path: root/include/sound/asound.h
2012-10-09UAPI: (Scripted) Disintegrate include/soundDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-12ALSA: Define more channel map positionsTakashi Iwai
For following the standard, define more channel map positions and shuffle the items a bit: - As both PulseAudio and gstreamer define MONO channel position explicitly, we should follow that, too. The mono streams point to this channel position unless they are explicitly assigned to certain channel positions. - Top-front-* and Top-rear-* positions are added, carried from PulseAudio's definitions. - Move NA and MONO definitions at the top of table right after UNKNOWN, since these are more abstract in comparison with other practical positions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-06ALSA: Follow channel position definitions to alsa-lib mixerTakashi Iwai
There is already a set of channel position definitions in alsa-lib mixer.h, and it'd be more practical to keep the same order for the PCM channel map, too. The value is shifted with 1 to keep zero for UNKNOWN. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-06ALSA: PCM: channel mapping API implementationTakashi Iwai
This patch implements the basic data types for the standard channel mapping API handling. - The definitions of the channel positions and the new TLV types are added in sound/asound.h and sound/tlv.h, so that they can be referred from user-space. - Introduced a new helper function snd_pcm_add_chmap_ctls() to create control elements representing the channel maps for each PCM (sub)stream. - Some standard pre-defined channel maps are provided for convenience. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-18ALSA: Add definitions for CEA-861 Audio InfoFramesRicardo Neri
Along with the IEC-60958 channel status word, CEA-861 Audio InfoFrames are used in HDMI and DisplayPort to describe the parameters of the audio stream. Hence, drivers for such devices may use these definitions to, for instance, fill a CEA-861 data structure and pass it to a display driver to configure an IP. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-09ALSA: control: add support for ENUMERATED user space controlsClemens Ladisch
Handling of user control elements was implemented for all types except ENUMERATED. This type will be needed for the device-specific mixers of upcoming FireWire drivers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: pcm: support for period wakeup disablingClemens Ladisch
This patch allows to disable period interrupts which are not needed when the application relies on a system timer to wake-up and refill the ring buffer. The behavior of the driver is left unchanged, and interrupts are only disabled if the application requests this configuration. The behavior in case of underruns is slightly different, instead of being detected during the period interrupts the underruns are detected when the application calls snd_pcm_update_avail, which in turns forces a refresh of the hw pointer and shows the buffer is empty. More specifically this patch makes a lot of sense when PulseAudio relies on timer-based scheduling to access audio devices such as HDAudio or Intel SST. Disabling interrupts removes two unwanted wake-ups due to period elapsed events in low-power playback modes. It also simplifies PulseAudio voice modules used for speech calls. To quote Lennart "This patch looks very interesting and desirable. This is something have long been waiting for." Support for this in hardware drivers is optional. Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@intel.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: pcm: Define G723 3-bit and 5-bit formatsBen Collins
This defines the 24bps and 40bps (8khz sample rate) G.723 codec formats. They are going to be used once I submit the driver for an mpeg4/g723 compression card. I've updated the signed value to -1 as per Takashi's comments since these are non-linear formats. Signed-off-by: Ben Collins <bcollins@bluecherry.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-11ALSA: include/sound/asound.h whitespace fixupsDaniel Mack
This fixes some whitespace/indentation flaws I stumbled over. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03ALSA: timer - pass real event in snd_timer_notify1() to instance callbackJaroslav Kysela
Do not use hardcoded SNDRV_TIMER_EVENT_START value. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-27ALSA: pcm - Increase protocol versionTakashi Iwai
Increase the PCM protocol version to indicate the drain ioctl behavior change. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-29ALSA: PCM midlevel: improve fifo_size handlingJaroslav Kysela
Move the fifo_size assignment to hw->ioctl callback to allow lowlevel drivers overwrite the default behaviour. fifo_size is in frames not bytes as specified in asound.h and alsa-lib's documentation, but most hardware have fixed byte based FIFOs. Introduce internal SNDRV_PCM_INFO_FIFO_IN_FRAMES. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-26Merge branch 'header-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'header-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) x86: headers cleanup - setup.h emu101k1.h: fix duplicate include of <linux/types.h> compiler-gcc4: conditionalize #error on __KERNEL__ remove __KERNEL_STRICT_NAMES make netfilter use strict integer types make drm headers use strict integer types make MTD headers use strict integer types make most exported headers use strict integer types make exported headers use strict posix types unconditionally include asm/types.h from linux/types.h make linux/types.h as assembly safe Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h headers_check fix cleanup: linux/reiserfs_fs.h headers_check fix cleanup: linux/nubus.h headers_check fix cleanup: linux/coda_psdev.h headers_check fix: x86, setup.h headers_check fix: x86, prctl.h headers_check fix: linux/reinserfs_fs.h headers_check fix: linux/socket.h headers_check fix: linux/nubus.h ... Manually fix trivial conflicts in: include/linux/netfilter/xt_limit.h include/linux/netfilter/xt_statistic.h
2009-03-26make most exported headers use strict integer typesArnd Bergmann
This takes care of all files that have only a small number of non-strict integer type uses. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: David Airlie <airlied@linux.ie> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Cc: linux-ppp@vger.kernel.org Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26make exported headers use strict posix typesArnd Bergmann
