path: root/include/scsi
2012-04-15SCSI: Fix error handling when no ULD is attachedMartin K. Petersen
Commit 18a4d0a22ed6 ("[SCSI] Handle disk devices which can not process medium access commands") introduced a bug in which we would attempt to dereference the scsi driver even when the device had no ULD attached. Ensure that a driver is registered and make the driver accessor function more resilient to errors during device discovery. Reported-by: Elric Fu <elricfu1@gmail.com> Reported-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 Pull SCSI updates from James Bottomley: "This is primarily another round of driver updates (lpfc, bfa, fcoe, ipr) plus a new ufshcd driver. There shouldn't be anything controversial in here (The final deletion of scsi proc_ops which caused some build breakage has been held over until the next merge window to give us more time to stabilise it). I'm afraid, with me moving continents at exactly the wrong time, anything submitted after the merge window opened has been held over to the next merge window." * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (63 commits) [SCSI] ipr: Driver version 2.5.3 [SCSI] ipr: Increase alignment boundary of command blocks [SCSI] ipr: Increase max concurrent oustanding commands [SCSI] ipr: Remove unnecessary memory barriers [SCSI] ipr: Remove unnecessary interrupt clearing on new adapters [SCSI] ipr: Fix target id allocation re-use problem [SCSI] atp870u, mpt2sas, qla4xxx use pci_dev->revision [SCSI] fcoe: Drop the rtnl_mutex before calling fcoe_ctlr_link_up [SCSI] bfa: Update the driver version to 3.0.23.0 [SCSI] bfa: BSG and User interface fixes. [SCSI] bfa: Fix to avoid vport delete hang on request queue full scenario. [SCSI] bfa: Move service parameter programming logic into firmware. [SCSI] bfa: Revised Fabric Assigned Address(FAA) feature implementation. [SCSI] bfa: Flash controller IOC pll init fixes. [SCSI] bfa: Serialize the IOC hw semaphore unlock logic. [SCSI] bfa: Modify ISR to process pending completions [SCSI] bfa: Add fc host issue lip support [SCSI] mpt2sas: remove extraneous sas_log_info messages [SCSI] libfc: fcoe_transport_create fails in single-CPU environment [SCSI] fcoe: reduce contention for fcoe_rx_list lock [v2] ...
2012-03-28[SCSI] libfcoe: Support extra MAC descriptor to be used as FCoE MACBhanu Prakash Gollapudi
Some switch implementations (eg., HP virtual connect FlexFabric) send two MAC descriptors in FIP FLOGI response, with first MAC descriptor (granted_mac) used as FPMA, and the second one (fcoe_mac) used as destination address for sending/receiving FCoE packets. fip_mac continues to be used for FIP traffic. This patch introduces fcoe_mac in fcoe_fcf structure. For regular switches, both fcoe_mac and fip_mac will be the same. For the switches that send additional MAC descriptor, fcoe_mac is updated. Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-27[SCSI] qla4xxx: Removed packed attr from struct iscsi_chap_recVikas Chaudhary
We don't need to pack 'struct iscsi_chap_rec' as buffer is built locally in the driver and pass to the user-space. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-27[SCSI] iscsi_transport: Added error status code for ping comp eventVikas Chaudhary
Defined error codes for ping completion status. This patch take care of Mike Christie's commets Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-24Merge tag 'bug-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/bug.h> cleanup from Paul Gortmaker: "The changes shown here are to unify linux's BUG support under the one <linux/bug.h> file. Due to historical reasons, we have some BUG code in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in linux/kernel.h predates the addition of linux/bug.h, but old code in kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h was including <asm/bug.h> to pseudo link them. This has caused confusion[1] and general yuck/WTF[2] reactions. Here is an example that violates the principle of least surprise: CC lib/string.o lib/string.c: In function 'strlcat': lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON' make[2]: *** [lib/string.o] Error 1 $ $ grep linux/bug.h lib/string.c #include <linux/bug.h> $ We've included <linux/bug.h> for the BUG infrastructure and yet we still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh - very confusing for someone who is new to kernel development. With the above in mind, the goals of this changeset are: 1) find and fix any include/*.h files that were relying on the implicit presence of BUG code. 2) find and fix any C files that were consuming kernel.h and hence relying on implicitly getting some/all BUG code. 3) Move the BUG related code living in kernel.h to <linux/bug.h> 4) remove the asm/bug.h from kernel.h to finally break the chain. During development, the order was more like 3-4, build-test, 1-2. But to ensure that git history for bisect doesn't get needless build failures introduced, the commits have been reorderd to fix the problem areas in advance. [1] https://lkml.org/lkml/2012/1/3/90 [2] https://lkml.org/lkml/2012/1/17/414" Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul and linux-next. * tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: kernel.h: doesn't explicitly use bug.h, so don't include it. bug: consolidate BUILD_BUG_ON with other bug code BUG: headers with BUG/BUG_ON etc. need linux/bug.h bug.h: add include of it to various implicit C users lib: fix implicit users of kernel.h for TAINT_WARN spinlock: macroize assert_spin_locked to avoid bug.h dependency x86: relocate get/set debugreg fcns to include/asm/debugreg.
