path: root/include/scsi
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] add support for variable length extended commandsBoaz Harrosh
Add support for variable-length, extended, and vendor specific CDBs to scsi-ml. It is now possible for initiators and ULD's to issue these types of commands. LLDs need not change much. All they need is to raise the .max_cmd_len to the longest command they support (see iscsi patch). - clean-up some code paths that did not expect commands to be larger than 16, and change cmd_len members' type to short as char is not enough. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29IB/iser: Count FMR alignment violations per sessionEli Dorfman
Count FMR alignment violations per session as part of the iscsi statistics. Signed-off-by: Eli Dorfman <elid@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-22[SCSI] rework scsi_target allocationJames Bottomley
The current target allocation code registeres each possible target with sysfs; it will be deleted again if no useable LUN on this target was found. This results in a string of 'target add/target remove' uevents. Based on a patch by Hannes Reinecke <hare@suse.de> this patch reworks the target allocation code so that only uevents for existing targets are sent. The sysfs registration is split off from the existing scsi_target_alloc() into a in a new scsi_add_target() function, which should be called whenever an existing target is found. Only then a uevent is sent, so we'll be generating events for existing targets only. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18[SCSI] iscsi: extended cdb supportBoaz Harrosh
Support for extended CDBs in iscsi. All we need is to check if command spills over 16 bytes then allocate an iscsi-extended-header for the leftovers. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Reviewed-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] libsas: fix missing inlines in header fileJames Bottomley
Two functions in include/scsi/sas_ata.h don't have static inlines leading to problems if they're built in: On Thu, 2008-04-03 at 14:06 +0200, Toralf Förster wrote: > drivers/scsi/mvsas.o: In function `sas_ata_init_host_and_port': > mvsas.c:(.text+0x0): multiple definition of `sas_ata_init_host_and_port' > drivers/scsi/libsas/built-in.o:(.text+0x37f4): first defined here > drivers/scsi/mvsas.o: In function `sas_ata_task_abort': > mvsas.c:(.text+0x7): multiple definition of `sas_ata_task_abort' > drivers/scsi/libsas/built-in.o:(.text+0x37fb): first defined here > make[2]: *** [drivers/scsi/built-in.o] Error 1 > make[1]: *** [drivers/scsi] Error 2 > make: *** [drivers] Error 2 Add the correct static inline modifiers. Tested-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] add scsi_build_sense_buffer helper functionFUJITA Tomonori
This adds scsi_build_sense_buffer, a simple helper function to build sense data in a buffer. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] export command allocation and freeing functions independently of the hostJames Bottomley
This is needed by things like USB storage that want to set up static commands for later use at start of day. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi: add wrapper functions for sg buffer copy helper functionsFUJITA Tomonori
LLDs need to copies data between the SG table in struct scsi_cmnd and liner buffer. So they use the helper functions like sg_copy_from_buffer(scsi_sglist(sc), scsi_sg_count(sc), buf, buflen) sg_copy_to_buffer(scsi_sglist(sc), scsi_sg_count(sc), buf, buflen) This patch just adds wrapper functions: scsi_sg_copy_from_buffer(sc, buf, buflen) scsi_sg_copy_to_buffer(sc, buf, buflen) Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] scsi_error: add target reset handlerMike Christie
The problem is that serveral drivers are sending a target reset from the device reset handler, and if we have multiple devices a target reset gets sent for each device when only one would be sufficient. And if we do a target reset it affects all the commands on the target so the device reset handler code only cleaning up one devices's commands makes programming the driver a little more difficult than it should be. This patch adds a target reset handler, which drivers can use to send a target reset. If successful it cleans up the commands for a devices accessed through that starget. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] libsas: Provide a transport-level facility to request SAS addrsDarrick J. Wong
Provide a facility to use the request_firmware() interface to get a SAS address from userspace. This can be used by SAS LLDDs that cannot obtain the address from the host adapter. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] iscsi class: regression - fix races with state manipulation and ↵Mike Christie
blocking/unblocking For qla4xxx, we could be starting a session, but some error (network, target, IO from a device that got started, etc) could cause the session to fail and curring the block/unblock and state manipulation could race with each other. This patch just has those operations done in the single threaded iscsi eh work queue, so that way they are serialized. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-23[SCSI] libsas: export sas_find_local_phy functionJames Bottomley
