[ Upstream commit f3205de98db2fc8083796dd5ad81b191e436fab8 ]
As of today we use hardcoded MCIP debug mask, so if we launch
kernel via debugger and kick fever cores than HW has all cpus
hang at the momemt of setup MCIP debug mask.
So update MCIP debug mask when the new cpu came online, instead of
use hardcoded MCIP debug mask.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[ Upstream commit 07423d00a2b2a71a97e4287d9262cb83c4c4c89f ]
In SMP systems, GFRC is used for clocksource. However by default the
counter keeps running even when core is halted (say when debugging via a
JTAG debugger). This confuses Linux timekeeping and triggers flase RCU stall
splat such as below:
| [ARCLinux]# while true; do ./shm_open_23-1.run-test ; done
| Running with 1000 processes for 1000 objects
| hrtimer: interrupt took 485060 ns
| create_cnt: 1000
| [ARCLinux]# INFO: rcu_preempt self-detected stall on CPU
| 2-...: (1 GPs behind) idle=a01/1/0 softirq=135770/135773 fqs=0
| INFO: rcu_preempt detected stalls on CPUs/tasks:
| 0-...: (1 GPs behind) idle=71e/0/0 softirq=135264/135264 fqs=0
| 3-...: (1 GPs behind) idle=4e0/0/0 softirq=134304/134304 fqs=0
| (detected by 1, t=13648 jiffies, g=31493, c=31492, q=1)
Starting from ARC HS v3.0 it's possible to tie GFRC to state of up-to 4
ARC cores with help of GFRC's CORE register where we set a mask for
cores which state we need to rely on.
We update cpu mask every time new cpu came online instead of using
hardcoded one or using mask generated from "possible_cpus" as we
want it set correctly even if we run kernel on HW which has fewer cores
than expected (or we launch kernel via debugger and kick fever cores
than HW has)
Note that GFRC halts when all cores have halted and thus relies on
programming of Inter-Core-dEbug register to halt all cores when one
halts.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
[vgupta: rewrote changelog]
This enhancement is needed to allow masking all available common interrupts
in IDU interrupt controller in boot time since the kernel can
discover a number of them from the build register. Also now there
is no need to specify in device tree a list of used core interrupts
by IDU. E.g. before:
idu_intc: idu-interrupt-controller {
compatible = "snps,archs-idu-intc";
interrupt-controller;
interrupt-parent = <&core_intc>;
#interrupt-cells = <2>;
interrupts = <24 25 26 27 28 29 30 31>;
and after:
Signed-off-by: Yuriy Kolerov <yuriy.kolerov@synopsys.com>
... which allows for use in drivers/clocksource later
Also remove the dependency on ARCv2, to increase compile coverage for
!ARCV2 builds
Acked-by: Daniel Lezcano <daniel.lezcnao@linaro.org>
ARC timers use aux registers for programming and this paves way for
moving ARC timer drivers into drivers/clocksource
