higher frequency. In the future, we'll look at the LLDD's and the transport to see if we can get rid of this extra overhead. - When moving to the other workq's we tightened up some object states and some lock handling. - Properly syncs adds/deletes - minor code cleanups - directly reference fc_host_attrs, rather than through attribute macros - flush the right workq on delayed work cancel failures. Large kudos to Michael Reed who has been working this issue for the last month. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fc transport: add permanent_port_name fc_host attributeAndreas Herrmann
Add fc_host attribute permanent_port_name which is used to show the port name of the primary port - the port that initially logged into the fabric. For a virtual port (registered via the primary port with FDISC command) it is useful to know not only its (virtual) port name but also the permanent port name. Signed-off-by: Andreas Herrmann <aherrman@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] fix for fc transport recursion problem.James.Smart@Emulex.Com
In the scenario that a link was broken, the devloss timer for each rport was expire at roughly the same time, causing lots of "delete" workqueue items being queued. Depth is dependent upon the number of rports that were on the link. The rport target remove calls were calling flush_scheduled_work(), which would interrupt the stream, and start the next workqueue item, which did the same thing, and so on until recursion depth was large. This fix stops the recursion in the initial delete path, and pushes it off to a host-level work item that reaps the dead rports. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-04Merge by HandJames Bottomley
Conflicts in dec_esp.c (Thanks Bacchus), scsi_transport_iscsi.c and scsi_transport_fc.h Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[SCSI] update fc_transport for removal of block/unblock functionsJames.Smart@Emulex.Com
We recently went back to implement a board reset. When we perform the reset, we wanted to tear down the internal data structures and rebuild them. Unfortunately, when it came to the rport structure, things were odd. If we deleted them, the scsi targets and sdevs would be torn down. Not a good thing for a temporary reset. We could block the rports, but we either maintain the internal structures to keep the rport reference (perhaps even replicating what's in the transport), or we have to fatten the fc transport with new search routines to find the rport (and deal with a case of a dangling rport that the driver forgets). It dawned on me that we had actually reached this state incorrectly. When the fc transport first started, we did the block/unblock first, then added the rport interface. The purpose of block/unblock is to hide the temporary disappearance of the rport (e.g. being deleted, then readded). Why are we making the driver do the block/unblock ? We should be making the transport have only an rport add/delete, and the let the transport handle the block/unblock. So... This patch removes the existing fc_remote_port_block/unblock functions. It moves the block/unblock functionality into the fc_remote_port_add/delete functions. Updates for the lpfc driver are included. Qlogic driver updates are also enclosed, thanks to the contributions of Andrew Vasquez. [Note: the qla2xxx changes are relative to the scsi-misc-2.6 tree as of this morning - which does not include the recent patches sent by Andrew]. The zfcp driver does not use the block/unblock functions. One last comment: The resulting behavior feels very clean. The LLDD is concerned only with add/delete, which corresponds to the physical disappearance. However, the fact that the scsi target and sdevs are not immediately torn down after the LLDD calls delete causes an interesting scenario... the midlayer can call the xxx_slave_alloc and xxx_queuecommand functions with a sdev that is at the location the rport used to be. The driver must validate the device exists when it first enters these functions. In thinking about it, this has always been the case for the LLDD and these routines. The existing drivers already check for existence. However, this highlights that simple validation via data structure dereferencing needs to be watched. To deal with this, a new transport function, fc_remote_port_chkready() was created that LLDDs should call when they first enter these two routines. It validates the rport state, and returns a scsi result which could be returned. In addition to solving the above, it also creates consistent behavior from the LLDD's when the block and deletes are occuring. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] Add an 'Issue LIP' device attribute in fc_transport classAndrew Vasquez
Ok, here's a patch to add such a common API for fc transport users. Relevant LLD changes (lpfc and qla2xxx) also present. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-16[SCSI] change port speed definitions for scsi_transport_fcAndreas Herrmann
obviously FC Port Speeds in scsi_transport_fc.h are defined according to FC-HBA: #define FC_PORTSPEED_1GBIT 1 #define FC_PORTSPEED_2GBIT 2 #define FC_PORTSPEED_10GBIT 4 #define FC_PORTSPEED_4GBIT 8 Problem is, whoever invented FC-HBA did not care about FC-FS or FC-GS-x. Following FC-FS/FC-GS-x defintions of port speeds would look like: 1 GBit: 0x0001 2 GBit: 0x0002 4 GBit: 0x0004 10GBit: 0x0008 (and new in FC-LS: 8 Gbit: 0x0010 16GBit: 0x0020) I really appreciate if scsi_transport_fc.h would define port speeds according to FC-GS-x/FC-FS. Thus mapping of port speed capabilities to values defined in scsi_transport_fc.h can be avoided in the LLDD. Attached is a patch to change the definitions. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-10[SCSI] fc_transport: Generalize WWN to u64 interger conversions.Andrew Vasquez
On some platforms the hard-casting of 8 byte node_name and port_name arrays to an u64 would cause unaligned-access warnings. Generalize the conversions with a transport helper function which performs consistent shifting of WWN bytes. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