2012-03-23headers: include linux/types.h where appropriateBobby Powers
This addresses some header check warnings. DRM headers which include "drm.h" have been excluded, as they indirectly include types.h. Signed-off-by: Bobby Powers <bobbypowers@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: Dave Airlie <airlied@linux.ie> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates from James Bottomley: "The update includes the usual assortment of driver updates (lpfc, qla2xxx, qla4xxx, bfa, bnx2fc, bnx2i, isci, fcoe, hpsa) plus a huge amount of infrastructure work in the SAS library and transport class as well as an iSCSI update. There's also a new SCSI based virtio driver." * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (177 commits) [SCSI] qla4xxx: Update driver version to 5.02.00-k15 [SCSI] qla4xxx: trivial cleanup [SCSI] qla4xxx: Fix sparse warning [SCSI] qla4xxx: Add support for multiple session per host. [SCSI] qla4xxx: Export CHAP index as sysfs attribute [SCSI] scsi_transport: Export CHAP index as sysfs attribute [SCSI] qla4xxx: Add support to display CHAP list and delete CHAP entry [SCSI] iscsi_transport: Add support to display CHAP list and delete CHAP entry [SCSI] pm8001: fix endian issue with code optimization. [SCSI] pm8001: Fix possible racing condition. [SCSI] pm8001: Fix bogus interrupt state flag issue. [SCSI] ipr: update PCI ID definitions for new adapters [SCSI] qla2xxx: handle default case in qla2x00_request_firmware() [SCSI] isci: improvements in driver unloading routine [SCSI] isci: improve phy event warnings [SCSI] isci: debug, provide state-enum-to-string conversions [SCSI] scsi_transport_sas: 'enable' phys on reset [SCSI] libsas: don't recover end devices attached to disabled phys [SCSI] libsas: fixup target_port_protocols for expanders that don't report sata [SCSI] libsas: set attached device type and target protocols for local phys ...
