path: root/include/sound/es1688.h
2010-05-10ALSA: Merge es1688 and es968 driversKrzysztof Helt
The ESS ES968 chip is nothing more then a PnP companion for a non-PnP audio chip. It was paired with non-PnP ESS' chips: ES688 and ES1688. The ESS' audio chips are handled by the es1688 driver in native mode. The PnP cards are handled by the ES968 driver in SB compatible mode. Move the ES968 chip handling to the es1688 driver so the driver can handle both PnP and non-PnP cards. The es968 is removed. Also, a new PnP id is added for the card I acquired (the change was tested on this card). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-10ALSA: es1688: allocate snd_es1688 structure as a part of snd_card structureKrzysztof Helt
Allocate the snd_es1688 during the snd_card allocation. This allows to remove the card pointer from the snd_es1688 structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA ES1688Takashi Iwai
Modules: ES1688 driver Remove xxx_t typedefs from the ISA ES1688 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
