path: root/include/sound/ak4114.h
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-11[ALSA] Fix misc bugs in i2c/others/ak4114.cPavel Hofman
* correct register for 'IEC958 Non-PCM Bitstream', 'IEC958 DTS Bitstream' to use AK4114_REG_RCS0 * correct check for control name: if (strstr(kctl->id.name, 'Playback')) * correct check: if (!chip->init) in snd_ak4114_external_rate * added PCM control 'IEC958 PPL Lock Status' Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] ak4114 - Fix a typo in DIF2 bit definitionTakashi Iwai
Fixed a typo in AK4114_DIF2 bit definition. This may fix some problems for Audiophile 192 and Juli boards. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add some more 'const', but needs changes in i2c/other/ak4*Takashi Iwai
Make data passed to ak4xxx_create 'const'. Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ak4114 - Use global workqueueTakashi Iwai
Use global workqueue for simplicity instead of own workqueue. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-01-03[ALSA] Remove xxx_t typedefs: I2C driversTakashi Iwai
Modules: AK4114 receiver,AK4117 receiver,AK4XXX AD/DA converters [Missing files in last commit] Remove xxx_t typedefs from the i2c drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