2012-03-22Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "This contains the usual set of updates and bugfixes to target-core + existing fabric module code, along with a handful of the patches destined for v3.3 stable. It also contains the necessary target-core infrastructure pieces required to run using tcm_qla2xxx.ko WWPNs with the new Qlogic Fibre Channel fabric module currently queued in target-pending/for-next-merge, and coming for round 2. The highlights for this series include: - Add target_submit_tmr() helper function for fabric task management (andy) - Convert tcm_fc to use target_submit_tmr() (andy) - Replace target core various cmd flags with a transport state (hch) - Convert loopback to use workqueue submission (hch) - Convert target core to use array_zalloc for tpg_lun_list (joern) - Convert target core to use array_zalloc for device_list (joern) - Add target core support for TMR_ABORT_TASK (nab) - Add target core se_sess->sess_kref + get/put helpers (nab) - Add target core se_node_acl->acl_kref for ->acl_free_comp usage (nab) - Convert iscsi-target to use target_put_session + sess_kref (nab) - Fix tcm_fc fc_exch memory leak in ft_send_resp_status (nab) - Fix ib_srpt srpt_handle_cmd send_ioctx->ioctx_kref leak on exception (nab) - Fix target core up handling of short INQUIRY buffers (roland) - Untangle target-core front-end and back-end meanings of max_sectors attribute (roland) - Set loopback residual field for SCSI commands (roland) - Fix target-core 16-bit target ports for SET TARGET PORT GROUPS emulation (roland) Thanks again to Andy, Christoph, Joern, Roland, and everyone who has contributed this round!" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (64 commits) ib_srpt: Fix srpt_handle_cmd send_ioctx->ioctx_kref leak on exception loopback: Fix transport_generic_allocate_tasks error handling iscsi-target: remove improper externs iscsi-target: Remove unused variables in iscsi_target_parameters.c target: remove obvious warnings target: Use array_zalloc for device_list target: Use array_zalloc for tpg_lun_list target: Fix sense code for unsupported SERVICE ACTION IN target: Remove hack to make READ CAPACITY(10) lie if thin provisioning is enabled target: Bump core version to v4.1.0-rc2-ml + fabric versions tcm_fc: Fix fc_exch memory leak in ft_send_resp_status target: Drop unused legacy target_core_fabric_ops API callers iscsi-target: Convert to use target_put_session + sess_kref target: Convert se_node_acl->acl_group removal to use ->acl_kref target: Add se_node_acl->acl_kref for ->acl_free_comp usage target: Add se_node_acl->acl_free_comp for NodeACL release path target: Add se_sess->sess_kref + get/put helpers target: Convert session_lock to irqsave target: Fix typo in drivers/target iscsi-target: Fix dynamic -> explict NodeACL pointer reference ...
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-29[SCSI] scsi_transport: Export CHAP index as sysfs attributeMike Christie
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] iscsi_transport: Add support to display CHAP list and delete CHAP entryNilesh Javali
For offload iSCSI like qla4xxx CHAP entries are stored in FLASH. This patch adds support to list CHAP entries stored in FLASH and delete specified CHAP entry from FLASH using iscsi tools. Signed-off-by: Nilesh Javali <nilesh.javali@qlogic.com> Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: revert ata srstDan Williams
libata issues follow up srsts when the controller has a hard time recording the signature-fis after a reset, or if the link supports port multipliers. libsas does not support port multipliers and no current libsas lldds appear to need help retrieving the signature fis. Revert it for now to remove confusion. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: async ata scanningDan Williams
libsas ata error handling is already async but this does not help the scan case. Move initial link recovery out from under host->scan_mutex, and delay synchronization with eh until after all port probe/recovery work has been queued. Device ordering is maintained with scan order by still calling sas_rphy_add() in order of domain discovery. Since we now scan the domain list when invoking libata-eh we need to be careful to check for fully initialized ata ports. Acked-by: Jack Wang <jack_wang@usish.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: restore scan orderDan Williams
ata devices are always scanned after ssp. Prior to the ata error handling reworks libsas would tend to scan devices in ascending expander phy order. Restore this ordering by deferring ssp discovery to a DISCE_PROBE event, and keep the probe order consistent with the discovery order, not the placement of sata devices. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: let libata recover links that fail to transmit initial sig-fisDan Williams
libsas fails to discover all sata devices in the domain. If a device fails negotiation and does not transmit a signature fis the link needs recovery. libata already understands how to manage slow to come up links, so treat these conditions as ata device attach events for the purposes of creating an ata_port. This allows libata to manage retrying link bring up. Rediscovery is modified to be careful about checking changes in dev_type. It looks like libsas leaks old devices if the sas address changes, but that's a fix for another patch. Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: fix mixed topology recoveryDan Williams