This is needed by the to be added I_T reset function in aic94xx. It needs to know the local phy so it can send a link or hard reset along the path. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] update SG_ALL to avoid causing chainingJames Bottomley
Since the sg chaining patches went in, our current value of 255 for SG_ALL excites chaining on some drivers which cannot support it (and would thus oops). Redefine SG_ALL to mean no sg table size preference, but use the single allocation (non chained) limit. This also helps for drivers that use it to size an internal table. We'll do an opt in system later where truly chaining supporting drivers can define their sg_tablesize to be anything up to SCSI_MAX_SG_CHAIN_ELEMENTS. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] Small cleanups for scsi_host.hPavel Machek
Small cleanups in scsi_host.h. Few #defines make me wonder if their description is still up to date..? Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] add protocol definitionsJames Bottomley
A lot of SCSI command replies have a protocol ID field. Add definitions for the interpretation of that from SPC-3. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: fix session age rollover and remove cid encodingMike Christie
The session age mask is only 4 bits, but session->age is 32. When it gets larger then 15 and we try to or the bits some bits get dropped and the check for session age in iscsi_verify_itt is useless. The ISCSI_CID_MASK related bits are also useless since cid is always one. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi: fix up iscsi printk prefixMike Christie
Some iscsi class messages have the dev_printk prefix and some libiscsi and iscsi_tcp messages have "iscsi" or the module name as a prefix which is normally pretty useless when trying to figure out which session or connection the message is attached to. This patch adds iscsi lib and class dev_printks so all messages have a common prefix that can be used to figure out which object printed it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi class: add async scan helperMike Christie
In qla4xxx's probe it will call the iscsi session setup functions for session that got setup on the initial start. This then makes it easy for the iscsi class to export a helper which indicates when those scans are done. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi class: add session scanningMike Christie
This just adds iscsi session scanning which works like fc rport scanning. The future patches will hook the drivers into Mathew Wilcox's async scanning infrastructure, so userspace does not have to special case iscsi and so userspace does not have to make a extra special case for hardware iscsi root scanning. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] iscsi class, libiscsi: add iscsi sysfs session state fileMike Christie
This adds a iscsi session state file which exports the session state for both software and hardware iscsi. It also hooks libiscsi in. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] libiscsi: make __iscsi_complete_pdu() staticAdrian Bunk
__iscsi_complete_pdu() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03include/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-30[SCSI] scsi_debug: add XDWRITEREAD_10 supportFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] bidirectional command supportBoaz Harrosh
At the block level bidi request uses req->next_rq pointer for a second bidi_read request. At Scsi-midlayer a second scsi_data_buffer structure is used for the bidi_read part. This bidi scsi_data_buffer is put on request->next_rq->special. Struct scsi_cmnd is not changed. - Define scsi_bidi_cmnd() to return true if it is a bidi request and a second sgtable was allocated. - Define scsi_in()/scsi_out() to return the in or out scsi_data_buffer from this command This API is to isolate users from the mechanics of bidi. - Define scsi_end_bidi_request() to do what scsi_end_request() does but for a bidi request. This is necessary because bidi commands are a bit tricky here. (See comments in body) - scsi_release_buffers() will also release the bidi_read scsi_data_buffer - scsi_io_completion() on bidi commands will now call scsi_end_bidi_request() and return. - The previous work done in scsi_init_io() is now done in a new scsi_init_sgtable() (which is 99% identical to old scsi_init_io()) The new scsi_init_io() will call the above twice if needed also for the bidi_read command. Only at this point is a command bidi. - In scsi_error.c at scsi_eh_prep/restore_cmnd() make sure bidi-lld is not confused by a get-sense command that looks like bidi. This is done by puting NULL at request->next_rq, and restoring. [jejb: update to sg_table and resolve conflicts also update to blk-end-request and resolve conflicts] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] implement scsi_data_bufferBoaz Harrosh