A number of standard posix types are used in exported headers, which is not allowed if __STRICT_KERNEL_NAMES is defined. In order to get rid of the non-__STRICT_KERNEL_NAMES part and to make sane headers the default, we have to change them all to safe types. There are also still some leftovers in reiserfs_fs.h, elfcore.h and coda.h, but these files have not compiled in user space for a long time. This leaves out the various integer types ({u_,u,}int{8,16,32,64}_t), which we take care of separately. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: David Airlie <airlied@linux.ie> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Cc: linux-ppp@vger.kernel.org Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-11ALSA: Use define for ioctl definitionsTakashi Iwai
Use define instead of enum for ioctl definitions since strace can't parse ioctls defined via enum properly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-11ALSA: Remove obsolete snd_xferv struct and ioctlsTakashi Iwai
Removed obsleted snd_xferv struct and ioctls that are no longer used in the current codebase. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-24ALSA: Add hrtimer backend for ALSA timer interfaceTakashi Iwai
Added the hrtimer backend for ALSA timer interface. It can be used for the sequencer timer source. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-10ALSA: Increase components array sizeTakashi Iwai
Increase the card components[] (and thus snd_card_info.components[], too) array size from 80 to 128 chars so that more strings can be stored. The 80 chars aren't enough for more than 2 HD-audio codecs, and this hits an ugly snd_BUG() as reported by Wu Fegguang for HP 2230s. The control protocol number is increased to 2.0.6 as well, in case it matters. Reported-by: Wu Fengguang <wfg@linux.intel.com> Acked-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-10-10ALSA: Remove bitwise from snd_pcm_hw_param_tTakashi Iwai
We have some arithmetic operations against snd_pcm_hw_param_t, thus bitwise isn't correct for it. Better to remove the flag to shut up sparse warnings. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-01ALSA: Add USB US122L driverKarsten Wiese
Added a new US122L usb-audio driver. This driver works together with a dedicated alsa-lib plugin. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] PCM interface - rename SNDRV_PCM_TSTAMP_MMAP to SNDRV_PCM_TSTAMP_ENABLEJaroslav Kysela
Change semantics for SNDRV_PCM_TSTAMP_MMAP. Doing timestamping only in the interrupt handler might cause that hw_ptr is not related to actual timestamp. With this change, grab timestamp at every hw_ptr update to have always valid timestamp + ring buffer position pair. With this change, SNDRV_PCM_TSTAMP_MMAP was renamed to SNDRV_PCM_TSTAMP_ENABLE. It's no regression (I think). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove PCM xfer_align sw paramsTakashi Iwai
The xfer_align sw_params parameter has never been used in a sane manner, and no one understands what this does exactly. The current implementation looks also buggy because it allows write of shorter size than xfer_align. So, if you do partial writes, the write isn't actually aligned at all. Removing this parameter will make some pcm_lib_* code more readable (and less buggy). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove indirect control accessTakashi Iwai
This patch removes the indirect control access to the control elements. The indirect access has never been used and is even broken on 32bit ioctl wrapper. Let's clean it up. The pointers still remain in snd_ctl_elem_* structs just to make sure that the struct size won't change. Once after checking the size consistency, we can get rid of them, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] PCM - added back TSTAMP ioctl for PCM (for old alsa-lib binaries)Jaroslav Kysela
2008-01-31[ALSA] Use posix clock monotonic for PCM and timer timestampsJaroslav Kysela
We need an accurate and continuous (monotonic) time sources to do accurate synchronization among more timing sources. This patch allows to enable monotonic timestamps for ALSA PCM devices and enables monotonic timestamps for ALSA timer devices. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Update SNDRV_HWDEP_IFACE_LASTTakashi Iwai
Updated the forgotten SNDRV_HWDEP_IFACE_LAST to point the really last member. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] hda-intel - Add hwdep interfaceTakashi Iwai
Added a hwdep interface for each codec (enabled per kconfig). This interface can be used for reading/writing HD-audio verbs and other purposes as future extensions. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Control API - more robust TLV implementationJaroslav Kysela
- added callback option - added READ/WRITE/COMMAND flags to access member - added WRITE/COMMAND ioctls - added SNDRV_CTL_EVENT_MASK_TLV for TLV change notifications - added TLV support to ELEM_ADD ioctl Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Control API - TLV implementation for additional information like dB scaleJaroslav Kysela
This patch implements a TLV mechanism to transfer an additional information like dB scale to the user space. The types might be extended in future. Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Add O_APPEND flag support to PCMTakashi Iwai
Added O_APPEND flag support to PCM to enable shared substreams among multiple processes. This mechanism is used by dmix and dsnoop plugins. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Core componentTakashi Iwai
Modules: ALSA Core Remove xxx_t typedefs from the core component. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Clean up includes in asound.h & asequencer.hTakashi Iwai
Modules: ALSA sequencer,ALSA Core Clean up includes in asound.h and asequencer.h. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] Timer API - SNDRV_TIMER_EVENT_RESUME - val is resolution in nsJaroslav Kysela
ALSA Core Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-08-30[ALSA] Timer API - added SUSPEND/RESUME eventsJaroslav Kysela
PCM Midlevel,Timer Midlevel,ALSA Core - added SNDRV_TIMER_EVENT_SUSPEND / RESUME events - changed timer events from PAUSE / CONTINUE in PCM midlevel to SUSPEND / RESUME Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-05-29[ALSA] Change some timer ioctls due to conflictionTakashi Iwai
Timer Midlevel,ALSA Core Change values of some timer ioctls to avoid confliction with FIO* ioctls. The protocol version is increased to indicate this change. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] usb-audio - add Extigy/Audigy 2 NX remote control supportClemens Ladisch
ALSA Core,USB generic driver Add an hwdep interface that supports reading remote control data from Sound Blaster Extigy and Audigy 2 NX devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] Increase timer protocol numberTakashi Iwai
ALSA Core Increase the timer protocl number (to distinguish the fix for TREAD ioctls). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] replace SNDRV_PCM_HW_PARAMS_RUNTIME -> SNDRV_PCM_HW_PARAMS_NORESAMPLEJaroslav Kysela