If we have a domain with sas and sata devices there may still be sas recovery actions to take after peeling off the commands to send to libata. Reported-by: Andrzej Jakowski <andrzej.jakowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: mark all domain devices gone if root port disappearsDan Williams
If the top level expander is hot removed, mark all child devices as gone before unregistration to short circuit futile recovery. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: fix sas_find_local_phy(), take phy referencesDan Williams
In the direct-attached case this routine returns the phy on which this device was first discovered. Which is broken if we want to support wide-targets, as this phy reference can become stale even though the port is still active. In the expander-attached case this routine tries to lookup the phy by scanning the attached sas addresses of the parent expander, and BUG_ONs if it can't find it. However since eh and the libsas workqueue run independently we can still be attempting device recovery via eh after libsas has recorded the device as detached. This is even easier to hit now that eh is blocked while device domain rediscovery takes place, and that libata is fed more timed out commands increasing the chances that it will try to recover the ata device. Arrange for dev->phy to always point to a last known good phy, it may be stale after the port is torn down, but it will catch up for wide port reconfigurations, and never be NULL. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: poll for ata device readiness after resetDan Williams
Use ata_wait_after_reset() to poll for link recovery after a reset. This combined with sas_ha->eh_mutex prevents expander rediscovery from probing phys in an intermediate state. Local discovery does not have a mechanism to filter link status changes during this timeout, so it remains the responsibility of lldds to prevent premature port teardown. Although once all lldd's support ->lldd_ata_check_ready() that could be used as a gate to local port teardown. The signature fis is re-transmitted when the link comes back so we should be revalidating the ata device class, but that is left to a future patch. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-25scsi: Use struct scsi_lun in fc/fcp.hAndy Grover
This allows us to use scsilun_to_int without an ugly cast. Fix up places that use scsilun_to_int on fcp->fc_lun accordingly. In fc target, this leaves ft_cmd.lun unused, so remove it. Signed-off-by: Andy Grover <agrover@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Kiran Patil <kiran.patil@intel.com> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-25scsi: update scsi.h with SYNCHRONIZE_CACHE_16Andy Grover
It's in SBC-3. Signed-off-by: Andy Grover <agrover@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-19[SCSI] libsas: add mutex for SMP task executionJeff Skirvin
SAS does not tag SMP requests, and at least one lldd (isci) does not permit more than one in-flight request at a time. [jejb: fix sas_init_dev tab issues while we're at it] Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: sas_phy_enable via transport_sas_phy_resetDan Williams
Execute the link-reset triggered by sas_phy_enable via transport_sas_phy_reset so that it can be managed by libata. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: execute transport link resets with libata-eh via host workqueueDan Williams
Link resets leave ata affiliations intact, so arrange for libsas to make an effort to avoid dropping the device due to a slow-to-recover link. Towards this end carry out reset in the host workqueue so that it can check for ata devices and kick the reset request to libata. Hard resets, in contrast, bypass libata since they are meant for associating an ata device with another initiator in the domain (tears down affiliations). Need to add a new transport_sas_phy_reset() since the current sas_phy_reset() is a utility function to libsas lldds. They are not prepared for it to loop back into eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: perform sas-transport resets in shost->workq contextDan Williams
Extend the sas transport class to allow transport users to attach extra data to a sas_phy (->hostdata). Use this area in libsas to move resets to workq context in preparation for scheduling ata device resets through libata-eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: use libata-eh-reset for sata rediscovery fis transmit failuresDan Williams
Since sata devices can take several seconds to recover the link on reset the 0.5 seconds that libsas currently waits may not be enough. Instead if we are rediscovering a phy that was previously attached to a sata device let libata handle any resets to encourage the device to transmit the initial fis. Once sas_ata_hard_reset() and lldds learn how to honor 'deadline' libsas should stop encountering phys in an intermediate state, until then this will loop until the fis is transmitted or ->attached_sas_addr gets cleared, but in the more likely initial discovery case we keep existing behavior. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: let libata handle command timeoutsDan Williams
libsas-eh if it successfully aborts an ata command will hide the timeout condition (AC_ERR_TIMEOUT) from libata. The command likely completes with the all-zero task->task_status it started with. Instead, interpret a TMF_RESP_FUNC_COMPLETE as the end of the sas_task but keep the scmd around for libata-eh to handle. Tested-by: Andrzej Jakowski <andrzej.jakowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: fix timeout vs completion raceDan Williams