In preparation for bidi we abstract all IO members of scsi_cmnd, that will need to duplicate, into a substructure. - Group all IO members of scsi_cmnd into a scsi_data_buffer structure. - Adjust accessors to new members. - scsi_{alloc,free}_sgtable receive a scsi_data_buffer instead of scsi_cmnd. And work on it. - Adjust scsi_init_io() and scsi_release_buffers() for above change. - Fix other parts of scsi_lib/scsi.c to members migration. Use accessors where appropriate. - fix Documentation about scsi_cmnd in scsi_host.h - scsi_error.c * Changed needed members of struct scsi_eh_save. * Careful considerations in scsi_eh_prep/restore_cmnd. - sd.c and sr.c * sd and sr would adjust IO size to align on device's block size so code needs to change once we move to scsi_data_buff implementation. * Convert code to use scsi_for_each_sg * Use data accessors where appropriate. - tgt: convert libsrp to use scsi_data_buffer - isd200: This driver still bangs on scsi_cmnd IO members, so need changing [jejb: rebased on top of sg_table patches fixed up conflicts and used the synergy to eliminate use_sg and sg_count] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] tgt: use scsi_init_io instead of scsi_alloc_sgtableBoaz Harrosh
If we export scsi_init_io()/scsi_release_buffers() instead of scsi_{alloc,free}_sgtable() from scsi_lib than tgt code is much more insulated from scsi_lib changes. As a bonus it will also gain bidi capability when it comes. [jejb: rebase on to sg_table and fix up rejections] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-28SG: Convert SCSI to use scatterlist helpers for sg chainingJens Axboe
Also change scsi_alloc_sgtable() to just return 0/failure, since it maps to the command passed in. ->request_buffer is now no longer needed, once drivers are adapted to use scsi_sglist() it can be killed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-25[SCSI] libsas: abstract STP task status into a functionJames Bottomley
Break out the frame processor for STP tasks from aic94xx so they can be shared by other SAS HBA's Original patch from Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] use dynamically allocated sense bufferFUJITA Tomonori
This removes static array sense_buffer in scsi_cmnd and uses dynamically allocated sense_buffer (with GFP_DMA). The reason for doing this is that some architectures need cacheline aligned buffer for DMA: http://lkml.org/lkml/2007/11/19/2 The problems are that scsi_eh_prep_cmnd puts scsi_cmnd::sense_buffer to sglist and some LLDs directly DMA to scsi_cmnd::sense_buffer. It's necessary to DMA to scsi_cmnd::sense_buffer safely. This patch solves these issues. __scsi_get_command allocates sense_buffer via kmem_cache_alloc and attaches it to a scsi_cmnd so everything just work as before. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] scsi.h: add macro for enclosure bit of inquiry dataJames Bottomley
The macro tells us whether the device is (or contains) an enclosure device. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sd: add fix for devices with last sector access problemsHans de Goede
This patch adds a new scsi_device flag (last_sector_bug) for devices which contain a bug where the device crashes when the last sector is read in a larger then 1 sector read. This is for example the case with sdcards in the HP PSC1350 printer cardreader and in the HP PSC1610 printer cardreader. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: don't use made up error codesJames Bottomley
This is bad for two reasons: 1. If they're returned to outside applications, no-one knows what they mean. 2. Eventually they'll clash with the ever expanding standard error codes. The problem error code in question is ETASK. I've replaced this by ECOMM (communications error on send) a network error code that seems to most closely relay what ETASK meant. Acked-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: add host SMP processingJames Bottomley
This adds support for host side SMP processing, via a separate SMP interpreter file. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi: convert xmit path to iscsi chunksOlaf Kirch
Convert xmit to iscsi chunks. from michaelc@cs.wisc.edu: Bug fixes, more digest integration, sg chaining conversion and other sg wrapper changes, coding style sync up, and removal of io fields, like pdu_sent, that are not needed. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix nop handlingMike Christie
During root boot and shutdown the target could send us nops. At this time iscsid cannot be running, so the target will drop the session and the boot or shutdown will hang. To handle this and allow us to better control when to check the network this patch moves the nop handling to the kernel. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix shutdownMike Christie
We were using the device delete sysfs file to remove each device then logout. Now in 2.6.21 this will not work because the sysfs delete file returns immediately and does not wait for the device removal to complete. This causes a hang if a cache sync is needed during shutdown. Before .21, that approach had other problems, so this patch fixes the shutdown code so that we remove the target and unbind the session before logging out and shut down the session Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: do not block session during logoutMike Christie