Until we have told the lldd to forget a task a timed out operation can return from the hardware at any time. Since completion frees the task we need to make sure that no tasks run their normal completion handler once eh has decided to manage the task. Similar to ata_scsi_cmd_error_handler() freeze completions to let eh judge the outcome of the race. Task collector mode is problematic because it presents a situation where a task can be timed out and aborted before the lldd has even seen it. For this case we need to guarantee that a task that an lldd has been told to forget does not get queued after the lldd says "never seen it". With sas_scsi_timed_out we achieve this with the ->task_queue_flush mutex, rather than adding more time. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: prevent double completion of scmds from ehDan Williams
We invoke task->task_done() to free the task in the eh case, but at this point we are prepared for scsi_eh_flush_done_q() to finish off the scmd. Introduce sas_end_task() to capture the final response status from the lldd and free the task. Also take the opportunity to kill this warning. drivers/scsi/libsas/sas_scsi_host.c: In function ‘sas_end_task’: drivers/scsi/libsas/sas_scsi_host.c:102:3: warning: case value ‘2’ not in enumerated type ‘enum exec_status’ [-Wswitch] Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: close error handling vs sas_ata_task_done() raceDan Williams
Since sas_ata does not implement ->freeze(), completions for scmds and internal commands can still arrive concurrent with ata_scsi_cmd_error_handler() and sas_ata_post_internal() respectively. By the time either of those is called libata has committed to completing the qc, and the ATA_PFLAG_FROZEN flag tells sas_ata_task_done() it has lost the race. In the sas_ata_post_internal() case we take on the additional responsibility of freeing the sas_task to close the race with sas_ata_task_done() freeing the the task while sas_ata_post_internal() is in the process of invoking ->lldd_abort_task(). Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: use ->set_dmamode to notify lldds of NCQ parametersDan Williams
sas_discover_sata() notifies lldds of sata devices twice. Once to allow the 'identify' to be sent, and a second time to allow aic94xx (the only libsas driver that cares about sata_dev.identify) to setup NCQ parameters before the device becomes known to the midlayer. Replace this double notification and intervening 'identify' with an explicit ->lldd_ata_set_dmamode notification. With this change all ata internal commands are issued by libata, so we no longer need sas_issue_ata_cmd(). The data from the identify command only needs to be cached in one location so ata_device.id replaces domain_device.sata_dev.identify. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: prevent domain rediscovery competing with ata error handlingDan Williams
libata error handling provides for a timeout for link recovery. libsas must not rescan for previously known devices in this interval otherwise it may remove a device that is simply waiting for its link to recover. Let libata-eh make the determination of when the link is stable and prevent libsas (host workqueue) from taking action while this determination is pending. Using a mutex (ha->disco_mutex) to flush and disable revalidation while eh is running requires any discovery action that may block on eh be moved to its own context outside the lock. Probing ATA devices explicitly waits on ata-eh and the cache-flush-io issued during device removal may also pend awaiting eh completion. Essentially any rphy add/remove activity needs to run outside the lock. This adds two new cleanup states for sas_unregister_domain_devices() 'allocated-but-not-probed', and 'flagged-for-destruction'. In the 'allocated-but-not-probed' state dev->rphy points to a rphy that is known to have not been through a sas_rphy_add() event. At domain teardown check if this device is still pending probe and cleanup accordingly. Similarly if a device has already been queued for removal then sas_unregister_domain_devices has nothing to do. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: convert dev->gone to flagsDan Williams
In preparation for adding tracking of another device state "destroy". Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: introduce sas_drain_work()Dan Williams
When an lldd invokes ->notify_port_event() it can trigger a chain of libsas events to: 1/ form the port and find the direct attached device 2/ if the attached device is an expander perform domain discovery A call to flush_workqueue() will only flush the initial port formation work. Currently libsas users need to call scsi_flush_work() up to the max depth of chain (which will grow from 2 to 3 when ata discovery is moved to its own discovery event). Instead of open coding multiple calls switch to use drain_workqueue() to flush sas work. drain_workqueue() does not handle new work submitted during the drain so libsas needs a bit of infrastructure to hold off unchained work submissions while a drain is in flight. A lldd ->notify() event is considered 'unchained' while a sas_discover_event() is 'chained'. As Tejun notes: "For now, I think it would be best to add private wrapper in libsas to support deferring unchained work items while draining." Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: convert ha->state to flagsDan Williams