There is not need to block the session during logout. Since we are going to fail the commands that were blocked just fail them immediately instead. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi, iscsi_tcp: iscsi pool cleanupOlaf Kirch
iscsi_pool_init simplified iscsi_pool_init currently has a lot of duplicate kfree() calls it does when some allocation fails. This patch simplifies the code a little by using iscsi_pool_free to tear down the pool in case of an error. iscsi_pool_init also returns a copy of the item array to the caller. Not all callers use this array, so we make it optional. Instead of allocating a second array and return that, allocate just one array, of twice the size. Update users of iscsi_pool_{init,free} This patch drops the (now useless) second argument to iscsi_pool_free, and updates all callers. It also removes the ctask->r2ts array, which was never used anyway. Since the items argument to iscsi_pool_init is now optional, we can pass NULL instead. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi_tcp, libiscsi: initial AHS SupportBoaz Harrosh
at libiscsi generic code - currently code assumes a storage space of pdu header is allocated at llds ctask and is pointed to by iscsi_cmd_task->hdr. Here I add a hdr_max field pertaining to that storage, and an hdr_len that accumulates the current use of the pdu-header. - Add an iscsi_next_hdr() inline which returns the next free space to write new Header at. Also iscsi_next_hdr() is used to retrieve the address at which to write the header-digest. - Add iscsi_add_hdr(length). What the user do is calls iscsi_next_hdr() for address of the new header, than calls iscsi_add_hdr(length) with the size of the new header. iscsi_add_hdr() will check if space is available and update to the new size. length must be padded according to standard. - Add 2 padding inline helpers thanks to Olaf. Current patch does not use them but Following patches will. Also moved definition of ISCSI_PAD_LEN to iscsi_proto.h which had PAD_WORD_LEN that was never used anywhere. - Let iscsi_prep_scsi_cmd_pdu() signal an Error return since now it is possible that it will fail. - I was tired of yet again writing a "this is a digest" comment next to sizeof(__u32) so I defined a new ISCSI_DIGEST_SIZE. Now I don't need any comments. Changed all places that used sizeof(__u32) or "4" in connection to a digest. iscsi_tcp specific code - At struct iscsi_tcp_cmd_task allocate maximum space allowed in standard for all headers following the iscsi_cmd header. and mark it so in iscsi_tcp_session_create() - At iscsi_send_cmd_hdr() retrieve the correct headers size and write header digest at iscsi_next_hdr(). Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] iscsi_tcp: rewrite recv pathOlaf Kirch
Rewrite recv path. Fixes: - data digest processing and error handling. - ahs support. Some fixups by Mike Christie Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi, iscsi_tcp: add device supportMike Christie
This patch adds logical unit reset support. This should work for ib_iser, but I have not finished testing that driver so it is not hooked in yet. This patch also temporarily reverts the iscsi_tcp r2t write out patch. That code is completely rewritten in this patchset. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sd,sr: add early detection of medium not presentJames Bottomley
The current scsi_test_unit_ready() is updated to return sense code information (in struct scsi_sense_hdr). The sd and sr drivers are changed to interpret the sense code return asc 0x3a as no media and adjust the device status accordingly. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] move single_lun flag from scsi_device to scsi_targetTony Battersby
Some SCSI tape medium changers that need the BLIST_SINGLELUN flag have the medium changer at one LUN and the tape drive at a different LUN. The inquiry string of the tape drive may be different from that of the medium changer. In order for single_lun to be effective, every scsi_device under a given scsi_target must have it set. This means that there needs to be a blacklist entry for BOTH the medium changer AND the tape drive, which is impractical because some medium changers may be paired with a variety of different tape drive models. It makes more sense to put the single_lun flag in scsi_target instead of scsi_device, which causes every device at a given target ID to inherit the single_lun flag from one LUN. This makes it possible to blacklist just the medium changer and not the tape drive. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libsas: Fix various sparse complaintsDarrick J. Wong
Annotate sas_queuecommand with locking details, and clean up a few more sparse warnings about static/non-static declarations. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