In preparation for adding new states (SAS_HA_DRAINING, SAS_HA_FROZEN), convert ha->state into a set of flags. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: replace event locks with atomic bitopsDan Williams
The locks only served to make sure the pending event bitmask was updated consistently. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: fix leak of dev->sata_dev.identify_[packet_]deviceDan Williams
These are never freed in the nominal path. A domain_device has a different lifetime than a sas_rphy we need a dev->rphy independent way of identifying sata devices. Reviewed-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: fix domain_device leakDan Williams
Arrange for the deallocation of a struct domain_device object when it no longer has: 1/ any children 2/ references by any scsi_targets 3/ references by a lldd The comment about domain_device lifetime in Documentation/scsi/libsas.txt is stale as it appears mainline never had a version of a struct domain_device that was registered as a kobject. We now manage domain_device reference counts on behalf of external agents. Reviewed-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: kill sas_slave_destroyDan Williams
Per commit 3e4ec344 "libata: kill ATA_FLAG_DISABLED" needing to set ATA_DEV_NONE is a holdover from before libsas converted to the "new-style" ata-eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: remove unused ata_task_resp fieldsDan Williams
Commit 1e34c838 "[SCSI] libsas: remove spurious sata control register read/write" removed the routines to fake the presence of the sata control registers, now remove the unused data structure fields to kill any remaining confusion. Acked-by: Jack Wang <jack_wang@usish.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] Handle disk devices which can not process medium access commandsMartin K. Petersen
We have experienced several devices which fail in a fashion we do not currently handle gracefully in SCSI. After a failure these devices will respond to the SCSI primary command set (INQUIRY, TEST UNIT READY, etc.) but any command accessing the storage medium will time out. The following patch adds an callback that can be used by upper level drivers to inspect the results of an error handling command. This in turn has been used to implement additional checking in the SCSI disk driver. If a medium access command fails twice but TEST UNIT READY succeeds both times in the subsequent error handling we will offline the device. The maximum number of failed commands required to take a device offline can be tweaked in sysfs. Also add a new error flag to scsi_debug which allows this scenario to be easily reproduced. [jejb: fix up integer parsing to use kstrtouint] Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] iscsi_transport: Added Ping supportVikas Chaudhary
Added ping support for iscsi adapter, application can use this interface for diagnostic network connection. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] scsi_transport_iscsi: added support for host eventVikas Chaudhary
Added support to post kernel host event to application using netlink interface. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libiscsi_tcp: fix max_r2t manipulationMike Christie
Problem description from Xi Wang: A large max_r2t could lead to integer overflow in subsequent call to iscsi_tcp_r2tpool_alloc(), allocating a smaller buffer than expected and leading to out-of-bounds write. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] Correctly set the scsi host/msg/status bytesMoger, Babu
Resubmitting as my previous post had format issues and did not go llinux-scsi. This patch changes the function to set_msg_byte, set_host_byte and set_driver_byte to correctly set the corresponding bytes appropriately. It will reset the original setting and correctly set it to the new value. The previous OR operation does not always set it back to new value. Look at patch 2/2 for an example. Signed-off-by: Babu Moger <babu.moger@netapp.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libfc: Add support for FDMINeerav Parikh
This patch adds support for Fabric Device Management Interface as per FC-GS-4 spec. in libfc. Any driver making use of libfc can enable fdmi state machine for a given lport. If lport has enabled FDMI support the lport state machine will transition into FDMI after completing the DNS states and before entering the SCR state. The FDMI state transition is such that if there is an error, it won't stop the lport state machine from transitioning and the it will behave as if there was no FDMI support. The FDMI HBA attributes are registed with the Management server via Register HBA (RHBA) command and the port attributes are reigstered using the Register Port(RPA) command. Signed-off-by: Neerav Parikh <neerav.parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Acked-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libfc: Make the libfc Common Transport(CT) code genericNeerav Parikh
Currently the libfc Common Transport(CT) calls assume that the CT requests are Name Server specific only. This patch makes it more flexible to allow more FC-GS services to make use of these routines. Signed-off-by: Neerav Parikh <neerav.parikh@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Acked-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
